Staro 04.01.2009., 15:42   #451
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,948
Autor DaNiJ3L Pregled postova
jesi sam kriv ili .... ?
zbog cega si bio ugrozen ? (zbog gorespomenutog partitial seeda ?)
Jedan kolega je dobio ban, a ja san ga pozvao
Nemoj me i ti sad zajebat jer još 100 GB minusa ne mogu podnit
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je online   Reply With Quote
Staro 04.01.2009., 19:12   #452
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,127
Autor AMD Pregled postova
Pokoj mu duši, ali vlasnik je doživio infarkt kad je vidio Mudrinićev račun za ADSL.
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 04.01.2009., 23:31   #453
Roberto
Roberto's Avatar
Postovi: 2,649
Fak. Žao mi je da si ti bio usputna žrtva moje gluposti
Eto što se dogodilo, ionako sam to mislio napisati da ukažem na što još treba paziti na BCG-u:
Stavio sam u petak zabunom istovremeno nekoliko torrenta u seed na dva računala. Jučer se vratim s puta i vidim da sam dobio ban.
Odmah sam ih kontaktirao na IRC i ispada da je jedan od admina to protumačio kao varanje i spičio mi ban (ne znam kako je to tako protumačio, ne kužim se previše u to).
Uglavnom, objasnio sam u čemu je bio problem a lik je rekao da će proslijediti info odgovornome tipu i da se probam logat kroz par dana. Uglavnom, sve ovisi o tome da li će se on smilovati ili ne. Nije uvažio niti to što sam mu ponudio da vidi na drugim trackerima (neki od njih vrlo visoko kotiraju, imaju mali broj usera i nemoguće je varati na njima) kakav status imam i da se uvjeri da nisam cheater. Ionako ne znam tko bi to trebao cheatati tamo, zaista na BCG-u nije nikakav problem odseedati torrent.
Ne dira me previše jer ionako nisam previše skidao od tamo, a i sve se manje igram. Žao mi je samo da je Ex popušio download
Inače BCG je u zadnje vrijeme imao dosta problema. Jedan od razloga zaštro sam neke stvari vratio na seed nakon mjesec dana je to što sam vidio u CP-u da mi neki downloadi stoje kao H&R, a siguran sam da sam ih odseedao i više nego što je trebalo...
Roberto je online   Reply With Quote
Staro 04.01.2009., 23:40   #454
Mr.Ex.President
Torrent freek
Postovi: 3,948
Prika, ne kažem da ti ne vjerujem, iako uvijek prije vjerujem nekome adminu koji nema nikakvog razloga da sa vlastitog sajta bez razloga banira usere, nego userima koji se kunu da te nisu zajebali, al opet...uvijek postoji mogućnost pogreške, a ja bez dokaza ne mogu sudit nikom.
Uglavnom on je poprilično siguran da si varao, šta je jasno izvuć iz ovog (stavljam samo dio PMa, da me opet ne kazne)
He is a bloody cheater
Tako da sumnjam da ćeš vidit svoj acc, kao šta sumnjam da ću ja vidit svojih teško zarađenih 100 GB Al nema veze, moglo je i svršit gore...
EDIT:
Ja u zadnje vrijeme nisan imao nikakve probleme, da buden iskren tamo san preko godine i ne sjećam se da sam ikad imao probleme kakve navodiš...
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Zadnje izmijenjeno od: Mr.Ex.President. 05.01.2009. u 00:47.
Staro 05.01.2009., 00:43   #455
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Roberto Pregled postova
Malo je to i meni sumnjivo, više se nemogu ulogirati (moram PMat Djeda ) i par puta nakon odseedanog torrenta mi sprćilo H&R, 1 put sam ima H&R jer sam FM ostavio na seedu, a komp tijekom noć blokao
Staro 05.01.2009., 00:46   #456
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
baja neznam da li si procitao pravila, ali na BCG svaki torrent MORASH dovesti na ratio 1.0. uploadom ili bodovima, ali svaki mora biti 1.0 inace je H'n'R. jesi siguran da si to napravio?
danij3l je offline   Reply With Quote
Staro 05.01.2009., 00:50   #457
Mr.Ex.President
Torrent freek
Postovi: 3,948
0,8
Inače koliko sam imao priliku vidit i doživit masu ekipe zajebe to šta se preseraju pa se logiravaju i doma i u susjeda i na faksu i na poslu i ... i ona iz želje za nabijanjem ratija, nabiješ sam sebi sranje.... jer:
# You are only allowed to use 1 IP and Client per torrent, ie. you can DL/UL 1 torrent from home and another torrent from your seedbox for example.
# Partially leeching is not allowed. Either try to download the torrent fully or don't try at all. You will only disturb the complete system
Uglavnon na tim "sitnicama" se popuši. Varanje i HnR neću niti spominjat, to su već mega prekršaji....
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 05.01.2009., 00:50   #458
Roberto
Roberto's Avatar
Postovi: 2,649
Čuj, svakakvih sam ja već ponašanja od admina doživio tako da me ništa nje čudi. Meni je jučer rekao da sam imao fejkani upload preko 350 kbps. Samo bi idiot napravio tako nešto, budući da u HR home user teško može dobiti takav upload. Da varam sigurno ne bih napravio takvu glupost...
No dobro, i jučer sam rekao njima da se nemam namjeru prepirat jer znam kako to ide s adminima, a i nije mi tolko stalo do trackera. Ja znam da sam čist i to mi je jedino bitno
Nedavno je lik koji me je pozvao na ScT dobio ban (a bio je tamo skoro od početka trackera), i od desetak njegovih inviteova samo smo dvojica nas preživjeli čistku
EDIT:
Ja sam se logirao isključivo od doma, kao što radim i za sve trackere na kojima ima account. A ovo za H&R je 100% istina. Ne znam gdje dolazi do greške, da sam znao da će to biti problem napravio bih pokoji SS... Imao sam tri torrenta prikazanih s manje od 0.5, a riječ je o torrentima koji su svi manji od 500 Mb i za koje 100% znam da sam odseedao preko 1.5...
Staro 05.01.2009., 01:01   #459
Baja 001
Baja 001's Avatar
Postovi: 7,504
DA, ali kako kažem nisam na tom jebenom FMu koji čak niti ne igram (bilo mi za priku).
Staro 05.01.2009., 01:05   #460
Mr.Ex.President
Torrent freek
Postovi: 3,948
Sad ćeš me pozvat na ScT da se iskupiš
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 05.01.2009., 01:08   #461
Roberto
Roberto's Avatar
Postovi: 2,649
Hehe.
Može, čim opet dobim pozivnice. Ostavili su me na trackeru ali su mi pobrisali inviteove
Staro 05.01.2009., 04:29   #462
Tomilajko
BadBoss
Postovi: 59
Hehe.
ne dobijaju se više invite-i, mogu se samo kupiti, ali ovo shto si rekao ako je istina bit će ti onemogućeno za sve vijeke vijekova da kupiš nov invajte
Tomilajko je offline   Reply With Quote
Staro 05.01.2009., 10:55   #463
Roberto
Roberto's Avatar
Postovi: 2,649
Autor Tomilajko Pregled postova
Nisam to znao, ne pratim baš zajednicu i forume na trackerima
a ods admina sam dobio vrlo šturu obavijest
Inače, crna berza je otvorena, ako nekog zanima
Staro 05.01.2009., 11:37   #464
hrc0
hrc0's Avatar
Datum registracije: Aug 2008
Lokacija: Virovitica
Postovi: 92
Nije istinaadmini na ScTu su u zadnje vrijeme darezljivi. bila je neka tema za Božić u kojoj uslikas svoj bor i napises svoje ime na papir i objesis ga na bor i dobijes jedan invite. Vjerovali ili ne ja bio 201 koji je to napravio a 200 ih je dobivalo. i sad imaju Flip book competition. ko napravi crtic vise od 10 str dobiva 100gb uploda, ko napravi 50 str dobiva 200gb. Prva tri naj dobivaju 500gb i jedan invite, prvi dobiva na ovih 500gb jos 750gb i 3 invite.
Eto i taj se tracker mijenja. Admini postaju darezljivi. ak vam je potreban ScT pozurite s nabavkom jer je ostalo cca 150 slobodnih mjesta.
hrc0 je offline   Reply With Quote
Staro 05.01.2009., 11:47   #465
Roberto
Roberto's Avatar
Postovi: 2,649
Autor hrc0 Pregled postova
Vidiš vidiš, dobro je znati da se može i tako dobiti ekstra upload
Inače, nemoj previše raju rajcati na ScT , to je definitvno najteži tracker za održavat ratio od svih na kojima jesam. Gotovo nemoguće bez seedboxa...
Staro 05.01.2009., 12:25   #466
Tomilajko
BadBoss
Postovi: 59
znam da su prošle godine svi PU+ dobijali invite, te fore sa borom eto recimo ja ne pratim lol, al mislim da do sljedećeg Božića ipak neće biti sličnih akcija
ne bi se složio s tim, teže je seedati na FTN po tome, SCT ima na svakom torrentu brdo leechera i u zadnje vrijeme brdo packova s kojima se pokušava kompenzirati jako loše vrijeme 0day uploada i manjak mnogih "izadanja".....a packovi su sci freeleech i uz partial download se može satima i satima uploadirati čak i sam najlošijom kućnom vezom.
za primjer evo ratio jednom momka kojeg sam pozvao a nema box
Uploaded 18.45 GB (478.52 MB / day)
Downloaded 408.26 kB (10.34 kB / day)
Staro 05.01.2009., 12:32   #467
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
FTN? ja sam bio pod dojmom da na FTN ne postoji ratio sustav kao takav. (nema izravnih kazni vezanih uz ratio - osim ako si kreten i skidash kao s publica )
Staro 05.01.2009., 12:36   #468
morph
morph's Avatar
Postovi: 1,530
Ne postoji ratio, ali postoji upload (kao mjerna jedinica).
morph je offline   Reply With Quote
Staro 05.01.2009., 12:59   #469
hrc0
hrc0's Avatar
Postovi: 92
hehe. znam tog momka i u dobrih sam odnosima s njim na hrovom forumu.
ma na ScTu ja lagan seed, ja mislio da je pretesko slusajuci ljude oko sebe koji su tamo ohoho.
Evo moj i sad recite da je tesko( bez boxa i ne namjeravam ga kupiti)
Join date2008-11-03 18:40:20 (8 weeks ago)
Last seen2009-01-05 10:56:04 (1 min ago)
Invited Byxxxxxxx
Uploaded 35.02 GB (572.06 MB / day)
Downloaded 3.11 GB (50.88 MB / day)
Share ratio
11.242
Staro 05.01.2009., 13:44   #470
Tomilajko
BadBoss
Postovi: 59
znači tvrdiš da se na FTN ne mora seedati ?
Staro 05.01.2009., 14:24   #471
Roberto
Roberto's Avatar
Postovi: 2,649
Mislim da na FTN moraš seedatio 24-72h ili nekaj slično. Nisam tamo pa nisam ziher.
Što se tiče ScT-a, meni je tamo (uz BitMeTV koji nema free leechanja) uvjerljivo najteže seedati, čak i s povremenim free leechanjem. Valjda ovisi o tome koji se sadržaj konzumira
Staro 05.01.2009., 14:48   #472
Tomilajko
BadBoss
Postovi: 59
ja sam tamo pa mi nije bilo jasno na što si točno mislio kad si rekao da nema ratio, što je istina ali nije imalo nikakve veze sa mojom tvrdnjom da je tamo teže seedati nego na sct na kojem je u biti vrlo lako seedati preko packova...
iako su ta oba trekera goli kurac, s oproštenjem, u usporedbi sa GFT-om koji ima vald duplo više 0day release-a od ta dva trekera zajedno
Staro 05.01.2009., 16:08   #473
Roberto
Roberto's Avatar
Postovi: 2,649
A jeli, moram se onda tamo ubaciti
Koliko sam čuo, GFT je sličan FTNu što se ratia tiče, ne?
Staro 05.01.2009., 16:25   #474
Mr.Ex.President
Torrent freek
Postovi: 3,948
Nego jako mi je ovako kad se ekipa dođe pohvalit šta ima pa se krenu vadit pusti ScLovi, Sctovi, bitmetvovi, razno razni ***** ****** **** sajtovi
A kad tamo ka glupan na pozivnicama pitaš ima li ko, onda te ne jebe živa sila, još te i popljuju da koji kurac to tražiš, da to nema nitko od Hrvata
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 05.01.2009., 16:33   #475
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
pa koliko sam ja proguglao na taj GFT se moglo upasti (realne shanse) preko irc, ali se vishe ne djele pozivnice. na #gft-support vele da ce biti poslije 20og
Staro 05.01.2009., 16:40   #476
Tomilajko
BadBoss
Postovi: 59
GFT dođeš u njihov irc kanal i pitash za invite, morash u prilog dati nekoliko svoji user details linkova sa drugih trekera gdje te isčekiraju i onda možda puste (iako teško).....nema ratio kao ni na FTN s tim da u 5 dana ti treba biti seed on od 48 sati, tako da nema brige sa eventualni prekid preko noći i slično.tamo njihova skripta automatski izbacuje ama baš sve što scena izbaci dok useri mogu uploadirati pakove kako ih je volja....
ja na top trekere pozivam isključivo provjerene ljude koje na ovaj ili onaj način znam i ljude koji bi htjeli pomoći trekeru na neke druge načine kao što je dizajn u jednom slučaju i support na forumima u većini drugih slučajeva, trejdere odmah križam u startu jer sam s njima imao previše problema u prošlosti, isto kao i kolektore koji upadnu u "težak" treker pa kontaju da im nije baš nešto i ne korsite ga il skuze da je sličan nekom low level trekeru al je bilo samo teško upast pa na kraju trejda za nešta drugo i opet mene osramoti....
ja recimo nisam tražio rabbitov invite već su mi ga ponudili i ja sam prihvatio, na isti način uskoro upadam u wheel čim otvore mogućnost zahtjeva za inviteom.
p.s. za SCT sam podijelio 6 invite do sad i 3 su banirana, dva na moj zahtjev jer sam ih sam uhvatio da skidaju pakove i uploadiraju na druga mjesta...nevjerojatno kakvog smeća ima među torentašima
btw na rabbitu ima solidno Hrvata i srba.,međuostalim fastest uploader je Hrvat, a na wheelu je srbin high ranked stuff a ima nekoliko VIP-ova naše gore listova
sa rabbita
ne djele se preko kanala, ali određeni useri (poput mene ) mogu pozivati ljude koje žele
Zadnje izmijenjeno od: Tomilajko. 05.01.2009. u 16:50.
Staro 05.01.2009., 16:41   #477
hrc0
hrc0's Avatar
Postovi: 92
ja sam na GFTu. Dobivas pointe i mjenjas za gige. Vjerojatno je po tome bolji od FTNa. al je problem DL brzina jer nema nesto korisnika pa je malo seedera.
vazno da nema ratia.
Staro 05.01.2009., 16:45   #478
morph
morph's Avatar
Postovi: 1,530
Biti na nekom siteu i imati pozivnicu nije ista stvar.
Hrvata ima na svim trackerima, a zasto se vise ne daju pozivnice je druga stvar.
Staro 05.01.2009., 16:50   #479
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
pucat cu si kroz nogu
pa hebate kak sam mogao propustiti to s irc-om (vishe me grize sto nisam imao pokushaj :P )
jel netko slucajno spushio bonus na RevTT? ajde pls nek prizna pa da se smijemo
Staro 05.01.2009., 17:05   #480
Mr.Ex.President
Torrent freek
Postovi: 3,948
Autor morph Pregled postova
Na to sam i mislija, kriva konstrukcija rečenice
Kako sam i napisa ovdje prekjučer, spojia se sinoć i dobija, očekivano jel
A ima ljudi koji su stavrno visili svih 5 dana, a onda sinoć ugasili i popušili
@Tomilajko
Ja se ispričavam ako si se osjetio osobno prozvan, možda je moj post došau u nezgodnom trenutku pa je ispalo ka da tebe prozivam, što mi nije namjera, govorin općenito jer sam u torrent svijetu neke 2 godine pa sam se nagleda ia nasluša svega.
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
