Staro 23.09.2009., 01:26   #301
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Jedan od prvih reviewa...
Link
Staro 23.09.2009., 01:49   #302
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,560
Neda mi se sad proucavati performanse, ali po ovom testu svaka im cast na idle potrosnji od samo 27W i sto je razina "buke" na razini 4890, a opet ispod NVIDIA high enda.
Hehe samo na povecanoj efikasnosti bi se dalo na godisnjoj razini ustediti do par stotina kn na struji.
Bono je online   Reply With Quote
Staro 23.09.2009., 07:00   #303
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
http://www.guru3d.com/article/radeon...-review-test/1
"The noise levels coming from the card paint a different picture. I'm not really thrilled about it. At IDLE you'll have no problem with the card whatsoever as noise levels remain under 40 dBA.
Once the GPU starts to heat up the fan RPM will go up as well. The card however remains steady at roughly 42 dBA which really is a very normal noise level. Not annoying at all. So that's good as well."
Office,classrom 50dB
Living room 40dB
Bedroom at night 30dB
2173 okr/min venta LOAD -> 77-81C (core,memorija,shadercore)
1070 okr/min venta IDLE -> 35C
Idle je super, mogao bi se ručno još sniziti pa se grafička nebi ništa čula, 2100 okr u loadu nije tako strašno prema onih 3000-3500okr/min kod h4870 ili koliko je već bilo (zaboravio sam)
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
Zadnje izmijenjeno od: Jelc. 23.09.2009. u 09:25. Razlog: prevelika slika
DraŽ je offline   Reply With Quote
Staro 23.09.2009., 07:15   #304
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
U jbt,kakve kartice...
Javite ako vidite koj jos review i neke linkove kada dodu u shopove (nase ili vani).
Majo je offline   Reply With Quote
Staro 23.09.2009., 07:18   #305
Postovi: 33,967
Iskreno - očikavao sam veću razliku između GTX285 i 5870. Ipak se radi o novom čipu i tehnologiju nasuprot preimenovanom i prastarom G92. A ono, kajla.
Staro 23.09.2009., 07:20   #306
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
http://www.pcekspert.com/articles/706.html , i naši su napravili review!
A čuj jača je za oko 95-100% od hd4870 to je napredak itekakav, samo kao što max kaže vjerovatno(mislim da to nije prava riječ) će nvidia rasturit.
S ovim postom iznad se slažem, malo sam više očekivao. Nvidia da napravi skok u performansama samo za 25% u odnosu na gtx285 sa gtx380 karticom ona je zasigurno pobjednik, ali mislim da će taj postotak biti viši.
TV: LG 7450
GAMEPAD: XBOX One
Staro 23.09.2009., 07:46   #307
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Mislim da će većini korisnika na našem tržištu 5850 model biti prihvatljiviji i cijenom,ali i bang-for-$$$ efektom,što zbog popularnosti 4850 modela,što analogijom stvari (5870=4870x2),lako moguće da je u rangu 4850x2 modela, što je odlično,uz Dx11 i ostale nove tehnologije. Eyefinity je stvarno impresivan ali opet,bojim se,kartice sa 6 DP-ova,kod nas - teško.
Staro 23.09.2009., 09:04   #308
maX
maX's Avatar
Postovi: 7,326
Toliko buke i galame nizašto... Lijepo je za vidjeti da su uspjeli obuzdati potrošnju i buku (kolko-tolko), ali što se tiče performansi, očekivao sam dosta više. Ako će cijena biti oko ~2500kn onda će se isplatiti kupnja, ali sve iznad toga je neisplativo. No uvjeren sam da neće biti niti blizu tih cijena kod nas kad dođu...
Staro 23.09.2009., 09:12   #309
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
ako budu visoke cijene ja cu radje kupiti jos jednu 260 polovnu i siknem je u sli
V.I.P je offline   Reply With Quote
Staro 23.09.2009., 09:26   #310
thedream
thedream's Avatar
Postovi: 5,458
Ne treba sad cicijati,direktna usporedba je 4870 vs. 5870 model,a ne 4870x2. Za to ćemo pričekati x2 model serije 5800.Pa onda usporediti,a ako je zaista suditi i po singleGPU 5870, x2 model će GTX295 pospremiti u lijevi džep,a u desni opasno konkurirati GT300tkama.
Pitanje po kojoj cijeni samo. Ostalo je manje više sve na mjestu u člancima, osim što zaboravljamo da će performanse itekako rasti novim driverima,i da se testiralo na betama,guru3d revw.
Bude to svjetski sa prvim Dx11 naslovima,W7 i korekcijom cijene kad se malkice bar namnože modeli.Da ne spominjem pad cijene Dx10 modela serije 4xxx kojeg svi priželjkuju sa starijim grafama.
Ali malo pomalo,novi šerif je u gradu,i painted je in red. Sa Dx11 značkom.
Staro 23.09.2009., 09:38   #311
pingmachine
machine that goes ping!
Postovi: 478
ja čekam 5670... ili kako se već nasljednik 4670 bude zvao. sve ovo troši previše struje, prebučno je i preveliko... nisu svi hardkor gejmeri
pingmachine je offline   Reply With Quote
Staro 23.09.2009., 09:43   #312
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor maX Pregled postova
A jesi sitničav
Obuzdali oni potrošnju, zagrijavanje i buku osjetno
Kartice manje troše i hladnije su od nvidijinih GTX modela što je veliko poboljšanje u odnosu na HD4800
Također performanse su pri velikim rezolucijama uz korištenje AA/AF u rangu ili čak i nešto bolje od HD4870x2 što je za jedan GPU odličan rezultat.
IMHO da na grafu nakaleme 2GB memorije kao što to imaju neke HD4890 bila bi još brža
Nadam se samo da thedreamu nebu otopila jadnu tv karticu sa 40°C u idle-u (vent na 20%) i jedva 80°C u loadu sa ventom na 30% jer očito je da se grafa pregrijava, to je ATI to mora biti tak
Mislim da bu mu sad jasan odgovor na ono njegovo pogrdno A ti jesi?
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 23.09.2009., 09:51   #313
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Dobar korak naprijed, iako bojim se nedovoljan. Sve boljke koje su do sada imali su uspjeli srediti. Svaka cast sto se tice svih tehnologija koje su uveli, ali nije mi jasno zasto se dizala tolika galama oko toga. Eyefinity? Wtf, pa ko ce to koristi da je tolika hajka oko toga?
I kako mogu reci da je ATI sad konacno u prednosti, kad na kraju ispada da se sa novom generacijom chipa natjecu sa nvidijinom starom? To nije korak naprijed, to je samo dostizanje. No dobro, driveri su tu u pitanju, perf ce samo rasti ali nekako mi se cini da ce ih gt300 ipak pokositi. Cak i ako nvidia ne implementira podrsku za dx11 (mislim, i za dx10.1 je bilo silovanje korisnika, svi zivi su znali da serija 4000 to podrzava a glupa nvidija ne, a ruku na srce - jel itko to gdje primjetio? Upalio sam dx10.1 rendering jednom u Clear Sky-u i dobio 25 fps na svojoj konfi? Ono, wtf, to bi kao trebao biti jedan od glavnih razloga za kupnju radeona?).
Ne znam da li biti sretan sto su napravili odlicnu karticu ili biti razocaran sto su konacno napravili odlicnu karticu?
Prava eksplozija performansi bi trebala biti nadam se sa X2 rijesenjem, iliti Hemlockom ajmo ga tako zvati, ali uspjeh 5870/5850 je bojim se trenutan.
U biti nista novo, uspoređujuci generaciju sa generacijom, ATI opet ide na slabije ali jeftinije rijesenje, jer ako gt300 zbilja bude brzi i luđi od ovog, nece im preostati nista drugo nego spustat cijene.
Staro 23.09.2009., 09:57   #314
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor bluefluid Pregled postova
Cak i ako nvidia ne implementira podrsku za dx11 (mislim, i za dx10.1 je bilo silovanje korisnika, svi zivi su znali da serija 4000 to podrzava a glupa nvidija ne, a ruku na srce - jel itko to gdje primjetio? Upalio sam dx10.1 rendering jednom u Clear Sky-u i dobio 25 fps na svojoj konfi? Ono, wtf, to bi kao trebao biti jedan od glavnih razloga za kupnju raeona?).
pa čuj iste su se stvari pričale kada su izašle prve dx10 grafe (G80 čip)
-koja to igra podržava
Sad imaš OS koji podržava dx11 a sumnjam da neće ubrzo i neki naslov s punom podrškom
Dalje koje su polemike bile kad je izašla CUDA, PhysX
-joj kaj će nam to, ko bu to koristil
A gle kak plaču kad ne mogu Shift vozit kak treba
Sve ima svog korisnika, glavno je da se ide naprijed sa tehnologijom
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 23.09.2009., 10:00   #315
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Ja isto ne kuzim kaj vama treba da bi vas zadovoljilo.
Grafa sa jednim cipom je brza nego ove stare sa dva, necujna je, ne zagrijava se pretjerano, slika ljepse zgleda i to bez ikakve zaebancije. Meni se svida
vga killer je online   Reply With Quote
Staro 23.09.2009., 10:07   #316
thedream
thedream's Avatar
Postovi: 5,458
A jesi sitničav
Mislim da bu mu sad jasan odgovor na ono njegovo pogrdnoA ti jesi?
Uzet ću USB Tuner.
Da,pa lijepo da si se pohvalio..
Ima nešto najavljenih igara Dx11,tipa DIRT2,Alien vs. Predator novi,i slično..
Staro 23.09.2009., 10:10   #317
maX
maX's Avatar
Postovi: 7,326
Pa isto kao što se i Phenomi II natječu sa "starim" socket 775 Quadovima, a dok je došao i7 je pokosio sve Phenome. Njima je valjda logično natjecat se s jednom generacijom starijeg hardvera
@ vga killer - sve 5, grafa je odlična, malo se grije i ima jako dobre performanse, ali znaš onu: tko se zadnji smije najslađe se smije... Tako da, čekamo odgovor iz nVidie i direktnu usporedbu "nova generacija vs. nova generacija".
Staro 23.09.2009., 10:17   #318
Wolverine
Wolverine's Avatar
Postovi: 12,425
maxonja daj reci mi kolko to ljudi kupuje high-end (čitaj Nehalem) a koliko ljudi kupuje mainstream
aj prestani pisat ko da 75% korisnika kupuje high-end i 99% njih klouka svoj stroj pa svim silama moraš imat najbolji CiPijU na tržištu
Da, natječu se sa starom jer nove nema na tržištu pa se moraju natjecat sa starom od koje btw ima bolje perf, manje se grije i manje troši
UJ pa fakat su u komi kaj ne?
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 23.09.2009., 10:19   #319
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Matth€w je offline   Reply With Quote
Staro 23.09.2009., 10:22   #320
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,560
A da ne spominjemo da ce sada pobrati vrhnje u iduca dva mjeseca dok ne izade Nvidia GT300 serija.
Stvarno neki pisu ko da imaju 15 godina i ne znaju apsolutno nista o trzistu i njegovoj strukturi.
Valjda bi svi bili zadovoljni da su performanse 2x GTX 295 i da kosta $99.
Staro 23.09.2009., 10:25   #321
naram-sin
The Last Akkadian
naram-sin's Avatar
Datum registracije: Apr 2008
Postovi: 194
Kao sto rece vucko: "Sve ima svog korisnika, glavno je da se ide naprijed sa tehnologijom". I ovo je korak naprijed, korak ispred nVidie, za sada. I kao sto je ATI morao napraviti taj korak da bude ispred aktualne nV generacije, isto ce morati i nV ciniti sa slijedecom generacijom. Koje za sada nema. Osim na papiru. I nVidia opet kasni, kaska i gubi market-share. Ukratko, ATI je opet zaje... nV i ima najbrzu single-chip grafulju za mase. A kada GT3xx izadje, vec ce biti kasno. Do tada ce 58xx, 56xx i druge biti ispod $250. A GT3xx ce biti $500-$600.
Da je nVidia u banani, vidi se i po izjavama glaveshina (ma koliko istinite bile, nije mi jasno kako si dopuste tako nesto): "DX11 nece biti presudan motiv za kupovanje graficke. Biti ce jedan od motiva." Alo?! Jedna od glupljih izjava u zadnje vrijeme. Znaci valjda: kaj god da nV napravi, sa DX11 motiviranim dijelom trzista se moze oprostiti. Mozda zvuci glupo (i jest), ali se na ovo, zapravo svodi...
A odgovor nVidije kasni, btw. Jos nije niti na papiru. Ne za nas. One najbitnije.
Zadnje izmijenjeno od: naram-sin. 23.09.2009. u 10:47.
naram-sin je offline   Reply With Quote
Staro 23.09.2009., 10:30   #322
Wolverine
Wolverine's Avatar
Postovi: 12,425
drito to
pa bilo bi žalosno da GPU koji dolazi kasnije bude sporiji jer su sad imali prilike vidit kaj trebaju potuč i dobro je da bude brža jer će to nastavit daljni razvoj
mene osobno više nervira kaj ATI nikak da složi neku adekvatnu zamjenu za PhysX koji se sve više koristi u igrama.
Autor Bono Pregled postova
high-end = prestige i marketing, a pare se zarađuju na mainstream komponentama
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 23.09.2009., 10:43   #323
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Ne kazem da dx11 nece biti super ako bude islo sve glatko kao sto najavljuju, i ne zelim ga usporediti sa dx10.1 jer je to nemoguce, cak sta vise - citajuci malo o njemu dobio sam dojam da ce biti veca revolucija nego prelazak sa dx9 na dx10, vec zelim iskazati kako se opet ponavlja trend trljanja na nos 'mi imamo, a vi nemate', a vec su se opekli. Trenutno, nama je dx11 totalno nebitan, a kad posane bitan za nadamo se nekoliko mjeseci kad izađe par naslova koji ga podrzavaju, bit ce tu i gt300.
Sto se tice cutting edge high end-a i mainstream-a - 5870 se nikao ne moze svrstati u mainstream po ovoj cijeni
Staro 23.09.2009., 10:46   #324
Wolverine
Wolverine's Avatar
Postovi: 12,425
nitko nije niti rekao da je HD5870 main
ono vezano za high-end i mainstream je vezano na maxovu verziju usporedbe Phenoma i Core i7
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 23.09.2009., 10:47   #325
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Staro 23.09.2009., 10:50   #326
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,560
Pare se zaraduju itekako na inovatorima, znaci onima koji rijetko pitaju za cijenu, ali moraju imati najnovije i najbrze, u tome je Ati u prednosti 2 mjeseca. Naravno da oni nisu baza zarade neke kompanije, ali jedan znacajan dio jesu na koje nove firme uvijek racunaju. Znaci zato se i zove strategija pobiranja vrhnja udu sa visokom cijenom iznad ravnotezne da bi pokupili lovu od takvih, a kasnije kad se trziste malo zasiti i prode vrijeme spuste ju na neku ravnoteznu. U toj fazi se pokrije dobar dio R&D jer su marze visoke, a kako znamo u IT svijetu ima jako puno takvih sta moraju imati nesto prvi dan. Zato sajtovi i casopisi i jesu najbolji prijatelji AMD-a, Nvidie i kompanije jer stvaraju potrebu i potraznju sa hype clancima i najavama.
Razlika u Idle potrosnji na godisnjoj razini izmedu 5870 i GX295 je ~300kWh, sto i nije tako mala brojka, necu to izraziti u kunama da sad ne racunam dvnevno i nocno racunanje vremena, ali kako sam rekao to je par stotina kuna na godisnjoj razini.
Staro 23.09.2009., 10:55   #327
Wolverine
Wolverine's Avatar
Postovi: 12,425
Istina, no takvi će prodat recimo HD5870 kad stigne GT300 samo da imaju najnovije na tržištu tak da od takve klijentele koristi imaju obje strane
No da, ATI će biti u prednosti jer je prvi pustio proizvod na tržište
no mislim da se već previše udaljavamo od teme
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 23.09.2009., 11:00   #328
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,560
Ma samo sam htio razjasniti da je i ATI sa tog aspekta u prednosti, ovaj put su u svim segmentima napravili veliki iskorak.
A proces sam htio opisati jer je i na ovom forumu vidljiv kako ljudi skartaju ili kako ce se sada rjesavati ati 4xxx serije samo zato sto nema 5 u nazivu.
Zaboravio sam opis kupaca kod grafa, pa cu sad staviti i necu vise o tome.
Code:
Innovators are the first to adopt and display behaviour that demonstrates that they likely to want to be ahead, and to be the first to own new products, well before the average consumer. They are often not taken seriously by their peers. The often buy products that do not make it through the early stages of the Product Life Cycle (PLC).
Early adoptors are also quick to buy new products and services, and so are key opinion leaders with their neighbours and friends as they tend to be amongst the first to get hold of items or services.
The early majority look to the innovators and early majority to see if a new product or idea works and begins to stand the test of time. They stand back and watch the experiences of others. Then there is a surge of mass purchases.
The late majority tends to purchase the product later than the average person. They are slower to catch on to the popularity of new products, services, ideas, or solutions. There is still mass consumption, but it begins to end.
Finally, laggards tend to very late to take on board new products and include those that never actually adopt at all. Here there is little to be made from these consumers.
There are a number of examples of products that have gone through the adoption process. They include Ipods or DVD players (or even video players and digital watches). Initially only a small group of younger or informed, well off people bought into these products. Opinion leaders, or the early adoptors then buy the product and tend to be a target for marketing companies wishing to gain an early foot hold. The early majority are slightly ahead of the average, and follow. Then the late majority buy into the product, followed by any laggards. New adoption process or curves begin all the time. Who knows what will happen with solid state technology or Internet purchases of media?
Staro 23.09.2009., 11:05   #329
McT.
McT.'s Avatar
Lokacija: tam negde :)
Postovi: 290
Powercolor i VTX3D 5800 series.
McT. je offline   Reply With Quote
Staro 23.09.2009., 11:08   #330
ZOX
ZOX's Avatar
Lokacija: Koprivnica
Postovi: 297
Po prvim testovima (H/W Canuks, Guru, Anand, Tech report) ispada da 4870X2 kartica zna biti brža od 5870!
Čini mi se da je problem u driverima jer izgleda da nije limitirana bandwidthom.
Ne može 2x800 konfiguracija biti brža od 1x1600.
ZOX je offline   Reply With Quote
