Administrator
Lokacija: Sesvete
Postovi: 15,963
BS player 1.0 809
Klikni!!! Nažalost mora se unijeti mail pa ti oni šalju link za download... Version 1.00 RC1 Build 809 released (16 Jun 2004) - Fixed problem with Matroska files with only audio streams - Sometimes audio stream names with Ogg files was corrupted, fixed - Selected audio output device will now be remembered when switching audio streams - Sometimes skin would revert back to base skin, should be fixed now - Fixed problem with freezing when seeking - Movie length was displayed as 0 after stop, fixed - Last subtitle line was still displayed after switching subtitles off, fixed - AC3 filter will be visible now in filter list - If video window was left on secondary monitor and in full screen mode, position wasn't remembered, fixed - chapters from ini files should now be read like in 0.8xx versions - ini shutdown option wasn't working, fixed - fixed bug with resolution switching in full screen mode - fixed freezing problem with some skins under Windows 98 * filters defined in bspfilters.dat will now be loaded even if other libraries are required (for ex. xvid.ax require xvidcore.dll), just put them all in .\filters directory + added option to open locked (in use) files + subtitle position will now also work when 'Draw subtitles to overlay surface option is checked' + Subtitle language for subtitles in Matroska files is now properly displayed |
Junior Member
Datum registracije: May 2003
Postovi: 3,205
Tor , aj ga skini pa stavi na OCE za downlaod:-)) POsto je freeware valjda se smije ![]()
__________________ |
Datum registracije: Aug 2003
Postovi: 3,193
Pa bar je link lako naci ![]() http://majorgeeks.com/download4147.html Poludirektno: http://majorgeeks.com/downloadget.ph...7a76b08b96384f Samo ne znam kaj ce vam to ![]()
#5 | |
Postovi: 3,193
Mv2 Player: http://mv2.czweb.org/ Media Player Classic: http://sourceforge.net/projects/guliverkli/ Zoom Player (Uz freeware ima i shareware verziju): http://www.inmatrix.com/files/zoomplayer_download.shtml Mv2 je glavni za filmove s titlovima, MPC za sve ostalo (titlove kroz ffdshow ili vobsub a ima i on nekakvu jadnu podrsku). Zoom trenutno isprobavam ali ima potencijala (ista opis kao i za MPC). A do ovoga svega dodjes Mozillom ![]()
#6 | |
Lokacija: Zagreb/Dubrava
Postovi: 2,869
![]() Imam ja te sve već na hardu osim browsera Mozillice. Ipak mi je Opera nekako draža. ![]() jedino mi se ovaj Zoom ne sviđa pregledavao sam svaku verziju al nije baš nešto. Ili BS ili Mv2. |
Sannin
Datum registracije: Jun 2003
Postovi: 1,568
YES - BUT / your evaluation is superb - behold the underlying truth |
