Staro 01.09.2010., 10:07   #541
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Evo jedna zanimljivog rijesenja za hlađenje
Colorful Unveils GeForce GTX 460 iGame Graphics Card
Colorful has come up with beastly-looking GeForce GTX 460 graphics card, that makes use of a shark-inspired GPU cooler design, coupled with an equally capable VRM design to facilitate a core clock speed of 900 MHz (vs. 675 MHz reference). The Colorful iGame GTX 460 custom-design PCB of the card makes use of a 6+1 phase VRM, with voltage-measure points. With two BIOS EEPROM chips installed, a switch allows users to choose between the two BIOS chips when the system is powered down. Apart from helping maintain two clock and fan profiles, the feature protects against overly-ambitious BIOS modifications by adding some redundancy. Apart from 900 MHz (core), the CUDA cores are clocked at 1800 MHz, and the memory at 1050 MHz (4200 MHz effective).
@demetrius - to je oc, link
The clock speeds out of the box are 780 MHz (core), 1560 MHz (CUDA core), and 900/3600 effective MHz (memory)
Inace, zanimljivo kod ove grafe sto su napravili, nema zujanja
Under the hood is a VRM that makes use of a 7+1 phase design with MSI's Solid State Chokes (SSCs), which don't give out high-pitched noise (translating into energy loss) during load.
Zadnje izmijenjeno od: bluefluid. 01.09.2010. u 10:13.
Staro 01.09.2010., 10:52   #542
anyway, neko je tu napisao da ima GTX 460 SLI. koliko komp sa time vuče iz zida, sa recimo i5 procesorom? hvala
Zadnje izmijenjeno od: Wolverine. 01.09.2010. u 18:14.
Staro 01.09.2010., 12:20   #543
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,439
stigle gig 460 1gb u ADM :-). finaly .
i uzeo sam seasonic 620w.
pozdrav.
BTW sinoc sam skuzio kad pokrenem MSI kombustor da i meni Corsair crvci :-(. neznam zasto, ali vidim da se mnogi zale na to.
geronimo_2 je online   Reply With Quote
Staro 01.09.2010., 12:33   #544
pozdrav.
jeste vi sigurni da napajanje cvrči? da ne cvrči možda grafička? to je i kod mene slučaj, ali samo u meniju od Call of Pripyat, nigdje drugdje, barem ovo što ja igram.
btw, stigle su i "Ciklonke" u ADM.
Staro 01.09.2010., 12:49   #545
geronimo_2
geronimo_2's Avatar
Postovi: 4,439
pa sta ja znam. sinoc sam onako nabrzaka skuzio slucajno jer istinu za volju moja zotac je prilicno glasna kad igram igre pa ni ne primjecujem to. ne brine me toliko sto to crvci vec zasto cvrci odnosno da nije mozda nesto u banani. anyway bodem novi gpu i psu tako da... hopefully novo nece cvrcat
Staro 01.09.2010., 13:26   #546
MAGARAC
MAGARAC's Avatar
Postovi: 5,995
Autor poker Pregled postova
U igri mafia 2 (core2duo 6750 oc 3,3 , 4gb ram na 1000 i gtx275)na rezi 1680*1050 sa postavkama u igri na max daje mi average fps 25.
Da li je netko radio benčmark u mafia 2 s gtx460 1gb pa da stavi koliki su mu fps
hvala
(grafa nije klokana)
2010-08-12 13:08:10 - mafia2
Frames: 14834 - Time: 319476ms - Avg: 46.432 - Min: 31 - Max: 287
Ovo je na 1920x1080, high, physx medium, gtx460 1gb. Znaći da na 1680 ide nešto bolje.
Staro 01.09.2010., 15:41   #547
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
nego, da ne spamamo toliko, što se tiče GTX 460 i OC-anja, jel sve kartice imaju Voltera naponsku regulaciju. Da mi se nebi omaklo kao i na GTX 260 da tog čipa nema.
Referentne imaju, Cyclone ima, Palit, Gigabyte i Gainward nemaju.
Zadnje izmijenjeno od: Wolverine. 01.09.2010. u 18:08.
fran123456 je offline   Reply With Quote
Staro 02.09.2010., 10:14   #548
geronimo_2
geronimo_2's Avatar
Postovi: 4,439
Autor DeadMan+ Pregled postova
da li netko ima ovaj problem:
Fermi Cards - Powersavings Driver Issue (GTX460 only or all Fermis)
ja ga imam, stavio sam 259.47, malo je bolje nego sa 258.96, ali jos uvijek nije kako bi trebalo biti
pozdrav.
moze malo pojasnjenje sta se ustvari desava jer me strah sada dali ce mi se taj problem manifestirat. pisali su na thread-u da se dogada na Pxx chipsetima, a onda je uletio jedan koji tvrdi da i sa 790GX ima probleme?
koliko sam skuzio radi se o stabilnosti kompa i performansama u 2D-u?
Kad je Aero ukljucen jel ide win u 2D ili ostaje u 3D?
hvala.
Staro 02.09.2010., 10:53   #549
poker
poker's Avatar
Lokacija: osijek
Postovi: 225
Autor MAGARAC Pregled postova
dosta bolje vrti na gtx 460 ipak se isplati je tržiti pokazuje znatan pomak na bolje u novim naslovima
Atrebao bih i zamjeniti proc mislim da e6750 ne može dati powera gtx460 da bi ona mogla raditi u punoj snazi
poker je offline   Reply With Quote
Staro 02.09.2010., 11:20   #550
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Zvijer : MSI Announces the N460GTX HAWK 1 GB High-Performance Graphics Card
"The world's first graphic card with triple overvoltage function supporting core voltage, memory voltage and PLL voltage adjustments, the N460GTX Hawk is also the only model on the market that has successfully achieved 1GHz under air-cooling during overclocking. "
http://www.techpowerup.com/img/10-09-02/15b.jpg
Clanak : http://techpowerup.com/130113/MSI_An...hics_Card.html
Staro 02.09.2010., 11:28   #551
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
pozdrav.
hvala.
2D
problem je kad gpu udje u "power save mode", dok su clockovi dignuti nema nikakvih problema, ali kad ih spusti onda DPC spike-ovi krenu
nije strasno, i navodno ce novi driveri to srediti, ali trenutno je malo iritantno
DeadMan+ je offline   Reply With Quote
Staro 02.09.2010., 12:00   #552
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Staro 02.09.2010., 12:47   #553
geronimo_2
geronimo_2's Avatar
Postovi: 4,439
pozdrav
dali koristiti sa gtx460, HDMI mini to HDMI normal adapter ili DVI - HDMI adapter (do sada sam ovako na 260) za slati na LCD TV ili je sasvim ista stvar. HDMI audio me ne interesira i iskljucio sam ga jer saljem preko optike na reciever.
hvala.
Staro 02.09.2010., 13:05   #554
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
pozdrav
hvala.
Sasvim ti je svejedno... tvoj izbor.
Core2Duo22 je offline   Reply With Quote
Staro 02.09.2010., 15:39   #555
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,882
ne razumijem mini hdmi adapter,mu nešto fali??kad se dobije mini hdmi to hdmi adapter,spojim hdmi kabel i imam sliku i zvuk,više ne treba ona bedastoća od spdif kabela.
Staro 02.09.2010., 15:47   #556
geronimo_2
geronimo_2's Avatar
Postovi: 4,439
Autor demetrius Pregled postova
zvuk saljem u Yamaha reciever, a ne u LCD TV. zvuk iz kompa saljem analogno (za igre) + optiku za DD i DTS (kod filmova). nisam niti siguran dali preko HDMI mogu slati "obicne" formate audio-a odnosno neke osim onih HD, ŽNJ, FLJ i sta ja znam audio-a. adapter DVI to HDMI ionako vec imam uboden u komp pa mi svejedno, zato sam htio potvrdit da je sve isto da to i ostavim.
Staro 02.09.2010., 15:50   #557
Shaka111
Shaka111's Avatar
Postovi: 650
ja na svojoj gtx460 ne mogu spojit hdmi-mini hdmi adapter jer mi kuciste smeta,preblizu je limu,osuden sam na DVI-HDMI...isto je sve,nema razlike
Shaka111 je offline   Reply With Quote
Staro 02.09.2010., 16:46   #558
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
Autor Shaka111 Pregled postova
Ni ja ne mogu ubost adapter, kejs preblizu, adapter predebel... radi se o POV GTX460 768MB.
Tomtam je offline   Reply With Quote
Staro 02.09.2010., 18:14   #559
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
Pilu u ruke i reži kučište.
Staro 02.09.2010., 18:16   #560
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Pa probaj gumu na adapteru odrezat, ak je gumiran. Znam da je moj bil i to puno previše gume.
danc00 je offline   Reply With Quote
Staro 02.09.2010., 21:10   #561
Osta
Osta's Avatar
Postovi: 283
imam ja, s i7 procom, ali nemam nikakav nacin da izmjerim
Osta je offline   Reply With Quote
Staro 03.09.2010., 00:26   #562
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
Autor pinkskin Pregled postova
Autor danc00 Pregled postova
Ako bude zatrebalo, al mislim da neće, komp je za gaming i samo se troši DVI , kažem, ako zatreba, riješit ću ja već to nekako, više mi se sviđa danc00-ov prijedlog.
Staro 04.09.2010., 01:16   #563
bahrija30
bahrija30's Avatar
Datum registracije: Dec 2009
Lokacija: KOPRIVNICA
Postovi: 272
danas dobivam 2dvije grafičke gainwardovu i point of wiev 768mb, verzija--nebum ih imal vremena testirati jer jedna odma ide u druge ruke-a jednu si ostavljam--po vašem iskustvu ak ga imate koju bi ostavili??obje su stare par dana!!!!!
bahrija30 je offline   Reply With Quote
Staro 04.09.2010., 01:23   #564
Shaka111
Shaka111's Avatar
Postovi: 650
ja bih sebi ostavio PoV...neznam iz kojeg razloga ali mi je nekako PoV drazi =S
Staro 04.09.2010., 01:26   #565
bahrija30
bahrija30's Avatar
Postovi: 272
nemogu na netu naći testove grafičkih-ak ju imaš kolko joj default temperatura i jel se da klokat kaj--imal sam gainwardovu par dana pa da znam otprilike kak je s tvojom situacija
Staro 04.09.2010., 01:40   #566
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
Imam POV, vrlo tiha i vrlo hladna (ako senzor ne laže) ostavi si POV. Kolko ti toga već imaš čovječe? Jedino što zamjeram PoV-u je to što bundlea doslovce nema... Dobiješ instalacijski CD i miniHDMI-HDMI...
Staro 04.09.2010., 01:54   #567
bahrija30
bahrija30's Avatar
Postovi: 272
Autor Tomtam Pregled postova
jednu gainwardicu prodal-pred par dana..jbga lik ima na lageru još te dvije pa cu uzet obje,a jedna opet ide legi odma... zato i pitam koju da ostavim....uzeo od njega i vtx 5850 ta mi u drugom kompu-nju nemislim prodavati....jbga imal je nenadani smrtni slučaj pa mu je lova hitno trebala nažalost!!!!!pa uz pov se mislim dobije i jedna igrica-bar tak piše po cjenicima ili?
Staro 04.09.2010., 01:59   #568
geronimo_2
geronimo_2's Avatar
Postovi: 4,439
pozdrav svima. evo stavio novu grafu Gig 460 1gb + seasonic 620W. radi sve iz prve, bez greske .
imam par pitanja/obzervacija:
PSU ima samo 2 linije molex (3 konektora na svakoj liniji). e sad meni je jedna linija vec zauzeta. sta ako stavim jos jednu grafu i potrebna su mi 2 x 6pin 12V linije?
ne kuzim kako su stavili cjelu hrpu SATA napajanja, a ovo ovako malo.
isto tako stavili su 1x8pin 12V i 2x4 pin 12V. koliko sam skuzio ova dva su ista samo je jedan splitan. ovaj puni sam uboo u maticnu, a splitani je spare.
srecom, koliko sam vidio po specsima sve GT240, GTS250 i 9800GT traze samo po jedan 6pin 12V pa mozda tu nece bit problema.
Everest (5.30.1900) mi ne vidi ni brzinu fan-a, ni temp, ni voltazu. pokazuje samo GPU temp i to je to. jel to zbog stare verzije ili treba negdje nesto resetirat?
odoh promjenit "moj komp" i u krpe
update1: mini HDMU to HDMI adapter ne stane isto kao kod vecine ljudi. izrezbario sam ga. morao sam probati jer izgleda da nesto nije u redu sa signalom. ako pomicem lagano HDMI konektor od kabela, slika mi ponekad nestane i ne uspijevam skuzit dali je kabel u banani (moja pretpostavka) ili nesto drugo. nemam na cemu drugome isprobat kabel pa sam na cudu. gdje u RI copit povoljni,kvalitetni HDMI do 1m?
edit2: stavio sam zadnju verziju everest-a i dalje vidim od graficke samo GPU temp, onih drugih nema, ali koliko vidim u GPU-Z isto ima samo GPU temp. sta ostali ne postoje na GTX 460? posebno sam uvjek pazio na VRM koji mi je znao biti prilicno visok.
Zadnje izmijenjeno od: geronimo_2. 04.09.2010. u 13:57.
Staro 04.09.2010., 12:11   #569
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
Autor bahrija30 Pregled postova
Piše prince of persia, no ja je nisam dobio, možda je na cd-u od drivera? možda je samo negdje ključ, međutim, nisam dobio ni molexe na PCIE... samo driver, karticu, mHDMI-HDMI i manji manual. Važno da je kartica unutra i da radi dobro (a radi jako dobro), iskreno, jebe mi se za princa iz perzije i te molexe, imam ih već 5 viška.
Staro 04.09.2010., 12:13   #570
baban
baban's Avatar
Datum registracije: Aug 2008
Lokacija: DE
Postovi: 591
pitanje za vlasnike gig 460gtx 1gb - koliko je glasna u idle-u?
da li se cuju njeni ventovi kroz kejs (moju 275gtx u idle-u cujem, doduse imam papir na kucistu pa mozda zato)
evo bio bi zahvalan ako neko moze ugasiti sve ventove i probati da li se cuje gigabytica
slozio bi si sto tisu konfu zato i pitam
baban je offline   Reply With Quote
