Staro 09.01.2008., 21:10   #31
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,315
..ovo je palitova izvedba,a palit je vrlo opak igrac,nema greske s ovom karticom,samo info da je u ve-mila stigla esc 8800gt (pasivno hladjenje) s 512ddr3 za 1650kn,kartica izgleda hebeno,cak ima posebne pasivce na memi
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 09.01.2008., 22:25   #32
pocho
Postovi: 13
Autor elvis again Pregled postova
Jesi prvo maknul stare drivere uninstal + dc pro? Kaj se događa kad ju spojis i upalis komp?
nisam, ni ne znam šta je dc pro :/
kad upalim komp vidim da joj ventilator radi, ništa ne tuli (kao ono kad ne ubodeš dobro karticu, pa se čuje, toga nema...), ali monitor mi ne prima nikakav signal. mrak.
guglam o tome, i našao sam ovo (na googleovoj memoriji, stranica više ne postoji, pa radim c/p):
Okey, i have bought a xfx 8800gt 512mb graphics card. I installed it, turned my computer On and .. black screen. It´s like "no signal" , but the fans and the computer starts ( i can hear the windows startup sound after a while..) :s .. i cant even see the bios screen or nothing, its just black. When i change to my old radeon card it works fine..
Okey, so, ive tried lots of things..
3 models of power-supplys including 420w, 430w and now i have a xilence 550w. Didnt help..
Ive tried the graphiccard on my friends computer, and it works fine, so its not the card thats broken..
i have un-installed the old radeon drivers but didnt help either. Ive set the bios to "PCIe"-mode ( so it´s not the onboard videocard). I have also updated my BIOS.
What to do? is there any fix?
Ive heard that the problem could be that the VIA chipsets doesnt work with PCI 2.0 cards.. can that be true? i mean the card should be backwards compatible.. :s
please, help me :/ it´s so frustrating..
evo još jedan link u tom smislu: http://answers.yahoo.com/question/in...7233555AA71A9v
Recently I bought an XFX 8800GT (Xtreme Edition), and was one of the unlucky people who got caught out with the incompatibility issue. XFX have since sent me patch for the card to bring it back to PCIE gen1...
uglavnom, neću je još nositi na reklamaciju, mogla bi biti sasvim ispravna a da je problem s mojom pločom. Soltek SL-K890Pro-939, chipset Via K8T890. (izgleda da je neki uklet chipset, ubo sam danas i Athlonax2 3800+ i ne vidim u task manageru dva procesora! :/ ovaj chipset ne podržava dual core, navodno postoji neka verzija koja radi ali su je kasnije povukli :/ našao sam je i sutra ću izgleda po prvi put u životu flashirati bios )
uglavnom, loš dan.
nego, nazad na grafičku - imaju li vama ovi citati gore smisla, to sa PCIe verzijom 1 i 2? koliko sam ja skužio grafička je PCIe 2 a moja ploča je PCIe 1. i, šta ću sad s tim? :/
idem sad probat skinuti stare drivere pa probati tako kako si rekao. i palim Bareta i Majke, onu stvar: nekaaa se čudooo desiii
pocho je offline   Reply With Quote
Staro 09.01.2008., 22:41   #33
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Da si bar napisal koju konfiguraciju imas pod moj komp bilo bi sve uredu ovak neznam ni s cim raspolazes i dal je sve kompatibilno.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 10.01.2008., 20:34   #34
pocho
Postovi: 13
evo sad sam napisao tamo pod nickom kakav mi je komp. sve sam više uvjeren da je moja ploča kriva.
danas sam radio onaj flash biosa ploče i dobro je prošlo (nije to tak komplicirano kako sam ja mislio ), al rezultati su bili loši - konačno mi prepoznaje dual core, ali PC je skroz nestabilan - zaledi se nakon minutu-dvije, sam se pali (?!), i takoto... uglavnom, raspitat ću se na prikladnom pdfu, samo se malo hvalim. matična mi je smeće.
da se vratim na graf. čitao sam da se 8800gt može flashati tako da postane PCIe v.1 kartica. ( http://evga.com/forums/tm.asp?m=158518 ) i da onda proradi na nekim chipsetima s kojima se prije toga svađala. mene prvenstveno zanima koliko je opasno flashati grafičku karticu i koliko je stvar REVERZIBILNA? bojim se da ne upropastim karticu.
Staro 11.01.2008., 16:08   #35
Moncho
Moncho's Avatar
Lokacija: Sarajevo
Postovi: 45
gotov ista stvar sa Maticnom, sa jednom razlikom, ukoliko skuris BIOS od maticne, nema mu softwareske pomoci, moze drugi BIOS chip. GFX ukoliko skuris bios, utaknes PCI graficku i naravno ovu skurenu i startas komp sa PCI grafom i flashujes bios skurene grafe.
U biti nista sto bi ti trebalo biti problem, ukoliko se kuzis u BIOS flashing maticne, samo su drugi alati u pitanju...
Moncho je offline   Reply With Quote
Staro 11.01.2008., 17:05   #36
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Malo sutra burazeru, ako nisi znao dobar broj pločica sa PCI-e sabirnicom izgleda da uopće ne šljivi PCI grafe tj nema šanse da bootaš sa PCIke jer je sustav ne kuži, tj ne diže se uopće iz mrtvih dok ne nađe PCI-e grafu, dakle tu ti igra samo dual PCI-e 16x ploča i druga PCI-e grafa iako niti ako uspiješ dići dos to ti NIJE garancija da ćeš moć fleshati tu grafu koja je unutra...
Have a nice day...
Staro 11.01.2008., 19:02   #37
Moncho
Moncho's Avatar
Lokacija: Sarajevo
Postovi: 45
ok onda my bad. Fala na ukazanim pogreskama...
Staro 14.01.2008., 23:26   #38
pocho
Postovi: 13
na kraju ipak ništa od flashanja. prodao sam 939 procesor, kupio novi na AM2 i novu ploču (Gigabyte MA770-DS3), sad grafa radi kao urica. dobro da nisam reklamirao.
hvala na odg
Staro 15.01.2008., 00:57   #39
Mar
Suit up!
Mar's Avatar
Postovi: 5,967
Ima u Ve-mulju ECSova 8800GT za oko 1650-1700 kn + dolazi sa Accelero S1 + turbo module.
- Barney Stinson
Staro 15.01.2008., 01:42   #40
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Autor yedwy Pregled postova
Imao sam problema zbog ovoga. Na mojoj krepanoj DFIci (dok je radila kako treba) ako ustekam i PCI-E i PCI grafu nece da bacim signal na monitor ni sa jedne. Ako ustekam samo jednu onda radi kako treba, ali ako su obije ustekane nema sanse.
Onda sam otisao do frenda koji ima jednu od onih ASSrock ploča koje imaju i AGP i PCI-e port, ustekao PCI grafu i moju spaljenu 6800GT (PCI-E) i sve je radilo kako treba (uspio sam vratiti fabricki BIOS na 6800GT).
Milentije je online   Reply With Quote
Staro 15.01.2008., 06:39   #41
yedwy
yedwy's Avatar
Postovi: 6,956
Ja sam na svojoj probao više PCI grafa od S3 koje sam imao pri ruci i niti s jednom nije išlo, za neke druge PCIke sam čuo da ljudima manje seru ali kako većina koji imaju u rezervi PCIku ima s3 - jbga...
Have a nice day...
Staro 20.02.2008., 21:30   #42
elvis again
In the ghetto
Postovi: 1,943
Gigabyte GF9600GT
Zadnje izmijenjeno od: elvis again. 20.02.2008. u 22:19.
Staro 20.02.2008., 22:39   #43
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Nekako sam uvjeren da se karticu ne bi moglo uzeti odmah sutra ujutro
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 20.02.2008., 23:49   #44
bili-rw
Superbad
bili-rw's Avatar
Lokacija: Milky Way
Postovi: 39
A pretty please, a pretty please, pretty please,
Get the hell away from me
bili-rw je offline   Reply With Quote
Staro 21.02.2008., 15:38   #45
darkijas
darkijas's Avatar
Postovi: 1,806
ak je suditi po ovom review-u ja bi rekao da je 8800gt ipak bolji izbor od dotične. Dosta korisnika nvidia x600gt serije kartica (među kojima sam i ja) od istih očekuje prvenstveno solidne perfomanse uz manje zagrijavanje i manju potrošnju struje od svoje veće braće a 9600gt troši neznatno manje od 8800gt i prilično se zagrijava. Ako joj cijena osjetnije padne bit će dobar izbor ali do tada ja bi prije uzeo npr. gigabyte 8800gt 512mb za 1650kn
darkijas je offline   Reply With Quote
Staro 21.02.2008., 19:00   #46
Speedbreaker
Postovi: 545
Čim izađe 9600GS ja prelazim.To će bit nekakav mainstream nadam se.
Speedbreaker je offline   Reply With Quote
Staro 21.02.2008., 19:12   #47
Buger
Postovi: 4,388
recimo da bi se cijenom od 1100kn dobro uklopila u trenutno stanje tržišta
http://www.vr-zone.com/articles/64_S...00GT/5575.html
vjerojatno će cijena padati i da će kartica postati best buy, ali ipak mislim da se više isplati za 1000kn uzeti HD 3850 ili za 1600kn uzeti 8800GT
Staro 22.02.2008., 10:18   #48
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
po ovom ispada da je 9600 gt bolja od 3870??
timmy je offline   Reply With Quote
Staro 22.02.2008., 10:49   #49
Omega
Omega's Avatar
Lokacija: Sibenik
Postovi: 1,226
Autor timmy75 Pregled postova
Guru3D
evo jedan malo kvalitetniji clanak sa 9600gt karticama.
3870 nije ni priblizno slaba kako je u tom gore testu predstavljaju... to mi smrdi na "zeleni" novac
Casemodd logs : Dragon Storm, Kali, Entourage
Complete Case Painting Guide
Omega je offline   Reply With Quote
Staro 22.02.2008., 11:03   #50
mmausa
Postovi: 109
Hm.. kartica je vrlo blizu 8800GS po performansama..
ukoliko je pozicioniraju prema 200eur, pored 8800GT nema sto traziti, morala bi kostat kao 3850 512MB i (preskupa kod nas) 8800GS da bi bila interesantna. S time da su i 3850 i 8800GS odlicni clockeri, a 9600 je pitanje koliko ima "lufta" za OC.
Sve u svemu, nasi trgovci bi je mogli "pokopat" ukoliko pretjeraju s cjenom, a 38xx kartice pojeftine.
mmausa je offline   Reply With Quote
Staro 22.02.2008., 11:12   #51
Postovi: 33,952
Lijepo vam je elvis dao link - košta 1.315kn. Za tu cijenu ja radije uzmem 3870.
Staro 22.02.2008., 12:39   #52
Mljac
Mljac's Avatar
Datum registracije: Feb 2003
Lokacija: Zaprešić/Laduč
Postovi: 460
ATI je sada "slučajno" spustio cijene 37xx serije kartica i sada bi 3870 trebala koštati vrlo blizu 9600gt.
NVidija neće imati izbora nego sniziti cijenu ako hoće prodati kartice, po meni kod nas 1000 do 1100 kuna.
Bit će zanimljivo slijedećih dana.
Mljac je offline   Reply With Quote
Staro 22.02.2008., 12:55   #53
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,734
ma iskreno me uopće ne "uzbuđuje" 9600...bilo bi fora da još padne HD3870..ja ih čekam kada će biti oko 800kn (polovne) jer sam židof i ne dam više od 800 za karticu
Staro 22.02.2008., 13:59   #54
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Hamm Pregled postova
Slicno kao i ja s tim sto ja ne dam vise od 900kn za NOVU karticu.
Sudeci po jos nekim testovima, 9600GT je ponegdje sporija a ponegdje brza od 3870, pogledati i Anandov test. Od 3850 je valjda uvijek brza.
ATi je vec najavio spustanje cijena, negdje su vec i pale, tako da ce vjerojatno HD38x00 i dalje biti bolji izbor nego neka endivija.
Staro 22.02.2008., 14:20   #55
Postovi: 33,952
Staro 22.02.2008., 14:55   #56
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Too much IMHO, jer ce cijene HD3800 kartica pasti.
Staro 22.02.2008., 15:39   #57
Index
Postovi: 142
Ja ću čekat kad cijena polovnih 9600 GT bude bila oko 450KN. Tada je budem kupil. Sad mi je 7800 GTX extreme koju sam također platio 450Kn sasvim dovoljna.
Index je offline   Reply With Quote
Staro 22.02.2008., 16:12   #58
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Autor SRV Pregled postova
Potpisujem...
Da cijene HD3800 serije ostanu na sadašnjoj razini, 9600 bi bio dostojan konkurent s dobrom cijenom, ali s obzirom na najavljeno snižavanje cijena HD3800 serije, ipak će ATi ostati kao bestbuy...
I5 3350P
XFX XTR 650W
Silencio 650
Staro 22.02.2008., 19:06   #59
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ma pasti ce i cijene 9600 kartica cim ih bude u vecim kolicinama. Nisam vjerovao da ce 9600GT biti ravna 3870, ali eto jest, ponegdje sporija, ponegdje brza. Iako su skresali GPU.
Staro 22.02.2008., 19:42   #60
Morpheous
Morpheous's Avatar
Postovi: 1,138
Uzmite u obzir da će s novim revizijama drivera 9600 postajati samo bolja, dok je 3870 već sad na svom maksimumu i ne može biti brža.
Morpheous je offline   Reply With Quote
