#32 |
Lokacija: Gospic
Postovi: 305
#35 | |
Postovi: 652
# xAx-xxxx : Samsung panel. # xLx-xxxx : AU Optronics panel. # xDx-xxxx : CMO panel. # xIx-xxxx : CPT panel. Inace,kupit cu vjerovatno taj monitor u Linksu pa me zanima dali mogu nekako drugačije pogledat koji je panel na njemu osim da mi ga ovako trgovac pali. |
#38 | |
Lokacija: Zagreb, Maksimir
Postovi: 437
Može li netko odgovoriti na ovo? http://www.hardforum.com/showpost.ph...&postcount=245 Da citiram post: Citiraj:
Zadnje izmijenjeno od: Jelc. 19.07.2008. u 22:44. |
#39 |
Postovi: 604
The ultimate argument by Samsung (and they are right!)The last subject brought up in our (long) discussion was : Samsung is wondering if we aren’t a little too curious and are overly exaggerating a problem that has been pointed out by none other than us. They clearly indicated that besides our articles and others that base their information on us without themselves testing the screens with the panels in question, no one has complained about their monitors. According to them, consumers have started returning screens to their warranty services under the sole pretext that we have said CMO panels were inferior to Samsung panel versions. This has been done without any verification by the client. Of course, we are in agreement. Also, what can we say when they tell us that in the case of the 2232BW, there was not a single telephone call from a client or store to their warranty services or offices to complain about the problems we revealed on this model? Here again, they are correct. Perhaps we should seriously ask ourselves: are we not just going a little too far and maybe our expectations do not correspond to the more normal standards of our readers? |
#40 |
Postovi: 437
Touché... Idem po sammyja... |
#42 |
Postovi: 437
Ma budem došao u dućan sa USB keyem sa monitor testom. Ak ne daju, idemo dalje. Našao sam odličnog phillipsa, samo što dođe 2200 kn i ima zvučnike. |
#44 |
Postovi: 437
http://www.digitalversus.com/duels.p...4&p2=2683&ph=9 Odluka izgleda ipak pada na Philips 220CW8FB ![]() Usporedio sa svim monitorima koji su dobili čak i po 5 zvjezdica... Kapa dolje. Zadnje izmijenjeno od: Punio4. 20.07.2008. u 01:48. |
#45 | |
Poboljsana verzija
Postovi: 482
IMHO bolji od tog philipsa. |
#46 |
Postovi: 437
http://www.digitalversus.com/duels.p...7&p2=2107&ph=1 Felšaju mu sive ![]() Philips: ![]() LG: ![]() A i ljudi se žale da radi lošijeg overdrivea ima kontra-efekt, tj negativ ghosting jako izražen. Zadnje izmijenjeno od: Punio4. 20.07.2008. u 12:51. |
#47 |
Lokacija: Zaprešić
Postovi: 101
Kao prvo mala isprika što ću vjerovatno postaviti već postavljeno pitanje ali moram biti siguran. Sve sam pročitao vezano za panele još samo jedna nedoumica...danas sam bio u technomaxu i prodavač mi je testirao panel te je imao oznaku A. E sada da li je to samsungov panel ili treba pisati S? Ako su oba samsungova da li ima razlike među njima? Kupujem monitor za par dana pa mi je to jako bitno. Hvala unaprijed svima ![]() |
#50 |
Does youer dewg byte?
Postovi: 1,941
Još jedan picajzla. Ak ti je JAKO bitno da uzmeš kvalitetniji panel, ne gledaj onda uopće Samsung 2232Bw . U suprotnom će te bilo koji zadovoljiti.
" Have you tried turning it off and on again ? Are you sure it is plugged in ? " ![]() |
