Staro 11.03.2012., 00:09   #1
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
(riješeno) Nepodržani video format, Toshiba Regza 32" na HD3870
Pozdrav,
Dokopao sam se ove TV na par dana za probu (stoji i skuplja prašinu kod rođaka u praznom stanu), spojim je na moj komp i dobijem poruku iz naslova. Uredno selektiran PC u postavkama TV-a, spojeno kabelom na PC port na poleđini TV-a, a na komp preko DVI/VGA adaptera na moju HD 3870. Inače, već sam se ovim spojem koristio na svom Panasonicu i radilo mi je bez greške. Prečešljao sam postavke Regze, ali ne nalazim ništa što bi mi bilo sumljivo... Može pomoć, savjet.
LP
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
Zadnje izmijenjeno od: O9g1. 12.03.2012. u 00:10. Razlog: riješeno
O9g1 je offline   Reply With Quote
Staro 11.03.2012., 00:47   #2
MMI
MMI's Avatar
Postovi: 913
pa rezolucija, restartaj komp, stišći F8 pa odaberi low resolution ili enable vga, kad dobiješ sliku podesi nativnu rezu televizora
MMI je offline   Reply With Quote
Staro 11.03.2012., 00:49   #3
Postovi: 23,517
Nađi manual na netu točno za taj tip i pogledaj koje rezolucije / frekvencije "prima" na vga ulazu, potom to postavi u driveru.
Napamet 1024x768 60Hz ili 1366x768 60HZ bi trebao raditi.
Staro 11.03.2012., 08:16   #4
6Finger
Lokacija: Zagreb, trešnjevka
Postovi: 1,166
Imam isti TV, mislim dok je bila spojena VGA kabelom da je max rezolucija bila 720p
6Finger je offline   Reply With Quote
Staro 12.03.2012., 00:09   #5
O9g1
O9g1's Avatar
Postovi: 323
Autor Nikky Pregled postova
Evo riješeno, kako si i napisao, prvo sam probao samo sa rezom i ništa, dok nisam frekvenciju spustio na 60Hz. Radi, ali dosta mi umara oči, prevelik ekran na 80 cm od očiju i mislim da ova proba neće biti dugog vijeka... Svedno, thnx!
OS: W10 x64
HDD: 320GB SATA
ODD: DVDRW DL
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
CAMERA: Yes
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
CAMERA: Yes
OS: Windows 10 64x
Staro 12.03.2012., 08:50   #6
Postovi: 23,517
LCD nije isto kao CRT, nebitno jel monitor ili tv, dizanje refresh - a ne rješava ništa jer radi sasvim drugačije od crt monitor - a / tv - a.
Rijetko koji radi sa refresh - om većim od 60 Hz. "Umaranje" očiju ovisi o izvedbi (elektronici) pojedinog LCD tv - a i kako prikazuje pojedinu podržanu rezoluciju.
Staro 12.03.2012., 10:27   #7
O9g1
O9g1's Avatar
Postovi: 323
Postao sam nakon cca pola sata rada na njemu i ne znam jeli uzrok možda prevelik ekran preblizu očima (80-ak cm) ili samo moj subjektivni osjećaj nelagode, ali da je ugodno, nije baš. Našao sam da je ovaj model (32AV635D) koji imam ispred sebe neki low-end u Toshibinoj ponudi za 32", pa najvjerojatnije ova tvoja tvrdnja o elektrnici može biti objašnjenje na moj osjećaj "umornih očiju". Pol sata nikako ne može biti dovoljno vremena za neku ozbiljniju procjenu, pa ću večeras još malo silovat oči, no na kraju nije ni bitno, jer je cijela priča ionako samo bila za probicu. Posebno me veseli činjenica da sam upravo sinoć finalizirao kupovinu Dell-a U2311H, pa vjerujem da će mi oke s njime doći na svoje!
OS: W10 x64
HDD: 320GB SATA
ODD: DVDRW DL
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
CAMERA: Yes
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
CAMERA: Yes
OS: Windows 10 64x
