Staro 18.03.2010., 17:51   #1981
CyCl0p$
Autor Neo-ST Pregled postova
Ovo je Kuky90 pisao, njega sam baš sinoć par puta izrešetao
Anyway, svejedno ne radi, zapnem na prvom koraku. Upišem BUG i ne izbaci ništa.
isti problem imam, mogu samo preko friendsa, a ne ostane u historyu.
mozda se danas promijenilo sta, ali sumnjam...
Staro 18.03.2010., 17:54   #1982
_Cox
_Cox's Avatar
Lokacija: Komin
Postovi: 89
meni search u server browseru nikako ne radi...prvo kliknem na full refresh pa čekam jedno pola sata da izlista sve servere, onda sam probao upisivati "bug", "pce", "ping300", itd. ali nikada ništa ne nađe. Jedini način da se joinam u bug-ov server je da vidim tko s friends liste igra na njemu pa se joinam tako...vrlo iritantno, tim više što ga na taj način ne mogu staviti pod favoritse...
Ima tko soluciju osim čekati EA da riješi sve probleme (možda) ?
Evo sto kazu iz DICE-a za taj problem:
Code:
We have tracked this down to being a firewall issue, not so much  blocking the game but blocking the Updater from getting the latest  version.
To solve the issue disable your firewall (quit the program totally not  just disable with a setting in the firewall itself as Comodo silently  still keeps blocking traffic that is disallowed even when "disabled").
Run the BFBC2Updater.
You should get the latest version of the client
Once you have it you can turn your firewall back on and load the game.  You should see servers in your in game browser.
You may also be able to add the BFBC2Updater to your accepted  applications list on your firewall but that may not work so the above  method is prefered.
It is also worth checking your Firewall settings to see if it is  allowing BFBC2 itself before loading the game. If it isn't in your allow  list then add it to be sure the game has the access it needs.
Nadam se da ce pomoc.
_Cox je offline   Reply With Quote
Staro 18.03.2010., 18:05   #1983
Hrwoye
Hrwoye's Avatar
Postovi: 245
Autor zgmmax Pregled postova
Najbolja mi je atmosfera kada se igra medic, igrali smo mapu isla inocentes i bili defenderi. Rokaju po nama ih blackhawka, mortari padaju na sve strane, sniperi rokaju, padaju granate oko mene kaos, a ja ko muha bez glave trcim okolo po otoku, nis ne cujem, neg sam vidim da neko lezi mrtav 50m dalje i idem mu pomoc.
Vjeruj mi da si ti prakticki jedini medic koji me oživljavao u ovih par dana igranja... Totalno igra dobije smisao uz ljude koji kuže bit igre!
I još nešto - poslao sam requeste cca 15-orici ovdje navedenih igrača i samo trojica me primila!
Možda da probam ovak?
PCE nick.................BF nick
Veki-OS..................Veki[CRO]
Slash555.................LegolasHR
Visitor Q.................Visitor Q
aircanada................S3mp3r (clan tag: [PcE])
ThePornstar.............carpediem90
blava......................Marko008
B3mt1.....................B3mt1
Mansky Hunt............ManHunt1986 (clan tag: [PcE])
proudixz..................proudixz
hammer_of_thor........Narsil
Neo-ST...................Neo-ST (clan tag: [PcE])
PointDexter..............Triumph2407 (clan tag: [PcE])
dUG1......................dUG1
Constantine.............The Constantine
zwer54....................zwerr | clan: [CTN]
bluefluid...................bluefluid
michel......................MichelGTX
bacyc......................bacyc385
Blue_Fatal1ty............Blue_Fatal1ty
zgmmax....................zgmmax
hobitxxx....................tOm[CrO]
tech.........................[PCE]JadrankaKosor
Danko86...................Danko86
Berovk......................(PCE)Bero
Ninja666xx.................AsaHayyim
Strider......................CRO Strider
Paxton......................var|skovic [clan tag: =BoX=]
Paxton......................varoskovic [clan tag: =BoX=]
_Cox.........................CoxUT [clan tag: p.3h]
morozinho..................Orozinho (cro)
Nebbo......................Nebbo
Jumper......................Jump3r101
Cartmann...................Cartmann
Hrwoye.....................[PcE]Capricosa
Hrwoye je offline   Reply With Quote
Staro 18.03.2010., 18:11   #1984
dean225
DD9512
dean225's Avatar
Postovi: 1,869
meni je igra totalno smece, prevelelike mape, preotvorene, respawn predugacak, onda te baci na pocetak mape pa pola sata hodanja do akcije, onda naletis na lika koji je 20 il 25, 30 level, onda naravno ponovno respawn itd.. Shit je veliki dok ne dodjes do 10 lev. a tek ona djecurlija koja ne razumije da treba cuvat bazu, kill-death ratio, svi igraju za sebe. Uzas!
dean225 je offline   Reply With Quote
Staro 18.03.2010., 18:16   #1985
Constantine
Constantine's Avatar
Postovi: 668
ako ti neznas igrat ne znaci da je igra smece
Constantine je offline   Reply With Quote
Staro 18.03.2010., 18:17   #1986
Cartmann
Cartmann's Avatar
Postovi: 488
Autor dean225 Pregled postova
Možeš se respawnat gdje hoćeš, imaš popis pa klikneš, ili klikneš na mapu.
S ostatkom se slažem, al jebga, treba naučit igrat i onda je sve ok. A što se tice sinhronizacije, i to je dobar prijedlog (već ga je netko dao), samo se trebamo dogovorit - netko iskusan preuzet inicijativu.
Cartmann je offline   Reply With Quote
Staro 18.03.2010., 18:19   #1987
zgmmax
zgmmax's Avatar
Postovi: 1,675
Autor Hrwoye Pregled postova
ma reko aj idem malo medica igrat, idem otkljucat M60 za njega kazu da je brutalan
poslje sam jos igro dok si ti otiso i ubiju me i neki lik medic pored mene prodje i ode on u kuruzu a ja mrtav lezim, il druga situacija, ubiju me ispred jedno troje igraca i da jedan uzme moj kit i ozivi me on dalje nastavi po svome.
Trebalo bi svaki put kada ulazis u igru ti pustit neki filmic o ponasanju u MP mozda bi se neki i naucili timskom radu i duhu
Problema sa friend listom je bilo i u beti i mislim da su rekli da je to sa prvim patchom popravljeno al izgleda da jos nije
Staro 18.03.2010., 18:36   #1988
_Cox
_Cox's Avatar
Lokacija: Komin
Postovi: 89
BF: BC2 regrutcije otvorene >> http://ping300.com/
Staro 18.03.2010., 18:46   #1989
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Nije M60 loš, ali nije ni nešt posebno, sad sam igrao medica zadnjih 2 sata, 19 lvl, sad ganjam 5k exp-a za XM8 machine gun, e tad je medic faca
blaa
Staro 18.03.2010., 19:35   #1990
Moree
Postovi: 328
Autor Constantine Pregled postova
Stvarno nekada ima ljudi koji pate od cerebralne paralize. Danas igram sa rusima, engineer klasa, ostenem bez metaka i trazim ammo. Lik nista. Trcim za njim 5 minuta, pisem velikim slovima AMMO, BULLETS, PATRONEEEEE! Ma kakvi...
Pa onda ovi koji neznaju uci u squad. 10tak igraca u teamu a samo 4 u squadu
Autor hammer_of_thor Pregled postova
Ma M60 je best lmg sigurno. Cak bi rekao da je i prejak
Moree je offline   Reply With Quote
Staro 18.03.2010., 19:38   #1991
CyCl0p$
bolji mi je t88 od m60, vise metaka, veci rof, manji recoil.
Staro 18.03.2010., 20:07   #1992
Constantine
Postovi: 668
Autor Moree Pregled postova
mozda lik nezna engleski i prvi put igra bf pa nema pojma o cemu se radi,no isto sam dozivio mnogo puta.
a sto se tice m60,meni nije nešto,no mnogo sam puta ubijen s njim i mnogi ga koriste,a xm8 lmg je ok,no opet ništa posebno,meni ja glavno da imam svoj GOL i M1911 i ne treba mi vise
Staro 18.03.2010., 20:12   #1993
Bezki
Datum registracije: Jan 2010
Lokacija: dbk
Postovi: 130
to je stvar ukusa, meni su iskreno premale i preogranicene mape za moj ukus, ocekivo sam vece mape al eto jbga.
Bezki je offline   Reply With Quote
Staro 18.03.2010., 20:17   #1994
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,812
Igra mi se sveukupno mozda 5 puta srusila od kad sam ju kupio, od toga 2 puta danas na BUGovom serveru. I jedino sam na njemu se susreo sa nekim problemima. Vec prije spomenuti mortar koji nisam mogao korisitit, vracanje lika na poziciju od prije 7-8 sekundi.
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 18.03.2010., 20:53   #1995
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 457
poz ekipa
imam problem,nabavio sam si bc2 i nakon instalacije kada idem joinat na server kaže da nemam punkbuster instaliran a instaliran je i updejtan????
imam winse7 64bit,nisam imao betu,imo sam samo pirata da malo probam
prije kupovine oriđiđija
molim help
dart_tom je offline   Reply With Quote
Staro 18.03.2010., 20:57   #1996
_Cox
_Cox's Avatar
Lokacija: Komin
Postovi: 89
Autor dart_tom Pregled postova
poz ekipa
molim help
Probaj rucno instalirat, skinit fajle s stranice i ubacit gdje treba. Ja sam trebao sebi rucno jer mi program sam nije sve skinio kako treba. A trebas i enableat punkbuster u opcijama.
Staro 18.03.2010., 21:22   #1997
Cartmann
Cartmann's Avatar
Postovi: 488
Ne može svaki medic oživljavat, npr. ja sam tek danas drugi put igrao s medicom i nemam ništa opreme pa ne mogu pomagat ljudima, koliko sam skužio niti bacat pakete pomoći niti oživljavat.. Ali sad ću 2-3 dana igrat s njim pa valjda dođem do toga ps. dobro si mi rekao za to s ammo, ja ostao bez municije kao sniper i nakon 2min razmišljanja skužim da nema pomoći pa prešao na pištolj i zaletio se u neprijatelje, naravno upucalo me za 2s.
Staro 18.03.2010., 21:29   #1998
Zmaj000
Neradnik
Zmaj000's Avatar
Lokacija: Slav.Brod
Postovi: 1,268
Eto sad upisete PCE i odma pronalazi ....
Zmaj000 je offline   Reply With Quote
Staro 18.03.2010., 21:45   #1999
CyCl0p$
otlična rabota!
Staro 18.03.2010., 21:47   #2000
PointDexter
Lokacija: Éire
Postovi: 1,812
Opet problemi sa tim prokletim mortarom
Ako nanisanim na cilj koji je predaleko mortar se zblikora i nemogu ga korisitit do kraja matcha.
Staro 18.03.2010., 21:57   #2001
Neo-ST
Neo-ST's Avatar
Postovi: 8,555
Mortar ima svoj doseg, ne možeš baš gađati na drugi kraj mape
Autor _Cox Pregled postova
Pomoglo!
Dodao igru u whitelist firewalla, i kompletno ga isključio, i sada pronalazi sve. Očito ga je bio djelomično ipak blokirao...
Zadnje izmijenjeno od: Neo-ST. 18.03.2010. u 22:18.
Staro 18.03.2010., 22:28   #2002
PointDexter
Lokacija: Éire
Postovi: 1,812
Ma jasno mi je da nemozezes gadjati drugi kraj mapa, ali ako ciljnik slucajno jednom ode van dometa, mortar mi se zablokira do kraja igre
Staro 19.03.2010., 00:51   #2003
Neo-ST
Neo-ST's Avatar
Postovi: 8,555
Čudno... Evo krepao BUG-ov server, čeka se reboot
Staro 19.03.2010., 00:52   #2004
PointDexter
Lokacija: Éire
Postovi: 1,812
Hehe, samo sam cekao da neko dodje i prokomentira
Staro 19.03.2010., 01:50   #2005
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Meni se igra počela pravo gaditi,bilo je zanimljiva dok nisam otključao sva oružja a sad ili treba biti snajpertist i čučat cijelu rundu u kutu ili biti freak da bi nešto napravio...
Počinje mi ličiti na BF2 koji mi se isto gadio.
Veki-os je online   Reply With Quote
Staro 19.03.2010., 02:32   #2006
Neo-ST
Neo-ST's Avatar
Postovi: 8,555
Mene je u zadnje 3 partije izbacilo jedno 20 puta iz igre sa ovom porukom:
Uđem u igru (bilo koji server), i nakon 10-ak sekundi me izbaci. Često ne stignem ni odabrati setup i već me izbaci, a katkad odmah počmem igrat pa me izbaci nakon par sekundi...Već mi je dodijalo. Tako se moram nekoliko puta joinat u igru pa jednom prestane izbacivat i onda mogu normalno igrati. Google ne daje baš neke odgovore, a ovaj fajl pnkbstrB.exe nemam nigdje...
Staro 19.03.2010., 03:16   #2007
Visitor Q
Visitor Q's Avatar
Lokacija: Požega
Postovi: 271
Veki naj' se sekiravlet :P Pa ova igra ti bar nudi opcije, za razliku od nekih..
Ja sam neki dan izgubio mislim, 11 partija za redom, i da skoro sam razbio Della, ali u bc2 uvijek postoji anger management
Uvijek mosh' ostat' u prvoj bazi i vozat se sa onim malim UAV'om i prakticirat snosaj sa kranijalnim shupljinama svojih neprijatelja
Muce te zalutali metci ? Pre jarko soontze i prashina i losha komunalna sluzba ? Lose zdravstveno osiguranje i stanje na virtualnim cestama ? Vozi sigurno - Vozi Tenk !
( ja sam jucer nakon totalnog' de'mOraliziranja sjeo u T90 i pametnim strateskim polozajem, inzinjerskim pozivom i koristenjem istog' prometala na jednom uskom grlu zaustavio cijelu Armiju, unistivsi 5 Abramsa, i 30ak pedestriana, dok su nas ti isti tek' pola sata ranije premazivali 3. slojem vazelina koji se jos nije stigao ni osusiti )
Sto se tice saniteta, vjerovatno sam najvise puta svrsishodno izginio trceci revajvat nekog' palog' prvoborca, a kad god. neki Hipokrat premine u gospodinu na moj ocigled' uvijek cu rado zamjenit svoj kit za njegov, ter mu podarit sansu da jos jednom pogine za domovinu, dok mu ja tjeshim ucviljenu udovicu sa njegovim LMG'om
Takodjer sam experimentirao i sa onim Recon analnim kuglicama koje stvarno imaju svoju funkciju, cak i u HC-u ! Dosuljao sam se do glavnog neprijateljskog spawna, uzicao par dogtagova pri ulasku, na drugom katu se pokusao sprijateljit, ali se nekom prozapadnjachkom dipl. ing. mehanike nije svidio moj crveno ofarbani nick, pa je postao nasilan te mi i on na kraju predao svoj dogtag, i onda sam otisao na krov, u svako stepeniste ubacio po kuglicu i sa prigusenim snajpom bockao u goozu nadobudne jurisnike koji su nestrpljivo hrlili prema ratnim dogodovstinama. Naravno nije im dugo trebalo da zakljuce da imaju najgori moguci ratni iscjedak u obliku spijunskog sabotera na vlastitom krovu, pa su poslali salvu specijalaca naoruzanih do neizraslih im umnjaka da me nadju, i tada su se kuglice oglasile k'o tamagochiji i uz malo sretje pri odabiru izlaza koji ce odabrat - prvi val sam docekao na svog' Colta, a kad je nestalo PATRONA nije bilo vremena ni za reload, vec samo James Bondovski skok unepoznato ! Padobran je ucinio svoje i ja prezivio da ispricam pricu
i sad nek' netko kaze da je igra 'gadljiva'
"Trcim za njim 5 minuta, pisem velikim slovima AMMO, BULLETS, PATRONEEEEE! Ma kakvi..." na ovo sam otkachio, napravi si bind; Throw me d Box with penislike symbols upon it!!!" mozda pomogne !?
p.s. Ljudi obrisite si Visitor Q'a sa friends liste, jer on je ghost of Xmas past.. nisam uspio vratit taj ID nazalost..
I'm all alone, I smoke my friends down to the filter, but I feel much cleaner after it rains..
Visitor Q je offline   Reply With Quote
Staro 19.03.2010., 04:21   #2008
Neo-ST
Neo-ST's Avatar
Postovi: 8,555
Svaka čast, svaki put odvalim od smijeha na ove tvoje pričice...
Imaš smisla za slikovito prepričavanje
Koji ti je novi nick?
Staro 19.03.2010., 09:07   #2009
Slash555
Slash555's Avatar
Lokacija: Slatina
Postovi: 363
haha
ja nemam problema s izbacivanjem, svega 2 ili 3 puta sam dobio lost connection, nikad iz igre nisam izbačen!
sinoć mi se zgadio conquest, K/D ratio si kvarim s njim zanimljivo je što u svakoj partiji conquesta imam preko 60% accuracy, a K/D ratio 0.5 max
ja dosadu rješavam tako što stalno mijenjam oružja i malo budem medic, malo assault, malo sniper, sve u istoj igri, kako situacija traži.
Slash555 je offline   Reply With Quote
Staro 19.03.2010., 09:25   #2010
morozinho
aka orozinho
morozinho's Avatar
Datum registracije: Mar 2008
Lokacija: SB/ZG
Postovi: 264
Autor Cartmann Pregled postova
DA. isto tako ne mogu ni svi bacati municiju.treba malo igrati sa assaultom. Ja sam recimo totalno zanemario assaulta jer mi je injzinjerac zakon, a assault mi je nekak sta ja znam dosadan, mos' sam ljude ubijat LOL glupo zvuci ali istina. Tako da i ljudi koji imaju veci cin mogu biti da nemaju taj ammo box
L E G A L I Z I R A J M O P I R A T S T V O ! ! !
morozinho je offline   Reply With Quote
