Staro 07.06.2008., 00:11   #331
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
Intel Core 2 Duo E8400/E8500 and Xeon E3110 Moving to E-0 Stepping Next Month
After moving all 45nm Xeon DP quad core processors from the C-O to the E-0 stepping, Intel announced today that three more 45nm processors will also be upgraded to E-0. The two desktop Core 2 Duo E8400 and E8500 plus the server Xeon E3110 CPUs will all be updated to the E-0 stepping next month. Changes that will come with the E-0 stepping include:
  • - CPUID will change from 0x10676 to 0x1067A
    - Power Status Indicator (PSI) is supported
    - PECI implementation change
    - New instructions added - XSAVE/XRSTOR
    - New ISA extension for save/restoring context of x87, SSE, and future processor state
    - New feature added - ACNT2
    - Improved mechanism for determining processor utilization. To be used for more efficient P-state determination.
    - Package change to Halide free package
The E-0 processors will not require any BIOS updates. They'll be easily recognisable by the new sSpec numbers: SLB9J for E8400, SLB9K for E8500 and SLB9C for E3110.
http://www.techpowerup.com/61345/Int...ext_Month.html
dobro pa nisam danas dobio e8400
timmy je offline   Reply With Quote
Staro 08.06.2008., 02:23   #332
Space
ASUS
Space's Avatar
Lokacija: Beograd
Postovi: 263
Evo materijala za razmišljanje E8500 4010 MHz na samo 1.18 V nešto više od 1h prime95
http://www.sx-team.com/forum/index.p...9&st=0&start=0
Zadnje izmijenjeno od: Space. 08.06.2008. u 14:50.
Space je offline   Reply With Quote
Staro 08.06.2008., 12:23   #333
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Autor Spacemaster Pregled postova
Evo materijala za razmišljanje 4010 MHz na samo 1.18 V nešto više od 1h prime95
space... lik sa Q814 batchem drzi wolfija na 4.4GHz sa 1.29V dok mu za 4.2GHz treba 1.16V tak da taj primjerak jos nije za razmisljanje
timmy75, novi batchevi sa manjim VIDom su puno bolji primjerci a prvenstveno mislim na Q813 i Q814
Staro 08.06.2008., 14:51   #334
Space
ASUS
Space's Avatar
Lokacija: Beograd
Postovi: 263
Autor Bullet1 Pregled postova
Može link ka tome ?
Isto tako samo da mi stigne nova količina arma, obećavam ti 1.0 V na SS i naravno na 4010 MHz gde će core temp prijavljivati oko 40C
Pazi ako bolje pogledaš link videćeš da je i ovaj primerak Q814 i da sve je rađeno na tem skoro pa 30C sobnoj naravno i to na zraku, stoga da je voda, hmmm 1.16 je smešno
Staro 08.06.2008., 14:56   #335
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Evo ga za 1.16V LINK
A evo i za 4.6GHz @ 1.35V sub 10sec 1M LINK
Staro 08.06.2008., 14:58   #336
Razer
Razer's Avatar
Postovi: 11,642
Držimo te za riječ, javi se
Staro 08.06.2008., 15:29   #337
Space
ASUS
Space's Avatar
Lokacija: Beograd
Postovi: 263
Hitar zaključak ovo je na vodi kao što rekoh
Staro 08.06.2008., 15:30   #338
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Da pogledas sta pise vidio bi i "Still using air (120 ultra extreme)... "
Staro 08.06.2008., 15:50   #339
Space
ASUS
Space's Avatar
Lokacija: Beograd
Postovi: 263
Prvi link E8400 4400(Q814A015 Wafer **91)@1.296 Vcore sorry wafer pročitah water, no nije problem naterati ovo na 1.16V ipak pričamo o Commandu, i naravno nisu poznate ambijentalne tem, Coomando je keva za FSB, no imam sad bro ploča, pa ću videti gde su granice.
Staro 08.06.2008., 15:50   #340
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Wafer inace znaci voda?
Stavi TRUE gore i vrti sve na komandu (iako je ovo na P5K Pro) pa javi jel ide na 4.2GHz pri toj voltazi. Temperature su u granicama normale tj. 55°C i 45°C u loadu tak da ambijent temperatura sigurno nije manja od 20°C a i valjda znas da u Grckoj sada nisu niske temperature.
Zadnje izmijenjeno od: Bullet1. 08.06.2008. u 16:01.
Staro 08.06.2008., 16:00   #341
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
@space
na p5k pro, nije na commandu, osim ak ne mislis na svog commanda
Staro 08.06.2008., 16:07   #342
Space
ASUS
Space's Avatar
Lokacija: Beograd
Postovi: 263
Autor timmy75 Pregled postova
@space
Kao što rekoh, konačan klok uvek bolje funkcioniše na novom čipsetu, Commando (moj) je bolja opcija za MAX FSB, imam jednu P45 zanimljivu ploču 24/7 558MHz, 0 vdrop, Hladna ko zmija (sa njom se ide na jedno svetsko takmičenje :d), stoga na njoj ću probati, ali bilo kako bilo ovo je najbolji primerak na našim prostorima koji sam imao priliku da vidim, probam, i još testiranje nije gotovo , tj. kako kod nas, tako i na pce nisam video ništa slično, tj. bolje
P:S Vas dvoica pametnica, pogledajte šta sam napisao
Bullet esi čuo za klima uređaje
Staro 08.06.2008., 16:23   #343
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Gle Space, to sto mi procitamo i odgovorimo dok ti edititiras svoj boldani post pa kasnije izgleda kao da si to u komadu napisao nije moj problem. Prvo je pisalo samo ono sto je Razer kvotao.
Evo samo za tebe cu popricat sa tim likom i pitat ga vise o procesoru i hladenju. Da je vani temp 25°C klima opet jedva scera temp na 18°C. Sad ces rec da, ako ima jacu moze ispod 16°C? Big fucking LOL. A u Grckoj sigurno ne nose duge rukave odavno. A sad ko je tu cuo za klima hladenje je upitno. Ti si rekao da si testirao na 30°C ambient temperaturi dok sam jos neki dan citao kako je vrijeme u Srbiji zahladilo i da je pogodno za klokanje.
LP!
Staro 08.06.2008., 17:43   #344
Space
ASUS
Space's Avatar
Lokacija: Beograd
Postovi: 263
LP!
Čuj stari nema potrebe za negodovanjem, nigde ne sporim da možda ima bolji primerak u svetu, ako malo bolje pročitaš ja sam se složio da je to jedan od naj primeraka u svetu, sa drugre strane rekao sam da je u sobi možda približno 30 znači moglo je biti i 27-28C, ali sa ovim postom sam i završio diskusiju, i da u Srbiji je zahladnelo i ok je za OC (ja živim sa nekim nisam klinac da otvaram prozore kad overklokujem), ali ovo je okačeno 4.5. stoga pozz i svako dobro
Zadnje izmijenjeno od: Space. 08.06.2008. u 18:08.
Staro 08.06.2008., 17:59   #345
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
ljudi počinju gledat vremensku prognozu za klokanje wolfova....strasno
Staro 08.06.2008., 18:07   #346
Space
ASUS
Space's Avatar
Lokacija: Beograd
Postovi: 263
Nasmejao si me do suza, ali da ne bi išli dalje u o.t, definitivno si u pravu, suludo
Staro 08.06.2008., 18:54   #347
Juggernaut
Lokacija: Varaždin, Bronx
Postovi: 1,097
Ot nije samo za klokanje wolfija, ima tu i gro drugih stvari koje se daju klokat ( ima jedan tu kod nas koji postaje ovisan o vremenskoj prognozi :P )
Juggernaut je offline   Reply With Quote
Staro 08.06.2008., 23:57   #348
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Eto Space samo za tebe odgovor Degalidisa...
Hello my friend...
Sorry for my late Reply but Erthquake hit our region here in Greece (6.5R) and we was out of our home...
I never TRY 4GHZ Under 1.1 Vcore but if you want More Information about my OC and alot of screenshots just follow this LINK http://www.thelab.gr/showthread.php?t=50334&page=4
Just scroll on Pages and you will find alot of info.
Currently ORTHOing at 4200 Mhz at 1.1488 vcore & better Ram Timmings to see how stable it is....
If pass 2 Hours (1 hour remains) i will post again on the same thread..
Room temperature was 28C and today is the same...
My highest probably stable(45mins ORTHOS) OC on air for now is 4600 MHz @ 1.338 Vcore but temps was over 72C and i stop the stability tests to avoid any cpu degredation.....
Dakle, ista sobna temperatura kao kod tebe. Budem jos pricao s njim.
Nitko tebi nije rekao da imas los procesor, naprotiv - Q814 je strava proc - samo sam htio rec kako nemas proc za divit se jer ima bolji. Cekam da vidim kakvi su ostali Q814 batcha a i nestrpljivo cu cekat tvojih 4010MHZ @ 1.0V u cemu ti zelim puno srece kao i u sljedecoj nabavci "najboljih procesora na svetu". Pozdrav
Staro 15.06.2008., 01:51   #349
Boogie
Lokacija: Sarajevo-Mostar-Bugojno
Postovi: 227
Na koliko E7200 moze ici sa ovom konfom, bez mijenjanja voltaze. Posto nisam nesto iskusan u oc-u, nebih zelio da spucam neku struju da ga sprzim.
Boogie je offline   Reply With Quote
Staro 15.06.2008., 02:07   #350
etna22
Postovi: 61
Autor Boogie Pregled postova
Moj na stock voltaži ide na 3.2GHz stabilno, na nekih 1.28V ide na 3.5GHz, ali mislim da imam primjerak procesora
etna22 je offline   Reply With Quote
Staro 15.06.2008., 13:16   #351
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Autor etna22 Pregled postova
Prije mislim da imas cooler.
Nadi mu max FSB i zatim max takt, naravno sa znatno povecanom voltazom pa onda reci da je banana. Ne mozes njih usporedivat sa E8x00 serijom
Staro 15.06.2008., 13:19   #352
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
3.5GHz na 1.28V je super, ne vidim u cemu je problem.
Staro 15.06.2008., 13:52   #353
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Ja sam svog uspjeo diči na 4,3GHz sa 1.5V hlađen Sonic tower-om ali mi to je nepotrebno(možda bi još malo išao) ali nisam dalje ni pokušavao do sada je radio na 3.8GHzna 1.38V(tem 38-40c)po Real temp-u ali zbog prijašnjih vručina sam spustio na 3.4GHz i sve super šljaka.Sve je pod moj komp a max.FSB 496. i toliko ide MBO te sam o istoj to pronašao na netu.
Uglavnom sam zadovoljan s obzirom na uloženo-dobiveno.
Citiram:Razer
Ploča ide više,isprobano
Neznam da li MBO ide više na 500FSB-a mi se nije htjelo diči u winse, možda sam trebao još napon podiči ali dalje nisam probao i nemam baš živaca max. se posvetiti OC-u uglavnom sam zadovoljan.I nisam našao na netu glede MBO da je neko dobio više od gore navedenog FSB-a. glede moje MBO.
Zadnje izmijenjeno od: ECHO. 15.06.2008. u 14:40.
Staro 15.06.2008., 13:56   #354
Razer
Razer's Avatar
Postovi: 11,642
Ploča ide više, isprobano.
EDIT: @tdominov - daj ploči više soka, neće joj ništa biti. Moja je išla na 520, a sa boljim procem idu i više
Zadnje izmijenjeno od: Razer. 15.06.2008. u 14:54.
Staro 15.06.2008., 13:57   #355
etna22
Postovi: 61
Nećemo o mome cooleru sada
Ma za 4GHz mu treba skoro 1.5V pa zato govorim da je u . Zar to nije malo previše?
Staro 15.06.2008., 14:51   #356
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Pa i ne bas previse lose. Proc svakako nije u banani, potrazi mu max FSB i uvjeri me da jest.
Staro 15.06.2008., 15:01   #357
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
To je. 3.5GHz i 1.28V dobro zvuci, ali 4GHz i 1.5V ne. Jednostavno postoji takt preko kojeg proc trazi jako puno napona, primjerice kod E2xx0 procesora je to nekih 3,2GHz.
Koliko vidim, taj E7200 potegne negdje do 3.8GHz na 1.4V, a ne znam jesi li isprobao takvo nesto.
Staro 03.07.2008., 07:32   #358
mskvorc1
mskvorc1's Avatar
Postovi: 288
Evo i mene na Intelu nakon dugih 7-8 godina. Pročitao sam sticky, ali mi ipak neke stvarčice nisu jasne. Prvo, uzeo sam E8400 i EVGA nVidia nForce 750i SLI FTW matičnu ploču. Procesor mi hladi ZEROtherm Nirvana NV120 Premium. Na default postavkama proca max temperature pod full loadom idu do 49-50 C. U sobi mi je vruće dosta po ljeti, neki 26-27 C, možda i više. Prvo me zanima jesu li to OK temperature za moj proc? Mjerio sam Realtempom 2.60, EVEREST pokazuje točno 10 C više od tih vrijednost. U Windowsima mi je napon proca 1.200V, a pod full loadom 1.192V-1.184V.
Ako su temp i to sve OK, ja bi sa oveclockom krenio. Ono što me zanima, pretpostavljam da prvo krećem sa dizanjem brzine FSB-a, zar ne? Da li da memoriju ostavljam na Linked ili Unlinked (koje je bolje)? Memorija je OCT Platinum XTC nVidia SLI Ready, maks na 1066 MHz na 5-5-5-15 @ 2.1V. Drugo što ne znam kada treba početi dizati napon SPP-a i još par tih što ih u BIOS-u ima? Za proc znam da treba dok više ne bude mogao izvrtiti testove.
Nov sam sa Intel, pa vas za pomoć molim. Sticky sam pročitao. Najviše što me zanima jesu temperature na Full load, na default postavkama, s tim da se Nirvana vrti na maksimalnom broju okretaja... Znači kao što je navedeno 49-50 na 1.192V-1.184V na default postavkama proca...
mskvorc1 je offline   Reply With Quote
Staro 03.07.2008., 09:07   #359
žile
žile's Avatar
Postovi: 3,074
To je tipično da ti everest i core temp pokazuju +10° od realtempa,i meni se to događa na dvije ploče već.
Temp su ok,dok su općenito ispod 70° ok je.
Diži fsb,dok ne prelaziš 1066 ostavi na linked.Nikad se ne overklokira više stvari istovremeno.Već ionako moraš pazit na dvije,ploča i proc,ne treba ti još mema u igri.
Zadnje izmijenjeno od: žile. 03.07.2008. u 10:54.
žile je offline   Reply With Quote
Staro 03.07.2008., 09:17   #360
mskvorc1
mskvorc1's Avatar
Postovi: 288
Autor žile Pregled postova
To je tipično da ti everest i core temp pokazuju +10° od realtempa,i meni se to dpgađa na dvije ploče već.
A ono,mogle bi bit manje,ali dok su općenito ispod 70° ok je.
Bio sam maloprije probao OCCT izvrtiti na pola sata - temperature su 46-47 C od obje jezgre. Razlika u temperaturi između jezgri je 1-2 C, tako da pretpostavljam da je cooler dobro sjeo. A kada smanjim broj okretaja na nirvani, temperature su par stupnjeva veće. U Idle su mi 36-37 C. I trenutno imam samo jedan vent koji izbacuje zrak i jedan naprijed koji diskove hladi...
Pasta je Zalman, ona za 50-ak kuna u Linksu, kistićem namazan. Cooler sam stegnuo koliko ide, odnonso dokle mi je odvijač dopuštao.
