#181 |
Postovi: 23,569
Alternativni fw i kako osposobit MaxTv
Ako ste poslušali savjet i spremili T-Com postavke ovo vam nije potrebno, međutim ako ste bili brzopleti pa niste evo kako osposobiti MaxTv na alternativnom fw a bez T-Com postavki (tnx. T0mB1ll). Kao i u prethodnim "rješenjima" koristite CLI preko Telnet - a (za one koji neznaju o ćemu se radi: Telnet commands, start->run->cmd pa unutra tipkati) Code:
(All commands entered are after the prompt “{admin}=>:” )
Log into the CLI interface – telnet 192.168.1.1<ip address="">
Username : administrator
Password : !M1PhoIAD2
2) List the atm interfaces.
{admin}=>:atm iflist
atm_Internet: dest : pvc_Internet
Retry : 10 QoS : default Encaps : llc Fcs : disabled Ulp : mac
Connection State : connected
3) Add a new ATM interface called TCOM_IPTV
{admin}=>:atm ifadd intf = TCOM_IPTV
4) Verify that the new ATM interface is added
TCOM_IPTV : dest : (none)
Retry : 10 QoS : default Encaps : llc Fcs : disabled Ulp : ip
Connection State : not-connected
5) Add a new phonebook entry for VPI=0 VCI=40
{admin}=>:atm phonebook add name=atm_pvc_0_40 addr=0.40
6) Verify that the new phonebook entry is added
{admin}=>:atm phonebook list
Name Use Address
pvc_Internet 1 0.33
atm_pvc_0_40 0 0.40
7) Configure the TCOM_IPTV ATM interface
{admin}=>:atm ifconfig intf=TCOM_IPTV dest=atm_pvc_0_40 encaps=llc ulp=mac
8) Attach and connect the ATM interface
{admin}=>:atm ifattach intf=TCOM_IPTV
9) Create a new bridge interface
{admin}=>:eth bridge ifadd intf=IPTV
10) Configure the bridge to TCOM_IPTV ensure multicast filter is disabled.
{admin}=>:eth bridge ifconfig intf=IPTV dest=TCOM_IPTV mcastfilter=disabled
11) Attach the bridge connection
{admin}=>:eth bridge ifattach intf=IPTV
12) Save the configuration to flash (default filename= user.ini)
{admin}=>:config save
filename = user.ini
{admin}=></ip>
#182 |
Lokacija: BJ/ZG
Postovi: 539
a ako ne koristim maxtv, a ocu thomsona preflashat na sluzbeni firmware, el mogu normalno ga konfigurirat preko njegovog sucelja? takoder da li je istina da se thomsona moze preflashat tako da radi na optimu? [narucio sam wlan router+wlan stick od optime, ali za slucaj da dobijem nekog telseya il kaj ja znam kaj] |
#183 | ||
Lokacija: Splity
Postovi: 3,003
#184 |
Postovi: 3
zna li netko kako se ovom uređaju može pristupiti udaljeno? npr kad sam imao Dlink onda sam upisao u browser ip od rutera... sad to ne pali. Tako sam mogao mjenjati postavke uređaja koji se nalazio kod mene u stanu gdje god ja bio. To mi je služilo da brzo forwardam port za remote desktop ili takve stvari... Mora postojat način. malo je preglupo ako ovaj uređaj nema tu mogućnost.. Btw znam za Remote assistance ali to nije to. Remote assistance kad ukljucim onda se sam zgasi nakon nekog vremena. |
#185 |
Datum registracije: Oct 2001
Postovi: 2,735
uf jesi siguran da bi to zelio? mislim da se nemoze kod njega to nikako... naime to je zastita .. zamisli da se moze i da ti ljudi pokusavaju uci u ruter ... mislim da bi ih brzo prokleo.. stavi iza njega neki komp i spoji se na njega remote desktopom i tamo otvori browser i to napravi.. |
#187 | |
Lokacija: Splity
Postovi: 3,003
Pa ionako mu ISP pristupa. Nije li upravo zato otvoren jedan? Citiraj:
Daljnje podešavanje je vjerojatno moguće jedino CLI-om. Zadnje izmijenjeno od: thopok. 13.07.2009. u 00:37. |
#188 |
Postovi: 3
sumnjam da mu T-com pristupa... danas sam ga upogonio a imam ga vec par mjeseci. intalirao sam novi firmware. neznam čemu bi oni pristupali mojem ruteru. šta imaju prckat po nejmu? firmware se ioanko nije mjenjao od 2007. no to nije bilo moje pitanje.. nastranu ISP i sigurnost i štajaznam šta. briga me za sigurnost jer šta mi ko može? ko prvo da me neko ide zajebavat treba saznat moj ip... onda mora nekak probit sifru od rutera i sta onda? moze mi se igrat s ruterom? lol. ak je nekom tak dosadno da mu se da tak nes radit i ako to ima nekog smisla dam mu i ip i sifru i nek odere!! :P dakle. jel se može kako? mene zanima kak da ja to napravim... mene čudi da to nisam našao, to više manje svi ruteri imaju |
#189 | ||||
Lokacija: Splity
Postovi: 3,003
#190 |
Datum registracije: Aug 2009
Lokacija: zagorje...
Postovi: 1
ovaj router sam dobil s max tv-om(onaj probni rok od 3mj), i nakon kaj smo ga odjavili, nismo vrnuli router(a i nije ko da su ga trazili )e sad, net je normalno prek njega delal par dana i onda iz cista mira krepal(dok sam bil na moru... to mi starci rekli) i sad sam isel glet u cem je problem, i ispada da mi dns-i ne delaju (isel sam na onaj connectivity check) i to sljedeca dva: 195.29.149.197, 195.29.166.117sad sam spojen prek drugog routera(koji nije wlan, i to je glavni prob) i nemrem pingati ove servere, ke to onda nikome ne delaju? jer sam bil i nasel gde je neko pital za nje i kao reklo se da su dobri ![]() onda sam mislil promijeniti dns na opendns servere i to kak je ovde opisano(jer nisam nasel nigde na stranice od routera kak tam zmeniti dns-e....): http://forums.opendns.com/comments.p...&page=1#Item_2 i prvo mi se htel spojiti prek telneta, i sve sam to napravil, al kad sam se spojil na net, mi je uzel defaultne dns-e... i nakon toga se vise nisam mogel spojiti prek telneta (dal moram neke iskljuciti/ukljuciti da se mogu spojiti?)pokusaval prek onog setup wizarda, al isto nije pomoglo, jer tam nemres upisivati dns adrese, i samo su dvije opcije, nakon cega se ni spajati na net vise nije htelo koristim isti username i pass, al mi je hitalo ili auth. failed ili disconected by the user, mislim wtf? a da mi bar nije 5min ranije to isto delalo ![]() onda sam mislil promijeniti firmware, al to trebas cijeli net pretraziti da najdes linkove i to sam jos nasel neke UK operatore, pa nisam ni pokusaval.. e ima neko od vas link na firmware koji bi delal i kojeg bi se moglo podesiti da dela na t-comu? ili kak da podesim nove dns-e?ponorel bum s ovim routerom... >_> |
#192 |
Postovi: 23,569
Manualni unos DNS servera
Poznato je da automatikom dodjeljeni / prepoznati DNS - ovi kod T-Coma ne rade uvjek i najbolje. Rješenje je odabrati korištenje manualno unesenih. Također je poznato da takva podešavanja (ako su i podržana) kroz web konfig ne rade zbog ogranićenja u T-Com custom fw za ovaj uređaj. Koje DNS servere ćete koristit ovisi o vama, u ovom vodiču ću koristit stari (koji još radi) od T-Coma i OpenDNS. Više DNS by ISP. Kao i u prethodnim "rješenjima" koristite CLI preko Telnet - a (za one koji neznaju o ćemu se radi: Telnet commands, start->run->cmd pa unutra tipkati) Code:
<ip address="">
Password : !M1PhoIAD2</ip>
Code:
{Administrator} :dns server route list
Code:
DNS Server Source Domain Metric Intf State 195.109.122.104 * 10 Internet UP 195.109.61.66 * 10 Internet UP Code:
dns server route flush dns server debug clear dns server route add dns=195.29.150.3 metric=1 intf=Internet dns server route add dns=208.67.222.222 metric=1 intf=Internet Code:
Code:
DNS Server Source Domain Metric Intf State 195.29.150.3 * 1 Internet UP 208.67.222.222 * 1 Internet UP Code:
saveall exit Nikky |
#193 |
Postovi: 159
imam thomsona 780 I WL. koristim carnet duo uslugu. je li se može postaviti u router mode. može li mi netko dati link sa objašnjenjem. pročitao sam ovih 7 stranica, ali ima raznih providera. nisam našao nikog sa carnet duo. ja se spajam preko PPPOE konkecije koju sam kreirao u network connections. uopće ne mogu ući u postavke routera sa 192.168.1.X. je li to zato što je u bridge modeu?
zbook G3 i7
#194 |
Postovi: 34,028
Baci oko na temu o Iskon.Duo usluzi. Tamo se i o tome raspravljalo. btw, u Iskonove uređaje se ulazi sa 192.168.100.1
#195 |
Postovi: 159
hvala! stalno zaboravim, ali ne mogu ući svejedno. ![]()
zbook G3 i7
#196 | |
Postovi: 23,569
Iskon je imao neke serije routera i na 192.168.5.1 koliko se sjećam. |
#197 |
Postovi: 34,028
Sam sam se sjetio da se i taj IP koristi. Imam stari (skoro 3g.) Thompson i otvaram ga sa 192.168.100.1.
#198 | |
Postovi: 159
hvala na odgovoru!
zbook G3 i7
#199 | |
Lokacija: Splity
Postovi: 3,003
Pa nije se ništa novo otkrilo. Citiraj:
#200 |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,280
zna netko dal se moze kako podesit ovog thomsona da se sam automatski reboot-a svaki dan u neko odredeno vrijeme? ta opcija dolazi sa novim simensovim ruterima pa reko ako netko zna caku za ovog nebi bilo na odmet |
#201 | |
Postovi: 613
#202 |
Lokacija: Pazin
Postovi: 1
pozdrav....imam problema sa konekcijom na net prek dotičnog routera. Komp mi se uspije spojit na sam router, međutim ne može se spojit na njega, kaže mi da da je "limited or no conectivity". Koristim d-linkov usb adapter za spajanje na router, i on ima neki wizard da se spojim na router, pita me wep zaštitu, ukucam je i kaže da mi bim sad trebao bit spojen na router..međutim nije :/ takodjer ne mogu se spojit na sam router prek njegove ip adrese prek ie! ima li tko ideju kaj krvio radim i šta da napravim?!! |
#203 |
Postovi: 23,569
Prvo pretresi komp da nema virusa/ crviiju i ine gamadi jer se oni vole igrati mrežnim postavkama, pročitaj smjernice i preporuke u ADSL Bibliji, prvo osposobi mrežnu konekciju (Lan) PC <> Router, a onda pređi na bežičnu, koristi fiksne IP adrese. |
#204 |
Lokacija: Petrinja
Postovi: 904
ja sam sve iz prve uspio. U IE upišeš 192.168.1.1. i dođeš u postavke routera, sve sam postavio, conectao se na net i dobio sam vezu na lapu tj. mogu ići na net preko wlan-a, a onaj cd/dvd od d-linka mi je nešto srao kod instaliranja, pa sam to riješio tako da windowsi sami nađu drivere na tom dvd-u. I čim se instaliralo dobio sam vezu na net. Prema ispisu spajanja vidim da mi se barem 1-2 puta na dan disconecta s interneta tj. pukne veza, a upload je mizerno mali. Nokia XM5800 nekada zna kada se poveže na router, resetirat ga.Vidim da i drugi imaju problema s tim routerom + nokia xm5800, ali meni se tek jedanput dogodilo. Onaj cd od t-coma nisam ni dobio, samo neki od routera od kojeg ništ koristi.
#205 |
Lokacija: varaždin
Postovi: 2
Pozdrav, nadam se da sam našao pravo mjesto za sljedeće pitanje: Imam Thomson st780i od t-coma koji mi već jedno vrijeme ne radi, naime, svijetli mi power lampica konstantno crveno, te se baš ništa drugo ne dešava što god uključio otraga. Probao i reset, ali niš se ne događa. Jel to znak da se skroz pokvario ili neka software grška?? KAko da ispitam radi li uopće ? |
#206 |
Postovi: 34,028
Zovi službu za korisnike i objasni im prroblem. Oni ga daljinski mogu iskontrolirati i resetirati. Moja pretpostavka je da je riknuo.
#207 |
Lokacija: Splity
Postovi: 3,003
S takvim uređajem ne mogu oni išta učinit… ![]() |
#208 |
Lokacija: varaždin
Postovi: 2
Ma problemi s ovim uređajem od samog početka. Sad nakon neznam kojeg pokušaja resetiranja svijetli mi power narančasto i žmirka ethernet zeleno. Uglavnom, komp ga nikako ne prepoznaje. |
#209 |
Lokacija: The Netherlands
Postovi: 3
Pozdrav, Postoji li mogucnost da netko zna za administratorski username & pass koji je u ST780WL eventualno mozda ujezdio novim remote updatom od strane t-com? Posto ovaj --> administrator / !M1PhoIAD2, ocito ne radi, a samo obicnim 'user'-skim se naravno nemre nis zeljeno i potrebno napraviti. Unaprijed zahvaljujem na trudu a akoBogda i trazenom odgovoru. |
#210 | |
Lokacija: Križevci
Postovi: 837
Nemogu ga nigdje naci, hvala.
