Staro 13.01.2010., 23:25   #661
Kyzo 051
Kyzo 051's Avatar
Postovi: 21
Kinetic scroling radi samo kad je izbornik u popis izgledu ne i mrezi
Ja sam kompjuterska neznalica
Kyzo 051 je offline   Reply With Quote
Staro 13.01.2010., 23:45   #662
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
Yep. Nisam ni ja oduševljen njime. Nekak mi to nespretno izvedeno ili sam ja sam nespretan.
Homescreen plus a pogotovo plus jer se mob ubrzao što posebno primjećujem kod pisanja poruka.
Staro 14.01.2010., 00:52   #663
syss
syss's Avatar
Postovi: 10,805
kinetic in da house
samo zašto čoban preko sebe kaže da nema update, a preko pc suite nađe.
Staro 14.01.2010., 08:17   #664
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
ajde super da su ga izbacili ..nego jel ima sad na home screenu onih widgeta kao kod n97?
edit: evo nasao sam
Changelog for Firmware V40.0.005:
* Kinetic Scrolling
* New Home-Screen (like 5530)
* Auto rotation on text input
* Fixes minor bugs
* Performance improvements
Changelog Update:
* Kinectic Scrolling everywhere except: main menu, application menu, browser
* Homescreen similar to that of 5530 with Contacts Bar (20 contacts).
* QWERTY Keyboard Auto Rotation (on text input screens)
* New screen alarm, but only when the screen is locked
* Ovi Contacts installed
* Removed Download! (Ovi Store still available)
* Replaced “Update Application” with “SW Update” as on the Nokia N97
* The application “Data transfer” was also implemented in “Settings”
* Real Player Updated to 12 October 2009
* Touch more responsive
* Improved stability
* NOT HACKABLE!!
izvor: http://www.tube5800.com/firmware-upd...ube5800.com%29
Zadnje izmijenjeno od: V.I.P. 14.01.2010. u 08:29.
V.I.P je offline   Reply With Quote
Staro 14.01.2010., 12:42   #665
bigAdvance
bigAdvance's Avatar
Postovi: 667
i ima drugaciji nacin javljanja, sad je nesto slicno ko kod iphone-ovog "slide to unlock", samo sto je ovdje "slide to answer"
isto vrijedi i za prekid alarma
bigAdvance je offline   Reply With Quote
Staro 14.01.2010., 12:45   #666
Kyzo 051
Kyzo 051's Avatar
Postovi: 21
NOT HACKABLE!! - nadam se da ce se ovo brzo rijesiti
Staro 14.01.2010., 12:55   #667
syss
syss's Avatar
Postovi: 10,805
isto tako alarm se može stopirat ili snoozat identično sa slajdanjem... naučio sam na teži način, skupa sa mojim suputnicima u autu jutros
Staro 14.01.2010., 13:28   #668
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Lokacija: Medulin
Postovi: 1,384
ja sam na poslu pa nemogu saznat.. jel se mora mjenjati produkt kod za update?
Staro 14.01.2010., 14:09   #669
hrki
Lokacija: ZG - VŽ - KR
Postovi: 279
za sada da
hrki je offline   Reply With Quote
Staro 14.01.2010., 17:12   #670
Corporal Clegg
Outlaw Torn
Corporal Clegg's Avatar
Postovi: 402
Autor bigAdvance Pregled postova
Da, samo kad je zakljucan ekran, doduse. Ali svejedno, zgodna fora.
Nije mi doduse jasno zasto su promijenili nacin podesavanja alarma, ono da se ekran okrene za 90 stupnjeva, ali ajde, nije feler...
The sun sets forever over Blackwater Park
Corporal Clegg je offline   Reply With Quote
Staro 14.01.2010., 18:00   #671
Enter Sandman
dark paradise
Enter Sandman's Avatar
Postovi: 551
Autor syss Pregled postova
dobar , i ja sam imao male radosti, jedno 2,3 min sam pokušavao smrada utišati dok nisam slučajno povukao prstom, krmelje i tako to....
Enter Sandman je offline   Reply With Quote
Staro 14.01.2010., 18:00   #672
Đuzepe
Datum registracije: Jan 2010
Postovi: 10
kako ste nadogradili? preko nokia software updatera?
meni ne pokaze da ima nova verzija... moram onda mijenjat kod? i jel moze neko objasnit kako se to radi? ispricavam se ako je to vec bila tema
Zadnje izmijenjeno od: Router. 14.01.2010. u 18:36.
Đuzepe je offline   Reply With Quote
Staro 14.01.2010., 18:31   #673
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Lokacija: Medulin
Postovi: 1,384
evo tu si procitaj http://www.ipmart-forum.com/showthre...e+product+code
ja sam bas sad napravio update
Staro 14.01.2010., 19:14   #674
Đuzepe
Postovi: 10
krivo sam ja postavio pitanje ne kuzim odakle mi taj kod u koji cu mijenjat?
evo updejto sam, predobar mi je fw... :P
Zadnje izmijenjeno od: Đuzepe. 14.01.2010. u 20:59. Razlog: bzvze
Staro 14.01.2010., 20:56   #675
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 647
Znaci za T-Mobile jos uvijek nema update-a na v41 FW??
Mejzlik je offline   Reply With Quote
Staro 14.01.2010., 21:39   #676
Enter Sandman
dark paradise
Postovi: 551
gle za t mobile nema ni v20 a kamoli v40
Staro 14.01.2010., 21:42   #677
domy_os
domy_os's Avatar
Postovi: 18,866
Zasad još ništa...
Latest available software for Nokia 5800 XpressMusic, product code 0577303
Version: 31.0.101
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 14.01.2010., 21:49   #678
Corporal Clegg
Outlaw Torn
Postovi: 402
Autor domy_os Pregled postova
Zasad još ništa...
Version: 31.0.101
... a i to je stiglo s mjesec, mjesec i pol zakasnjenja u odnosu an druge kodove.
Staro 14.01.2010., 22:14   #679
domy_os
domy_os's Avatar
Postovi: 18,866
Nitko vam ne brani da promijenite kod u balkans, flashate novi firmware i vratite stari kod.
Staro 14.01.2010., 22:29   #680
Corporal Clegg
Outlaw Torn
Postovi: 402
Ma ne kazem nista slazem se s tobom, samo napominjem da za T-Mobile uvijek nova verzija FW-a uvijek kasni.
Staro 14.01.2010., 22:32   #681
mislav_os
freak
Postovi: 2,688
Isto kao i na N97...Ako su vec stavljali iste stvari kao sto ima N97 mogli su onda staviti i te famozne widgete...Al eto,usredotocili su se XM seriji novih modela,a ne N seriji..Al oke,kada je to XM model. A jel mobitel brzi s novim softom?
EDIT: I da,u vezi tog kinetic scrolling...jeste sigurni da to radi samo dok je meni kao popis? ako je tak,onda je preglupo :S
Staro 14.01.2010., 22:41   #682
Corporal Clegg
Outlaw Torn
Postovi: 402
Autor mislav_os Pregled postova
Da, tako je. Dakle, najcesce u imeniku i popisu poruka.
I da, glupo, prilicno glupo. Ali ajde, nije los feature. Dobro dodje pri listanju imenika.
Staro 15.01.2010., 00:06   #683
blackened
blackened's Avatar
Postovi: 1,281
Ne znam kako drugima ali meni je dosta brži i to mi je najbitniji dio ovog apdejta. Velim, pogotovo kod pisanja poruka, em je brži em je precizniji touch kod pisanja.
Novi homescreen kako tako, dok mi je kinetičko korisno u galeriji jer tamo imam najviše datoteka.
Staro 15.01.2010., 01:34   #684
Izet Fazlinovic
Izet Fazlinovic's Avatar
Lokacija: Osijek-Zagreb
Postovi: 336
Ja ne mogu nikako skinit sa neta JAF PKEY Emulator v5., kada dode do 100% pise da ju ne moze spremit i da zovem administratora, loool! probo i na XP i Win7, i sa 20 razlicitih linkova i servera i posluzitelja i isto.... Jel ima netko rjesenje? Jel ima netko link koji 100% valja?
Zadnje izmijenjeno od: Izet Fazlinovic. 15.01.2010. u 17:38.
Izet Fazlinovic je offline   Reply With Quote
Staro 15.01.2010., 14:34   #685
brunci-vg
Lokacija: vel.gorica
Postovi: 303
evo nakon update firmwarea mob je brzi, sve je ljepse... Jedino me muci sto nemogu pokrenuti videopoziv umjesto klasicnog razgovora. jel to netko uspio? Koristim tele2 mrezu.
brunci-vg je offline   Reply With Quote
Staro 15.01.2010., 23:24   #686
domy_os
domy_os's Avatar
Postovi: 18,866
Autor Izet Fazlinovic Pregled postova
Probaj isključiti antivirusni program.
Staro 17.01.2010., 09:51   #687
branimiros82
branimiros82's Avatar
Postovi: 113
Zasad još ništa...
Version: 31.0.101
da moj kod je isto taj.E sad ako skinem onaj JAF i premjenim kod napravim update,vratim kod...i slucajno mi nest rikne a ovi vide da je software 4...oce bitzi problem za garanciju?
branimiros82 je offline   Reply With Quote
Staro 17.01.2010., 14:03   #688
Izet Fazlinovic
Postovi: 336
ma jesam, nista ne pomaze! ako netko moze i ima zelju moze mi se javit da mu dam mail da mi posalje nek se javi!
Staro 17.01.2010., 14:09   #689
domy_os
domy_os's Avatar
Postovi: 18,866
Autor branimiros82 Pregled postova
A čuj, može biti, ali i ne mora. Možda bi se mogao izvući na to da su ti džabe flashali u Mobisu prije xx dana...
Probaj onda JAF PKEY Emulator v4.0, ako ti već 5.0 ne radi...
Staro 17.01.2010., 18:09   #690
slish480
Yeeepiyaye
slish480's Avatar
Lokacija: Graz, Austria
Postovi: 294
Koji product code trebam stavit da mogu updateat, i na koji kasnije moram vratit da ne skuze nista u t-comu??
Hvala
slish480 je offline   Reply With Quote
