Staro 26.06.2023., 11:18   #361
Postovi: 8,354
Autor MegaSkot Pregled postova
Neki predlog sta uraditi?
Provjeri sve od već prije spomenutog, uključujući i šašave Windows + BIOS postavke, pa posloži na način koji ti najbolje odgovara i s kojim imaš najmanje zajebancije.
To make sure gaming workloads find the right CCD, AMD has implemented a high degree of software-level control, in the form of its 3D Vertical Cache Optimizer Driver, which is included with the latest version of AMD Chipset Software. This driver ensures that workload from games are directed to the CCD with the 3D Vertical Cache using dynamic "preferred cores" flagging for the Windows OS scheduler. You may either use the default (controlled by AMD's drivers with input from game detection) or override that mechanism and push all workloads on the cores with 3DV-Cache first ("prefer cache"), and only when all those cores are busy use the high-frequency cores on CCD2. The third option is to run all tasks on the high-frequency cores first, and put additional load on the 3DV-Cache cores ("prefer frequency").
Izvor: TechPowerUp Ryzen 9 7950X3D Software and Driver Requirements
Staro 26.06.2023., 12:10   #362
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 918
Odradjen update Chipset drivera.
Staro 26.06.2023., 12:28   #363
markecSMB
Lokacija: Cro
Postovi: 1,034
Moja preporuka bi bilo da se ne oslanjaš na AMD, bios i microsoft i da naučiš kako se koristi process lasso.
https://www.youtube.com/watch?v=9xlC...nnel=BeefyTech
Razlog je što u nekim situacijama možeš imat benefite od toga da aplikacije/igre koriste oba CCD.
Nije komplicirano, besplatno je i ima brdo tutorijala, i sam ćeš vidit jel ti igra radi bolje s CCD s 3d il onim na većem taktu.
32GB je za sada dosta za sve. Možeš dobit dosta performansi ako si daš vremena pa tjuniraš memoriju.
Više info https://www.overclock.net/threads/am...hread.1800926/
https://www.overclock.net/threads/of...50x3d.1803292/
Uživaj
Staro 26.06.2023., 13:10   #364
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 918
Hvala.
Staro 26.06.2023., 19:41   #365
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Testiraj pc sa nekim normalnim bench programom, ovaj je baš ono loš ako mene pitaš..
MojSkuter
Staro 26.06.2023., 20:42   #366
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,562
Autor Eladio Pregled postova
Složio bih se sa ovim, taj superposition je sad već (pra)star. Bez obzira na to, ta kombinacija proca i gpu-a bi trebala dati 44k-45k (superpositon se uvijek relativno jadno vrtio na AMD-u) u medium 1080p.
Core affinity sigurno nije problem jer je razlika prevelika, nešto drugo je posrijedi. Kolega markec sigurno ima dobre namjere oko savjeta za laso, ali da imam takav jedan komad hardvea koji od mene zahtijeva da koristim 3rd party programčiće da radi kako spada, to bi izletilo van iz kučišta u roku odmah. Možda dok sam imao 18g i masu vremena
Po meni odvrtiti neki obični timespy i timespy extreme, pa da vidimo
Exy je online   Reply With Quote
Staro 26.06.2023., 21:52   #367
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 918
Nešto tu definitivno ne valja.
Test od 21.05 i danas, velika razlika.
https://www.3dmark.com/3dm/96231307
ID:	26446   Click image for larger version
Zadnje izmijenjeno od: MegaSkot. 26.06.2023. u 22:02.
Staro 26.06.2023., 21:59   #368
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,601
Pa sad je čak i ok
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 26.06.2023., 22:01   #369
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 918
Vidi datume, danas mnogo manji rezultat.
Staro 26.06.2023., 22:02   #370
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,601
Aha, obrnuto je
Ovaj od 21.05. je OK score, znači da sad nešto ne valja
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 26.06.2023., 22:06   #371
Exy
Exy's Avatar
Postovi: 2,562
Ne znam zašto ti pod gpu2 piše microsoft basic adapter, trebalo bi biti amd radeon, jesu sigurno svi driveri instalirani?
Možeš odvrtiti neki cinebech r23 all core recimo i uz njega staviti HWiNFO64 prozor da se malo vide temperature, potrošnja i ostalo?
Staro 26.06.2023., 22:12   #372
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,601
Možda malo glupo pitanje, ali što će mu iGPU? Ja sam svoju odmah disableao u BIOS-u
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 26.06.2023., 22:22   #373
Exy
Exy's Avatar
Postovi: 2,562
Autor maXonja Pregled postova
Kad mu se 4090 zapali da može troubleshootat
Kod mene je ostao raditi igpu zato što volim imati backup ako ovo čudo od grafe odapne (bez da moram resetirati bios) i zato što sam stavio da sve low power fore idu preko njega, ovaj glupi 6800xt je volio paliti ventove i izlaziti iz zero rpm mode-a za nekakve beznačajne stvari.
Ali ako se neće koristiti uopće i nije potreban kao backup onda ga je bolje disableati u bios-u nego ga držati sa generic driverima.
Staro 26.06.2023., 22:23   #374
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,601
Dobro ajd, jedino to
Mislio sam da ima možda neke velike benefite na performanse pa zato govoriš
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 26.06.2023., 22:25   #375
Exy
Exy's Avatar
Postovi: 2,562
To sigurno da ima
Odvrtio sam davno firestrike na igpu, čisto da se vidi kako to izgleda:
https://www.3dmark.com/3dm/87679801?
Staro 26.06.2023., 23:15   #376
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 918
Nek čeka do custom loopa, onda ide novi Win, da se podešava. Hvala svima.
Staro 03.07.2023., 13:54   #377
Flegma
Flegma's Avatar
Datum registracije: Jul 2004
Lokacija: Zagreb/Šibenik
Postovi: 832
U opisu pod moj komp ti i dalje stoji Windows 10. Nadam se da je greska i da radis na 11ici, posto ona ima puno bolji scheduler.
Bila je toliko lijepa da sam poželio da nikad ne otvori usta. A onda mi je nekako objasnila da je nijema. Oženio sam ju Las Vegasu, tjedan dana kasnije. I sad napokon živim sa ženom koju razumijem.
Moj PC - https://www.twitch.tv/flegmoar
Flegma je offline   Reply With Quote
Staro 26.09.2023., 14:29   #378
nino
nino's Avatar
Postovi: 12,613
uspio izbencat dok kolegi forumasu nisam poslao.
13400F / Sapphire PULSE Radeon RX 7800 XT 16 GB GDDR6
Staro 15.10.2023., 19:03   #379
nino
nino's Avatar
Postovi: 12,613
7800X3D - Kingston Renegade 32GB 7200Mhz - Sapphire Nitro RX 7900 XTX 24GB
Staro 17.10.2023., 22:45   #380
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Power color rx 7800xt Hellhound, undervolt 1050 mV, cca 2800mhz
ID:	26731   Click image for larger version
Zadnje izmijenjeno od: MAGARAC. 17.10.2023. u 23:27.
Staro 18.10.2023., 20:13   #381
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,601
Gainward Phantom RTX4090
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 19.10.2023., 09:01   #382
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Ko bi reko da je x3d toliki bottleneck u 1080p medium...
Staro 19.10.2023., 11:19   #383
markecSMB
Lokacija: Cro
Postovi: 1,034
Autor ansha Pregled postova
Pa kad ima najjadniji X3d, i vjerojatno mu je i RAM netuniran.
Staro 19.10.2023., 11:24   #384
Exy
Exy's Avatar
Postovi: 2,562
AMD je uvijek bio prilično jadan u tom benchu. A i vjerojatno bi bilo dobro benchat u nečem malo novijem
Staro 19.10.2023., 18:04   #385
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,601
Pa neznam, mislim da ima i 7800x3d koji je jadniji
Ram je sa upaljenim EXPO profilom i to je to, prošla me volja za finim podešavanjem, random rušenjima i BSOD-ovima usred igre
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 19.10.2023., 22:12   #386
Exy
Exy's Avatar
Postovi: 2,562
Pa, zapravo, ako pričamo o gaymingu, a valjda pričamo kad smo na unigine benchu , 7800x3d je najbolji 3d proc. 7900x3d ima 2 chipleta, od kojih samo jedan ima 3d cache, znači 6 jezgara ima, 6 nema. Ubaci u to problem među-čipletske komunikacije i dobiješ proc koji za gayming nema smisla u stvari.
Staro 19.10.2023., 22:15   #387
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,601
Znam sve, podhebavam malo
Uzeo sam 7900X3D radi future proofinga, 8 jezgri je sad ok, ali tko zna što bude za 2-3 godine, a sigurno planiram ovo sad imat barem 4-5 ako ne i više pa da ne zafali
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 19.10.2023., 22:19   #388
Exy
Exy's Avatar
Postovi: 2,562
Je je, to svi kažu. Već te vidim za godinu dana sa 8900x3d
Nego, vidim da imaš hynixa, uloži desetak minuta i tjuniraj to malo:
https://youtu.be/dlYxmRcdLVw
https://www.patreon.com/posts/low-effort-rank-77403831
Low effort, znači to je to
Staro 20.10.2023., 06:01   #389
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
PC 7800XT Hellhound, 940mV..
ID:	26739   Click image for larger version
Staro 20.10.2023., 08:30   #390
markecSMB
Lokacija: Cro
Postovi: 1,034
Za CB, obradu videa, blender, 7800x3d je jadniji, u igrama je znatno bolji.
7900x3d je škartni procesor, i to od dva škarta, oba CCD su defektna. Povezana su sporom sabirnicom i tu nastaju problemi kod igri.
Sam se ti tješi s fjućurproof (to je AMD trebo trejdmarkat, a pokazalo se da je gomila govana), AMD ti je prodao muda pod bubrege...internet je pun dokaza o navedenom
