Staro 28.03.2009., 17:47   #1
knezigor
knezigor's Avatar
Datum registracije: Aug 2003
Postovi: 412
Gdje Microsoft Outlook sprema mailove?
Dakle: trebam frendu formatirati i počistiti disk, ali hoće da mu sačuvam mailove...
Znam gdje su mailovi u Outlook Express-u, ali frend radi s Microsoft Outlook-om, a ne znam gdje taj program sprema mailove....
Moze mi netko napisati putanju do foldera u kojem se nalaze ti mail-ovi???
Thanks....
ZnaM Da niŠta Ne ZnaM
knezigor je offline   Reply With Quote
Staro 28.03.2009., 18:59   #2
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
C:\Documents and Settings\User\Local Settings\Application Data\Microsoft\Outlook
Al tamo nema postavke za acc.
žmnpp
Staro 28.03.2009., 19:32   #3
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Najjednostavnije ti je ući u Outlook - File - Export - Messages i Adress Book i poslije vratiš (Import).
Mr.Black je offline   Reply With Quote
Staro 28.03.2009., 19:42   #4
thopok
Lokacija: Splity
Postovi: 3,003
Using the Microsoft Outlook Personal Folders Backup tool
Other things you might want to do
Depending on the type of account you use, Outlook may create a new data file called a Personal Folders file (.pst). That is great if you are a new user but probably not what you want if you were already an Outlook user, you had your e-mail messages delivered to a .pst file, and you want to keep using that .pst file.
Staro 29.03.2009., 19:22   #5
domy_os
domy_os's Avatar
Postovi: 18,923
Također, ne zaboravi spremiti i NK2 datoteku, možda će mu zatrebati... Ona se nalazi u C:\Documents and Settings\user\Application Data\Microsoft\Outlook.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 30.03.2009., 14:00   #6
knezigor
knezigor's Avatar
Postovi: 412
Ma nije mi se za igrati.... frend unutra ima poslovne kontakte od Francuske do Kine unazad 8-9 mjeseci, i da mu se to izgubi mogao bi gotovo staviti ključ u bravu i objaviti bankrot...
Nije samo stvar u adresama nego u prepisci u raznim fazama poslovnih ponuda i dogovora...
Ima li koji siguran način da se pospreme ti mailovi kao što se to jednostavno može u Outlook Expressu???
Staro 30.03.2009., 14:24   #7
thopok
Lokacija: Splity
Postovi: 3,003
A dotični nema backup rješenje?
Što u slučaju otkazivanja diska?
Vjerojatno bi i stvoreni image bio prevelik?
Staro 04.04.2009., 00:11   #8
domy_os
domy_os's Avatar
Postovi: 18,923
Gle, jednostavno negdje prekopiraj ta dva gore navedena foldera...
C:\Documents and Settings\User\Application Data\Microsoft\Outlook
...i onda još u samom Outlooku obavezno napravi export osobnih i arhivskih mapa, ali ne zaboravi uključiti da ti exportira i podfoldere! Osim toga, možeš još dodatno exportirati samo kontakte i listu obaveza, tek toliko da budeš još sigurniji.
Ako paziš što radiš, nemaš brige, sve će se 100% vratiti. To sam već radio najmanje 100 puta i nikad nije bilo problema, a ljudi su znali imati i preko 1 GB mailova...
Staro 04.04.2009., 01:13   #9
mymoon
nautic expert
mymoon's Avatar
Lokacija: Rijeka-Opatija, negdje između
Postovi: 1,386
Autor knezigor Pregled postova
zar je problem reinstall napraviti na novom disku i onda prebaciti podatke sa netaknute instalacije winsa sa starog diska?
parsto kuna dođe novi disk, zaboga. kod bitnih podataka nema igranja...
mymoon je offline   Reply With Quote
Staro 03.06.2009., 16:09   #10
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Jel ima neki način da se Exporta Account iz MS Outlooka 2007 i da ga kasnije samo importam?
Zujio sam po netu nekoliko puta i nikad nisam našao rješenje za to, za mailove nije problem ali za acc je. Jel zna netko?
Zašto MS Outlook nema kao Express Export, import i bok. -_-
žmnpp
Staro 03.06.2009., 20:15   #11
thopok
Lokacija: Splity
Postovi: 3,003
