#31 |
N0teb00k n00b
Lokacija: Zagreb/Koprivnica
Postovi: 2,112
#32 |
Postovi: 5,795
jucer na novi disk KC3000 stavio svjezu instalaciju Proxmoxa, sve updejtao, restorao backup VM (haos) i sve radio ok, danas ujutro opet ista stvar, proxomx smrznut, VM HAOS također. Prosao jos jednom kroz postavke (mrezne, firewall Proxmoxa i VM-a, sve ok), podesio C states (quiet pcie_aspm=off nvme_core.default_ps_max_latency_us=0 nvme_core.io_timeout=35000 nvme.noacpi=1 intel_idle.max_cstate=1 processor.max_cstate=1), sve provjerneo i loadano u GRUBU, čak sam napravio i skriptu koja mi svakih 10 min zapisuje logove diska pa u vidjet jel ima sta u tim logovima i ovo je trenutni zapis: root@pve:~# tail -n 40 /var/log/proxmox-health.log ===== Sun Dec 7 12:10:01 PM CET 2025 ===== Uptime: 12:10:01 up 43 min, 1 user, load average: 0.05, 0.06, 0.09 Zauzeće RAM-a: total used free shared buff/cache available Mem: 15Gi 4.9Gi 10Gi 39Mi 320Mi 10Gi Swap: 8.0Gi 0B 8.0Gi Zadnjih 10 NVMe poruka iz kernela: [ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.8.12-17-pve root=/dev/mapper/pve-root ro quiet pcie_aspm=off nvme_core.default_ps_max_latency_us=0 nvme_core.io_timeout=35000 nvme.noacpi=1 intel_idle.max_cstate=1 processor.max_cstate=1 [ 0.038524] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.12-17-pve root=/dev/mapper/pve-root ro quiet pcie_aspm=off nvme_core.default_ps_max_latency_us=0 nvme_core.io_timeout=35000 nvme.noacpi=1 intel_idle.max_cstate=1 processor.max_cstate=1 [ 1.827409] nvme nvme0: pci function 0000:01:00.0 [ 1.832962] nvme nvme0: Shutdown timeout set to 10 seconds [ 1.834397] nvme nvme0: 6/0/0 default/read/poll queues [ 1.836434] nvme0n1: p1 p2 p3 Zadnjih 10 CPU/C-state poruka: [ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.8.12-17-pve root=/dev/mapper/pve-root ro quiet pcie_aspm=off nvme_core.default_ps_max_latency_us=0 nvme_core.io_timeout=35000 nvme.noacpi=1 intel_idle.max_cstate=1 processor.max_cstate=1 [ 0.038524] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.12-17-pve root=/dev/mapper/pve-root ro quiet pcie_aspm=off nvme_core.default_ps_max_latency_us=0 nvme_core.io_timeout=35000 nvme.noacpi=1 intel_idle.max_cstate=1 processor.max_cstate=1 [ 0.198328] cpuidle: using governor ladder [ 0.198328] cpuidle: using governor menu [ 0.460127] intel_idle: max_cstate 1 reached Zadnjih 10 kernel poruka općenito: [ 6.999335] e1000e 0000:00:1f.6 eno1: entered promiscuous mode [ 10.779525] e1000e 0000:00:1f.6 eno1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx [ 10.779568] vmbr0: port 1(eno1) entered blocking state [ 10.779574] vmbr0: port 1(eno1) entered forwarding state [ 15.972218] tap100i0: entered promiscuous mode [ 16.011614] vmbr0: port 2(tap100i0) entered blocking state [ 16.011622] vmbr0: port 2(tap100i0) entered disabled state [ 16.011643] tap100i0: entered allmulticast mode [ 16.011736] vmbr0: port 2(tap100i0) entered blocking state [ 16.011739] vmbr0: port 2(tap100i0) entered forwarding state Memoriju sam prije jos testirao sa mem testom koji ste mi rekli i sve je proslo ok. Suma sumarum, BIOS HP-a updejtan i podesen, promjenio 2 nova diska, memorija istestirana problem i dalje tu. Jedino sto mi jos ostaje je stavit drugu memoriju i probat s njom, ako je problem i dalje prisutan, nabava novog racunala jer je onda ocito problem negdje u mbo/pitaj boga gdje ![]() |
#33 |
Postovi: 10,248
Podsjeti me, kad spojis monitor na HP, da li imas video output i mozes li se kroz konzolu ulogirati u proxmox te raditi na njemu dok je u "smrznutom" stanju? Vidim da sam te to pitao, ali nisam iz odgovora skuzio jesi li probao
#34 |
Postovi: 5,795
Nisam to probao, iskreno, jer mi je HP u ormaru, spojen na PSU i LAN. I kad ga ulovim smrznutog, samo ga isteka iz napajanja i ponovo ustekam. Onda kad se sljedeci put smrzne trebam ustekati monitor i vidjeti jel imam video output na monito i ako imam probat se ulogirat u Proxmox? P.S. Pitao Cloude za problem, kaze da je problem u mreznoj kartici Intel i219-LM i dodao u GRUB: GRUB_CMDLINE_LINUX_DEFAULT="quiet pcie_aspm=off nvme_core.default_ps_max_latency_us=0 nvme_core.io_timeout=35000 nvme.noacpi=1 intel_idle.max_cstate=1 processor.max_cstate=1 e1000e.InterruptThrottleRate=0,0,0,0 e1000e.EEE=0" Claude kaze da trebam u biosu ugasiti opciju "Wake on LAN" pa cu i to napraviti jer nemam potrebu za tim featureom |
#35 |
Postovi: 10,248
Tako je, kad se ulogiras direktno na hosta onda debugiraj (ako host uopce radi, a prilicno sam siguran da bi mogao raditi). Provjeri mreznu i ima li dobar IP, vidi li host net i lokalnu mrezu, itd itd. Pokreni htop ili slican tool za pracenje tko sta i koliko cucla (instaliraj ga unaprijed). Nisam bas na "ti" s debugiranjem VM-ova, al sigurno postoji neki nacin da provjeris i VM. Ovo sa mreznom me ne iznenadjuje, to sam u prvom postu spominjao, ali mi je bizarno to da host zakuha dok je "neresponzivan". Nemam iskustva s ovim grub parametrima.
#36 |
White Rabbit
Postovi: 5,290
Ja da sam na tvom mjestu bih spojio cijelo vrijeme monitor i mozda lupio journalctl -f nekl vrti. Kad se desi sranje mozda ces vidjet koji mu je vrag. I da - makni molim te iz default kernel linije sve sto je iza quiet, updejtaj grub i rebotaj komp nakon toga. |
#37 |
Postovi: 10,248
Da, definitivno kreni s cistim grub-om, zelis reproducirati problem s monitorom pri ruci a ne pogadjati sto je rijesilo problem kad ne znas sto je problem :) baby steps!
#38 |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,137
Kod mene je problem da jednostavno nema mrežu. Ištekam uštekam i radi. Mijenjao i kabel već. Oni Nucevi kaj imam.. Isto proxmox u clusteru.
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free |
#39 | |
Postovi: 5,795
Update, vise host odnosno HP ne zakuha, radni mormalno, ali mu ne mogu pristupiti. Sljedeci put kad se se smrzne cu se probati spojiti direktno na njega preko monitora, i onda ce se vidjeti jel proble sa mrezom (pa ga ne vidim preko IP-a) ili bas cijeli host zasteka. Za sad bi ostavio kako je, pratio i pa onda poslije postavio defaultni grub i testirao dalje |
#40 | |
White Rabbit
Postovi: 5,290
Mozda...samo po ovim cijenama memorije bude malo problem. P.S. - u slucaju kernel panica moze se dogoditi da na ekranu neces nista vidjeti ako ga naknadno ustekas nece biti od koristi > zato je bolje to napraviti vec sad. A kaj se ovih svih opcija tice > odmah testiras dali radi sve kak spada kad su deaktivirane > ako tad sve radi > onda dodajes jednu po jednu ponovno. Deducirali smo vec sad da nije SSD problem i sve mi vise smrdi da je nesto krivo optimirano na razini proxmoxa. Ukratko > pokusavamo ti ubrzati proces debugginga. |
#41 |
Postovi: 5,795
Memorija je poslije uredno prosla memetest koji mi je predlozen, pa sam ju prekrizio kao moguci problem. Spojio sam monitor i sada journalctl -f vrti sve logove, potencijalni problem je sto ne mogu nista s tim logovima, (tipa c/p) osim uslikat ih mobitelom, a osobno nemam znanja da mogu problem iščitat iz njih samih, nadam se da bude neki "crveni log" prija samog crasha pa da cu biti pametniji. |
#42 | |
White Rabbit
Postovi: 5,290
Samo poslikaj sto pise kad se smrzne...najcesce kernel: nesto |
#43 |
Postovi: 5,795
OK, sad čekam prvo smrzavanje u visokom stupnju pripravnosti ![]() Fora je sto sam napravio sva ona podesenja u Proxmoxu by GPT i nakon toga je uredno radilo 8 dana, prvi crash i onda se počelo dogadjati svaka 24 sata, ubačen novi disk opet crash u roku par sati U svakom slučaju hvala svima na supportu, valjda cemo naci krivca ![]() ![]() |
#44 | |
Postovi: 7,699
Vidim da ova tema više odlazi u krivom smjeru.
__________________ |
#45 |
Postovi: 5,795
Pitao sam GPT, proguglao ono sto mi je predlozio i internet kaze da to moze biti legit problem, probao sa cisto instalacijom i drugim diskom, problem i dalje prisutan. Zao mi je ako u tvojim očima izgleda kao trosenje vremena kolega koji zele pomoci, samo sam zelio napraviti sto je u mojoj moci i znanju da rijesim problem. Trenutno je sve postavljeno kako su kolege sugerirali i monitoriram situaciju u nadi da cu dobiti log koji ce biti trag k rijesenju problema. Jos jednom hvala svima na pomoci ![]() |
