Staro 10.09.2009., 10:54   #151
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,391
According to our own sources, the new HD 5870 offers over 1600 Stream processors. Amazingly AMD doubled the number of SIMD units from 10 to 20. Since each SIMD unit contains 16 5-D units and a Quad-TMU overall, that means we count 1600 stream processors and 80 TMUs. We are talking about a new videocard whose core speed is at 850 MHz and whose 256-bit GDDR5 runs at 1200 MHz – all for the suggested retail of $399! AMD is expecting HD 5870 to come close to the performance of a HD 4870-X2 or the GTX 295.
There is a new feature that is called “eyefinity” which means that three LCDs can be simultaneously supported at 2560×1600, with options for future cards to support up to six LCDs!
The HD 5870 die size is slightly over 330 MM2 and packed with over 2 billion transistors. This translates into one beast of a card with just over 150 GB/second bandwidth. It is very likely that the 8X + 8X PCIe CrossFire slots of the new p55 motherboards for Core i5 will become saturated with two of them.
What is outstanding is that we are hearing that the HD 5870 will perform at just under 28 watts at idle and peak below 190 watts maximum!! That is quite a challenge for Nvidia to meet or beat in their own upcoming GT 300 series as the performance to watt ratio is outstanding.
What is also new to watch for in the HD 58X0 series besides its DX11 capability is that there is a new AA/AF algorithm, where everything on the render back end has been doubled. As a benefit for gamers, that means much less of a performance hit when going from no AA to 4xAA or perhaps even from 4xAA to 8xAA.
The new HD 5850 will launch on September 23 also. We hear it is priced below $299. HD 5850 will sport 1440 stream processors and it will have lower clockspeeds than its big brother. We are hearing somewhere around 700/1000 MHz and it can also display simultaneously on three LCDs at up to 2560×1600 resolution.
Finally, you can expect the HD 5870-X2 to be released in the second half of October.
You heard it here at AlienBabelTech first. And we also think that you may be pleasantly surprised when you actually get your hands on one.
Izvor:
http://alienbabeltech.com/main/?p=11135
Staro 10.09.2009., 15:16   #152
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
HD5870 Crysis Benchmark 分数
CPU:AMD Phenom II X4 955BE
Win 7 RTM
VGA:HD5870 1GB
Crysis 1900x1200 4AA+16AF DX10 Very High
min:30.**
avg:43.**
max:54.**
sigurno neki fake, ali eto...
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 10.09.2009., 15:35   #153
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,311
Znaci 23-eg počinje rasprodaja "starih" kartica. .. dam dam da prodam.
Moram priznati da ovih dana ne bih htio biti vlasnik (uskoro starog i) skupog ati hardvera, kakav ce to biti pad cijena i vrijednosti x2 kartica. ... s 2500kn na 899kn.
Staro 10.09.2009., 15:37   #154
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
A sve to zbog cega? Par igara? Po meni glupo ali tako ce biti
dmr je offline   Reply With Quote
Staro 10.09.2009., 16:29   #155
Mad_Duke
Autor Gilbert5 Pregled postova
Kao da tako nije sa svakim. A uostalom. Ne bi se bas toliko veselio. Kriza, prodaja ide slabo i cijene padaju slabo!
Staro 10.09.2009., 17:22   #156
Atrax
Atrax's Avatar
Postovi: 553
Autor McG Pregled postova
Izvor: techPowerUp
Bolesno izgleda grafa. Jednostavno, čiste linije, minimalistički...opako
Kakve su to dvije "spulje" s prednje strane Remus?
Stvarno je gigantska, takve su otprilike X2 kartuše danas, živo me zanima zbog čega je tako. Kako će onda eventualnu X2 izvesti? Možda neće biti ništa veća od obične čak.
Vidit ćemo. Kad izađe bit će taman vrijeme da pošaljem svoju hd3870 u mirovinu.
Atrax je offline   Reply With Quote
Staro 10.09.2009., 18:32   #157
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
A koliko je dugačka?
HD4870 je ak se nevaram 24cm dugačka.
TV: LG 7450
GAMEPAD: XBOX One
Staro 10.09.2009., 19:15   #158
theobromine
theobromine's Avatar
Postovi: 167
Meni izgleda moćno, kao da može dobro potegnuti
theobromine je offline   Reply With Quote
Staro 10.09.2009., 19:57   #159
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Autor theobromine Pregled postova
Jel to cisto zbog hladnjaka il si bacio grah pa mozes predvidjet?
Staro 10.09.2009., 20:08   #160
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Grafa izgleda super ovako na prvi pogled, ali mislim da je slika fejk... Dapace izgleda mi ko 4870x2 sa modificiranim (citaj: photoshopiranim) hladnjakom..
Staro 10.09.2009., 20:51   #161
Postovi: 7,568
Autor Sn4k3 Pregled postova
Nisu fake, već je vrlo vjerojatno riječ o inženjerskim primjercima kakvi se koriste za sva ova demo okupljanja.
Pitanje dal budu finalni proizvodi opće ličili na ovo sa slika, a pogotovo kad se u sve uključi ekipa proizvođača koja radi svoj PCB, cooler, itd., tj. koji rade sve sami osim GPU-a.
Driving all of this is AMD's next-generation GPU, which will be announced later this month. I didn't leave out any letters, there's a single GPU driving all of these panels. The actual resolution being rendered at is 7680 x 3200; WoW got over 80 fps with the details maxed. This is the successor to the RV770. We can't talk specs but at today's AMD press conference two details are public: over 2 billion transistors and over 2 TFLOPs of performance.
Zadnje izmijenjeno od: McG. 10.09.2009. u 21:07.
Staro 10.09.2009., 21:21   #162
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,557
pa sta je to ?? 80 frejmova na high i to na rezi 7680 x 3200 ??
Staro 10.09.2009., 21:24   #163
Postovi: 7,568
Očito da je brutala. Specifikacije kartica su danas još dodatno potvrđene i čini se da je 1600SP-a (uz ostatak kaj RV870 nudi) dosta i za takve perverzne rezolucije.
Staro 11.09.2009., 00:30   #164
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,557
1600 shader procesora ??? a gtx 260 ima 216 ? Brutalno
Staro 11.09.2009., 00:35   #165
maX
maX's Avatar
Postovi: 7,326
Nemožeš uspoređivati nVidiu i ATI po broju shadera. HD4870 ima 800 pa je sporija ili u rangu GTX260...
Staro 11.09.2009., 00:42   #166
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,557
Ma svejedno je prebrutalno, al posto preferiram nvidiu drzim palceve da ce GT300 biti cudo naspram ove jer ovo je stvarno bolesna grafa.
Staro 11.09.2009., 00:50   #167
Postovi: 7,568
Autor xulos Pregled postova
Stream procesora, a to nije isto ko i shader kod nVidie.
Staro 11.09.2009., 08:44   #168
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Jos jedan prilog raspravi
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 11.09.2009., 09:45   #169
Mad_Duke
A čuj. Sljedeća stepenica što se tiće rezolucija je quad-HD. 1920x1080 je već desetljeće sa nama! (dobro, možda je bolji primjer 1920x1200)
Znaći, trebalo bi očekivati 3840x2160 odnosno 3840x2400.
1920x1080 - 2073600 pixela
3840x2160 - 8294400 pixela
1920x1200 - 2304000 pixela
3840x2400 - 9216000 pixela
Bilo bi lijepo furati jedan recimo 48-56 incha monitor na toj rezi. (zamisli tek onda dual monitor setup )
Staro 11.09.2009., 10:01   #170
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Da se nadovezem, ovako to izgleda sa 4 karte u CF-u
http://brightsideofnews.com/news/200...-computer.aspx
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline   Reply With Quote
Staro 11.09.2009., 10:33   #171
Jerry
Jerry's Avatar
Postovi: 1,816
A sto mislis da stare i skupe nVidia grafe nece okinuti zajedno s njima?
Mislim da sve GTX260, GTX280, GTX295 na forumu ceka cjenovni rang od 699kn, 999kn i 1499kn!
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 11.09.2009., 10:46   #172
theobromine
Postovi: 167
Autor bluefluid Pregled postova
inače proričem iz šalice kave, a ovo je bila opaska na hladnjak...
Staro 11.09.2009., 10:47   #173
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,311
Autor Jerry Pregled postova
Uf, riječi ti se pozlatile. (iako nije baš isto, envidija je nešto kao Golf )
Samo da envidija odgovori uskoro, tako da ati spusti cijene, recimo HD5850 sa 299$ na 229$..već viđeno ali odlična politika za nas kupce.
Staro 11.09.2009., 11:09   #174
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,585
Ati i Samsung su vec spremili nesto "slicno".
http://www.fudzilla.com/content/view/15456/1/
http://www.fudzilla.com/content/view/15457/1/
Svida mi se kod nove kartice sto je energetski efikasna, mogla bi dobit A rating.
Morat cu mjenjat svoju 4890 za novu efikasniju, razliku u cijeni nadoknadim u struji, hehe.
Bono je online   Reply With Quote
Staro 11.09.2009., 11:13   #175
LUXX
Vodenjak :)
LUXX's Avatar
Lokacija: Križevci
Postovi: 667
Padat ce cijene garant.
Uglavnom onima koje se prodaju ovdje na trži ili u oglasniku.
U ducanima sumnjam da ce pojeftinit.
Uglavnom sretan onaj ko ima integrušu grafu il neku zamjensku slabu pa može svoju mrcinu od grafe još kak tak dobro prodat prije nego što se nove zvijeri pojave.
Kad izađu na tržište curit ce cijene sadašnjim rabljenim zvijerima da to nije humano.
Skupljajte lovu i upecajte si nešto fino za sicu
LUXX je offline   Reply With Quote
Staro 11.09.2009., 11:24   #176
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ajme majko
Staro 11.09.2009., 11:44   #177
Jerry
Jerry's Avatar
Postovi: 1,816
24 monitora i rezolucija od 50MP!!!
http://www.youtube.com/watch?v=N6Vf8R_gOec
Ako nije dovoljno sto velite na Crysis i rezu od 5760x2160
http://www.hwupgrade.it/articoli/skvideo/2280/13.jpg
Staro 11.09.2009., 12:33   #178
Postovi: 33,989
Sve je to lijepo, ali je meni malo sumnjivo da je sve to napravljeno sa samo jednom grafom. Vidim da se spominje i 6 displayportova, a znam da nema grafe sa tolikim brojem. Na svim slikama grafe su vidljiva 2 dvi i 1 dp. Ok, dvi se mogu pretvoriti u dp (neka custom grafa), ali opet su kratki za 3 komada.
Staro 11.09.2009., 12:48   #179
Momir
Momir's Avatar
Postovi: 1,011
Pa i receno je da ce biti razlicitih grafa.
Dolazit ce sa 2DVI 1 HDMI i 1 DP, znaci 4 izlaza, ali grafa ce od toga mocu bacati sliku na 3 istovremeno. Kolko sam negdje procitao modeli s 1GB rama na sebi.
A modeli koji ce moc sliku slat na 6 monitora istovremeno imaju 2GB rama i njihove slike ja jos nisam vidio.
Zivi bili pa vidili
Momir je offline   Reply With Quote
Staro 11.09.2009., 12:51   #180
domis
Lokacija: Hrvatistan
Postovi: 4,164
hm...možda greška u pisanju?
http://www.pcekspert.com/articles/698-1.html
