Postovi: 298
kako disejblat desni klik na stranici ?
kako napraviti da se ne može selektirat text niti desni klik na stranici .. prvo što mi padne na pamet je javascript .. ali http://www.arhiteh.hr/shop/index.php...oducts_id=3216 ovdje nije java u pitanju .. zna netko ? |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radi uredno na toj stranici ![]()
Postovi: 9,069
Ubacis u head html-a, sa ili bez popup prozora.... Code:
<script language="JavaScript1.1">
<!-- var debug = true; function
right(e) { if (navigator.appName == 'Netscape' && (e.which == 3 || e.which
== 2)) return false; else if (navigator.appName == 'Microsoft Internet Explorer'
&& (event.button == 2 || event.button == 3)) { alert('This Page is fully
protected!'); return false; } return true; } document.onmousedown=right; if (document.layers)
window.captureEvents(Event.MOUSEDOWN); window.onmousedown=right; //--></script>
___________ Just atha x |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
Super Moderators
Postovi: 17,485
To vi koji imate đi-pi-bi imate takvih problema... ![]()
Lokacija: Zagabria
Postovi: 492
A zakaj jednostavno nisi pogledao source stranice? Tamo lijepo sve piše. Code:
<SCRIPT TYPE="text/javascript"> <!-- //Disable right click script //visit http://www.rainbow.arch.scriptmania.com/scripts/ var message="Sorry, right-click has been disabled"; /////////////////////////////////// function clickIE() {if (document.all) {(message);return false;}} function clickNS(e) {if (document.layers||(document.getElementById&&!document.all)) { if (e.which==2||e.which==3) {(message);return false;}}} if (document.layers) {document.captureEvents(Event.MOUSEDOWN);document.onmousedown=clickNS;} else{document.onmouseup=clickNS;document.oncontextmenu=clickIE;} document.oncontextmenu=new Function("return false") // --> </SCRIPT> <SCRIPT TYPE="text/javascript"> <!-- //Disable select-text script (IE4+, NS6+) //visit http://www.rainbow.arch.scriptmania.com/scripts/ /////////////////////////////////// function disableselect(e){ return false } function reEnable(){ return true } //if IE4+ document.onselectstart=new Function ("return false") //if NS6 if (window.sidebar){ document.onmousedown=disableselect document.onclick=reEnable } // --> </SCRIPT> ![]() |
Postovi: 298
2 atha .. thx .. u stvari dokopao sam se coda trebaju 2 scripte .. 1 za text i 1 za d click .. ako kome još treba evo coda Code:
</SCRIPT>
return false
return true
//if IE4+
//if NS6
</SCRIPT>
Zadnje izmijenjeno od: mcclarion. 28.05.2008. u 12:25. Razlog: u isto vrijeme postano kad i Fadolf |
Lokacija: Zagabria
Postovi: 492
He he he... Ipak si napravio ono kaj sam ti savjetovao sekundu prije. Brz si! ![]() |
Postovi: 298
Lokacija: NA
Postovi: 2,620
pa bolje nego da je zasluge pripisao sebi. kad vidim to sranje s disejblanjem desnog klika - pa hebote koji je to kurac - uvijek HTML source mogu vidjet - svi slike,video,flv i sl. su na mom racunalu jer sam otvorio stranicu - to je tu samo da vadi zivce. |
Postovi: 298
pa fakat je debilno .. pogotovo na stranici na kojoj ništa nije njihovo autorsko djelo .. pa ni scripte lol ..neš ti popisa komponenti laptopa .. |
Super Moderators
Postovi: 17,485
Procesor Intel® Core2™ Duo T8100 CPU 2.1 GHz L2 Cache: 3MB, FSB 800 MHz Tehnologija Intel® Core2 Duo Mobile tehnologija Chipset Mobile™ Intel® 965GM Express Chipset Sistemska memorija 2048 MB DDR2 667 MHz max 4GB, dual channel memory Hard disk 160 GB, S ATA HDD 5400 rpm Optički uređaj DVD+/-RW SuperMulti DL Drive Monitor 15,4" WXGA anti-glare LCD Rezolucija 1280x800 Grafika Mobile Intel® Graphics Media Accelerator X3100, Microsoft DirectX 9 capable do 384 MB dijeljene sistemske memorije Audio ADI1981HD High Definition CODEC Audio support w/24-bit DAC Zvučnici Stereo zvučnici Mikrofon Ugrađen Mreža Broadcom NetLink Gigabit Ethernet Controller (10/100/1000 NIC) Bežična mreža Intel 802.11 a/b/g wireless lan Bluetooth 2,0 modul Modem Modem 56k v.92 I/O Portovi 4 x USB 2.0 1 x Audio out 1 x Mic In 1 x Modem RJ-11 1 x LAN RJ-45 1 x S-video/ TV-out (NTSC/PAL) port 1 x IEEE 1394 port 1 x VGA (15-pin mini D-Sub) 1 x Travel batery connector 1 x Docking port connector Ostalo 6-in-1 card reader (SD, MMC, MS, MS Pro, MS Duo, xD-Picture) PCMCIA tip II slot HP Fingerprint Sensor (čitač otiska prsta) TPM 1.2 Embedded Security Chip Smart Card Reader * HP ProtectTools Security Manager Configuration Control Hardware Memory Change Alert Ownership Tag Setup Password Power-On Password TPM Enhanced DriveLock HP Disk Sanitizer HP 3D DriveGuard Kensington Lock Slot Baterija 6-cell (55 WHr) Lithium-Ion battery External 90W HP Smart AC adapter Autonomija Do 5,3 sati autonomije baterije Dimenzije 357 x 265 x 35 mm (ŠxDxV) Težina 2,6 kg Boja crna Operativni sustav Uz doplatu Preporučeni OS Microsoft® Windows® Vista™ Software Drivere i podršku za ovaj model možete skinuti sa ovog mjesta >>> Dodatna oprema HP 3-in-1 NAS Docking Station - Opcija HP Advanced Docking Station - Opcija HP Docking Station - Opcija HP Standard Monitor Stand - Opcija HP Adjustable Notebook Stand - Opcija HP External MultiBay II - Opcija Jamstvo 12 mjeseci u ovlaštenom servisu Lagani c/p, Opera tak jasno a ne đi-pi-bi ![]()
Postovi: 267
Mogu oni braniti to koliko hoće na kojim god stranicama. Ili Opera ili FireFox + NoScript pa ti pokusaj netkome zabraniti nesto na stranici ![]() |
#17 |
Postovi: 310
CTRL+A, te onda CTRL+C, u Word, i onda CTRL+V - i to je to... :P Ili jednostavno, uzmeš source i pejstaš ga u Mozzilin composer i to ti je to... ![]() |
