Staro 15.08.2004., 16:32   #1
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
Outpost pro 2.5 beta
dakle evo izlazi, uskoro, i nova verzija outposta. Lista promjena i updateova je dugacka i imao sam priliku isprobati tu verziju i mogu reci da je sada daleko konfigurabilniji i ima mnogo vise naprednih mogucnosti koje sad nebum nabrajal zato evo copy/paste iz programa:
Build 338/350
Personal Firewall
- Network mask support in Select Address dialogs
- Filtering of localhost packets in Rules creation dialog
- Filtering of transit packets in Rules creation dialog for better performance on the gateway PCs
- RAWSOCKET and non-IP protocols control
- Ability to allow/block ICMP type 10 (Router Solicitation)
- Presets for working in Windows Domain
- Support for creating rules for applications with non-English names
- Ability to add command line parameters in Rules->Action->Run application dialog
Component Control
- Option to accept one changed component for all applications at once
- Option to view all controlled components for particular application
- Option to rebuild component control database from scratch
Leaktests
- Protection against process memory space hijacking by malicious code (Copycat and Thermite leaktests)
- Prompt for launching a process in hidden window (former DisableNetworkForHiddenPrcoess option in outpost.ini)
- Password protection from unauthorized stopping/terminating of Outpost service
Logging
- Option to turn logging off without Outpost restart
- Export of log files in CSV format
- Log viewer shows records in real time
- Component control events are logged
Advanced Configuration Wizard
- Option to edit application rules while performing auto configuration during installation
- Option to build component control database during installation
- Option to run auto configuration similar to one run during installation when creating a new configuration
Miscellaneous Outpost improvements
- Access to Log Viewer can be password protected
- Faster IGMP and ICMP packet processing
- "What's new" is available" from the Help menu
- Warning if user exits Outpost or switches it to Disable mode
- "Show Logging" option added to tray shortcut menu
- Outpost does not require a restart after entering registration key
- All passwords used in Outpost are encrypted
- The date before license expiration is shown
- [Last Hosts] option in outpost.ini is no more logged
- Automatically switching to Block most policy after certain period of inactivity or screen saver activation
- Ability to select a policy for Background mode
Attack Detection plug-in
- Option to play sound when attack or port scanning is detected
- Option to unblock the IP that was blocked by Attack Detection plug-in after attack or port scanning
- Turn on and off detection of attacks of particular type
- Exclusion list of IPs from which port scanning would not be detected
- Exclusion list of ports to which port scanning would not be detected
- Customizing a weight of danger for port to trigger Port Scanning detection warning
- Customizing a weight of danger to trigger Port Scanning detection warning for Minimum, Normal and Paranoid mode
- Fine tuning of attack and scanning detection internal parameters
DNS Cache plug-in
- All requests to remote port 53 violating the DNS standards are blocked
- Ability to exclude host from being cached
Attachment Filter plug-in
- Non-English attachments now also can be renamed
- CLSID now also can be renamed
- Attachment extensions are shown in Properties dialog
Advertisement blocking plug-in
- Ability to download list of keywords from Agnitum forum (AGNIS list)
- Import and export of the settings
Active Content plug-in
- Referrer blocking on site-per-site basis
- Prompt option for referrers
zasada je verzija dostupna iskljucivo za beta testere. finalana verzija bi kao trebala biti gotovo pred kraj ljeta i tu je sada potpuna podrska za SP2 a pod time misle integraciju u security centar.
prilikom rada sam videl da je izuzetno zasad nestabilan, barem meni, uglavno jako cesto zamrzava i usporava komp.
jos malo citata:
“Microsoft is pleased to be working with Agnitum to deliver an easy to use and more secure computing experience to our customers,” said Neil Charney, director, Windows Product Management at Microsoft. “The integration of Agnitum Outpost Firewall Pro within the Windows Security Center feature of Windows XP Service Pack 2, is one example of how industry collaboration is helping to combat the challenges associated with online threats.”
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Zadnje izmijenjeno od: Bl@de. 15.08.2004. u 16:45.
Bl@de je offline   Reply With Quote
Staro 15.08.2004., 23:17   #2
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Bas sam stavio 2.5.341.4327 (356) i radi punom parom. Nemam nikakvih smrzavanja niti ista slicno. Lijepo su to sredili. Svaka im cast
Staro 16.08.2004., 00:03   #3
Bl@de
Bl@de's Avatar
Postovi: 2,004
ja imam neku stariju verziju pa mozda i tu leze problemi. inace ono sto sam vidio jako mi se svidja i jedva cekam finalnu verziju.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 16.08.2004., 15:48   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Je, stvarno odličan fw.
Staro 16.08.2004., 16:31   #5
Bl@de
Bl@de's Avatar
Postovi: 2,004
evo malo sam se jos pozabavio sa testiranjem, tj zasto zamrzava komp. dakle otkril sam sljedece gasenjem servisa "security center" postaje stabilan u windowsima ali nazalost se i dalje zamrzava prilikom spajanja na net. Costa je rekao da njemu na SP1 radi bez problema pa je vjerojatno i u SP" i problem ove nove verzije.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 16.08.2004., 17:36   #6
Freek
Freek's Avatar
Lokacija: Zagreb/Dubrava
Postovi: 2,869
Da li vrijedi prelazit sa ZA na Outpost.
Staro 16.08.2004., 17:43   #7
Bl@de
Bl@de's Avatar
Postovi: 2,004
Strucnjak Rak bu ti rekel da ni u ludili a obicni korisnik, ja, kako oces. meni osobno je on bolji tj nekak mi je lakse raditi sa njime i stvarno je nenametljiv dok ZA nepotrebno za svaku sitnicu zmirka, zvoni i sl.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 16.08.2004., 17:55   #8
Freek
Freek's Avatar
Postovi: 2,869
Da za RAK-a znam šta bi rekao, Costa bi rekao Outpost....
Probam pa vidim...
P.S. kakvi prozorćići i dojave, samo namjestiš da te ne "gnjavi" kad za svaki qurac i radi ko beba.
Staro 16.08.2004., 19:25   #9
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Ma ja kod svakog reinstala stavim malo ZA malo AO. Sad sam zaglavio na zadnje dvije na AO. Nekako mi više leži.
Staro 16.08.2004., 20:41   #10
Bl@de
Bl@de's Avatar
Postovi: 2,004
Tako treba
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 17.08.2004., 13:09   #11
Elven
Elven's Avatar
Datum registracije: Sep 2002
Postovi: 2,721
Ima puno ljudi koji se na to bune. I onda kad im RAK kaže da nije do ZA nego do njih, tj da se očito ne znaju služit s njim onda se uvrijede, frknu nosom i kažu "Kaj god". Ko Otto Barić...
Staro 17.08.2004., 15:08   #12
FlowMaster
FlowMaster's Avatar
Postovi: 232
a da bacite koji link decki???? :clap:
FlowMaster je offline   Reply With Quote
Staro 17.08.2004., 15:49   #13
Bl@de
Bl@de's Avatar
Postovi: 2,004
za daljnje konzultacije koristimo PM
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
