#571 | |
Postovi: 1,313
http://www.gainward.net/main/vgapro.php?id=88 "Gainward strikes again,,,, Gainward’s award Winning Technology and High-Performance / Wide-Bandwidth™ hardware design powered by massive 896MB version of GTX 260 graphic card. GF GTX260, 896MB, Equipped with stunning 576MHz on the core clock and a super fast 999MHz (DDR 1998) MHz on the memory clock, 216 Stream Processors with 1242MHz shader clock leads towards ultimate performance for enthusiasts, in addition the massive 896MB /448bits width memory interface size can undoubtedly allow the graphics processors to achieve higher resolutions without running into memory capacity bottlenecks in games. Gainwards GeForce™ GTX 260 series graphics card is definitely the weapon you must have to lead the world of new generation games." treba otic u ducan i procitat na kutji (pokusava ih dobit na tel pa pitat da vide ako budu imali dobre volje i vremena)
MSI Z77 MPower Intel i5 3570K @4,2GHz, NOCTUA NH-U12S Gigabyte GTX 1070 DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance Carbide Series Air 540, Corsair RM750i CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud DELL U2515H Synology DS413 |
#572 |
Postovi: 351
Uspio sam ih dobiti na telefon i veli tip prvo da ih nemaju iako je zelena točkica na cjeniku (što znači da je raspoloživa), i misli da je to sa 216SP znači da nije siguran. |
#573 |
Postovi: 1,313
![]() a ko prodaje onda noviju sa 216 SP ???
#575 |
Postovi: 2,898
To ti je kad zivis u banana drzavi. Em nema tih kartica jer je ati best buy (yeah, right) em nasi trgovci mogu uvjetovati prodaju starih nenabavljanjem novih... Nisam vidio da recimo u kanadi nemogu kupiti evge ili bfg-e..... bilokoje modele... |
#577 |
Postovi: 1,313
#578 | |
Postovi: 2,898
Uglavnom, danas (gtx 260) i e8x00 serija procesora su par... kvad je neiskoristen i sporiji (bar isti cjenovni rang). |
#579 | |
Postovi: 1,313
na gainward stranicama odes pod "EOL Products (end of line ili ti ne proizvodimo vise) najdes gtx 260 i gle cuda proj se poklapa http://www.gainward.net/main/vgapro.php?id=68 gledajte broj pod stavkom Barcode: 471846200-9368 a jos malo nize u opisu pise "192 Stream Processors" ![]() izgleda da nema 219 SP GTX 260 ispod 2000kn ![]()
#582 |
Postovi: 1,313
kolega Blue_Fatal1ty svaka cast dobro ti nju kuris (milslim na grafu), a i proc se bas ne stedi ![]() koliko si digo voltazu grafi da ide na 760 MHz ???
#583 |
Lokacija: Čazma
Postovi: 1,728
#584 |
Postovi: 1,313
nemojte nikome rec ![]() ali izgleda da u hardveraju imaju GTX260 sa 219 SP za 1900 kn cekam potvrdu od njih, ako se nisu zeznili sa serijskim brojevima to bi trebal bit to ![]()
#586 |
Registered Abuser
Lokacija: Velika Gorica \ ZG
Postovi: 747
ante ovo si vidio AKCIJA VRIJEDI ISKLJUČIVO ZA NARUDŽBE NA SHOPU ZA PLAĆANJE OPĆOM UPLATNICOM odn. VIRMANSKO PLAĆANJE I TRAJE DO 10.01.2009. do 24 h odn. do isteka zaliha! NA NAVEDENU CIJENU NEMA DODATNIH POPUSTA! --------------------------- ništa ja njima ne vjerujem |
#587 | ||
Postovi: 2,898
1 g garancije? Maaaarš. Mjenjanje kulera im je big no, no. kao i oc i sve drugo... Opekao se sa 4870 i nikad vise gainward. zbog 14, bas i ne toliko, ali radi se 24 sp ![]() Citiraj:
Kad sam ja kupovao svi obicni xfx kod nas su bili 192.. a be nisam nigdje mogao naci.... |
#589 |
Lokacija: Small village Near Teheran
Postovi: 258
evo već na hgspot jelovniku nestaju stariji modeli,triba se strpiti do veljače...valjda prema obečanjima iz nvidi-e(samo da nije naše gore list)...285 bi triba oko 2500kn,znači nove 260 max do 2000kn |
#591 |
Postovi: 2,898
Ok, natjerao sam djubre na 710/1512/1200 i to sa 100% venta. i dobijem oko 68 stupnjeva u furmark extreme. Stavim 720, sve 5 dok ne dodje do 70+ i onda blokada. Kartica voli biti hladana, a kuler nemoze vise... E sad, naravno da je 720 u igrama manje od 70 i stabilno, ali opet, nevolim biti naklokan na nesto sto softwer ne moze dokraja iscijediti... Vrijeme je za balkon... |
#592 | |
Lokacija: Čazma
Postovi: 1,728
#593 |
Postovi: 1,450
@Blue_Fatal1ty Koju su ti max. stabilni taktovi na kojima možeš igrat npr. Crysis i Far Cry2..meni su na 751/1513/2702 |
#594 | |
Lokacija: Čazma
Postovi: 1,728
nisam jos probao, ali idem sad pa cu ti javit kroz 1h. Evo trenutno su jako loši klokovi.. 700/1475 2300 Stavio sam EVGA-in bios i pokazo se lošiji od BFG-ovog Zadnje izmijenjeno od: Blue_Fatal1ty. 11.01.2009. u 14:11. |
#596 | ||
Postovi: 2,898
Ma bas je lose.. pogotovo za tu karticuNego, ja mislio da vi stabilne sisteme klokate, a ne suicide shotove.. pih. Citiraj:
#597 |
Lokacija: Čazma
Postovi: 1,728
#598 |
Postovi: 11,642
Zadnje izmijenjeno od: Razer. 11.01.2009. u 20:24. |
#600 |
Postovi: 11,642
Hehe, jest. Napon procesora pokazuje krivo, inače sve to zajedno ide još više (CPU @ 4.2GHz), ovo je samo potvrda kako je čip stabilan na 810MHz ![]() |
