Staro 01.05.2010., 21:12   #1
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Post Corsair GS600 PSU ... recesijski
Kao što smo svi svjesni Corsair se oduvijek trudio biti dostupan omjerom cijene i kvalitete ... kako bi se reklo, gotovo za svačiji džep
Nova Corsairova AC/DC uzdanica je Corsair Gaming Series GS600 High Performance PSU ATX Power Supply CMPSU-600G*
*Gornji link na Corsairovu stranicu je trenutno down .... interes očito postoji
The Corsair Gaming Series GS600 power supply is the ultimate price-performance solution for building or upgrading a Gaming PC. A 48A single +12V rail provides reliable, continuous power for multi-core gaming PCs with multiple graphics cards. 80Plus certified efficiency and a 140mm fan (with blue LED illumination) guarantee cool, quiet operation with minimal wasted energy.
  • The Corsair Gaming Series GS600 power supply is the ultimate price-performance solution for building or upgrading a Gaming PC.
  • A 48A single +12V rail provides reliable, continuous power for multi-core gaming PCs with multiple graphics cards.
  • 80Plus certified efficiency and a 140mm fan (with blue LED illumination) guarantee cool, quiet operation with minimal wasted energy.
  • It supports the latest ATX12V v2.3 standard and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
  • An ultra-quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature.
  • 80%+ energy efficiency at 20%, 50% and 100% load conditions means less heat generation and lower energy bills.
  • 0.99 Active Power Factor Correction provides clean and reliable power.
  • Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
  • Extra long fully-sleeved cables support full tower chassis.
  • A three year warranty and lifetime access to Corsair's legendary technical support and customer service.
Kao što se može pretpostaviti, proizvod je namijenjen gejmerima koji zahtijevaju fata ko u priči, plavim LED-icama obasjani vent, uz određene uštede (npr. nisu svi kondići japanskog podrijetla).
Također nije na odmet istaknuti da je u pitanju običan 80 Plus White standard uz garanciju srezanu na 3 godine.
Navjerojatnije se radi o tajvanskom OEM-u CWT-u ... odnosno njihovom PSH 600 modelu - 80Plus.org link.
Cijena bi trebala pratiti navedene rezove u proizvodnji GS600 (zasad je oko 90-ak $, ali se očekuje naknadna korekcija).
Navali narode
Staro 01.05.2010., 21:14   #2
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Svjetleće napajanje nikad nebu sletilo u moje kućište
fran123456 je offline   Reply With Quote
Staro 01.05.2010., 22:41   #3
Markos
Markos's Avatar
Postovi: 1,061
ovo je fakat dobra cijena za to napajanje,vrijedi svake lipe ipak je to cors,možda čak i spuste cifru još malo
Zadnje izmijenjeno od: Markos. 02.05.2010. u 00:37.
Markos je online   Reply With Quote
Staro 02.05.2010., 02:16   #4
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Sajt im je konačno gore ... nezgodno je to, imati tako popularne proizvode
Za svaki slučaj, evo još infa:
The Secret ...
Staro 02.05.2010., 07:47   #5
Postovi: 33,978
Baš su mogli staviti još jedan 6/8pin PCI-E konektor. Dobar dio gaming grafi zahtjeva 2 komada, a obzirom da Cors u nazivu ima 'gaming' onda je bezveze stavljati samo 1.
Staro 02.05.2010., 08:41   #6
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Pa taj Cros i ima 2 puta 6+2 za grafe, pogledaj malo bolje...
Campeonato je offline   Reply With Quote
Staro 02.05.2010., 09:44   #7
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Da, recesijska gaming konfa neće imati 2x5870, nego prije recimo 2x5770
MC
Staro 02.05.2010., 10:23   #8
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Recesijska konfa ne treba 600W napajanje
d4rk_ch1ld je offline   Reply With Quote
Staro 02.05.2010., 10:30   #9
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Autor d4rk_ch1ld Pregled postova
Gamersko recesijska xD
ivand123 je offline   Reply With Quote
Staro 02.05.2010., 14:30   #10
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Šteta što nije modularno
Baš me zanima kakvo je po pitanju tišine, 140mm vent ne bi trebao biti nešto posebno čujan, od kojeg proizvođača stavljaju vent unutra?
C L O W N I N G A R O U N D
Staro 02.05.2010., 14:50   #11
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Pa zar ima Corsair glasna napajanja?
MC
Staro 02.05.2010., 18:23   #12
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Rijec je o Double Ball Bearing ventu od nekakvih 2-2,5k okretaja na 12V.
Znači nešto slično onim 140mm ventovima iz TX 750/850 modela, sto bi znacilo ovako nesto.
Posto su vrlo slicni po dizajnu, jer oboje koriste CWT-ov PSH dizajn, koji se proteze od VX550 pa sve do TX850 ... vrlo je vjerojatno da su slicni i po buci sa navedenim TX750/TX850.
The Secret ...
Staro 03.05.2010., 14:33   #13
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Autor Sa_Stilom Pregled postova
Bome dosta se žali na buku od VX450, pa i CX400.
Fino napajanje, no kako je "recesijsko" ( ) pomalo i logično što nije modularno.
blaa
Staro 03.05.2010., 14:41   #14
Doink the Clown
Postovi: 6,214
Autor hammer_of_thor Pregled postova
Ma nemoj, pa trebali su riješiti to kao na HX450W, modularac ali samo nekolicina kablova, to bi bila prava recesijska ušteda
Staro 03.05.2010., 15:13   #15
hammer_of_thor
Postovi: 5,430
I time povečati troškove proizvodnje na recesijskom napajanju ?
blaa
Zadnje izmijenjeno od: hammer_of_thor. 03.05.2010. u 15:19.
Staro 03.05.2010., 15:56   #16
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Potpisujem, imao sam vx450, i cx400...oba glasna. Pre glasna za mene...
Fortron350 mila majka, tih, hladan. Diš bolje za 100 kn, kablove i to pregrmim lako, 6pinske i sleevane kablove.
Ontopik, mene samo zanima ako dodje do nas kakva bude cijena bila toga "lowcost" napajanja
Staro 03.05.2010., 16:51   #17
Doink the Clown
Postovi: 6,214
100 bucksa cijena u US, znači kod nas mu cijena neće biti ispod 650kn, čak bih se usudio reći i preko 700kn, ipak ima svjetlucav vent
Staro 03.05.2010., 16:57   #18
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
kaj nije onda bolje Kamariki uzet,VX550 il se ispruzit 100kn i uzet ne-recesijskog,ktome i ne svijetleceg Corsaira?
Staro 03.05.2010., 17:13   #19
dzeneral
Valar morghulis
dzeneral's Avatar
Postovi: 280
I ja mislim da neće bit ispod 650kn. Novi Seasonic S12II je u SAD-u 70$, kod nas je nešto preko 500kn.
Autor trouble Pregled postova
Da su ga stavili jeftinije, više nitko ne bi kupio CX 400 i vx 450/550..
"The objective of war is not to die for your country, but to make the other bastard die for his."
dzeneral je offline   Reply With Quote
Staro 03.05.2010., 18:33   #20
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Meni je tišina najvažnija,lako pregrmim par desetaka W manje na 12V, samo da ni ne znam da je unutra,naravno,to podrazumijeva i stabilnost. Ali tišina prije svega,zato sam vjeran CM-u godinama. Inače mi se jako sviđa ovo napajanje po speckama iz naslova teme. Nisam pobornik kiča i led ventova,dapače,sve Xilence plave led ventove iz casea sam zamijenio sa S-Flexovima na 800+ rpm, tako i kod napajanja preferiram vulgaris,ali vrlo snažno i pouzdano Cors mainstream napajanje mi se čini.
Staro 04.05.2010., 02:09   #21
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Samo da vas prenesem obavijest koju sam dobio iz Corsaira ... cijena novog GS600 ce biti znatno manja od TX650 ... najvjerojatnije negdje oko VX550 ili mozda cak i nesto manje.
Sto bi reklo nekakvih 550-600 kn
Staro 04.05.2010., 09:32   #22
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
maržeee,maržeeee....maaaaa-aaaržeeeeeeeeeeeeeee
ako i iz Corsaira imaju plan da ce doc dost manje od TX650,naši bu vratili tik do njega
Al ajmo sagledat realno,600kn,za to se dobije Seasonic 620 u diskontu. Nisam neki expert od napajanja i struje(Ruđer zaslužan) ali mislim da je kotira bolje od ovoga,bar čim cujem napomene od kolege dh....nisu svi kondici.... srezana gara ... OEM CWT....
Potom se u toj cjenovnoj klasi nalazi i VX550 te Antec Earthwatts.
Uostalom,treba Cors doc na test,da dh il Wolw naprave obdukciju pa bumo pametniji
Zadnje izmijenjeno od: trouble. 04.05.2010. u 09:44.
Staro 05.05.2010., 12:54   #23
Wolverine
Wolverine's Avatar
Postovi: 12,425
Pa primjera radi tvoj HX850 definitivno nije oličenje tihog napajanja
Za ekipu kojoj je CX400/VX450 glasan, niti Sisa 520 neće biti tiha. Posebice ne ako je opterete.
Njima onda od ''jeftinijih'' modela ostaju samo na odabir još poneki modeli be quiet! i Scythe Kamariki napajanja.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 05.05.2010., 14:11   #24
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Hm, ne znam o kojem HX850 govoriš, ali moj je skoro nečujan.
Također, gledam baš na corsair stranici te chartove, HX520 kojeg sam iscjedio praktički, je uvijek bio nečujan.
Pa sad ne znam kak oni mjere te decibele
MC
Staro 05.05.2010., 14:31   #25
Wolverine
Wolverine's Avatar
Postovi: 12,425
Nečujan je my ass
Vent se čuje i to prilično. Posebice ako ga se nagazi.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 05.05.2010., 14:49   #26
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
... Za ekipu kojoj je CX400/VX450 glasan, niti Sisa 520 neće biti tiha. Posebice ne ako je opterete.
Bas me zanima kakav je veci brat (620W) također u loadu iznad 400W ...
Staro 05.05.2010., 14:59   #27
Wolverine
Wolverine's Avatar
Postovi: 12,425
U principu to je load od kakvih 330-350W
I zbilja mi je glupo što nema nekog laganog prijelaza već iz sasvim tihog rada na niskim okretajima pređe na vrlo visoke okretaje uz dosta buke.
IMHO među napajanjima koja su tiha u gotovo svim režimima rada u zadnjih par mjeseci iznenadili su me jedino Scythe Kamariki 4 450/650 i be quiet! Dark Power.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 05.05.2010., 15:51   #28
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Autor dh41400 Pregled postova
620W se jako jako grijao, ja sam ga imao 7 dana i bacio van iz kante.
Ali ponavljam, 520W je bio mrtav tih.
520W sam furao (ponavljam ko papiga) na:
Q6600@3,6 nakon nejga i7@4.0
9800GX2 pa nakon nje 5870
pumpa za vodu 7ventova
3 hdda, 2 ssda
Više se ni nesjećam, bemu miša....
Poanta je, ovo moje je zbilja bilo "mrtvo", režem glavu.
MC
Staro 05.05.2010., 16:27   #29
Wolverine
Wolverine's Avatar
Postovi: 12,425
On govori o Seasonicu S12II 520/620, ne o HX520/620.
Daj čitaj malo
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 05.05.2010., 17:13   #30
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
A yeb... te, šta ja znam šta ti je "Sisa" 520W, kad smo već kod toga ne
MC
