Staro 16.01.2013., 13:38   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Smile Kako potrošiti novac na T-mobile Simpa računu?
Totalno sam zaboravio da me sutra prebacuju na tele2, a na simpa računu mi je ostalo nešto novaca i nešo mb neta. Iz principa im ne želim ništa ostaviti, a nemam baš volje ni vremena s nekim pričati. Ima li tko ideju kako to korisnije potrošiti? (Parking i javni prijevoz ne dolaze u obzir danas, jer nisam u ZG)
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 16.01.2013., 13:49   #2
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Zagreb / Maksimir
Postovi: 4,007
Bome svakakvih tema se nađe u ovoj svaštari...
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 16.01.2013., 13:51   #3
syss
syss's Avatar
Postovi: 10,805
nazovi točno vrijeme, zapisuj na brzinu šta ti teta priča na komp u neki word i onda kad završiš razgovor uzmi skrinšot napisanog, sejvaj ko .bmp i pošalji si na mob.
eto sve potrošeno, razgovarao nisi.
Staro 16.01.2013., 13:53   #4
MuroF
MuroF's Avatar
Lokacija: VŽ-okolica
Postovi: 118
hodaj po gradu,slikaj čudne stvari i šalji MMS na portale,novine itd. Možda postaneš slavan
MuroF je offline   Reply With Quote
Staro 16.01.2013., 13:53   #5
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor fanATIk Pregled postova
Pa zato i postoji, zar ne? Nisam vidio prikladniju...
Da mi išta pada na pamet, ne bih pitao. Od googla u ovom slučaju nikakva korist.
Neću im ostaviti skoro 100kn i točka; jer su ionako totalni ižikutori.
Može li se to uplatiti ili prenijeti nekome drugome na račun ili nešto sl.?
Kužim zajebanciju i to, ali ja bi ipak nešto konkretno ako tko ima ideju.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 16.01.2013. u 14:01.
Staro 16.01.2013., 14:03   #6
Postovi: 23,534
Ako imaš nekog sa Simpa brojem, mislim da mu možeš prebaciti nofčeke na br / račun.
Staro 16.01.2013., 14:05   #7
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
E pa to se traži. Ali kako?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 16.01.2013., 14:08   #8
Postovi: 33,979
Nazovi 0800 9000 pa pitaj.
Staro 16.01.2013., 14:08   #9
tomov
tomov's Avatar
Datum registracije: Feb 2011
Postovi: 591
Odi u grad u prvu zonu i nudi ljudima uslugu da im platiš čuku parkinga za 20% manje novaca...
tomov je offline   Reply With Quote
Staro 16.01.2013., 14:11   #10
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor tomov Pregled postova
Nit sam blizu grada (što sam i napisao u prvom postu) nit imam vremena za zajebancije...tak da ništa od toga...iako, i nije loša ideja ak imaš volje i vremena...
Autor coconut Pregled postova
Nemam baš volje pričati s njima, pošto se nismo baš razišli u miru, ali dobro, evo idem čuti što kažu.
EDIT: Kaže telekom baba sa helpdeska da se može samo ako se dođe u t-mobile centar i ispuni zahtjev, a pošto sam u zadnjoj pripizdini trenutno, i zatrpan snijegom, ništa od toga do sutra u 11 kad me prebacuju.
Slušam druge ideje!
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 16.01.2013. u 14:23.
Staro 16.01.2013., 17:53   #11
Ludy
Postovi: 204
zovi neke humanitarne brojeve
Ludy je offline   Reply With Quote
Staro 16.01.2013., 18:13   #12
Rade0n
Datum registracije: Jun 2012
Postovi: 820
Autor Ludy Pregled postova
Najpametniji post.
http://www.sos-dsh.hr/hr/humanitarni_telefon.aspx
Rade0n je offline   Reply With Quote
Staro 16.01.2013., 19:40   #13
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor Rade0n Pregled postova
Slažem se. Zovem!
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
