Staro 19.07.2008., 22:53   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
PCI Express 3.0 Brings Triple Slot, 300W, 1.5kg Cards in 2010
Ovo su izgleda konačne specifikacije PCI Express 3.0 standarda-najblaže rečeno nije za povjerovat
PCI-SIG (Special Interest Group) is currently in the process of finalizing the PCI Express 3.0 spec for graphics. One of the main improvements this spec brings to the table over 2.0 is twice the interconnect bandwidth. The 3.0 spec is rated at 8 GT/s (Giga transfers per second) compared to effective 4 GT/s currently available. The standard promises to remove the 20% overhead traditionally associated with previous releases. The 3.0 standard is backward compatible with older standards, just as 2.0 was with 1.1.
Aside from the improvements, the electromechanical specifications are already being drafted for triple slot, 300W, 1.5 kg cards. If you are a PCI-SIG member, you can get these specs from here http://www.pcisig.com/specifications...ower_graphics/
PCI-SIG expects the 3.0 spec to be finalized in mid 2009 with certified products showing up in 2010.
http://gpucafe.com/?p=31
Staro 19.07.2008., 23:04   #2
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,834
Ovi stvarno nisu normalni, za par godina budemo grafe u tačkama vozili doma iz dućana
Sva sreća da su omogućili veću potrošnju grafa, kako će inače prodavati kilovatna napajanja?
potemkin.hr je offline   Reply With Quote
Staro 19.07.2008., 23:24   #3
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor potemkin.hr Pregled postova
Mislim da se vraćamo u 60te / 70te
U ove 2 sobe mi je komp, tu je WC, ovde spavam ....
Staro 19.07.2008., 23:42   #4
generic
generic's Avatar
Postovi: 1,075
Kako je krenulo s gorivom i kompovima, prodavat ćemo aute i preuređivat garaže. Trebat će negdje pored kompa i generator smjestit
generic je online   Reply With Quote
Staro 20.07.2008., 14:34   #5
sipe
sipe's Avatar
Postovi: 993
Ovdje spavam, ovo je soba di se nalazi napajanje kompjutera, u ove tri sobe je kompjuter, u trećoj sobi je grafa.
Umjesto da čipovi i ostala "nano" tehnologija smanjuje, tačke će zabilježiti ogroman porast.
sipe je offline   Reply With Quote
Staro 20.07.2008., 14:41   #6
subtex
subtex's Avatar
Postovi: 329
Napokon, već mi je odsta ovih feminizirano minijaturnih kompova, očemo muscle
Abit AB9 Pro \\ INTEL E6300 1.86Ghz & CoolerMaster Gemini II + 2X Xsilence RedWing 120mm \\ G.E.I.L PC26400CL5 2GB \\ Sapphire 3870 TOXIC 512mb
Seagate Barracuda 320GB 16mb SATA2 + 2x WD 500Gb, 16mb,SATA2 \\ DVD-RW SAMSUNG SH-W163A SATA & LITEON SHM-165S6S SATA
LCD Asus PW201 20,1" \\ Antec P160 Aluminium \\ Enermax Liberty 500W \\ MX518 + func 1030\\ Potenciometar ZALMAN ZM-MFC1 plus, sreberni 5.25"
subtex je offline   Reply With Quote
Staro 20.07.2008., 15:04   #7
mislav_os
freak
Postovi: 2,688
LOOOOOL....OMG!
ma to je previseee
Staro 20.07.2008., 15:17   #8
domis
Lokacija: Hrvatistan
Postovi: 4,164
Zadnje izmijenjeno od: tor. 20.07.2008. u 17:21.
Staro 20.07.2008., 15:32   #9
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
@beast- nema sory, popravi sad to...lol
Meni je vec sad ulegao laminat u kutu(...jos da sam ga malo bolje slozio), a ove budale spominju 1.5kg?!
al kvadovi, tripl slijovi, i 1000w napajanja...a sad budale i ovo izmisle još, nekidan sam imo mx440 od 16g, a jos malo planiraju cudovista od jeden i pol kile...
E ak to nebude moglo i letit, i pospremat krevet neka se paze...
Staro 20.07.2008., 15:37   #10
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
a koliko su teški današnji highend aftermarket cooleri?
ovo jest pretjerivanje, al stalna samo mijena jest
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 20.07.2008., 15:38   #11
sipe
sipe's Avatar
Postovi: 993
Hmm crosfirex 4X1.5=6 kg
Hladnjak na procu je barem kila 7
matična hdd psu i ostala sranja bokte bagerom će nam dostavljat kompjuter
Staro 20.07.2008., 15:45   #12
domis
Postovi: 4,164
Zadnje izmijenjeno od: tor. 20.07.2008. u 17:22.
Staro 20.07.2008., 15:55   #13
Razer
Razer's Avatar
Postovi: 11,642
Smiri se i duboko udahni. Za ostatak će se pobrinuti čika Buljo. Psovanje Isusa i ostalih svetaca zbilja nije potrebno koliko god da te ovo frustrira. Zbilja svašta.
Staro 20.07.2008., 16:13   #14
Rain Man
Lokacija: x
Postovi: 1,447
To su specifikacije za max sto ce se spajat ili moci spojit na to. Vjerujem da osim onih ekstremnih kartica, triple-sli i slicno, nece biti previse korisnika s takvim potrosacima. Ali kako je netko reko za napajenje, od viska glava ne boli. PCI-SIG su se osigurali s dovoljnim bandwidthom pa sad spajaj gore sta imas.
Rain Man je offline   Reply With Quote
Staro 20.07.2008., 17:03   #15
Postovi: 7,568
Autor d'beast Pregled postova
btw. kog kurca misle ovi ugurati u 3 slota kaj bu tezilo 1.5kg???
Isti onaj qrac koji su natrpali u GX2 i X2, ali koja stotina milijuna tranzistora i koji 8-pinski konektor više. Ne znam čemu čuđenje, niko te (osim marketinga) ne tjera da kupuješ brutalu od hardvera.
S druge strane Amerikanci, vikend i samoprozvani gameri/clockeri s posterima Fatal1tya diljem sobe, jedva čekaju PCI-E 3.0 i živo ih zaboli kolko kaj troši i košta.
Staro 20.07.2008., 17:23   #16
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Da se nauči ponašanju i komunikaciji na internetu. To što ti lik i djelo stoje skriveni iza monitora ne daju ti za pravo da pišeš takve prostote po forumu!
