Staro 27.08.2009., 18:20   #1
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
MPC Home Cinema
MPC HC v1.3.1249 (x86 installer)
MPC HC v1.3.1249 (x86 zip)
MPC HC v1.3.1249 (x64 installer)
MPC HC v1.3.1249 (x64 zip)
New features :
  • Support for Flac audio streams
  • Support for Dolby Digital+ (Eac3) and Dolby true HD (MLP)
  • Nellymoser audio decoder
  • Belarusian, Brazilian and Sweedish translation
  • New shader "Sharpen Complex 2" (required hardware compatible with pixel shader 2.A)
  • Support for madVR video renderer (http://madshi.net/madVR.zip)
  • Additional information on video using MediaInfo (DLL can be download from http://mediainfo.sourceforge.net and placed in mpc-hc directory)
  • Internal DXVA decoder support for H264 with Intel G45 (thanks for people who help me at Intel Corp.)
Changes :
  • Add support of interlaced flags in software mode for MPCVideoDecoder filter
  • D3DFullScreen mode now takes into account the monitor to full-screen mode in options, if monitor is not specified on the command line.
  • Auto-hide playlist on fullscreen(feature request #2219561)
  • Detours library updated to v2.1
  • Support for AC3 in MP4 splitter
  • Support for EAc3 in Matroska splitter
  • Hotkeys added to support more remote control keys
  • Support for Theora in Matroska internal splitter
  • LibVorbis updated to v1.2.3
  • LibOgg updated to v1.1.4
  • Improved streaming performances
  • Prevent display or computer to sleep during playback
  • Faad library updated to rev 2.2.7
  • LibPNG updated to release 1.2.38 (fix security bug)
  • Playlist file is now saved in mpc folder (patch # 2671496)
  • frame by frame modify to support step frame back functionality (except for VMR9)
  • support for AC3 in MP4 files created by Nero Digital
  • EVR custom and VMR9 renderless revamped (Beliyaal), better synchronisation, remove tearing in windowed mode, support for dialog box in DirectX exclusive mode, ...
Bugs fixed :
  • Support for Theora stream in Ogg internal splitter
  • Save thumbnails crash in x64
  • Bugs on presentation graphics (missing subtitles, better synchronization)
  • Audio change on M2TS files reset the selected subtitle
  • Switch to "Minimal view" reset main menu language to English
  • Bug in Mpeg splitter for VC1
  • Maximum texture resolution to "Desktop" not working with Haali renderer (Bug #2456735)
  • Better synchronization with EVR custom to improve playback smoothness
  • 24 bits LPCM not properly play
  • Possible deadlock with Reclock
  • Support of framestep backward, even if the codec didn't support it natively (bug #2600542)
  • DXVA decoder support multiple graphics cards (PCI vendor id detection on the fly)
  • Incorrect aspect ratio for some H264 files with DXVA1 decoder (extended SAR)
  • H264 files with 16 reference frames freeze during playback (bug #2795785 and #2784256)
  • AVI with H264 not decoded properly (bug #2794854)
  • Revamped DXVA h264 decoder based on new insights, fixing black screen, macroblock, support for AVI, ...
  • Incorrect playback for padded DTS
  • Hang when moving player between monitors
Sultan je offline   Reply With Quote
Staro 29.08.2009., 16:14   #2
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Sad sam isprobao i super je jer su omogucili puuuuno novih opcija za x64 drustvo.
Staro 07.09.2009., 04:06   #3
Mad_Duke
Pozdrav.
Zanima me nesto dal je to samo do mene ili nije. Nes sam se zezao i rekao, ajde da probam osposobiti hardware akceleraciju (vec sam prije probao i radila je) na mkv fajlovima (DXVA naravno kodiranih). Cisto, testa radi, zanimalo dal ima neke razlike u kvaliteti same slike ako koristim procesor (E5200) + VMR9 windowed, te ako koristim EVR Custom i GPU (Ati 4850). Do sad se nisam sa tim zamarao pošto mi procesor normalno guta sve 1080P sadržaje koje imam bez ikakvog zastajkivanja.
Ukratko, primjetio sam nešto čudno. Na EVR custom-u su mi sve scene na bilo kojem filmu koji probam svjetlije??. U prijevodu, crna nije crna. Tek toliko da to nije do mene (iako je očito), točno se vidi kada pustim neki sadržaj koji ima black barove, pa mi na VMR9 boja filma kada fade to black-a identična onoj u black barovima. Dok na EVR-u je sivih tonova. Uzeo screenshota 2 na kojima se jasno vidi.
http://www.best.hr/share/privatno/Borna/evr.png
http://www.best.hr/share/privatno/Borna/vmr9.png
Any ideas?
EDIT:
Skužio da je izašla najnovija verzija i sada "sve radi kak spada". Ali eto, dva primjera koja pokazuje kakva je razlika izmedju software renderinga (coreAVC pro 1.9.5 i gpu hardware renderinga od mplayer-ovog codeca)
http://www.best.hr/share/privatno/Borna/evr%20novi.png
http://www.best.hr/share/privatno/Borna/vmr9%20novi.png
Zadnje izmijenjeno od: Mad_Duke. 07.09.2009. u 05:04.
Staro 08.09.2010., 00:08   #4
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
MPC Home Cinema v1.4.2499.0
Staro 08.09.2010., 02:25   #5
trancer
trancer's Avatar
Datum registracije: Aug 2010
Postovi: 182
Jel bolje x64 ili 32bit-nu verziju? Vidim da su neke stvari iz x64 verzije izbačene i da su neke još eksperimentalne pa jel se isplati stavljat tu verziju, odnosno ima li kakvih dobitaka u performansama ili sl. ili se još uvijek bolje držati 32bit-ne verzije?
trancer je offline   Reply With Quote
Staro 08.09.2010., 11:47   #6
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Drži se još x32, x64 nedonosi ništa boljeg trenutno no ima potencijala dakako.
ivand123 je offline   Reply With Quote
Staro 25.09.2010., 16:20   #7
strgani
strgani's Avatar
Lokacija: Zagreb-Križevci
Postovi: 572
ja sam isprobo i x32 i x64 i mogu rec da x64 puno bolje radi na win7 x64 nego x32 bitna verzija programa..inace, koristim ovaj program kao glavni media player za sve osim glazbu koju sam si organizirao..
strgani je offline   Reply With Quote
Staro 25.09.2010., 16:32   #8
trancer
trancer's Avatar
Postovi: 182
Autor strgani Pregled postova
Možeš reći kako ti točno bolje radi, jel ti brže radi aplikacija ili? Pitam zato jer kada je došla x64 verzija x32 je brže radila i na 32 bitnim i 64 bitnim sustavima!
Staro 25.09.2010., 16:37   #9
strgani
strgani's Avatar
Postovi: 572
pa recimo, s 32 bitnom verzijom nisam mogo gledati neke formate, sad se ne sjecam vise koje ali sa x64 gledam prakticki sve, jedino .3gp sad nemogu gledati ali vjerujem da i za to postoji rjesenje..program se brze pokrece, reagira na zapovijed, ne steka nikad i cak mi ni hd filmovi vise ne stekaju, a sve usporedbe sam naveo radeci na jednom te istom racunalu...
Staro 25.09.2010., 18:05   #10
Postovi: 10,329
Osobno sam sa x64 verzijom imao samo probleme na WinXP x64... Što od plejbeka nekih formata, što do nekih opcija koje u to vrijeme nisu bile dostupne na x64 verziji MPCHC-a. Šta nije fora da u slučaju x64 verzije trebaš imati i 64-bitne codece? Mislim da je to netko s ovog foruma spominjao...
Anyway, zadnja verzija mi je na W7 napokon donijela Display stats (ctrl+J) koji mi uporno nije radio, dok je na XP-u radio ok.
Staro 25.09.2010., 19:19   #11
strgani
strgani's Avatar
Postovi: 572
ja sam sve ovo testiro na win 7 a ne na xp-u, na xp-u sam radio samo sa 32 bitnom verzijom tako da sta se tice tog dijela nebi znao..a sad cu probat na windows xp-u x64 pa javim kako je proslo..za kojih par sati
Staro 25.09.2010., 20:51   #12
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,473
ima netko neki setup za mpchc? trza mi prilikom reprodukcije hd materijala, dok km player radi uredno.
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 25.09.2010., 21:04   #13
strgani
strgani's Avatar
Postovi: 572
Staro 25.09.2010., 21:12   #14
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,473
mislio sam na postavke mpchc imam, ali ga nemogu nikako nastimati da uredno vrti HD...
Staro 25.09.2010., 21:23   #15
strgani
strgani's Avatar
Postovi: 572
meni po postavkama uredno vrti HD,kak sam ga instaliro tak radi i to bez problema i to samo onaj x64..
Staro 25.09.2010., 21:34   #16
Dr. Beast
Postovi: 1,505
Autor Renesis Pregled postova
Nakon instalacije za Output sam postavio WMR9 (zbog prikaza titlova), pod Internal Filters (Transform Filters) isključio H264/AVC(DXVA) i H264AVC(FFmpeg), instalirao CoreAVC i u njegovim postavkama uključio Preffered Codec i Skip When Safe (ovo ne moraš ako je sve OK).
Dr. Beast je offline   Reply With Quote
Staro 27.09.2010., 12:29   #17
Daten
Daten's Avatar
Postovi: 404
click
Ja sam sve porihtao kako je napisano u ovom vodiću i nema nikakvih trzanja prilikom gledanja 1080p filmova...
Daten je online   Reply With Quote
Staro 27.09.2010., 12:40   #18
nexus-6
Pero_Snajper
nexus-6's Avatar
Postovi: 649
Autor Dr. Beast Pregled postova
Meni titlovi uredno rade i na EVR Custom. I jos imas dekodiranje preko GPU-a.
A vezano uz 64 bitnu verziju, moja iskustva su katastrofalna, random rusenja tijekom reprodukcije. Stvarno ne vidim ni jedan teoretski razlog za 64 bita. Pa nije da jedan multimedijalni player treba 4+ GB raspolozivog rama za rad...
nexus-6 je offline   Reply With Quote
Staro 27.09.2010., 17:04   #19
trancer
trancer's Avatar
Postovi: 182
Evo i ja sada probo x64 i iako nije bilo rušenja i sl. jasno sam osijetio sporije izvršavanje naredbi, od paljenja, play-pouse do seekanja. Te moramo uzeti u obzir da x32 ima više ugrađenih codeca, tako da ja do daljnjeg ostajem na 32 bit-a.
Staro 28.09.2010., 10:03   #20
Ziiky
Ziiky's Avatar
Postovi: 2,883
Za HD materijale ce ti trebati ipak nesto jace od P4 i ati9800.
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Staro 03.10.2010., 11:05   #21
strgani
strgani's Avatar
Postovi: 572
ja imam celerom m550 koji radi na 2.0 GHz i ati x1100 i bez problema mi vrti hd 720p..1080p steka ali to ni ne skidam onda..
ako stvarno trebate neki program za puštanje hd-a i sa svim mogućim codecima skinite si bs player najnoviji for free, stvarno ima sve codece koji su potrebni prosječnom korisniku, a radi i hd 1080p bez problema na normalnim računalima
Zadnje izmijenjeno od: tor. 15.10.2010. u 20:30.
Staro 01.02.2011., 14:59   #22
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
MPC Home Cinema v1.5.0.2827
New features:
  • Added new options to always default to external subtitles, ignore embedded subtitles and to set the autoload subtitle paths
  • Added support for "in24", "fl64", 8-bit "sowt", "IMA4" and "NONE" audio (old QuickTime PCM)
  • Added support for "in24", "in32", "fl32", "fl64" (both big-endian and little-endian) in .mov files
  • Ticket #784, Enable ctrl+A in the MediaInfo window
  • [DVB] LCN support, added EPG current event information, offset parameter for scanning channels, added channel encryption detection for DVB-t during scan
  • Added ignore encrypted channels checkbox during DVB scan
  • Armenian translation
Changes:
  • Updated FFmpeg
  • Updated MediaInfoLib to v0.7.39
  • Updated ZenLib to v0.4.17
  • Updated Little CMS to v2.1
  • Updated libpng to v1.4.5
  • Updated libogg to v1.2.2
  • Updated libvorbis to v1.3.2
  • Cleaned up and optimized code for QT PCM, small corrections in MP4Splitter
  • DVB: the current channel audio stream is memorized and selected by default each time the channel is switched back
Fixes:
  • Ticket #52, [playlist] shuffle is broken
  • Ticket #78, ESC key cannot be assigned to other actions
  • Ticket #293, giving "remember last window size" a meaning
  • Ticket #564, EVR Sync enabled when it shouldn't be
  • Ticket #627, Don't create the "AppData\Roaming\Media Player Classic" folder if the "Remember items" in playlist is disabled
  • Ticket #628, Enable ctrl+A in Player-->Keys page
  • Ticket #647, Weird "keys" listed
  • Ticket #650, Non-media entry in playlist halts playback
  • Ticket #651, Make EVR CP stats graph smaller
  • Ticket #652, Escape key on certain form causes form to collapse
  • Ticket #655, Crash with some BBC-HD samples
  • Ticket #678, Remember last window size NOT working and mpc-hc.ini
  • Ticket #698, VMR-9 (Renderless) + pixel shaders crashes
  • Ticket #699, fix EAC3 mediatype and string
  • Ticket #712, Audio renderer menu problem with Haali splitter after r2339
  • Ticket #724, Frequency range and bandwidth value are currently not taken into account when doing a scan
  • Ticket #753, DVB-T, internal MPEG-2 filter & wrong aspect ratio
  • Ticket #775, Default options of DVD/OGM Preferred language should be "Default" not "English"
  • Ticket #776, Mouse pointer hovering over window/video should be normal, not hand
  • Ticket #778, Playlist interface problem
  • Ticket #782, VMR-7 & 9 filter names misspelled
  • Ticket #791, Change the cursor behavior
  • Ticket #796, MPC HC window doesn't stay snapped to desktop corners
  • Ticket #809, Resize-arrows no longer appear with caption hidden
  • Ticket #889, [DVB] <enter> keypress in channel list makes whole pane grey
  • Ticket #891, [DVB] clicking empty slot in channel list causes small playback hiccup
  • Ticket #895, [DVB] some characters don't show in EPG OSD
  • DVB Screen sizing: takes into account the TV Navigation panel
  • Workaround to avoid madVR renderer freezing when switching DVB channels
  • Bandwidth value was hardcoded to 8MHz when doing a scan or switching channels. The value entered in scan is now saved in the configuration
MPC HC v1.5.0.2827 (x86 installer)
MPC HC v1.5.0.2827 (x86 zip) ili MPC HC v1.5.0.2827 (x86 7z)
MPC HC v1.5.0.2827 (x64 installer)
MPC HC v1.5.0.2827 (x64 zip) ili MPC HC v1.5.0.2827 (x64 7z)
Changelog:
New features:
Changes:
  • Updated FFmpeg
Fixes:
Zadnje izmijenjeno od: Sultan. 05.02.2011. u 14:18.
Staro 12.02.2011., 11:20   #23
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,800
Pitanjce, ako ispod filma kojeg vrtim piše Playing(DXVA) to zanači da da je uključeo hardversko dekodiranje preko grafe?
U postavkama MPC-HC kod filtera je MPC video decoder i EVR (custom presenter).
tintin je offline   Reply With Quote
Staro 12.02.2011., 14:38   #24
diablo535
Lokacija: Sveti Ivan Zelina
Postovi: 5
Playing(DXVA) znači da se dekodiranje izvodi preko grafičke.
diablo535 je offline   Reply With Quote
Staro 27.04.2011., 12:40   #25
Mad_Duke
Rekao da ovdje stavim u nedostatku coreAVC topica!
Izašla nova verzija CoreAVC codeca. Sada podržava osim CUDA i DXVA preko AMD-a! Jako lijepo radi u kombinaciji sa mpc-hc!
Staro 23.07.2011., 09:37   #26
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
MPC Home Cinema v1.5.2.3456
New features:
  • Added optional fp32 (full float point) processing, fp16 is now half float point
  • Support for BluRay chapters
  • Added Hebrew translation (beta version, the right-to-left layout is not applied to all dialogs yet)
  • You can switch between the remaining time and the current time by clicking on the time itself on the toolbar
  • Ticket #29, Added an option to make the player on top only when playing video files. When using this option, the player won't be on top when playing an audio-only file
  • Ticket #1216, Added a "Clear" option to the playlist context menu
  • Ticket #1224, Added OSD messages when changing the audio boost and the audio balance
  • Ticket #1311, Added an "After Playback" => "Lock" option
  • Ticket #1350, Added a time tooltip for the seek bar whose position can be specified (above or below the seekbar)
  • Ticket #1377, Keep the same playback speed for all the items of the playlist
  • Ticket #1382, Added an OSD message when taking a screenshot
  • Ticket #1487, Show the saved position for favorites with "remember position" enabled in the "Organize Favorites" dialog
  • Ticket #1489, Add the ability to open favorites from the "Organize Favorites" dialog by double-clicking on an item
Changes:
  • The filters' settings are now saved in [HKCU\Software\Gabest\Media Player Classic\Filters]
  • Improved the OSD message when changing the playback speed
  • The hand cursor is not used anymore for the video frame unless the mouse pointer hovers a button in a DVD menu.
  • Ticket #519, Replace the "Next (Previous) Playlist Item" command by a "Next (Previous) File" command which can also be used to play the next (previous) file in folder without stopping at chapters.
  • Ticket #559, Replace jump forward and backward buttons in Windows 7 taskbar by next and previous buttons as they are probably used more often.
  • Ticket #846, Use a different program id for x64 builds so that there is no conflict over file associations between x86 and x64 builds.
  • Updated libpng to v1.5.4
  • Updated MediaInfoLib to v0.7.47
  • Updated ZenLib to v0.4.20
  • Updated SoundTouch to v1.5.1pre r104
  • Updated Little CMS to v2.2
  • Updated libdca to SVN r90
  • Updated French, German, Hungarian, Russian, Turkish, Ukrainian translation
Fixes:
  • Ticket #20, [MKV] 2 or more video streams get played back simultaneously on top of each other
  • Ticket #71, [MPEG] LPCM mono causes 50% playback speed
  • Ticket #199, [MpegSplitter] no video with some files
  • Ticket #285, Ambarella AVC not correctly splitted by MPC-HC's internal MP4/MOV source filter
  • Ticket #384, disable Relative drive
  • Ticket #613, Bugs of MPC-HC Dialog Fonts
  • Ticket #622, Favorites are now correctly saved when changing settings location from registry to ini and vice versa.
  • Ticket #740, Make EVR Sync stats better looking
  • Ticket #760, Fixed playback of old .mov files with 'raw', 'twos' and 'ima4' audio
  • Ticket #805, EVR Custom scanline and refresh rate detection fails occasionally, causing superspeed video
  • Ticket #829, MPC-HC plays recent BBC HD recordings with no video
  • Ticket #965, Add Full File Path Parameter to Status.html
  • Ticket #989, Sliders at options are consistent with volume slider. Scroll/button up will move slider up (increase the value) while going other way, scroll/button down will decrease the value.
  • Ticket #1029, MPEG-2 Profile detected incorrectly with MPEG splitter
  • Ticket #1032, MPC-HC x64 does not work with Flash 64-bit
  • Ticket #1059, Don't add files to Windows recent files list when "keep history of recently opened files" is unchecked.
  • Ticket #1128, Thumbnails wider than 2048p
  • Ticket #1157, The mute button had no effect if triggered during startup
  • Ticket #1178, Fix OSD messages when toggling "Screen Space Pixel Shader" on/off
  • Ticket #1212, Playing "Recent File" clears playlist, even though playlist contains file
  • Ticket #1220, MPC fails to play specific MKV files
  • Ticket #1251, If the window is maximized, it will stay maximized when removing the caption or the menus. The video frame will be extended rather than reducing the size of the window.
  • Ticket #1321, IMpegSplitterFilter uses CString - should be WCHAR or BSTR instead
  • Ticket #1383, Fix OSD positioning: messages displayed at the top-right of the window before going fullscreen were incorrectly positioned after switching to fullscreen
  • Ticket #1483, Wrong order of "Video" and "Audio" in "Properties -> Details"
  • Ticket #1509, Fix the "Prev Angle (DVD)" hotkey and add an OSD message when changing the angle using the hotkeys or the "Navigate" menu
  • Ticket #1515, Disable "Disable Desktop composition (Aero)" menu entry on XP
  • DVB, Channel switching for H-264 services is more stable now
  • Some OSD messages were not translatable
  • Use the correct icon for the message box appearing after the online subtitles database has been tested: the warning icon was always used even if the test was successful
  • Numerous other bugfixes
MPC HC v1.5.2.3456 (x86 installer)
MPC HC v1.5.2.3456 (x86 zip) ili MPC HC v1.5.2.3456 (x86 7z)
MPC HC v1.5.2.3456 (x64 installer)
MPC HC v1.5.2.3456 (x64 zip) ili MPC HC v1.5.2.3456 (x64 7z)
Changelog:
New features:
Changes:
Fixes:
Staro 06.10.2011., 21:18   #27
DropIt
Datum registracije: Oct 2011
Postovi: 4
Na 32-bitnoj verziji mi se često ruši kada seekam određeni dio filma. Inače odličan player, jedino me smeta što ne podržava real media sadržaje.
DropIt je offline   Reply With Quote
Staro 07.10.2011., 01:17   #28
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,149
Autor DropIt Pregled postova
zato sam se ja revertao na verziju 1.4.2824
ta se ne rusi
HumWeed je offline   Reply With Quote
Staro 07.10.2011., 01:25   #29
Baja 001
Baja 001's Avatar
Postovi: 7,504
Je li ima neki autosubtitle downloader kao u SPlayeru?
Staro 07.10.2011., 01:59   #30
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,149
/obrisati molim/
Zadnje izmijenjeno od: HumWeed. 07.10.2011. u 02:01. Razlog: x
