Super Moderators
Datum registracije: May 2002
Postovi: 17,485
PCI Express 3.0 Brings Triple Slot, 300W, 1.5kg Cards in 2010
Ovo su izgleda konačne specifikacije PCI Express 3.0 standarda-najblaže rečeno nije za povjerovat ![]() PCI-SIG (Special Interest Group) is currently in the process of finalizing the PCI Express 3.0 spec for graphics. One of the main improvements this spec brings to the table over 2.0 is twice the interconnect bandwidth. The 3.0 spec is rated at 8 GT/s (Giga transfers per second) compared to effective 4 GT/s currently available. The standard promises to remove the 20% overhead traditionally associated with previous releases. The 3.0 standard is backward compatible with older standards, just as 2.0 was with 1.1. Aside from the improvements, the electromechanical specifications are already being drafted for triple slot, 300W, 1.5 kg cards. If you are a PCI-SIG member, you can get these specs from here http://www.pcisig.com/specifications...ower_graphics/ PCI-SIG expects the 3.0 spec to be finalized in mid 2009 with certified products showing up in 2010. http://gpucafe.com/?p=31
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Ovi stvarno nisu normalni, za par godina budemo grafe u tačkama vozili doma iz dućana ![]() Sva sreća da su omogućili veću potrošnju grafa, kako će inače prodavati kilovatna napajanja? ![]() |
Postovi: 7,504
Postovi: 993
Ovdje spavam, ovo je soba di se nalazi napajanje kompjutera, u ove tri sobe je kompjuter, u trećoj sobi je grafa. Umjesto da čipovi i ostala "nano" tehnologija smanjuje, tačke će zabilježiti ogroman porast. |
Postovi: 329
Napokon, već mi je odsta ovih feminizirano minijaturnih kompova, očemo muscle ![]()
Abit AB9 Pro \\ INTEL E6300 1.86Ghz & CoolerMaster Gemini II + 2X Xsilence RedWing 120mm \\ G.E.I.L PC26400CL5 2GB \\ Sapphire 3870 TOXIC 512mb Seagate Barracuda 320GB 16mb SATA2 + 2x WD 500Gb, 16mb,SATA2 \\ DVD-RW SAMSUNG SH-W163A SATA & LITEON SHM-165S6S SATA LCD Asus PW201 20,1" \\ Antec P160 Aluminium \\ Enermax Liberty 500W \\ MX518 + func 1030\\ Potenciometar ZALMAN ZM-MFC1 plus, sreberni 5.25" |
muimerP
Lokacija: VG
Postovi: 3,334
@beast- nema sory, popravi sad to...lol Meni je vec sad ulegao laminat u kutu(...jos da sam ga malo bolje slozio), a ove budale spominju 1.5kg?! al kvadovi, tripl slijovi, i 1000w napajanja...a sad budale i ovo izmisle još, nekidan sam imo mx440 od 16g, a jos malo planiraju cudovista od jeden i pol kile... E ak to nebude moglo i letit, i pospremat krevet neka se paze...
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,472
a koliko su teški današnji highend aftermarket cooleri? ![]() ovo jest pretjerivanje, al stalna samo mijena jest ![]() |
Postovi: 993
Hmm crosfirex 4X1.5=6 kg Hladnjak na procu je barem kila 7 matična hdd psu i ostala sranja bokte bagerom će nam dostavljat kompjuter |
Postovi: 11,642
Smiri se i duboko udahni. Za ostatak će se pobrinuti čika Buljo. Psovanje Isusa i ostalih svetaca zbilja nije potrebno koliko god da te ovo frustrira. Zbilja svašta. |
Lokacija: x
Postovi: 1,447
To su specifikacije za max sto ce se spajat ili moci spojit na to. Vjerujem da osim onih ekstremnih kartica, triple-sli i slicno, nece biti previse korisnika s takvim potrosacima. Ali kako je netko reko za napajenje, od viska glava ne boli. PCI-SIG su se osigurali s dovoljnim bandwidthom pa sad spajaj gore sta imas. |
Postovi: 7,568
Isti onaj qrac koji su natrpali u GX2 i X2, ali koja stotina milijuna tranzistora i koji 8-pinski konektor više. Ne znam čemu čuđenje, niko te (osim marketinga ) ne tjera da kupuješ brutalu od hardvera. S druge strane Amerikanci, vikend i samoprozvani gameri/clockeri s posterima Fatal1tya diljem sobe, jedva čekaju PCI-E 3.0 i živo ih zaboli kolko kaj troši i košta. ![]() |
#16 |
Administrator
Lokacija: Sesvete
Postovi: 15,964
