Staro 26.07.2004., 02:47   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ympeg 1.3
MPEG offers you the most simplest way to encode or convert your favorite videos. YMPEG is a first Freeware MPEG Codec which can integrate itself with Windows and offers seamless encoding from your favorite application (VFW). This unique feature of YMPEG makes it possible to encode your video from virtually any video applications which uses Windows Compression Manager (like VirtualDub, Adobe Premiere, AE, Vegas, DVDx, K!TV etc.)
YMPEG Supports:
- MPEG-1, MPEG-2, VCD, SVCD (ISO/IEC 13818, 11172), DVD, KVCD (non-standard), CVD Encoding
- Audio Layer 1, 2
- PAL/NTSC
- Variable and Constant Bit Rates
- and lot more...
YMPEG Advantages:
- Direct encoding from your favorite applications without any intermediate file or frame servers. This is most simplest way to create MPEG files.
- YMPEG is only MPEG codec which integrates with OS.
- Real-time Encoding
- Highest Applications Compatibility
- Very good Quality
- Fast
- Rich set of options.
- Very handy in converting to MPEG from other formats
- SDK to integrate with your own software and customized GUI. Very easy to use API can provide instant encoding capabilities to your own software applications (only for freeware and non-commercial applications).
- FREE for MPEG-1 encoding. (Can not be shipped with any commercial products, link is fine).
Changes from YMPEG 1.2 to YMPEG 1.3:
- Fixed problem with KVCD. KVCD encoding works fine now.
Note: YMPEG evaluation version will be fully functional for 14 days, after which some of the functionalities will be disabled (like MPEG-2). You can however, continue to use YMPEG evaluation version for encoding MPEG-1, VCD, ... even after evaluation version is expired, completely FREE.
http://www.free-codecs.com/download/YMPEG.htm
Staro 26.07.2004., 14:03   #2
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Meni se srusi kod instalacije. Probao sam i na virtualim XP i opet se srusi. I probam ja na virtualnoj 98ici i ovaj put se ne srusi nego ispise da mi proc ne podrzava SSE
Staro 26.07.2004., 16:03   #3
Jelc
Super Moderators
Postovi: 17,485
Jesi bar mejlo autoru dotičnog softa kaj ga ide?
Staro 26.07.2004., 17:43   #4
Costa
Costa's Avatar
Postovi: 3,193
Ne treba mi, htio sam ga samo isprobati ali eto.
