Staro 15.02.2009., 23:23   #811
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor nick praskaton Pregled postova
a kako na zamzung t220HD provjerit koji je panel, ona standardna procedura ne vrijedi...
Zar nedolaze t2*0 HD monitori iskljucivo sa samsungovim?
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 15.02.2009., 23:32   #812
Hindenburg 129
Hull
Hindenburg 129's Avatar
Lokacija: - okolica Koprivnice -
Postovi: 25
Da ne otvaram novu temu (sorry mod): jel ima pomoći za blago površinski oštečen(ogreban) ekran lcd-a???
Neka pasta, bilo kaj?
- dell 3543 i7 -
Hindenburg 129 je offline   Reply With Quote
Staro 16.02.2009., 07:28   #813
M.Vlahovic
Postovi: 888
Autor sdfdsf Pregled postova
gledao sam samsung SM2433bw, pa me zanima kakav je? Kakavi paneli idu u njega? (samsung ili kineski?)
Jel ima bleedinga i ako ga netko ima neka napise nesto, trazio sam po netu recenzije pa nigdje nema.
to je Tn matrica jeli?
I jos nesto, taj isti monitor nema sjajni premaz po ekranu, nego ima mat jeli? (ne mislim po rubovima)
Matrica je TN Film, mat je, i onaj koji sam ja vidio u dućanu je bio samsung panel
M.Vlahovic je offline   Reply With Quote
Staro 17.02.2009., 14:15   #814
lancoma
Postovi: 1
Pozdrav
Trebam pomoć. Ne mogu se odlučiti koji od ova 2 monitora uzeti. Problem je razlika u rezoluciji, a ne znam da li da mi to igra odluku pro kipnji ili ne. Dell-a još nema kod nas, ali u Kodeksu su mi rekli da će doći u trećem mjesecu i da će koštati 2,300 + PDV. Lenovo košta 3900. Razlog zbog kojeg još uvijek radim na CRT-u je tak što se bavim digitalnim crtanjem i obradom fotografija, a usmjerena sam i 3D-u u budućnosti, a LCD-ovi koje se nalaze (barem većina) na tržištu ne prikazaju boje kak te treba, il su previše osvjetljeni ili previše tamni. Ova 2 monitora upala su mi u oko, al ne znam koji je bolji za grafiku i što gubim ako uzmem nižu rezoluciju. Muči me što pak Dell ima bolju matricu.
Hvala
http://www.mikronis.hr/shop/item.asp...=6507&catid=59
http://www.cnet.com.au/desktops/moni...9294389,00.htm
lancoma je offline   Reply With Quote
Staro 17.02.2009., 15:53   #815
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
ja bi čekao dell.a ali prvenstveno mi manja rezolucija odgovara za igre. Nema neke velike mudrosti, ako imaš potrebe za višom rezolucijom uzmi lenova mada mada kažem; ja bih sačekao dell.a jer na 22" mi više odgovara njegova rezolucija a i novi je model..
Staro 18.02.2009., 18:29   #816
Blaster32
Blaster32's Avatar
Postovi: 154
Autor lancoma Pregled postova
Pozdrav
Hvala
u istoj sam situaciji ko i ti, čekam dell
Blaster32 je offline   Reply With Quote
Staro 20.02.2009., 20:58   #817
syzygy
syzygy's Avatar
Lokacija: Zagreb (centar)
Postovi: 910
prodao samsung 971p i uzeo samsung t220.
velicina i 2ms-a se osjete, ali tn matrica je doslovno smece.
jos uvijek ne mogu brightness nastimati normalno
syzygy je offline   Reply With Quote
Staro 20.02.2009., 22:11   #818
syzygy
syzygy's Avatar
Postovi: 910
ovo je koma, ne mogu nikako nastimati boje niti brightness niti nist kak spada, sve izgleda lose
kakve postavke imaju ostali vlasnici?
Zadnje izmijenjeno od: syzygy. 11.05.2009. u 20:04.
Staro 23.02.2009., 07:52   #819
Hoff
Resident Arse
Hoff's Avatar
Postovi: 49
Jel može netko objasniti što je to točno HDTV pošto je razlika između običnog i takvog modela parsto kuna. A s obzirom da mi kartica to ionako ima, uzeo bi takvog ako se ne radi o nečem trivijalnom.
.:: The Hoff ::.
Hoff je offline   Reply With Quote
Staro 23.02.2009., 11:01   #820
Chome
TK
Chome's Avatar
Postovi: 1,090
Autor Hoff Pregled postova
Ako je fullHD znači da može prikazat punu HD rezouciju 1080 progressive. E sad ovisi jeli kupuješ monitor za gledati filmove u fullHD-u ili samo za rad za kompom.
Ovdje pogledaj!
Chome je offline   Reply With Quote
Staro 24.02.2009., 14:25   #821
MiL
MiL's Avatar
Postovi: 120
Autor syzygy Pregled postova
Brightness=55, Contrast=57, Gamma=Mode2, Color Tone=Warm, RTA=Mode2
Samsung panel, prilicno mracna soba, oci osjetljive.
Dobrodosao u TN svijet
MiL je offline   Reply With Quote
Staro 24.02.2009., 14:52   #822
syzygy
syzygy's Avatar
Postovi: 910
ma vise manje sam sredio boje..iako ga navecer bez svijetla ne mogu nikako gledat...cim skupim lovu prodajem i uzimam nesto bolje :/
Staro 24.02.2009., 15:28   #823
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Meni je super, brightness drzim na 25 kad surfam, i po noci bez svijetla ga drzim na isto toliko. Uglavnom je super!
Provjeri koji si panel dobio.
TV: LG 7450
GAMEPAD: XBOX One
Staro 24.02.2009., 20:31   #824
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
ja imam samsung panel i ak stavim brightness na 22 zuji ko da sam u kosnici jbt!
wtf??
Shockre je offline   Reply With Quote
Staro 24.02.2009., 23:04   #825
bigAdvance
bigAdvance's Avatar
Postovi: 667
pozdrav, prelisto sam zadnjih par stranica u ovom threadu i nisam naso ono sto sam trazio
dakle treba mi 20/21/22" wide za <1200...moze li se ista kvalitetno nac za te novce?
pretezito mi treba za uredske poslove, povremeno koji film i tu i tamo neka igra
hvala
bigAdvance je offline   Reply With Quote
Staro 24.02.2009., 23:06   #826
bigAdvance
bigAdvance's Avatar
Postovi: 667
dupli
Staro 24.02.2009., 23:48   #827
velorien
velorien's Avatar
Datum registracije: Aug 2008
Lokacija: Bjelovar
Postovi: 347
Kako ne, LG W2242T 22", ovisno gdje kupuješ je ispod 1200 kn, u HGSpotu i Vemilu je bio 1250 kn.
velorien je offline   Reply With Quote
Staro 25.02.2009., 14:41   #828
bigAdvance
bigAdvance's Avatar
Postovi: 667
zasad mi je taj favorit, a ako ima mozda nesto bolje/kvalitetnije, a da je 20 ili 21" za istu cijenu (ili manje) neka netko nesto kaze
Staro 25.02.2009., 16:46   #829
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 846
jednostavno nema. za te pare svi su manje vise jednaki... razlike su jako male ..i ja sam u dilemi da kupim taj lg il da stedim još malo pa ubodem nešto bolje,al onda opet sve je to tn matrica pa si uvijek skoro na istom. najbolje bi bilo kad bi bilo nekog jeftinijeg monitora sa ips il pva matricom,al ih jos na žalost kod nas nema.. a 3000 kn nemam pa ću očito morat tog lg-a..
snorky_vk je offline   Reply With Quote
Staro 25.02.2009., 16:53   #830
agm7007
noise freak
agm7007's Avatar
Postovi: 323
Autor velorien Pregled postova
Tog ja planiram nabaviti uskoro... Samo W2042T, jer bi mi možda 22" bilo malo preveliko, izgleda mi čudno budući da sam priviknut na ovih 15.4" na laptopu...
agm7007 je offline   Reply With Quote
Staro 25.02.2009., 17:10   #831
velorien
velorien's Avatar
Lokacija: Bjelovar
Postovi: 347
Ma ja mislim da ćeš požalit ako uzmeš 20", bolje uzet (crni afkors) W2242T i bit miran. I 20" i 22" će ti izgledat veliko i čudno, ali opet navikneš se za par sati/dana.
Staro 25.02.2009., 22:28   #832
Vragoder
Drone
Vragoder's Avatar
Lokacija: Senj
Postovi: 396
Potpis - privikavanje kratko traje, a upotreba je (skoro) trajna... Veća površina FTW!
Vragoder je offline   Reply With Quote
Staro 25.02.2009., 22:45   #833
Doms
Datum registracije: Apr 2008
Lokacija: Kod kuce, a di dalje?
Postovi: 58
Hehe, meni je trebalo puna pola sata ba se naviknem na svoj mon od 22".
Imao sam prije 17" CRT, star je bio bar 5 godina...
Quid Quid latine dictum est altum viditur!
Bilo što rečeno na latinskom zvuči pametno!
Doms je offline   Reply With Quote
Staro 26.02.2009., 14:12   #834
Hoff
Resident Arse
Hoff's Avatar
Postovi: 49
Na svom starom kompu furam 14" Belineu staru 11 godina.
.:: The Hoff ::.
Staro 26.02.2009., 18:23   #835
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Jel se to meni čini ili sam dobio neki golden sample primjerak Samsung T220?
Moj ništa nezuji ni na brightness 0 ni na 100 i contrastom na 0 i na 100...
Ovaj mi je tako dobar da bi ga mogao držat 5god, i mogu gledat iz svih kutova, nema izbijanja svjetlosti(neprimjetno, i jako malena površina) predobro.
Ali sam zato dobio opet "loš" primjerak procesora...
TV: LG 7450
GAMEPAD: XBOX One
Staro 26.02.2009., 20:17   #836
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
ma ne kuzim to..
meni pocne zujat kad smanjujem brightness od 90 na nize..
svijetlost izbija i gore i dole..nije bas neprimjetno,al mi ne smeta. naviko sam od prijasnjih monitora i jer rijetko imam neku tamnu sliku na ekranu.
samo me to zujanje je*e.
mozda ne cujes od buke oko tebe (televizor,kompjuter il nesto),stavi brightness na npr 50 i pribilizi se monitoru,zuji od iza na sredini otprilike..
Staro 26.02.2009., 20:50   #837
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
sutra cu provjerit , kada starci odu na posao(sutra nema škole hehe).Ako ti to čuješ onako kad normalno sjediš 0,5-1m od monitora,ja to bome nečujem na toj udaljenosti(komp je skroz nečujan u idle), ako i zuji kada se skroz približi uho k monitoru to se može zanemariti.
TV: LG 7450
GAMEPAD: XBOX One
Staro 27.02.2009., 11:43   #838
josip22
Lokacija: svugdje
Postovi: 54
Jel može mišljenje , a najbolje bi bilo i sikustvo ako ko ima model od Samsunga sm2333hd 23inch , model koji ima u sebi i tv tuner pa bi posužio kao tv ?
josip22 je offline   Reply With Quote
Staro 27.02.2009., 12:42   #839
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Evo provjerio sam, cuje se kad dođem s uhom oko 3-5cm od monitora i to do onih proreza sa zadnje strane, a sa prednje strane se ništa nečuje.
Bio sam iskljucio 120mm vent, vent od proca, a od grafe vent stavio na 0% u ATT-u = dead silence.
TV: LG 7450
GAMEPAD: XBOX One
Staro 27.02.2009., 15:22   #840
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
pa jeb*mu sve!
ne znam sad kaj da radim..pizdim na to i nemrem imat navecer brightness na 90 ko prek dana jer me oci pocnu bolit,a ovo cujem dosta jako posto mi je komp skroz necujan jer je vent samo na procu i to na 20%..
jel moze bit da je to nes sto garancija uvazava il je to od primjerka do primjerka pa je tak kak je?
