Staro 26.04.2008., 20:03   #91
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Jup ja sam štopao svoje XPe točno 8min od ubacivanja boot CDa do boota potpuno spremnih XPa sa Acronis imageom...
Have a nice day...
Staro 26.04.2008., 20:20   #92
Odojak
Odojak's Avatar
Postovi: 267
Autor strasilo Pregled postova
Možeš li me uputiti na temu ili dio foruma gdje je to malo detaljnije objašnjeno i sa kojim programima se to radi ... THX
Acronis True Image (nije besplatan) i upute http://www.whatsabyte.com/P1/Acronis_image.htm
DriveImage XML (besplatan) i upute http://www.runtime.org/driveimage-xml.htm i http://www.youtube.com/watch?v=PTEnKA7tOXM i http://frozenpixels.wordpress.com/backups-part-1/
Moj glas ide Acronisu, brz, jednostavan i fleksibilan
Odojak je offline   Reply With Quote
Staro 26.04.2008., 20:49   #93
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
ja sam instalirao pravi (build 5512) i zasad nikakvih problema, dapače, neke stvari su mi se ubrzale (kao recimo start up) ili se to meni samo čini.....štagod, ne mislim ga uninstalirat jer nemam razloga još
Z-man je offline   Reply With Quote
Staro 26.04.2008., 21:23   #94
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
nemojte instaliravat SP3 koji je skinut s nekih drugih stranica..
evo sa jednog foruma...
IMPORTANT - READ THIS FOR YOUR OWN SAFETY
This is for your own good. So many people having been sharing the Windows XP Service Pack 3, but it is not real and there is a high chance that it may contain a keylogger which captures everybutton you've entered. So for your own safety be patient for the next couple days as they have confirmed that is will come out on the 29/04/2008 which is about 5 Days from now. THIS IS FOR YOUR OWN GOOD!!
ja sam osobno našao jedan *.reg key, ubacio u registry, i preko windows updejta skinuo SP3 i instalirao.. i sve radi..
T0mB1ll je offline   Reply With Quote
Staro 26.04.2008., 22:11   #95
strasilo
strasilo's Avatar
Lokacija: pozega
Postovi: 152
THX...
strasilo je offline   Reply With Quote
Staro 27.04.2008., 04:09   #96
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
evo danas presudio visti i isao vratiti dobre stare XP pa rekoh sto ne bih odmah stavio SP3. napravim slipstream instalaciju, sprzim i pokrenem instalaciju. otisao van, reko kad se vratim sve ce ionako biti gotovo. kad sam dosao kuci imao sam sto vidjeti, sve stoji na enter product key screenu.
malo u cudu ukucam ga ponovno i nista, ne prima.
da se razumijemo, kljuc je orginalan windows xp pro, ne neki s neta ili akademski. no - ne radi, nece kurva da ga primi.
pa sad, ili s tim SP3 koji je na netu dostupan nesto opasno ne valja ili cu imati posla za MS hrvatska SZK.
cisto napomena, normalno se instalira na vec instalirane win s tim istim kljucem, isprobano sad u vmware
tako da se ja ne bi zaletao i slipstreamao medije s njim, cekajte onaj "pravi" na MSovoj stranici.
Staro 27.04.2008., 10:10   #97
tOta
Lokacija: ...
Postovi: 685
Da nisi kojim slučajem slipstream radio pod Vistom? Pošto se baš taj problem spominje ovdje.
Autor tOta Pregled postova
Čini se da bez problema ide slipstream SP3 na instalacijski disk na kojem se već nalazi SP2, samo je preporučljivo da se slipstream ne radi pod Vistom.
tOta je offline   Reply With Quote
Staro 27.04.2008., 17:40   #98
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
bome jesam....eto, jedna misterija rjesena
vec sam planirao MSu mater spominjati...iako, nije da nisu zasluzili jer i za taj problem je kriva njihova vista.
Staro 28.04.2008., 15:49   #99
strasilo
strasilo's Avatar
Lokacija: pozega
Postovi: 152
Autor Odojak Pregled postova
I sam znaš da je to dvosjekli mač, imaš na torrentima i izdanja s prepravljenim "sadržajem". Sumanjm da će ti itko uspjeti pomoći jer nitko ne zna koji i odakle si skinuo (nemoj slučajno linkati) tako da probaj s "pravim" ponovo pokrenuti instalaciju ili pokušaj taj isti obrisati. SP3 se nakon instalacije pojavi u Add/Remove programs.
Sretno
evo mene ponovno ...
našao sam SP3 u add/remove i maknuo.... ali problem nije nestao.... možda nije bilo do toga....
Staro 28.04.2008., 16:02   #100
evilstoy
evilstoy's Avatar
Lokacija: Enterprise bridge
Postovi: 285
Jednom kad ga stavis, vise nema povratka )
Inace, za kloniranje preporucujem Clonezilla-u, a SP3 ima za skinut na Majorgeeks - sto bi trebao biti pouzdan izvor.
Ubuntu 8.10
cpu Intel Q6600 @3GHz (333x9) w/Scythe MINE Rev.B - 29C idle
mbo Gigabyte P35-DS3 ram 8GB Kingston DDR2 667MHz
gpu Asus EN9600GT hdd 2xWD3200AAKS - RAID1
case Chieftec BX-03B-B-B psu Fortron BS 400W
evilstoy je offline   Reply With Quote
Staro 28.04.2008., 16:07   #101
Artistar
Vječni Student
Artistar's Avatar
Postovi: 316
Moj glas ide Acronisu, brz, jednostavan fleksibilan
Acronis u zadnje vrijeme radi smeće od softvera, a True Image 11 je perjanica te ponude. Bezobrazluk koji dotična firma prakticira spram vlastitih korisnika je neviđen, jer izdati posljednju nadogradnju gotovo neupotrebljive verzije tamo negdje u 11. mjesecu prošle godine je sve samo ne profesionalno. Za isto vrijeme im je forum zatrpan problemima i molbama korisnika da nešto naprave, dok gospoda, barem kako kažu, rade na novoj verziji bugova - True Image 12.
Svima preporučam da prije korištenja gore navedenog softvera posjete njihov službeni forum pa se uvjere sami šta se događa. Također, ako vam TI trenutno radi dobro, ne znači da neće prvom prilikom nešto zeznuti. Meni je - bezbroj puta.
Koga zanima, dostojna alternativa je ShadowProtect.
Btw, isprika na totalnom OT-u, ali morao sam se nadovezati da se ljudi ne bi čudili kada im u kritičnom trenutku TI javi kako je image corrupted, i sl....
Artistar je offline   Reply With Quote
Staro 28.04.2008., 16:46   #102
Odojak
Odojak's Avatar
Postovi: 267
Kod Acronisa ja ni nisam na posljednjoj verziji jer kod takvih stvari i poslova većinom ostajem ka provjerenim verzijama prije nego poletim na nove. Ovo s image corrupted mi se još nikad nije dogodilo. Na kraju dok pravim image koristim verify i prije nego radim restore odabirem verify.
A za ovaj ShadowProtect cu zaviriti kakav je
Staro 28.04.2008., 17:14   #103
Artistar
Vječni Student
Artistar's Avatar
Postovi: 316
Drž se stare verzije ako ti dobro radi i ako si zadovoljan. Ja sam morao zbog Viste na 11-icu.... Btw, verifikacija često ne pomaže, da stvar bude još žalosnija....
Isplati se probati u svakom slučaju.
Staro 28.04.2008., 17:35   #104
yedwy
yedwy's Avatar
Postovi: 6,956
Ja imam već duuugo 10ku i nemam nikakav razlog (za sad) se s nje micati, radi perfektno pod Vistom (probao na x86 i x64 Visti) i pod XPima (isto probano na x86 i x64) i napravio više puta one "rescue medija" boot CDe (tj image i poslje ga izeditirao i ubacio unutra image sistema tako da imam boot opciju i ne ovisim o stanju OSa) i apsolutno sve je radilo savršeno i niti jednom mi nije zakazao do sada, tako da stvarno nemam primjedbi...
Ja inače prelazim na novije verzije programa uglavnom kad moram ili kad donose stvarno nešto meni zanimljivo i novo, a u biti u ovoj branši softwarea neznam što bi to uopće i moglo biti...
Naime 10ka sve feautre koje treba za svoju namjenu i radi stabilno i pouzdano i to je sve kaj tražim od softa te namjenje, e sad ja radim isključivo full backup image pa neznam kako je kod incremental backupa i ostalih i dal ima s tim problema neko s 10kom ali meni ionako vrijeme pravljenja slike ne igra ulogu pa me niti ne muči ta stavka...
Have a nice day...
Staro 28.04.2008., 18:34   #105
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,955
Ma najbolje imati DOS, i u njemu Ghost . I čak ne treba cd onda DOS never fails
m4dm4n je online   Reply With Quote
Staro 28.04.2008., 20:55   #106
allenn
allenn's Avatar
Datum registracije: Apr 2008
Lokacija: zagreb blizu
Postovi: 1
you are using safe mode bios,please update the system with latest bios from epox web.....ljudi moze li mi neko pomoci ,objasnit o cemu se radi.stalno mi to izbacuje kad ukljucim komp i to odkad instalirao xp sp3.p.s. probao update al i connection failed svaki put....beginner
allenn je offline   Reply With Quote
Staro 28.04.2008., 21:08   #107
Dule
Dule's Avatar
Postovi: 718
dajte sacekajte FINALNU verziju (dakle onu sa download.microsoft.com), a ne se zezat sa ovim ili onim verzijama sa torrenta (pa makar to bile i RTM).
Dule je offline   Reply With Quote
Staro 28.04.2008., 22:39   #108
Odojak
Odojak's Avatar
Postovi: 267
Ne nužno, ima na MSDN-u. MS je promijenio politiku (again). A ne da oni koji plaćaju dobiju kasnije
Staro 28.04.2008., 23:58   #109
yvanus
yvanus's Avatar
Postovi: 15
treba li sp3 instalirati na goli win xp (sp2 naravno) ili ga je moguće (zdravo) naknadno instalirati?
yvanus je offline   Reply With Quote
Staro 29.04.2008., 17:58   #110
Odojak
Odojak's Avatar
Postovi: 267
Autor yvanus Pregled postova
Moguće je naknadno.
Staro 29.04.2008., 18:07   #111
Raging Demon
Raging Demon's Avatar
Lokacija: Trogir
Postovi: 224
danas je trebao biti dostupan sp3 preko micosoftovih stranica, jel zna neko di to ima za skinit? ja nemogu nac...
Raging Demon je offline   Reply With Quote
Staro 29.04.2008., 18:08   #112
Odojak
Odojak's Avatar
Postovi: 267
Staro 29.04.2008., 18:37   #113
Raging Demon
Lokacija: Trogir
Postovi: 224
hvala, ovo je nadam se finalna verzija...
Staro 29.04.2008., 19:07   #114
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,741
Evo na brzim sistemima se ne primjeti razlika u performansama, ali na jednoj kanti Celeron 1100 512mb rama cini se da je odaziv OS-a puno brzi nego u slucaju SP2. Probao instalaciju na 20 masina nije ni na jednoj bilo problema.
Staro 29.04.2008., 19:30   #115
Raging Demon
Lokacija: Trogir
Postovi: 224
evo san instalira i sve radi ok, al zar nije sa sp3 trebao doc i novi izgled windowsa??
Staro 29.04.2008., 20:03   #116
m4dm4n
m4dm4n's Avatar
Postovi: 1,955
Nije trebao doći nikakav novi izgled, lol, kaj će ti to
Instalirali na windowsima sa SP1, totalno nismo ništa skužili, ni približna ubrzanja.
Intel 1.6 P4 i 512 MB rama
Al nešto sam negdje vidio da se radi o RC retail verziji I da, sa službene stranice Microsofta je skinut.
Staro 30.04.2008., 12:04   #117
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,741
Hmm Microsoft je povukao SP3, bez starog Billa nista nije kao prije
Povukli bi oni i Vistu SP1, ali vec je instalirana na vecini kompjutera.
http://www.fudzilla.com/index.php?op...=7099&Itemid=1
Staro 30.04.2008., 12:51   #118
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
lmao
danij3l je offline   Reply With Quote
Staro 30.04.2008., 19:08   #119
Rain Man
Lokacija: x
Postovi: 1,447
Bas citam na BOL-u. Smijeh. Treba da puste medu mase, a oni otkazu. Pa sta su radili s tim SP tako dugo da jos nije usavrsen. Bome ko da se radi o novim windowsima a ne o SP.
Rain Man je offline   Reply With Quote
Staro 01.05.2008., 12:06   #120
Odojak
Odojak's Avatar
Postovi: 267
Nitko kao MS. Toliki novac, toliko korisnika i opet na kraju ovakvi problemi....
