#1261 | ||||||||
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,748
Nemam pojma, ne koristim Notepad na Windowsima. Ali moji mama i tata ga koriste i ono, sasvim su OK s njime. Citiraj:
![]() Citiraj:
![]() Citiraj:
![]() Citiraj:
Programeri danas kada trebaju 1000 bajtova: p = malloc(1000) Wait, what? Citiraj:
S druge strane, evo ti obican WebKit-GTK na brzinu nakucan primjer pokrenut na Mintu. Tab u zadnjem Chromeu zauzima ~60MB. ![]() Code:
bubba@goldenaxe:~/Downloads/tmp$ file ./bolja_vremena ./bolja_vremena: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=46d68482d6aea5a72666d7012a711ae32a4e7286, for GNU/Linux 3.2.0, stripped bubba@goldenaxe:~/Downloads/tmp$ valgrind --tool=massif ./bolja_vremena ==271099== Massif, a heap profiler ==271099== Copyright (C) 2003-2017, and GNU GPL'd, by Nicholas Nethercote ==271099== Using Valgrind-3.18.1 and LibVEX; rerun with -h for copyright info ==271099== Command: ./bolja_vremena ==271099== ==271099== Warning: noted but unhandled ioctl 0x644f with no size/direction hints. ==271099== This could cause spurious value errors to appear. ==271099== See README_MISSING_SYSCALL_OR_IOCTL for guidance on writing a proper wrapper. ==271099== bubba@goldenaxe:~/Downloads/tmp$ ms_print massif.out.271099 -------------------------------------------------------------------------------- Command: ./bolja_vremena Massif arguments: (none) ms_print arguments: massif.out.271099 -------------------------------------------------------------------------------- MB 14.82^ : | #:: : :: :::::::@::: | #:: : :: :::::::@::::::::::::@ ::: | #:: : :: :::::::@:::::: :::::@ ::: | #:: : :: :::::::@:::::: :::::@ ::: | ::::#::::::::::::::::@:::::: :::::@ ::: | :::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @ :::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @ :::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @ :::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @ :::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @ :::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @:::::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @:::::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @:::::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @ :@:::::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | :@ :::@:::::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | ::@ @::::@:::::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | :@::@:@::::@:::::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: | @:@::@:@::::@:::::::#::: ::::::::::::@:::::: :::::@:::::@::::::@::: 0 +----------------------------------------------------------------------->Gi 0 1.124 Number of snapshots: 83 Detailed snapshots: [3, 5, 8, 10, 15, 24 (peak), 41, 56, 66, 76] |
#1263 | |
#erase startup-config
Postovi: 3,654
Windows 11 - info, how-to, pitanja, novosti, savjeti...
Sjećam se kada bi slučajno pokušao otvoriti par megabajta velik file u Notepadu na Win95/98 na mašinama s 4 ili 8MB RAMa. Toliko bi Windoze zablokirale da te ni Vulkan pinch CTRL-Alt-Del ne bi spasio ![]() Ono kad slučajno drag-n-dropaš mp3cu u Notepad umjesto u WinAMP…. gotov si. Moli se da si sejvao sve na čemu si radio ![]() Situacija se vrlo polako popravljala sa svakom novom verzijom Windoza. |
#1264 |
Lokacija: München/Varaždin
Postovi: 4,695
@Bubba kad kazem fluidnost mislim na recimo startanje aplikacija, micanje prozora, ugladenost efekata u normalnoj upotrebi OS-a. Posto na Windowsima najcesce samo igre pokrecem - na vecini igara neku mjerljivu razliku ne vidim. Neke igre ne rade tak fluidno...kod da na istoj razini detalja znaju zacvikat na tren. Mozda je do grafickih drivera, necu tvrditi da nebre biti ali na Win10 nit Fedori nemam tih problema.
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16 GB DDR5 / 1TB Micron M.2 2242 / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk Plus / nVidia Geforce GT 730 / FreeBSD 14.3 |
#1265 | |
Postovi: 633
![]() Mislim očito je da ja nisam target audience za Windows 11... Al kad smo kod neoptimiziranosti aplikacija, radim u industriji pa mogu svjedočiti. Održavamo bazu za zubarske ordinacije sa tisućama tablica i storanih procedura u SQL-u koje sad samo bog isus zna kako rade... Sve se vrti na SQL Serveru koji košta desetke tisuća dolara mjesečno... ali ima se para, ima se computing powera, nema smisla optimizirati. Jel radi? Radi. Kad ne bude radilo bacit ćemo još para na scaling. Optimizacija nije prioritet. A dok su resursi bili ograničeni vjerujem da se pazilo što se stavlja na bazu. Zadnje izmijenjeno od: Dule. 06.08.2024. u 20:32. |
#1267 |
Postovi: 4,695
#1268 |
Prvoklasni Krkan
Postovi: 5,237
A jbg, još najbolje da koristi iexplorer...pa ne znam wordpad i slično...paint i onaj novi 3d paint ili kako već! ![]() ![]() Za sve te krnjave govnarije postoji prava alternativa. To je sve bloatware. Ja ne koristim ni file explorer, ne mogu ga smislit, kako sam dijete DOSa i Norton Commandera, meni je Total Commander bog i batina. ![]() Na linuxu je tu Double Commander... |
#1269 |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,010
Sad ste me nešto sjetili, jel bio neki hrvatski program sličan notepadu++? Tamo prije jedno 10-tak i više godina Za Windose bi nešto kao Caja. Meni jedan od boljih koji nije TC klon.
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free |
#1271 |
Lokacija: Sesvete
Postovi: 1,010
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free Zadnje izmijenjeno od: spiderhr. 07.08.2024. u 08:51. |
#1272 |
Postovi: 3,654
Noutped plusplus mi fali na Linđi… |
#1273 | |
Kostolomac
Postovi: 1,449
Meni 11tka dobro radi, samo da još poprave povremeni explorer lag, i da napokon prebace sve opcije u novi UI, a ne da je dio u starom CP-u, dio u novim Settingsima. Također, nikad nisam dobio update/random restart kad nisam htio ni na jednim Windowsima, Defer updates mi je na tjedan ako naleti nešto šfušano da ga stignu povući, i sve ok. Iritantne stvari su se često mogle namjestiti preko LGP-a ili PS/cmd. |
#1275 |
Postovi: 4,695
#1276 |
Lokacija: Sesvete
Postovi: 1,010
#1277 | ||||||
E Pluribus UNIX
Lokacija: M82
Postovi: 6,748
Mensecini da tebi nesto drugo ne radi i da to nema veze s OS-om nego ili neispravnim hardverom/softverom ili si pristran. ![]() ![]() Citiraj:
![]() 8 sekundi bilo je potrebno da Flux.schnell model izgenerira ovo na mojem relativno prosjecnom racunalu. Zajedno sa tekstom, BTW. Nekada su pisali "optimiziraniji softver"? Daj ajde... Moram priznati da mi se xed pokazao apsolutno sjajnim. Malen, razumno mocan, ima sve sto covjeku treba za prvu ruku...
#1278 |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,320
#1279 |
Datum registracije: Apr 2017
Lokacija: SB
Postovi: 713
Stari notepad dobijete tak da uninstall ovaj spori i ljigavi koji dolazi default sa windowsima. |
#1280 | |
Postovi: 4,695
https://www.techspot.com/news/104309...it-latest.html
#1281 | |
Postovi: 4,695
#1283 | |
E Pluribus UNIX
Lokacija: M82
Postovi: 6,748
#1284 |
Postovi: 4,695
#1285 |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,197
Evo nebi vjerovao meni 🤣 Mislim, imam gui alat s kojim to vec rjesavam, ali nebi bilo lose da to konacno implementiraju u sam win. Naime, priroda posla trazi format vecih sd kartica (32+ GB) u fat32 no trenutno to ne mogu odradit bez 3rd party alata 🙂 |
#1286 | ||
E Pluribus UNIX
Lokacija: M82
Postovi: 6,748
#1288 |
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,746
Zato što razrno razni proizvođači se još nisu makli s FAT32. Npr. Audi (Škoda i VW također) za ažuriranje svojih navigacijski karata traži isključivo FAT32 USB stick. Karte imaju ono 31,9GB, a većina 32GB deklariranih stickova ima nešto manje, tako da moraš formatirati 64GB stick ili veći da si miran. ![]() |
#1289 |
Postovi: 633
Istina, moj auto prihvaća USB stickove samo sa FAT32 i samo MP3 ![]() Anyway, što fali FAT32? Podržan je na svemu već desetljećima, i što se tiče kompatibilnosti je najbolji FS. |
#1290 | |
Postovi: 4,695
Jedina prednost je da ga svaka susa podrzava...ostalo - iskreno draze bi mi bilo da je NTFS "standard". https://en.wikipedia.org/wiki/Compar...f_file_systems
