Staro 22.08.2009., 17:36   #691
Postovi: 7,568
Dobro, ja samo pitam. Pošto ti ploča podržava ove quad procesore koje sam spomenul, a da su kaj lošiji od Q9400 - baš i nisu.
Staro 22.08.2009., 19:06   #692
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Autor McG Pregled postova
ne bude ni prvi ni zadnji put da se novi (i relativno skupi) procesori i ploče pokupuju čim stignu u dućane.
Kao sto sam ja napravio sa Dk P45-T2RS i onda se drkario s njom i reklamirao je mjesec dana (3 ploce zamjenio) da bi nakon izlaska novog bios-a ploca proradila kao beba.Nis ne treba odmah kupit kad je novo .Garant ni te ploce nece bit bez bugova , stovise bit ce ih ohohoj i samo ce bit glavobolja korisnicima( kao onaj sa P6T dlx i 12 GB rama) , umjesto da se strpe tam do 1-2 mj a i kasnije,ionda kupe kad to sve bude radilo kak treba.
Staro 24.08.2009., 15:22   #693
Postovi: 7,568
DFI LanParty DK P55-T3eH9 LGA-1156 ploča
DFI's retail-grade pack of motherboards for socket LGA-1156 platform will be lead by the LanParty Dark P55-T3eH9. Dressed in black and orange, the P55-T3eH9 sports a fairly standard feature-set for the Intel P55 chipset. The CPU socket is powered by a 6+2 phase VRM, and is wired to four DDR3 DIMM slots for dual-channel memory. Expansion slots include three PCI-Express x16, depending on what's under the heatsink south of the CPU socket, the orange slots could be (dual x16 or x8). The black slot looks like PCI-E x4, wired to the PCH. Two PCI-E x1 and PCI slots make for the rest of the expansion.
Apart from all the features the P55 PCH provides, including six SATA II ports, an additional controllers add two SATA II, an eSATA and one IDE connector for two devices. Connectivity is care of one gigabit Ethernet controller, and a number of USB ports, including one mini-USB. A high-grade HD audio codec also provides digital audio connectivity through optical and coaxial SPDIF connectors. The LanParty Dark P55-T3eH9 is expected to be priced at 175€.
Izvor: techPowerUp
Staro 24.08.2009., 16:24   #694
Pantera-N
Pantera-N's Avatar
Lokacija: In front of the monitor
Postovi: 1,593
a su izbacili koju "normalnu" ploču, da nije flag ship ???
Pantera-N je offline   Reply With Quote
Staro 24.08.2009., 16:48   #695
Postovi: 7,568
Pa imaju Blood Iron i DK serije ploča, koje nisu vrh DFI-ove ponude.
Ili ako pitaš općenito, imaš masu ECS, ASRock, Asus, MSI i Gigabyte P55 ploča koje ne budu koštale ko suho zlato.
Staro 24.08.2009., 17:39   #696
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Zasto ova ploca : http://www.techpowerup.com/img/09-08-21/125c.jpg ima 2x 8 pin za procesor ?I jos nesto ova dfi-jevka ima 6 + 2 faznu regulaciju, asusica i55 saber ima 12 + 2 , a asus P7P55D ima digitalnu 32+2 .NIje li onda kod DFI 6+2 ipak premalo na odnosu ove 2 ili DK verzije imaju tako male regulacije (moja bivsa DK P45 je imala 4 faznu ).
Staro 24.08.2009., 17:44   #697
Postovi: 7,568
Ova DFI je namijenjena srednjem tržišnom segmentu, dok EVGA svoju ploču reklamira i svrstava u čisti high-end namijenjen brutalnom clockanju.
Svaka od tih ploča je namijenjena različitim tržišnim segmentima i samim tim imaju bolju ili lošiju "opremu".
Osim toga ne bi DFI plasiral tu ploču na tržište, da ploča ne zadovoljava sve potrebne standarde.
Staro 25.08.2009., 13:31   #698
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
A zasto ta evga ima 2x 8 EPS na sebi ? i de mi jos nest reci ak nije bed. Koja je svrha dolaska westmere u 32 nm procesu i koje ce on procesore zamjenit ? jel to nova arhitktura ili samo novo kodno ime tipa lynnfield , bloomfield?
Staro 25.08.2009., 13:41   #699
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Autor xulos Pregled postova
Zato što je ploča must have za OC-ere, koji ce davati brutalne napone uz extremna hlađenja i frekvenciju iznad 5 gigi...i onda dolaze do brojki od 350W+ potrošnje procesora...a 8 pinski EPS je ograničen na nekih 300-350W.
Da ne spominjem napajanja sa dva EPS-a, pa bi bio red da ih imaju kuda piknuti.
Zadnje izmijenjeno od: Gilbert5. 25.08.2009. u 15:32.
Staro 25.08.2009., 13:43   #700
Postovi: 7,568
Ima dva EPS konektora, jer kak sam i rekel EVGA ima neku svoju viziju te ploče za brutalno clockanje pod tekućim dušikom ili helijom, a svrha konektora je bolje i kvalitetnije "opskrbljivanje" procesora tolko potrebnim naponom kod takvih ekskurzija. Westmare je kodni naziv za arhitekturu na kojoj budu temeljeni 32nm (manja potrošnja, IGP, nove instrukcije i tak dalje) Clarkdale, Arrandale i Gulftown procesori. Sve budu to i dalje modeli iz Intel Core i9, i7, i5 i i3 serije procesora. Mislim sve to ti piše kaj na ovim stranicama, kaj po netu, a ovo kaj ja radim je ništ više nego prijevod već postojećih materijala. Daj si truda i sam najdi sve kaj te zanima, jer ovo "prevađanje" IMHO nema nekog prevelikog smisla.
Staro 25.08.2009., 15:10   #701
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Ok thx Gilb i McG , nebudem davio vise , iako volim cut iz prve ruke ovak, jer citao sam po wikipediji i sve mi je to onak previse kodnih imena i svega za skontat.
Staro 26.08.2009., 13:21   #702
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Neću se hvatat toga kao picajzla, no kad si već izvor informacija ovdje samo da rečem da je hlađene LHe nemoguće na Intelovoj platformi odnosno na iX procesorima, tako da ostanimo samo na LN2 ovdje
Staro 26.08.2009., 15:05   #703
Postovi: 7,568
Ma daleko od toga da sam ja ikakav izvor informacija. Moj zayeb za helij, spomenul sam ga samo da skuži za kakve uvjete je EVGA namijenil tu ploču s dva EPS konektora.
Staro 26.08.2009., 15:36   #704
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Ne brini, skontah ja to
A to da nisi izvor informacija objesi mačku o rep. Prolistaj par ovakvih threadova pa vidi tko je taj koji ljude informira o novostima
Staro 29.08.2009., 20:12   #705
medjimorec
medjimorec's Avatar
Datum registracije: Jul 2009
Postovi: 20
dobar dan....moze li mi neko reci nesto o intelovom procesoru Intel Xeon E5440....?
hvala unaprijed....
medjimorec je offline   Reply With Quote
Staro 29.08.2009., 20:33   #706
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
http://tinyurl.com/lgswaw
Nema na cemu.
I kriva tema BTW.
Di sam stao?
Staro 19.09.2009., 01:07   #707
Postovi: 7,568
DFI Hybrid P45-ION-T2A2 hibridna LGA-775 ploča
What we got a look at today was a pre-production version of the Hybrid P45-ION-T2A2 motherboard. At first, we didn’t know exactly what to expect, when DFI called and asked us to come and visit and see its "hybrid motherboard". We know the term in modern times from cars and most things green, but when the word is added before motherboard, it really did get us thinking exactly what we should expect and what we would be getting a look at on our visit. It turned out that DFI created a totally unique motherboard design that actually allows for two systems to run shared (KVM style) or fully independent of each other, on the one single board. The left side of the system is built up of the components for the nVidia Ion and Intel Atom platform. This part could be used as a low-power file server or torrent downloading system or even Blu-ray movie playback. And the right side of the board features the parts seen on a traditional P45 + Socket 775 CPU motherboard, which could be used for gaming, video editing or other intensive applications.
Izvor: TweakTown
Ploča i ideja su lude, ali da nisu mogli najti nekoga ko zna bar donekle razumljiv engleski. Tip je glavni inženjer i još k tome predstavlja novi proizvod, a engleski mu je strani pojam.
Kome pukne film, nek rađe sluša nekaj konkretnije (1, 2), jer se tip žešće muči s riječima/izgovorom i jednostavno ga je grdo za slušati skoro 10min.
Staro 20.09.2009., 00:14   #708
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Pa majko mila, kakav je ovo engleski. Ne znam ni zasto ni kako, ali lik mi je poremetio ritam disanja svojim engleskim jezikom.
Ideja je predobra, bas mi ovako nesto treba u zadnjih par mjeseci.
Cijena je li-la, ali prvi put nesto takvo na trzistu pa je opravdano. Jedva cekam prve testove da vidimo kako to sve stvarno funkcionise.
Staro 20.09.2009., 03:15   #709
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
Ovo je jedno od fenomenalnijih ideja kaj sam videl u zadnje vrijeme.
Evo kak uštediti na struji a i dok ti dođe frend imaš drugi kompjuter
na kojem moreš zaigrati dotu .
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 21.09.2009., 02:24   #710
Dottore
Dottore's Avatar
Postovi: 7,691
čini se dobra ideja. ali kako god mislim da su iz normalnu ploču DFI pretvorili u hibridni s malim Juniorom. premalen broj sata ( koliko na filmu vidim 4 priključka ) i jedan PCI ( npr. audigy) koju su preblizu PCI-e grafičke s standarnim velikim hladnjakom.
nije da prigovaram lošu ideju ali cijena će biti paprena. koliko vidim 399 usd. izgleda da još nije dovršeno a time i pouzdanost.
kad malo razmislim za tu cijenu ipak dobiješ normalnu ploču 900kn i asrock Ion ploču cca 1300kn. više priključka i više prostora a sve spojiš u jedan monitor ( zaboravio sam kako se zove iz dva računala na jedan monitor s tipkovnicem i mišem )
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 22.09.2009., 16:37   #711
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,759
Intel six-core Core i9 photo's
'Thoughy incredibly dull to look at, as they all look the same, the first photo's of a six-core Core i9 processor surfaced over the weekend, this is the Gulftown SKU based on 32nm Intel Some of its features are:
Six-core
Twelve threads
Socket 1366 like 45nm Bloomfield
6×256KB of L2 cache
12MB of L3 cache
Support for X58 chipset
Turbo Boost technology
Integrated three-channel memory controller
QPI bus
130 W TDP (not 100% sure about this one though)
It is rumored that Gulftown will launch in first half of 2010.'
Izvor:guru3d
Staro 22.09.2009., 17:05   #712
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Bolesno...
Majo je offline   Reply With Quote
Staro 22.09.2009., 17:15   #713
Facelessone
Facelessone's Avatar
Postovi: 4,204
Baš me zanima kolko ekipe bude to kupovalo da bi dobili 3i pol fps-a više u cod7
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 23.09.2009., 03:00   #714
Postovi: 7,568
MSI "Big Bang" LGA-1156 ploča + Lucid Hydra 200
A year ago Lucid announced the Hydra 100: a physical chip that could enable hardware multi-GPU without any pesky SLi/Crossfire software, game profiles or anything like that. At a high level what Lucid's technology does is intercept OpenGL/DirectX commands from the CPU to the GPU and load balance them across any number of GPUs. The final buffers are read back by the Lucid chip and sent to primary GPU for display.
The technology sounds flawless. You don't need to worry about game profiles or driver support, you just add more GPUs and they should be perfectly load balanced. Even more impressive is Lucid's claim that you can mix and match GPUs of different performance levels. For example you could put a GeForce GTX 285 and a GeForce 9800 GTX in parallel and the two would be perfectly load balanced by Lucid's hardware; you'd get a real speedup. Eventually, Lucid will also enable multi-GPU configurations from different vendors (e.g. one nVidia GPU + one AMD GPU).
At least on paper, Lucid's technology has the potential to completely eliminate all of the multi-GPU silliness we've been dealing with for the past several years. Today, Lucid is announcing the final set of hardware that will be shipping within the next ~30 days. It's called the Hydra 200 and it will first be featured on MSI's Big Bang P55 motherboard. Unlike the Hydra 100 we talked about last year, 200 is built on a 65nm process node instead of 130nm. The architecture is widely improved thanks to much more experience with the chip on Lucid's part.
There are three versions of the Hydra 200: the LT22114, the LT22102 and the LT22114. The only difference between the chips are the number of PCIe lanes.
The high end product will be launching in October, with the other two versions shipping into mainstream and potentially mobile systems some time later.
Izvor: AnandTech
Staro 23.09.2009., 03:13   #715
Dottore
Dottore's Avatar
Postovi: 7,691
Zanimljivo. Pošto ploča ima tri PCI-e pa bi mogao ići kao tri monitora ( Triple monitor ).
ipak me pomalo podsjeća na Matrox TripleHead2Go
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 23.09.2009., 07:53   #716
Postovi: 34,028
Zgodna fora na istoj ploči imati endiviju i radajnera. Ali mislim da će to biti skupa ploča. Barem u početku.
Staro 23.09.2009., 08:35   #717
Elpresidente1
Datum registracije: May 2009
Postovi: 389
genijalno, samo da ta hydra postane mejnstrim i sve će bit sjajno
Elpresidente1 je offline   Reply With Quote
Staro 29.09.2009., 11:39   #718
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,759
Intel Gulftown comes with tower HSF
'At IDF Intel showed the processor cooler for its upcoming six-core Gulftown processors.
As you can see this is a tower heatsink with four heatpipes, a large PWM fan, and a bolt-thru mounting kit instead of flimsy push-pins. It's unknown if Intel will ship this with all Gulftown processors, or only with the Extreme Edition models. Different from the previous design, the fresh cooler employs tower design with horizontal blowing for enhanced airflow, and it features four copper heatpipes.
Als, no irritating Push-pin any more. It installs with screws.'
Izvor:guru3d
Staro 29.09.2009., 15:21   #719
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,744
Izgleda na novi i9 neče biti hladan kao i7 i i5
Staro 29.09.2009., 21:06   #720
Bara_st
Datum registracije: Mar 2009
Postovi: 197
Jel se zna kada stiže na tržište i koje novosti će donit P57 čipset?
Bara_st je offline   Reply With Quote
