Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 04.07.2009., 12:48   #271
e1ectra_one
Creepshow
e1ectra_one's Avatar
Postovi: 417
Autor kArLo Pregled postova
Evo malo i moje zvecarke
Dosta slicni rezultati Dizel
E6750@3.8GHz/1.45V + 2x1GB Kingmax PC2-8500
Kad mi dodu sad Dominatori, pa cu probat opet bas da vidim...
Igraj se malo sa Performance Level-om u biosu
Zadnje izmijenjeno od: Razer. 30.09.2009. u 20:19.
e1ectra_one je offline   Reply With Quote
Staro 04.07.2009., 15:24   #272
kArLo
kArLo's Avatar
Postovi: 368
Autor e1ectra_one Pregled postova
Ma to cu jednom kad mi se bude dalo, pa i isprobat limite, ovo sam brzinski samo da vidim kakva ce reza ispasti
Desktop:
System: Asus X99 Deluxe / Intel i7 5820k + Noctua NH-D14 / 32GB DDR4 Corsair Dominator Platinum 3000Mhz (4x8Gb) / Asus DUAL-GTX1060-O3G / A-DATA XPG SX8200 Pro M.2 SSD 1TB / Sound Blaster Z / Fractal Design Core 3000 / Corsair HX1200
Storage (total of 54TB): 6 x Seagate IronWolf 8TB / WD My Passport Ultra 4TB (2,5") + WD Nomad case / WD Scorpion Blue 1TB (2,5") + Orico case
Video/audio/input/misc:
HP Z32 (32" 4K) / Logitech G933 Artemis Spectrum / Samsung Harman/Kardon Q70 soundbar / Sony XD100 / Corsair K95 / Logitech G9X / Logitech VX Revolution / Canon scanner LIDE 70 / HP LaserJet P1102
Mobile: Lenovo ThinkPad X1 tablet (Intel Core m7 / 8GB DDR3 / 256GB SSD)
kArLo je online   Reply With Quote
Staro 04.07.2009., 17:34   #273
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Autor Doink The Clown Pregled postova
Drago mi je što te moja klaunska malenkost uveseljava kolega Zaboravljaš da su Dominatori još uvijek na defaultu
L2 nema nikakve veze sa RAM-om
Staro 11.07.2009., 08:35   #274
Melani
Lokacija: doma
Postovi: 964
Melani je offline   Reply With Quote
Staro 12.07.2009., 17:05   #275
Orgazmatron
Orgazmatron's Avatar
Postovi: 139
Orgazmatron je offline   Reply With Quote
Staro 12.07.2009., 17:34   #276
Baja 001
Baja 001's Avatar
Postovi: 7,504
Netko neka opere Dizela sa Wolfyom i nekom P35/45 pločom (dosta je više flejma sa QuadGT i flagshipom)
Moram ja zaletit svoga Wolfya na QuadGT
baš mora biti p35,45 ?
ili dobro i ovo
http://forum.pcekspert.com/showpost....&postcount=233
whatever, samo ga skinite i veličanstvenu X38icu
Koji ste vi kokosari, pogledajte sad dobro svojim dioptrijama vrata vesmasine kako E6850 na 400MHz manjem kloku (3600->4000MHz) od vaseg velicanstvenog 45nm uberklokerskog procesora ima bolje rezultate u L2
Stavite svoje uberprocesore na 3600MHz i onda usporedjujte, kad vas toliko bode u oci Koji ste vi kokosari, pogledajte sad dobro svojim dioptrijama vrata vesmasine kako E6850 na 400MHz manjem kloku (3600->4000MHz) od vaseg velicanstvenog 45nm uberklokerskog procesora ima bolje rezultate u L2
Stavi ti svoga na 4000 MHz
Šta si se uhvatio L2, gledaj malo SPi i ostale gluposti ako se već kitiš sa flagshipom
Zadnje izmijenjeno od: Baja 001. 13.07.2009. u 07:48.
Staro 12.07.2009., 18:30   #277
Melani
Lokacija: doma
Postovi: 964
ili dobro i ovo
Staro 12.07.2009., 22:04   #278
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Staro 13.07.2009., 16:34   #279
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Houston we have lift-off Nije baš flagship pederko but who cares Još tu ima mjesta, samo BSOD je granica
C L O W N I N G A R O U N D
Staro 13.07.2009., 16:53   #280
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Kewl, bas si frajer sa 4000MHz
Staro 01.09.2009., 21:58   #281
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
jedan zilavi starac, danas napokon osposobljen 5/5:
uglavnom, sve se vrti iznenadujuce dobro. a cak i cod4 se pokrece iznad 30 fpsa, istina u 800x600, ali ide . jos samo nakeljit neku 7600gs/gt umjesto ove 9600pro, isle bi igre i triput bolje.
i moja kantica, na def. stalo odgadam OC, a morat ce ici. a, i ovako mi je dosta, ali svejedno ce morati ici malo gore. uglavnom:
tako sada imam 370 vrlo ok kanticu, 478 bolju kanticu, i 775 kantu .
Staro 19.09.2009., 21:04   #282
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ihaaa
Obratite pozornost kako Celer na 3.7GHz gazi kao FAP zabu Woldalea E8200 od Burka u L2 rezultatu
Staro 29.09.2009., 08:10   #283
centaur
Datum registracije: Jul 2009
Postovi: 127
Ovaj rezultat mi nije jasan, al mislim da je to zato jer je ploča teži šit.
Zadnje izmijenjeno od: centaur. 30.09.2009. u 16:01. Razlog: Sliku u thumb!
centaur je offline   Reply With Quote
Staro 29.09.2009., 12:43   #284
Gx25
RiSeN FrOm tHe BaNNeD
Lokacija: cro
Postovi: 662
Koji proc imas jer koliko znam athloni nemaju ni otkljucan mnozitelj ni l3 cache?
Sigurno imas phenoma, probaj nadogradit bios ako nemas zadnji.
Gx25 je offline   Reply With Quote
Staro 29.09.2009., 14:02   #285
centaur
Postovi: 127
Je istina, to je Phenom II X2 550 BE, BIOS je zadnji (flešao ga prije tri tjedna), a što se tiče RAM-a, to je Corsair XMS2 2x2 GB, e sad dali možda znaš, dal je ovo normalna pojava: katkad mi se u Everestu konkretno u ovom prozoru (nalazi se dolje) pojavljuju različiti rezultati za memoriju (u kvadratiću koji sam označio) npr 521 MHz - 1042 ili 526 MHz -1052, dakle uglavnom niži od nazivnog takta 533 -1066, to nestaje kad izađem iz programa i ponovno uđem u isti (tad je normalno, kao što je na ovom primjeru - prozoru dolje), sad dal ne znači ništa i uobičajeno je ili mi je RAM u qurcu.
Evo slike kad je normalno:
Nakon restarta kompa dešava se ovo:
Kao što se može viditi i FSB takt je snižen, nakon izlaska iz Everesta i ponovnog pokretanja istog sve je OK. Međutim pojava je svakako čudna (bar ja tako mislim), smatram da je tome kriv šit od ploče, koji ću zamijeniti što prije budem mogao, jer ovakve komponente ne zaslužuju takvu kaznu da budu na takvoj ploči.
Zadnje izmijenjeno od: centaur. 29.09.2009. u 14:23.
Staro 29.09.2009., 14:45   #286
markmofa
Skupljam pare za LCD :)
markmofa's Avatar
Postovi: 32
evo mog rezultata:
Dok sam imao 2.5 GB ( 2 keksa sa 1 GB i jedan od 512)
Kad sam maknuo taj od 512:
procesor:
Zadnje izmijenjeno od: Jelc. 30.09.2009. u 13:32. Razlog: Slike u thumb!
markmofa je offline   Reply With Quote
Staro 29.09.2009., 14:51   #287
Melani
Lokacija: doma
Postovi: 964
Autor centaur Pregled postova
poznati everest bug.
ovaj test memorije je teži šit jer ubiti ni ne mjeri nek preračunava prema tome kaj očita od vrijednosti tak da...
ima dosta primjera gdje je i7 bclk očitan prek 300 ,a cpu-z ga očital normalno ali je everest shodno svom očitanju stavio i takav rez kao da je stvarno bclk na 300.
Staro 29.09.2009., 14:51   #288
centaur
Postovi: 127
Trebam sam ubost jači cooler (a ne stock) za northbridge i za procesor, a onda ću ga ganjat do boli, prije svega dizat i takt memorijske sabirnice (memory bus-a) i množitelj.
Staro 29.09.2009., 14:55   #289
centaur
Postovi: 127
Autor Melani Pregled postova
Neznam dal je Everest bug il nije jer mi u memtestu (zadnjem) očitava RAM ovako: 519 -1038, tak da neznam. Uglavnom to mi je sve uvalilo veliki crv sumnje (paranoje) u ispravnost nekih komponenata (il RAM-a il ploče).
Staro 29.09.2009., 15:00   #290
Gx25
Lokacija: cro
Postovi: 662
Imam isti prolem kao i ti everest i neki drugi programi mi znaju ocitati da mi fsb skace s 231 na 240 i dole. Mislim da je do softvera jer nikako se nemoze mijenjati nesto sto se trenutno ne dira. To se ponekad pojavi
Staro 29.09.2009., 15:03   #291
centaur
Postovi: 127
Autor Gx25 Pregled postova
Aj bar zrnce utjehe, i malo smanjenje psihoze, hvala prijatelju !
Izgleda da te programe treba uvijekm uzeti sa dozom sumnje.
Al mi memtest svejedno nije jasan.
Zadnje izmijenjeno od: centaur. 29.09.2009. u 15:26.
Staro 30.09.2009., 00:32   #292
B@re
B@re's Avatar
Lokacija: Split,Hrvatska(Croatia)
Postovi: 313
Evo malo i moga rezultata,
- dakle C2D E8200, def. clockovi / 2*1gb Supertalenta
Zadnje izmijenjeno od: B@re. 03.10.2009. u 15:51. Razlog: Sliku u thumb!
B@re je offline   Reply With Quote
Staro 30.09.2009., 13:27   #293
Gx25
Lokacija: cro
Postovi: 662
Evo i moje 810-tke na 3ghz, mema na 924mhz, 5-5-5-15 2T inace kingmax 2x2gb 800mhz
Staro 30.09.2009., 19:36   #294
centaur
Postovi: 127
Malo čačkanja po latencijama (našao sam na netu kompletni popis default latencija za moju memoriju) i malo (zanemarivo) bolji rezultati:
Uglavnom kad se u BIOSU stavi opcija Ganged, onda su duplo bolji reultati.
Staro 17.10.2009., 17:44   #295
Doink the Clown
Postovi: 6,214
Malo da i to odvrtimo...
CPU@4.61GHz, RAM@1763MHz
Staro 17.10.2009., 20:40   #296
Razer
Razer's Avatar
Postovi: 11,642
Ni više ni manje, nego začuđujuće loši, da ne kažem katastrofalni rezultati s obzirom na frekvencije.
Staro 17.10.2009., 20:42   #297
Doink the Clown
Postovi: 6,214
Autor Razer Pregled postova
Da, nije ni meni jasno zašto, imaš kakvu teoriju?
Staro 17.10.2009., 20:47   #298
Razer
Razer's Avatar
Postovi: 11,642
S obzirom da sam testiranje memorija obavljao većinom na 790i Ultra čipsetu, tako sam imao prilike često vidjeti kako su prevelike frekvencije ponekad rezultirale slabijim rezultatima nego na manjima. Frekvencije memorije. Slično kao Aquamark čini se...
Skombiniraj si ovako...digni množitelj memorije i spusti frekvenciju procesora na oko 4GHz (spusti multi) pa vidi kakva će biti situacija, ali da frekvencija memorije bude slična ili manja trenutnim.
Staro 17.10.2009., 20:51   #299
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ma ta Everest test je ionako sranje jer moj E6850 uredno gazi sve Wolfdale-e i na vecoj frekvenciji, sto granici s nemogucim
Staro 17.10.2009., 20:52   #300
Razer
Razer's Avatar
Postovi: 11,642
Našao si uzimati rezultate testa za memoriju merotornim za usporedbu snage procesora...
