			 LateralusX
					Postovi: 1,788
				Nvidia izdaje 180.42 beta drivere - "Big Bang II"
			NVIDIA Releases 180.42 Beta Drivers DOWNLOAD Code:
	Beta driver for GeForce 200-series, 9-series, and 8800-series desktop GPUs. Recommended for the best experience on Far Cry 2: “Since we first began working on Far Cry 2 in early 2005, we have used GeForce GPU’s to develop the game and worked closely with NVIDIA’s excellent engineers. While Far Cry 2 represents an outstanding PC gaming experience for a wide range of systems, GeForce users can expect to enjoy the game quite literally ‘The Way It Was Meant To Be Played’.” - Louis-Pierre Pharand, Ubisoft, Far Cry 2 Producer Enables NVIDIA SLI technology on SLI-certified Intel X58-based motherboards with the following GPUs: GeForce GTX 280, GeForce GTX 260, GeForce 9800 GX2, GeForce 9800 GTX+, and GeForce 9800 GTX.  |
				Lokacija: CROATIA
					Postovi: 31
		 jesu tu oni drveri koje su nazvali big bang?  |
			 Xulos :)
					Postovi: 7,570
		 Ja probao i nemogu ih nasnimiti instalacija stalno stoji na istom mjestu nema onog no responding i tih shema i kad prekinem instalaciju i reset kompa driver i kao instalirani :S
	The Rich pays to win. The Poor spends to lose.  |
		#4 | |
					Postovi: 12,427
 Prožvakano već gro puta Prije instalacije ili uninstaliraj PhysX softver ili napravi extract drivera u folder i pokreni samo instalaciju drivera Ovako on nakon kaj instalira drivere želi instalirat i PhysX koji ti već imaš instaliran pa zato stoji
	''Of all the things I've lost I miss my mind the most'' Mark Twain  |
			 Xulos :)
					Postovi: 7,570
		 Ma znam kako se brise to... Obrissem uvjek prvo nvidia physX pa nvidia drivere pa cleaner pa restart i onda nove ali jednostavno nece. Ove177.89 isprve uvijek.A te nove 180 drivere nemos extractat posto odmah krene zip pa insatalacija ,a ne pita gdje ces extract tako da..
			 Xulos :)
					Postovi: 7,570
		 Moja isprika Wolv.Uspio sam extract.Hvala.Samo jos jedno pitanje,: negdje sam citao da su ovo driveri napravljeni kao ne samo zbog Far Cry 2 ali tak nes pa me zanima koliko je to istina i ako je dali to znaci da ce bit jako velika razlika izmedju 17x i 180 drivera u Cry-u 2 ?
			 Xulos :)
					Postovi: 7,570
		 Pazi ovo.Napravim sve kako treba fino instalacija krene STANE opet na istom mjestu stoji 11 minuta i izbaci kao nije napravljeno nista pokrenite instalaciju kad retsartate komp.Opicim restart driveri normalno snimljeni leti sve ali nema PhsyX-a.Nasnimim ga rucno 8.10 ver i sad kad u CP otvorite phsyX nema vise onih demo cuda i gluposti nego u nvidia CP-u otvori samo jednu postavku i to dali zelite enable ili disable i to je to( Physx nema vise svoj menu poseban).
			 DJ_Darude kicks ass...
				Lokacija: Virovitica
					Postovi: 213
		 da tak imam i ja... čudno je malo sve to...
	..:: Vlak je uvijek brži ::..  |
					Postovi: 12,427
		 Evo ja fino skinuo stare drivere, maknuo stari PhysX, očistio DCPro-om, reboot ponovo očistio Driver cleanerom i instalirao nove derivere bez ikakvog zastajkivanja
				Lokacija: Livingrad
					Postovi: 539
		 nemres vjerovat da smo dosli do toga da jedna igra zasluzuje svoje drajvere...nije da slicnog nije bilo i prije...ali bas gustam vidjet taj FC2....i kako ce se druziti sa Mr.Slijem  ![]()
				Lokacija: VG
					Postovi: 1,758
		#14 | |
			 Super Moderators
			Datum registracije: May 2002
					Postovi: 17,485
 Isa ti...đesoblaci na Endiviji? ![]()
		#15 | |
			 LateralusX
					Postovi: 1,788
		#18 |
			 its slightly turbocharged
					Postovi: 5,430
		 Stavio svježe windowse danas i prvi put pokušam instalirati, dođe do pola, i stoji i odjednom kaže da nisu instalirani bla bla Ja restartam, kad ono imam nVidia Control Panel i tamo piše 180.42 Pokrenem ponovo instalaciju i normalno "succesfully" završi ![]()
	blaa  |
		#20 |
					Postovi: 213
		 men je isto tak nešt rekao setup... pa sam opet pokrenio setup i sve cool
		#22 |
				Lokacija: dalmacija
					Postovi: 37
		 napravili su mali update! sad je v180.43  |
		#26 |
					Postovi: 12,427
		 vidim već je teško postalo i c/p u google nayiv bete  ![]() http://www.google.hr/search?hl=hr&q=...aživanje&meta=
		#27 |
					Postovi: 213
		#30 |
					Postovi: 353
		 Stavim ove najnovije 180.43 i kod inst. sve prođe ok, ali u win xp reza 800x600 i ne mogu je mijenjati kao ni boje koje su na 4bit. Kak to riješiti  |
