#1981 |
#1982 | |
Lokacija: Komin
Postovi: 89
Code:
We have tracked this down to being a firewall issue, not so much blocking the game but blocking the Updater from getting the latest version. To solve the issue disable your firewall (quit the program totally not just disable with a setting in the firewall itself as Comodo silently still keeps blocking traffic that is disallowed even when "disabled"). Run the BFBC2Updater. You should get the latest version of the client Once you have it you can turn your firewall back on and load the game. You should see servers in your in game browser. You may also be able to add the BFBC2Updater to your accepted applications list on your firewall but that may not work so the above method is prefered. It is also worth checking your Firewall settings to see if it is allowing BFBC2 itself before loading the game. If it isn't in your allow list then add it to be sure the game has the access it needs. |
#1983 | |
Postovi: 245
![]() I još nešto - poslao sam requeste cca 15-orici ovdje navedenih igrača i samo trojica me primila! Možda da probam ovak? PCE nick.................BF nick Veki-OS..................Veki[CRO] Slash555.................LegolasHR Visitor Q.................Visitor Q aircanada................S3mp3r (clan tag: [PcE]) ThePornstar.............carpediem90 blava......................Marko008 B3mt1.....................B3mt1 Mansky Hunt............ManHunt1986 (clan tag: [PcE]) proudixz..................proudixz hammer_of_thor........Narsil Neo-ST...................Neo-ST (clan tag: [PcE]) PointDexter..............Triumph2407 (clan tag: [PcE]) dUG1......................dUG1 Constantine.............The Constantine zwer54....................zwerr | clan: [CTN] bluefluid...................bluefluid michel......................MichelGTX bacyc......................bacyc385 Blue_Fatal1ty............Blue_Fatal1ty zgmmax....................zgmmax hobitxxx....................tOm[CrO] tech.........................[PCE]JadrankaKosor Danko86...................Danko86 Berovk......................(PCE)Bero Ninja666xx.................AsaHayyim Strider......................CRO Strider Paxton......................var|skovic [clan tag: =BoX=] Paxton......................varoskovic [clan tag: =BoX=] _Cox.........................CoxUT [clan tag: p.3h] morozinho..................Orozinho (cro) Nebbo......................Nebbo Jumper......................Jump3r101 Cartmann...................Cartmann Hrwoye.....................[PcE]Capricosa |
#1984 |
DD9512
Postovi: 1,869
meni je igra totalno smece, prevelelike mape, preotvorene, respawn predugacak, onda te baci na pocetak mape pa pola sata hodanja do akcije, onda naletis na lika koji je 20 il 25, 30 level, onda naravno ponovno respawn itd.. Shit je veliki dok ne dodjes do 10 lev. ![]() |
#1985 |
Postovi: 668
ako ti neznas igrat ne znaci da je igra smece ![]() |
#1986 | |
Postovi: 488
![]() S ostatkom se slažem, al jebga, treba naučit igrat i onda je sve ok. A što se tice sinhronizacije, i to je dobar prijedlog (već ga je netko dao), samo se trebamo dogovorit - netko iskusan preuzet inicijativu. |
#1987 | |
Postovi: 1,668
![]() poslje sam jos igro dok si ti otiso i ubiju me i neki lik medic pored mene prodje i ode on u kuruzu a ja mrtav lezim, il druga situacija, ubiju me ispred jedno troje igraca i da jedan uzme moj kit i ozivi me on dalje nastavi po svome. Trebalo bi svaki put kada ulazis u igru ti pustit neki filmic o ponasanju u MP mozda bi se neki i naucili timskom radu i duhu Problema sa friend listom je bilo i u beti i mislim da su rekli da je to sa prvim patchom popravljeno al izgleda da jos nije |
#1988 |
Lokacija: Komin
Postovi: 89
BF: BC2 regrutcije otvorene >> http://ping300.com/ |
#1989 |
its slightly turbocharged
Postovi: 5,430
blaa |
#1990 |
Postovi: 328
Stvarno nekada ima ljudi koji pate od cerebralne paralize. Danas igram sa rusima, engineer klasa, ostenem bez metaka i trazim ammo. Lik nista. Trcim za njim 5 minuta, pisem velikim slovima AMMO, BULLETS, PATRONEEEEE! Ma kakvi... ![]() Pa onda ovi koji neznaju uci u squad. 10tak igraca u teamu a samo 4 u squadu ![]() Ma M60 je best lmg sigurno. Cak bi rekao da je i prejak |
#1991 |
bolji mi je t88 od m60, vise metaka, veci rof, manji recoil. |
#1992 | |
Postovi: 668
a sto se tice m60,meni nije nešto,no mnogo sam puta ubijen s njim i mnogi ga koriste,a xm8 lmg je ok,no opet ništa posebno,meni ja glavno da imam svoj GOL i M1911 i ne treba mi vise ![]() |
#1993 | |
Datum registracije: Jan 2010
Lokacija: dbk
Postovi: 130
#1994 |
Lokacija: Éire
Postovi: 1,811
Igra mi se sveukupno mozda 5 puta srusila od kad sam ju kupio, od toga 2 puta danas na BUGovom serveru. I jedino sam na njemu se susreo sa nekim problemima. Vec prije spomenuti mortar koji nisam mogao korisitit, vracanje lika na poziciju od prije 7-8 sekundi. |
#1995 |
Lokacija: osijek
Postovi: 454
poz ekipa imam problem,nabavio sam si bc2 i nakon instalacije kada idem joinat na server kaže da nemam punkbuster instaliran a instaliran je i updejtan???? imam winse7 64bit,nisam imao betu,imo sam samo pirata da malo probam prije kupovine oriđiđija molim help ![]() |
#1996 |
Lokacija: Komin
Postovi: 89
Probaj rucno instalirat, skinit fajle s stranice i ubacit gdje treba. Ja sam trebao sebi rucno jer mi program sam nije sve skinio kako treba. A trebas i enableat punkbuster u opcijama. |
#1997 | |
Postovi: 488
#1999 |
otlična rabota! ![]() |
#2001 |
Postovi: 8,355
Zadnje izmijenjeno od: Neo-ST. 18.03.2010. u 21:18. |
#2002 |
Lokacija: Éire
Postovi: 1,811
#2005 |
Datum registracije: Jun 2004
Postovi: 3,996
Meni se igra počela pravo gaditi,bilo je zanimljiva dok nisam otključao sva oružja a sad ili treba biti snajpertist i čučat cijelu rundu u kutu ili biti freak da bi nešto napravio... Počinje mi ličiti na BF2 koji mi se isto gadio. |
#2006 |
Postovi: 8,355
Mene je u zadnje 3 partije izbacilo jedno 20 puta iz igre sa ovom porukom: ![]() Uđem u igru (bilo koji server), i nakon 10-ak sekundi me izbaci. Često ne stignem ni odabrati setup i već me izbaci, a katkad odmah počmem igrat pa me izbaci nakon par sekundi...Već mi je dodijalo. Tako se moram nekoliko puta joinat u igru pa jednom prestane izbacivat i onda mogu normalno igrati. Google ne daje baš neke odgovore, a ovaj fajl pnkbstrB.exe nemam nigdje... |
#2007 |
Lokacija: Požega
Postovi: 271
Veki naj' se sekiravlet :P Pa ova igra ti bar nudi opcije, za razliku od nekih.. Ja sam neki dan izgubio mislim, 11 partija za redom, i da skoro sam razbio Della, ali u bc2 uvijek postoji anger management ![]() Uvijek mosh' ostat' u prvoj bazi i vozat se sa onim malim UAV'om i prakticirat snosaj sa kranijalnim shupljinama svojih neprijatelja ![]() Muce te zalutali metci ? Pre jarko soontze i prashina i losha komunalna sluzba ? Lose zdravstveno osiguranje i stanje na virtualnim cestama ? Vozi sigurno - Vozi Tenk ! ![]() ( ja sam jucer nakon totalnog' de'mOraliziranja sjeo u T90 i pametnim strateskim polozajem, inzinjerskim pozivom i koristenjem istog' prometala na jednom uskom grlu zaustavio cijelu Armiju, unistivsi 5 Abramsa, i 30ak pedestriana, dok su nas ti isti tek' pola sata ranije premazivali 3. slojem vazelina koji se jos nije stigao ni osusiti ![]() Sto se tice saniteta, vjerovatno sam najvise puta svrsishodno izginio trceci revajvat nekog' palog' prvoborca, a kad god. neki Hipokrat premine u gospodinu na moj ocigled' uvijek cu rado zamjenit svoj kit za njegov, ter mu podarit sansu da jos jednom pogine za domovinu, dok mu ja tjeshim ucviljenu udovicu sa njegovim LMG'om ![]() Takodjer sam experimentirao i sa onim Recon analnim kuglicama koje stvarno imaju svoju funkciju, cak i u HC-u ! Dosuljao sam se do glavnog neprijateljskog spawna, uzicao par dogtagova pri ulasku, na drugom katu se pokusao sprijateljit, ali se nekom prozapadnjachkom dipl. ing. mehanike nije svidio moj crveno ofarbani nick, pa je postao nasilan ![]() ![]() ![]() ![]() i sad nek' netko kaze da je igra 'gadljiva' ![]() "Trcim za njim 5 minuta, pisem velikim slovima AMMO, BULLETS, PATRONEEEEE! Ma kakvi..." ![]() ![]() p.s. Ljudi obrisite si Visitor Q'a sa friends liste, jer on je ghost of Xmas past.. nisam uspio vratit taj ID nazalost.. ![]()
I'm all alone, I smoke my friends down to the filter, but I feel much cleaner after it rains.. |
#2009 |
Lokacija: Slatina
Postovi: 362
haha ![]() ja nemam problema s izbacivanjem, svega 2 ili 3 puta sam dobio lost connection, nikad iz igre nisam izbačen! sinoć mi se zgadio conquest, K/D ratio si kvarim s njim ![]() ![]() ja dosadu rješavam tako što stalno mijenjam oružja i malo budem medic, malo assault, malo sniper, sve u istoj igri, kako situacija traži. |
#2010 | |
aka orozinho
Datum registracije: Mar 2008
Lokacija: SB/ZG
Postovi: 264
L E G A L I Z I R A J M O P I R A T S T V O ! ! !
