Staro 23.07.2010., 22:25   #1
Sail
Sail's Avatar
Postovi: 77
Speedtouch bandwitdh limit CLI
Poz ekipi s foruma. Radi se o t-comovom thompson speedtouch st780wl routeru vjerojatno vecini svima poznat. Pokusavao sam pronaci da li se na koji nacin moze na njegovim interface-ima, tj. pojedinim portovima ograniciti bandwitdh no bas kad sam se ponadao da ce sve raditi eto problema..
Komande koje bi to trebale omogucit su:
eth switch shaper config
eth switch shaper config shaper number{0--1}
control = <{enabled|disabled}>
shaper -> The shaper instance.
control -> Shape MAC control traffic.
eth switch shaper ifconfig
eth switch shaper ifconfig port = number{1-4}
ingress = {enabled|disabled}
shaper = number{0--1}
[state = {enabled|disabled}]
[speed = number{64000-100000000}]>
[burstsize = <{}]>
port -> The port. REQUIRED
ingress -> Ingress port = enabled; egress port = disabled. REQUIRED
shaper -> The shaper instance. REQUIRED
state -> Enable/disable shaping. OPTIONAL
speed ->Speed in bits/sec. OPTIONAL
burstsize ->Burst size in KBytes. OPTIONAL
No medjutim kad se pokusa konfigurirat "switch shaper" on javlja poruku tipa: Shapers are not supported by the onboard switch.
Do firmware-a ne bi trebalo biti, jedino do router hardwera.. toliko o tome kakve routere t-com izdaje, vjerojatno neka kineska roba a ne original pa zato i ne radi jer po svemu - trebalo bi radit kad ove komande stoje u official dokumentaciji routera.
Da li je netko ovo vec pokusavao i da li netko od iskusnijih ima mozda jos kakav prijedlog?
Zadnje izmijenjeno od: Sail. 23.07.2010. u 22:36.
Sail je offline   Reply With Quote
