Staro 30.06.2009., 16:59   #91
sick_boy
sick_boy's Avatar
Postovi: 680
Dobio sam preporuku za Beljski Merlot. Trenutno je u Konzumu na sniženju (55kn, bio 64kn, čini mi se). Kolega s posla je rekao da ga je rijetko koje vino tako oduševilo (naravno, treba uzeti u obzir i cjenovni razred).
Ukoliko ga ovih dana stignem probati - javiti ću iskustva.
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 02.07.2009., 14:58   #92
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
ak netko ima doma onaj aparat za vodu ko u uredima, predlažem da si ga ponese na roštilj a bačvicu napuni gembom... odlična fora , imaš dvajst litri ledene gembe, i kad god netko prođe sam si natoči u čašicu , hehe
Pizz je offline   Reply With Quote
Staro 02.07.2009., 15:16   #93
syss
syss's Avatar
Postovi: 10,805
nice catch!
Staro 02.07.2009., 18:48   #94
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,799
Izvanredna ideja. Predpostavljam da je kolateralna zrtva ono sto neminovno ispadne kada okrenes bocu za 180 stupnjeva i dok je ne nabijes na aparat, ili ste prokljuvili neku inovaciju kako u kucnoj radinosti nabiti onaj cep natrag?
Programer
Staro 02.07.2009., 18:54   #95
domis
Lokacija: Hrvatistan
Postovi: 4,165
pa, ne stavljas bocu na aparat, nego aparat na bocu
Staro 02.07.2009., 19:15   #96
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,799
Autor d'beast Pregled postova
Hail to the king!
Tako jednostavno, a tako ucinkovito. Awww!
Programer
Staro 02.07.2009., 19:16   #97
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Najbolje to odmah direktiva spojit u ćube. HC style!
Matth€w je offline   Reply With Quote
Staro 02.07.2009., 22:31   #98
sick_boy
sick_boy's Avatar
Postovi: 680
Ova ideja je super. Šteta što ne mirišem baš gembu, a mislim da bi 20l čistaka bilo malo previše (opet, ovisi kolika je i kako raspoložena ekipa).
U svakom slučaju:
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 02.07.2009., 22:56   #99
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
¸@buba, pa dec-dva prolivenog gembita nije ništa pored večeg dobra... galona ! :-)
@ sik boj, pa ti onda uliješ crnjaka pa u jednoj točiš ladan a iz druge ide kuhano vino, par klinčiča u čašu i amen
svakom svoje , hehe
Staro 02.07.2009., 23:56   #100
sick_boy
sick_boy's Avatar
Postovi: 680
Istina, ali ja bih isključio hladjenje (ako se crno vino pije hladno, gubi se onaj pravi okus vina, za razliku od bijelog kojeg volim 'ladnog).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 03.07.2009., 00:05   #101
domis
Postovi: 4,165
koliko negdje kosta ta spravica...mislim...dobro bi mi došla za gorice, more itd
Staro 03.07.2009., 00:09   #102
sick_boy
sick_boy's Avatar
Postovi: 680
Vidio sam u Metrou dvije verzije - samostojeći, te manji, koji se stavi na stol (nekako mi taj ne ulijeva povjerenje, ali valjd' oni znaju).
Ugl. ne mogu se sjetiti koliko para, ali nije bilo nešto enormno skupo.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 03.07.2009., 00:10   #103
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
a neznam,
bilo bi zgodno da par ljudi ima pa da se onda bacimo u tjuning,
frend mi ima to čudo, pa ču baš pitat kolko i di,
al čini mi se da su oni kupovali tipa dvije za ured pa su treču dobili besplatno, taj je doma ;-)
EDIT; samostoječi treba uzet, malo stila ne....
Staro 03.07.2009., 00:31   #104
syss
syss's Avatar
Postovi: 10,805
yebote led... hladno za gem, toplo za crnjak i klinčiče.
postao si (u mojim alkoholnim očima) korisnik godine i desetljeća za sada
šalu na stranu, ideja je za 5!
Staro 03.07.2009., 01:15   #105
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
@sis , fala, fala samo neka teče !
edit; imam, samo ne na prstu, :-)
Zadnje izmijenjeno od: Pizz. 03.07.2009. u 01:25.
Staro 03.07.2009., 01:24   #106
syss
syss's Avatar
Postovi: 10,805
ma šta hvala, ako imaš papa-like prsten, ja ljubim odmah
Staro 07.07.2009., 20:33   #107
sick_boy
sick_boy's Avatar
Postovi: 680
Upravo sam bio na Hvaru i Braču. Kupio domaći Hvarski plavac, te plavac mali (ovaj potonji u rinfuzi), a na Braču sam posjetio "Najstariju Dalmatinsku vinsku zadrugu" u Bolu, te kupio vrhunski Bolski Plavac mali crni.
Za sada sam probao plavac mali s Hvara i nije loš (za 20kn/lit je skroz OK).
Fora mi je ova zadruga u Bolu - uđeš unutra, a tamo baš buteljiraju pred tobom. Ono, uopće ne izgleda kao trgovina, ali imaju izložene butelje u jednom kutu, pa možeš kupiti (55kn vrhunski plavac, 35kn kvalitetni, 35kn Postup... ili ono bijaše Pošip).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 07.07.2009., 22:12   #108
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
hehe, to kak si opisao vidim več barbu kak zubima tefteri pluteni čep od bocu,
Staro 07.07.2009., 22:44   #109
domis
Postovi: 4,165
evo dvije prigodne
http://www.youtube.com/watch?v=E6WpdbFGuAI
http://www.youtube.com/watch?v=LIXFxulbGjI
sad mi se baš pije, a sutra imam ispit pred jednom rospijom
Staro 08.07.2009., 00:08   #110
sick_boy
sick_boy's Avatar
Postovi: 680
Autor Pizz Pregled postova
Al' nije, baš. Imaju neki stroj za kojim sjedi lik (barba ) i upucava čep. A, pazi sad - izabrao ja butelju, a na njoj cijena. Kaže lik, evo druga bez cijene.... ček, ček, ova ima crnu foliju (ono, preko čepa), sad ćemo mi napraviti jednu s crvenom (naime, pokazna butelja s cijenom je imala crvenu). Ma, doživljaj, kažem vam.
Vjerujem da je vino prva liga (smlatio sam sav Plavac mali s Hvara - 1,5 litra u boci od studene - pa nema smisla otvarati ovo, jer bi mi sad i Ribar bio dobar). Kad probam, napišem dojmove.
E, a u subotu idem kod sestrične na Pelješac - domovina Dingača. Mljac.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 11.07.2009., 21:43   #111
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
od 18h kuham brudetič od bakalara, nutra ide kutjevačka graševina berba 2008, a za gembač sastrane , zericu bolja 2007 kaj je več u butelji...
neloše uglavnom, a lagano i preuzima...
heh, frend se usro kaj je kasnije dofuro neku Belje graševinu
pa smo na kraju isprali usta sa ovim frenč šardonejom iz 2004 kaj se hladi več jedno pol godine u fridžu... nice touch !
Zadnje izmijenjeno od: Pizz. 12.07.2009. u 03:06.
Staro 11.07.2009., 22:20   #112
Malacrass
RAKIJA
Malacrass's Avatar
Datum registracije: Aug 2008
Lokacija: Orahovica
Postovi: 76
Hodite vi na koju litru orahovačke frankovke =)
Malacrass je offline   Reply With Quote
Staro 12.07.2009., 12:46   #113
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
sinoc si piknuo između ostale cuge i ROSE CAB. SAUVIGNON Gato Negro..
vino je u najmanju ruku užasno
prije sam pio SHIRAZ Gato Negro pa sam ocekivao da valjda i ovaj ROSE necemu valja
Staro 12.07.2009., 18:35   #114
messiah
aka Mithrandir
messiah's Avatar
Postovi: 449
Prekjucer diplomirao, pa otisao kupit koju bocu finijeg vinceka...kupio enjingi grasevinu..meni odlicna grasevina..i neki malbec 1865 reserva..vino kosta 110kn, iskreno, meni vrijedi max 50
messiah je offline   Reply With Quote
Staro 12.07.2009., 21:35   #115
sick_boy
sick_boy's Avatar
Postovi: 680
Kakva grijehota - bio danas u Lumbardi na Korčuli i nisam kupio niti probao Grka. Joj, joj.
No, za kaznu sam svratio u vinariju Medirazza i kupio Dingača (90kn), dva Plavca mala (kvalitetno - 30kn po butelji), te jednog Pošipa (80kn - ovo sam i kušao tamo - jedno od najboljih bijelih IMHO). Sutra svraćam u vinariju Mili (Plavac Mili mi se smiješi ).
Jučer sam, btw, pio neko domaće iz Broca (odmah pored Stona) - prva liga. Ne znam koja je sorta (pretpostavljam neki Plavac). Prije nego odem s Pelješca moram ugrabiti par litri (navodno je lik koji ga proizvodi dobio zlatnu medalju).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 14.07.2009., 20:29   #116
sick_boy
sick_boy's Avatar
Postovi: 680
Ispravljen propust - našao i kupio Grk Lumbarda (vrhunski, Stipo Cebalo) u Stonu
E, a sad ispravci - nije Medirazza, nego Madirazza, a onaj Mili nije "onaj" Mili, nego jedna mala privatna vinarija (obitelj Rozić). Imali su na izboru samo Pošip po 50kn (dosta dobar) i neki predikatni Plavac mali (180kn, buteljica od 0,5l). Za ovo potonje se ipak nisam odlučio isprsiti 180 kunića - nisam baš toliki zaljubljenik (posebno kad uzmem u obzir da se za te novce mogu triput kvaliteno napiti).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 21.07.2009., 23:05   #117
sick_boy
sick_boy's Avatar
Postovi: 680
Vratija se Šime s mora i donio kući dva kartona Vina (najrazličitijih, najviše Plavca iz Broca, ali buteljiranog). Nešto se i popilo usput, jelda
I, tako ja danas gledam gdje to uskladištiti, skupa sa onim što sam prikupio kod kuće i sjetim da sam vidio one male hladnjake za vino. I, tako, kupio danas u Metrou dvozonski wine fridge kapaciteta 18 boca za nešto ispod 1000kn.
Ovakav je (samo crni, a ne srebrni, te se prodaje pod brandom Alaska, a ne EdgeStar): EdgeStar TWR181ES aka Alaska WC1052
Trenutno je napunjen do čepa (6 butelji bijelog i 12 crnog) i već par sati se pati spustiti temperaturu (namješteno je 18 čeltijevaca za crno, te 10 za bijelo - trenutno je dostigao 19/18). Čuje se kao PC (zbog ventilatora koji non-stop radi - čak i kad postigne željenu temperaturu). Možda bih ga mogao modati sa kakvim Papstovima umjesto ovih njegovih
Nedostatak (osim buke) je i što malo višlje butelje ne stanu (Madirazza Pošip, te onaj Rozićev, npr. ).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 21.07.2009., 23:29   #118
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor sick_boy Pregled postova
Meni je to jedno od boljih vina
Staro 22.07.2009., 00:03   #119
tutix
tutix's Avatar
Postovi: 4,069
Evo šta sam pio zadnjih nekoliko dana. Frankovka Feričanci - two thumbs up, izuzetno mi je dobro prijalo. Graševina Belje - nažalost, nije mi kao Kutjevačka - ili pakiraju u onaj trolitreni karton nešto drugo al' bilo mi je izuzetno kiselo - dodavana je mineralna . E da pio sam neki Pelješac za 38 kuna - nebuteljiran - flaša od 1 L (bijela etiketa, magare na njoj, berba meni se čini 2007.) - isto mi nije neko bilo.
I da na kraju, našao sam mjesto gdje je Tikveški Vranec - T'ga za Jug najjeftinije - definitivno Billa - 36 kuna za buteljicu .
sick_boy congrats na akviziciji hladnjaka, fin komad hardvera .
Staro 22.07.2009., 00:47   #120
syss
syss's Avatar
Postovi: 10,805
kolko te došla ta igra?
ja sam se odlučio neki dan na low level rješenje i sad filam laganini: http://free-zg.t-com.hr/matija/forums/vine.jpg
mob slika koja je onak... loša
