#182 |
Postovi: 232
#183 |
Postovi: 56
Možete li mi savjetovat da ne skidam bezveze najnoviji Americas Army...ako ne mogu vrtit na mom računalu, ako može hitan odgovor hvala!!! Sadašnje requirments su: The current Recommended System Requirements for AA:SF (Overmatch) are as follows:
Processor Model : AMD Athlon(tm) XP 2600+ Speed : 1.92GHz Model Number : 2600 (estimated) Performance Rating : PR2848 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA AGP PCI USB FireWire/1394 i2c/SMBus MP Support : No MP APIC : No System BIOS : Phoenix Technologies, LTD 6.00 PG Mainboard : nVidia-nForce Total Memory : 1.5GB DDR-SDRAM Chipset 1 Model : Nvidia Corp nForce2 AGP Controller Front Side Bus Speed : 2x 167MHz (334MHz data rate) Total Memory : 1.5GB DDR-SDRAM Memory Bus Speed : 2x 167MHz (334MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : ATI Radeon 9600 / X1050 Series Adapter : ATI Radeon 9600 / X1050 Series Secondary Imaging Device : Logitech QuickCam Messenger Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : Maxtor 6L160P0 (153GB) Hard Disk : Maxtor 6Y160P0 (153GB) Hard Disk : ST3802110A (75GB) Hard Disk : M600i USB Device Hard Disk : USB Flash Memory USB Device Hard Disk : Maxtor 6 Y080L0 USB Device Hard Disk : Sony Eri Memory Stick USB Device CD-ROM/DVD : PIONEER DVD-RW DVR-111D (CD 63X Rd, 8X Wr) (DVD 8X Rd, 1X Wr) CD-ROM/DVD : KB3323I MDM317G SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd) MultiMedia Device(s) Device : NVIDIA(R) nForce(TM) MIDI UART Device : Standard Game Port Device : Realtek AC'97 Audio Device : NVIDIA(R) nForce(TM) MCP Audio Processing Unit |
#184 |
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
@ganci, primjetio sam da kika ljude zbog toga, budem se baš čuo sa glavnim adminom za srver (S@ky-em) pa če on to riješit i vidjet.....javim ti situaciju... @supertovar - radit če, ali u nekih 30-40 fps-a, možd malo više (kako u kojoj sitaciji i mapi) - procesor če te malo kočit ali probaj....... Inače, ja sma novi komp kupio samo zbog AA-a ![]()
#185 |
muimerP
Lokacija: VG
Postovi: 3,334
Ono..ja prasim samo BORDER, nekad sam samo Moutmckenu... NIck: NEF-kljaja_CRO_ hehe POZZ
#186 | |
Lokacija: dubrovnik
Postovi: 289
ja sam do prije neki dan imao sličnu konfiguraciju kao i ti.. imao sam bartona 2500+. nforce 2 matičnu, gigu rama i nvidiu 6600.. mogao sam igrati sasvim solidno.. igrao sam na rezoluciji 1024x768 i postavke normal (isključi sjene, lightning i neke gluposti) tvoja grafička je malo slabija od moje bivše no ja sam igrao i sa 9200 ati (prije ove) a znam da i danas neki ljudi igraju na 9600.. jedini problem biti će ti možda najnovije mape koje su dosta zahtjevnije a americas army se sastoji ja mislim od jedno 50-60 mapa ako ne i više.. moj savjet ti je da provaš u nekoga posuditi dvd americas army-a ako ima već snimljeno u compu.. pozdrav ![]() |
#187 |
Postovi: 56
Hvala na odgovoru radoznalko i ostali, probat cu pa sto bude ...ja sam ==JUBA== zadnji put sam igrao 2005 imam 46 honor ![]() |
#188 |
Lokacija: dubrovnik
Postovi: 289
ja imam 96 honor..igram aa već jedno 3-4 godine ratni vojni invalid sam, neradim, pa onda tako ubijam vrijeme uz protivnike te liječim posttraumatski ![]() omiljene mape su mi...dusk, pipeline, urban assault, sf courtyard, od novijih old town i rummage.. |
#189 |
Postovi: 1,401
daj javi nick pa da se nađemo na pipelinu jednom... |
#190 |
Postovi: 56
Di mogu skinut ovu igricu na njihovom oficijelno ima milijun linkova ali svi se placaju po apr dolara da se skine to sve...ima neko aternativu, direct link, torrent, isl...sve dobrodoslo samo da je brzo i free... ![]() |
#191 |
Postovi: 1,401
#192 | |
Postovi: 56
#194 |
Postovi: 1,401
#195 | ||
Postovi: 232
isprike Citiraj:
sve to i jos vise na www.ri051.com |
#196 |
Postovi: 56
Molim da mi netko napiše što moram da isključim a da imam najbolje performanse a opet da mogu igrat normalno...hvala Koja reza itd... |
#197 |
Postovi: 232
#198 |
Postovi: 56
#199 | ||
Postovi: 232
nemoram niti spominjat da pogasis sve AV programe koje imas, isto kao i messenger i sve tome slicno dok igras |
#200 | |
Lokacija: dubrovnik
Postovi: 289
![]() http://www.tweakguides.com/AASF_1.html |
#201 |
Postovi: 4,707
#202 |
AutoCad & Allplan expert
Postovi: 2,159
da malo dignemo temu medju "žive" evo bliže se praznici, vljda medju svim tim pijakama bude i nekog mjesta za neki okršaj u AA. pisiekspertovci ajmo se dogovorit za neko match ![]()
none |
#204 |
Postovi: 2,159
none |
#208 |
Postovi: 1,401
Evo rješenja za bolničara: Airway management: A, A, A, C, C, B, A, B, D, B, A, E, A, C, C, A, A, D Control bleeding: B, B, A, B, C, D, A, C Treat shock: B, D, B, C, B, B, B |
#209 | |
Postovi: 374
btw, ja sam konstantno na Borderu, pa se mozda vidimo tamo, [MN]_--=firefly=--
1) P4 Prescott 3.0 on Abit IC-7 MAX3 with 2GB DDR400 ST 2) P4 Northwood 2.6 on PX865PEC Pro v2.0 with 1GB DDR400 3) HP Compaq nx6125 with 1256MB DDR333 4) AMD Athlon 950Mhz on MSI K7T Turbo2 with 768MB SDRAM 5) PIII 600E on Procomp BVC2B with 384MB PC100 Win98 6) PIII Celeron 1300 on Asus TUEP2-M with 384MB PC100 Linux |
