Staro 02.10.2009., 09:15   #601
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
ASUS HD 5870 Overclocks to 1035/1290 MHz on Air, Aces 3DMark Vantage in CrossFireX
'Here is what four AMD Cypress GPUs can achieve with some careful overclocking, without needing any third-party cooling. Renowned overclocker Kinc sent us details of his latest achievement using four ASUS Radeon HD 5870 1 GB cards installed in a 4-way CrossFireX setup, all overclocked, and cooled by AMD's reference cooler, taking a shot at 3DMark Vantage (Extreme Preset). The four cards returned a score of X26,332 points, with an average frame-rate of 79.49 fps in GT1, and 74.83 fps in GT2.
To begin with the cards were overclocked to 1035/1290 MHz, up from reference speeds of 850/1200 MHz (core/memory). This was supported by raising the vGPU to 1.330V using GPUTool, from 1.015V. The platform to drive this feat comprised of an Intel Core i7 965 XE processor, cooled by Intel's reference (boxed) cooler, clocked at 4257 MHz. To seat them all was an ASUS P6T7 WS SuperComputer motherboard. The feat serves as a prelude to what the future holds in two "Hemlock" accelerators, which make use of two Radeon HD 5870 GPUs each.'
Staro 02.10.2009., 09:42   #602
Verbum
Postovi: 682
Eto i HD5850 uskoro u obliznjem ducanu http://tinyurl.com/ydcux8x
Verbum je offline   Reply With Quote
Staro 02.10.2009., 10:09   #603
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Držite se teme, Furmark to nije
Staro 02.10.2009., 10:24   #604
Mad_Duke
Autor creativo91 Pregled postova
19xx kuna. Znaći samo 500 kuna više nego što su 4850 koštale prije godinu dana. Na žalost nvidia će se loše provesti. Barem do gt4xx
Staro 02.10.2009., 10:30   #605
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Opla
2iljade, nije loše. ali mi je simpatično kako se lagano isprse, a nemaju ih na skladištu...
Staro 02.10.2009., 10:35   #606
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Mail im je valjda zaštopan od narudžbi već,tako mi se čini bar. Da je golem interes. Pa tu na forumu bi je najmanje 50 ljudi valjda uzelo.
Staro 02.10.2009., 11:40   #607
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Evo i za ljude plićeg džepa.
On par with HD 4870, GTS 250 cards
A forum member on mymypc.com posted several images and benches of AMD's upcoming HD 5750, and the new cards looks pretty nice.
The HD 5750 reportedly has 1120 stream processors and 56 texture units. Like the 5800 series, it packs GDDR5 memory, but on a 128-bit bus. Two 5700 cards are expected to appear, the $199 HD 5770 and the $149 HD 5750. They should replace current generation HD 4890 and HD 4870 cards, and they should compete with Nvidia's GTS250, GTX260 cards, as well as upcoming DX11 Nvidia hardware.
Anyway, in synthetic tests the HD 5750 manages to beat both the HD 4850 and the GTS 250, although by a rather tight margin. According to GPU-Z, the HD 5750's core clock is 625MHz, while memory is clocked at a surprisingly high 1150MHz, offering 73.6GB/s of bandwidth. We're really not sure about the memory spec, so take these numbers with a grain of salt.
Ovdje je link na temu na nekom forumu gdje benchano.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 02.10.2009., 11:55   #608
panisher20
panisher20's Avatar
Postovi: 939
panisher20 je offline   Reply With Quote
Staro 02.10.2009., 12:02   #609
Postovi: 33,916
Cijene već padaju, ali su još uvijek visoke u odnosu na vani. 5850 bez poreza dođe u Trstu 207€, a ovdje 1.700kn što je 200kn više.
Staro 02.10.2009., 14:03   #610
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Autor coconut Pregled postova
KO bu mi dal povrat poreza ovdje? Neda se meni čekat god dana na to....Trieste/Graz here I come.
S tim da ciljam na 5850,omjere cijene/perf. ne pridonosi ništa na stranu 5870.
A i CF ce u prvom kvartalu 2010. bit jeftiniji
Staro 02.10.2009., 15:01   #611
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
fran123456 je offline   Reply With Quote
Staro 02.10.2009., 16:12   #612
Wolverine
Wolverine's Avatar
Postovi: 12,423
ako već želiš piknut link nekog proizvoda onda nemoj to radit sa privatnog acc-a jer ga ostali ne mogu otvorit
Sapphire HD5870
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 02.10.2009., 17:33   #613
Igor_Zg
Igor_Zg's Avatar
Postovi: 905
IMO ok cijena za 5870
Igor_Zg je offline   Reply With Quote
Staro 02.10.2009., 17:37   #614
Verbum
Postovi: 682
Dok iscekujemo smanjenje cijena 5xxx serije u lokalnim ducanima i uopce izlazak naslova vrijednih kupovine takve grafe, jedno pitanje.
Da li je Q6600 na recimo 3.5Ghz dovoljan da hd5870 ili hd5850 zasjaje u punom svijetlu?
Staro 02.10.2009., 17:45   #615
naram-sin
The Last Akkadian
naram-sin's Avatar
Datum registracije: Apr 2008
Postovi: 194
Radeon HD 5750
Autor techPowerUp!
Radeon HD 5750 Pictured, Tested
A Chinese tech community MyMyPC.com member pictured, and tested a Radeon HD 5750 graphics accelerator, which is intended to be AMD's flagship product in the sub $150 market segment. Unlike the Radeon HD 5770, which is pictured with a different cooler that resembles that of the Radeon HD 4770 (AMD reference), and Radeon HD 3870, this card makes do with a GPU cooler essentially similar to that of the more common Radeon HD 4770 cooler design, except for a few changes with the fan and the cooler shroud. Under the black, egg-shaped shroud is a heatsink with radially-projecting fins, in which is nested a red 80 mm fan. Everything else on the card, relies on its air-flow.
With the cooler taken apart, we get the first glimpse of the Juniper graphics processor, the next-generation successor to the RV740. Although its package itself isn't very big, perhaps because it has lesser number of memory pins, the 40 nm die certainly is larger than that of the RV740. There are four GDDR5 memory chips surrounding it, and perhaps there are four more right behind them. A simpler 3+1 phase circuit powers the card, and power is drawn from a single 6-pin connector. This reference-design board is using GDDR5 memory chips made by Hynix. The output connector cluster is identical to those of the Radeon HD 5800 series accelerators, with two DVI-D, one HDMI, and one DisplyPort. Although the specifications of the GPU aren't out yet, the driver reports that it is clocked at 700/1050 MHz (core/memory).
Here's the interesting part, the performance figures unearthed by the previewer. The HD 5750 was pitted against Radeon HD 4850, HD 4770, and GeForce GTS 250. At 3DMark Vantage (GPU score) and 3DMark06, the Radeon HD 5750 outperformed both the Radeons from the previous generations, and edged past the GeForce GTS 250, which were tested on the same testbed. After 220 seconds of FurMark, the Radeon 5750 was chugging along at 70 °C, with an average frame-rate of 35 fps.
izvor: techPowerUp!
Ako ne volite Googleove prijevode...
Ma nije ruzna... Mada, ako je ovo bas za kinesko trziste, ne cudi me. Ugl, nisam ocekivao power connector. Mozda pogresno, no whatever. Za 100€ dusu dala i nije neka prevruca pecnica...
naram-sin je offline   Reply With Quote
Staro 02.10.2009., 18:02   #616
Mad_Duke
Ovo samo zakopava nvidiju dulje i dublje u drek. Neznam kakve uopce ima šanse taj njihov mrcinski GT3xx ako Ati zasiti tržište od glave do pete sa svim mogućim modelima dok će se oni trgati da naštancaju 1 ili 2 u startu.
Staro 02.10.2009., 18:13   #617
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,746
Ja bi reka da jest... Don't get me wrong , sigurno da ce biti razlika u odnosu na npr. i5 na 3.5Ghz ali mislim da nece biti znacajna..
Staro 02.10.2009., 18:36   #618
Postovi: 33,916
Mene ova 5770 po izgledu (cooler) i karakteristikama (128-bitna sabirnica na GDDR5) strašno podsjeća na 4770. A ona je bila preskupa za ono što je pružala pa se bojim da bi se to moglo i sada desiti.
Staro 02.10.2009., 18:41   #619
MAGARAC
MAGARAC's Avatar
Postovi: 5,983
Autor Sn4k3 Pregled postova
Ovisi od igre do igre,pogledaj armu 2 i Resident evil 5. Moja 5870 stize veceras ili sutra ,270 jura nakon svih rabata i poreza
Staro 02.10.2009., 18:46   #620
naram-sin
The Last Akkadian
naram-sin's Avatar
Postovi: 194
Jaca je od GTS250. Kojoj je cijena vani od 110-140$, cca.
Ne zna je li cjenovna politika sa 4770 imala veze sa prelaskom na 40nm niti kako se to tocno moglo/trebalo odraziti/opravdati, ali su naznacili na tom kineskom sajtu da bi ova trebala fakat i biti top ponuda za cjenovni razred do 150$. Valjda ce i biti tako. Sto znaci da bi cijene cijele 5xxx serije mogle i jos brze padati (osobito 58xx) nego sto ocekujemo, s obzirom na omjer performansi i (zasada) preporucene cijene ove kartice u odnosu na 58xx kartushe. Osim ako kod nas ne bude oko 1500kn s PDVom, zbog cega bi se konkretno mogli nacekati na povoljnija vremena.
Kako to inace biva kod nas...
BTW, vele na TPU forumu, kako su na neweggu dobili i rasprodali sve primjerke 5850 u manje od dva sata. Nadam se da ce ATI moci dostici potraznju...inace bi cijene u retailu mogle i rasti, ha?
Staro 02.10.2009., 18:46   #621
Mad_Duke
Autor MAGARAC Pregled postova
Mnogo dobra cijena!
Staro 02.10.2009., 18:50   #622
Jelc
Super Moderators
Postovi: 17,485
Pa, ak ne opereš Wolva bolje ju prodaj za 100€
Staro 02.10.2009., 19:23   #623
2 die 4
2 die 4's Avatar
Postovi: 2,238
Došla je, evo sada skidam drivere, i idem instalirati, ćim sve osposobim bacim par fotki kako izgleda u kućištu, i da uz nju se dobiju dvije igere, Dirt2 i Battlestations Pacific !
Idem
RedGreenBlue
Staro 02.10.2009., 19:41   #624
Postovi: 33,916
Autor naram-sin Pregled postova
Vani je 4770 bila (i još je) oko 110$, a kod nas preko 800kn u početku da bi sada pala na 650kn.
Baš sada gledam 5870 'preko bare' i vidim da se kreće oko 380$
http://www.newegg.com/Product/Produc...ption=5870+ati
Staro 02.10.2009., 19:52   #625
thedream
thedream's Avatar
Postovi: 5,458
Na kraju ćemo svi imat istu grafu.
Staro 02.10.2009., 20:08   #626
naram-sin
The Last Akkadian
naram-sin's Avatar
Postovi: 194
Autor 2 die 4 Pregled postova
Idem
Brze mijenjaj 'VGA' pod Moj komp.
Da, pa ova cijena po kojoj je 2 die 4 dobio 5870 je zapravo boli glava. A sto se tice 4770 mislim da ce odredjivanje daljnjih cijena (po)ostati diskreciono pravo retailera sada, jer jedina briga koje im je svima (pa i ATIju) ostala oko HD4xxx je rjesavanje zaliha i poliranje polica za HD5xxx. S obzirom na ATIjev dumping, yieldove, isplativost i sve druge faktore, mislim da ce se dinamika cijena jos pojacati, jer je ATIju u interesu napraviti plasman velikog obujma jos isplativije proizvodne linije nego li je ranija, jer ima sve uvjete da zagrize ogroman dio trzisne kifle, ovaj, kolaca, jelte.
Naravno, ovo ovisi i o razvoju price oko GT300.
To ne bi bilo lose. Samo da je 5870X2 i da je imamo svi. Zivio tehnoloski komunizam!
Staro 02.10.2009., 20:17   #627
TROOPER007
Propali User
TROOPER007's Avatar
Postovi: 221
Idem
hmm sta nije dirt2 izlazak pomaknut?
TROOPER007 je offline   Reply With Quote
Staro 02.10.2009., 20:19   #628
naram-sin
The Last Akkadian
naram-sin's Avatar
Postovi: 194
Mislim da se dobije kupon, kaj ne?
Staro 02.10.2009., 20:26   #629
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Da kupon se dobije, a igricu dobiješ kada pokažeš kupon(u trgovini gdje si je kupio valjda) za koji mjesec.
TV: LG 7450
GAMEPAD: XBOX One
Staro 02.10.2009., 20:29   #630
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Mislim da je samo CD-Key na njoj koji se zgrebe.
Matth€w je offline   Reply With Quote
