Staro 30.03.2021., 15:13   #1
Postovi: 8,140
Intel "Rocket Lake" LGA-1200 Info Thread
Intel Core i9-11900K Review - World's Fastest Gaming Processor?
It seems Cypress Cove is sometimes able to make up a two-core deficit against Skylake, but not always. When comparing against AMD's recent Zen 3 releases the Core i9-11900K can't impress.
Even in the equal-matched duel against the 8-core Ryzen 7 5800X, the i9-11900K loses with 3%. Against the 5900X and 5950X the gaps are big: 18% and 28% respectively.
  • Very high price for what's offered
  • Lower gaming performance than AMD Zen 3 and Core i9-10900K
  • Only eight cores (vs ten on 10900K)
  • Application performance can't even match Ryzen 5800X
  • High power consumption
  • Lots of heat once power limit unlocked
  • Only minimal software support for AVX-512 & DLBoost
  • Gear 1 memory mode unable to run modern memory speeds
  • Many BIOS bugs
  • Only one PCIe 4.0 M.2 slot, others are PCIe 3.0
  • CPU cooler not included
Izvor: Interneti
Staro 30.03.2021., 15:21   #2
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,239
A što nebi ovo išlo u Intel dio, a ne AMD?
Slobodno me dodajte na PSN
Staro 30.03.2021., 15:27   #3
Postovi: 8,140
Ide, ali ovo je taman tema za novi Rocket Lake. Još kad Pat (Gelsinger) a Mat pređu na 7nm i počnu proizvodnju za druge - milina.
Staro 30.03.2021., 16:03   #4
Nick7
Lokacija: Velika Gorica
Postovi: 1,513
Ako koga zanima taj Intelov minimalni (inkrementalni) IPC pomak po generacijama:
Core i7 All Generations (From 1st to 10th) | RTX 3080 10GB PC Gameplay Tested
Problem je sto ovo ne usporedjuje IPC, nego procesore. I tu cak nema nekih bitnih skokova.
Naime, svaki proc je na stock settingu, tj. 2600K je na 3.4GHz/boost na 3.8GHz, dok je recimo 9700K na 3.8GHz/4.9GHz boost.
Trebalo je napraviti 3 grafa:
1) Sve na stock
2) Svi procovi na istom clocku (npr 4GHz), i tu se vidi IPC napredak ili manjak
3) Max overclock
1 i 3 su da se vidi koliko su procevi jaci/napredovali, a 2 je bas za IPC napredak.
Nick7 je online   Reply With Quote
Staro 30.03.2021., 16:23   #5
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,181
Slažem se u pravu si. Krivo sam napisao IPC pomak nego sam opcenito mislio ako koga zanima generacijska razlika među i7 -icma u FPS-u.
To što govoriš je napravio Gamers Nexus u ovom videu donekle:
10 Years of Intel CPUs Benchmarked: i7-930, 2600K, 4790K, & Everything Since (2020)
https://www.youtube.com/watch?v=KPWEdbfJ0oE
Pak bum dobio po prstima za Intel OFF-topic u ryzen temi
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 30.03.2021., 20:01   #6
Sapunator. Kad te TechPowerUp koji ti je inače naklonjen ovako ocjeni, ne znam, ne znam...
  • Many BIOS bugs
Staro 30.03.2021., 20:08   #7
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,848
ok,par fpsova u odnosu na 10600k,već ima 11600k za 2100 10600k je 1800 kuna,fino nije vrijedan 300 kuna više.
Staro 30.03.2021., 20:17   #8
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Razmišljao sam o prelasku na lga1200, u rasponu od h510+pentium sve do z590+ i9xxxxx. Ali sam odustao. Jer mi je h510 razočaranje (m2 nije pcie4), Pentiumi su ostali isti i nisu postali punokrvni quadovi, a sve ostalo mi je realno nepotrebno. Ostajemo na lga775 i u 2021
Campeonato je offline   Reply With Quote
Staro 30.03.2021., 20:39   #9
Dr. Strange
Datum registracije: Aug 2020
Postovi: 892
Znači još jedan šipak od velikog Intela...
Staro 31.03.2021., 00:25   #10
Postovi: 8,140
Heavy Metal Steve za novi Core i9 povlači usporedbe s Bulldozerom.
Staro 31.03.2021., 05:46   #11
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,239
Meni nikako nije jasan potez izdavanja ovih procesora.
Jel to oni moraju zbog dioničara ili koji vrag?
Staro 31.03.2021., 06:47   #12
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 916
Da.
Staro 31.03.2021., 10:30   #13
Postovi: 8,140
Da, to je to, cijelo vrijeme su igre u pozadini, isto kao s ovim silnim najavama za nove tehnologije, proizvodne procese i popratne kapacitete - samo da cijena dionica bude visoka i da se oda dojam snažne firme s jasnom vizijom i ciljevima.
Umjesto da se koji puta malo zamisle, priznaju da više nisu najbolji (nisu čak ni treći najbolji: TSMC, Samsung, Apple, nVidia, itd.), pa onda krenu s konkretnim planovima i rješenjima - ne - bacaj sve što dobro zvuči u eter, pa nek mediji kokodaču.
Staro 31.03.2021., 10:42   #14
Gigi1
Postovi: 2,138
Nisam više tolko prisutan na forumu, ali gdje vam je Mladen?
Staro 31.03.2021., 11:02   #15
Mladenxy
Mladenxy's Avatar
Postovi: 4,301
Autor Gigi1 Pregled postova
Zbog čega me prozivaš? Fali ti rasprava, dosadno bez mene
Evo kad želiš. Stveo kaže kupite Intel, i i to i5 10600KF za 1500 kn jer je Ryzen 5 precijenjen. Ima na njegovom kanalu da ne linkam, ne bi ni spominjao da ne uzburkam neke osjetljive duhove koji će se sada masovno javiti, ali s obzirom da me vučeš za jezik
Staro 31.03.2021., 11:09   #16
Patetika.
Staro 31.03.2021., 11:21   #17
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,312
I održavanje nerealno visokih cijena je dio te marketinške priče, jer bi njihovo smanjivanje bilo priznavanje poraza.
Međutim, mislim da ipak malo previše hatea. Jest, inferiorna je platforma naspram Zen 3, ali glavna razlika je u core counteu i potrošnji. Ok, core count je bitan za produktivnost, ali preko 6 nebitan za gamere. Potrošnja je u sintetičkim testovima i dupla u odnosu na 5600x (i neopravdano veća od 10600k), to je veliki fail, ali temperature su na stocku zapravo tu negdje, par stupnjeva razlike (6): https://www.techpowerup.com/review/i...11600k/22.html.
Max power limit je već puno ozbiljniji problem, ali tu bi onda trebalo naći brojke i za 5600x OC.
Tko kupi taj proc, nije prošao najbolje što može, ali neće mu ni biti loše. Nije to Bulldozer priča gdje imamo puno veću potrošnju i manje performanse, jer performanse su tu (https://www.techpowerup.com/review/i...11600k/17.html).
Staro 31.03.2021., 11:38   #18
Mladenxy
Mladenxy's Avatar
Postovi: 4,301
Autor Brko Pregled postova
Patetika.
Kurac patetika kad su novci u pitanju.
Staro 31.03.2021., 11:39   #19
Gigi1
Postovi: 2,138
e to sam cekao, izbacis novu seriju da bi rivjueri mogli preporuciti staru
Staro 31.03.2021., 11:49   #20
Postovi: 8,140
Međutim, mislim da ipak malo previše hatea. Nije to Bulldozer priča gdje imamo puno veću potrošnju i manje performanse, jer performanse su tu.
Usporedba s Bulldozerom je u kontekstu da novi high-end Core i9 ima slabije performanse od prošlogodišnjeg Core i9 modela i to stoji, dok potrošnja i zagrijavanje idu rukom pod ruku s ostatkom skalamerije.
Nije bezveze većina recenzenata odabrala Core i5-11600K kao primarni materijal, jer taj procesor je sasvim solidan, dok je Core i9 pucanj u prazno samo takav.
Mada, čak i da se sve to zanemari, zajedno s AMD-om, Intel je godinama ismijaval sve oko sebe, koristeći marketing kao glavno sreCtvo komunikacije i sad lutaju, a sami ne vjeruju u ono kaj promoviraju i najavljuju.
Staro 31.03.2021., 12:12   #21
Mladenxy
Mladenxy's Avatar
Postovi: 4,301
Do kraja godine i nova serija će ići po cijeni trenutne stare wink
i5 11600kf je sada ispod 2000 kn, za 1500 kn biti će fenomenalan izbor.
Staro 31.03.2021., 14:31   #22
Odinarius
All-rounder
Postovi: 1,312
i9 je ozbiljno bacanje novca u ništa, to stvarno treba biti specijalac da se kupi
Staro 31.03.2021., 14:50   #23
Postovi: 8,140
Staro 31.03.2021., 20:23   #24
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,552
Puuuuno prije.
Staro 31.03.2021., 21:06   #25
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,499
Jeben je taj 11900K, skuplji, topliji i sporiji od prethodne generacije. Svaka čast Intelu, da li su ikad prije ovakav fijasko napravili?
No znali smo da će biti banana, meni je iz Stevičinog bencha nešto drugo upalo u oko:
To koliko je zapravo CPU beznačajna komponenta u nekom normalnom gaymingu. Ovo je dakle 1080p na RTX3090, znači worst case scenario. Razlike između proca za 200 i za 1200 dolara su smiješne. Kod grafa naravno nije tako (na stranu trenuto ludilo oko cijena).
Po meni da sad kupujem bi vjerojatno išao na 10700F, on je na par % od 5600x, jeftiniji a sa vremenom će +2 jezgre doći do izražaja.
Kad bi išao na neki budget best buy onda naravno opet 10400F, i to je to.
Staro 31.03.2021., 21:34   #26
Postovi: 8,140
Autor Exy Pregled postova
Sličnu situaciju su imali prije više od 15 godina ...
Seemingly overnight AMD went from about to fall off of the performance charts to being competitive with Intel's latest and greatest. But there's much more to this situation than proclaiming a winner and leaving it at that; AMD has lost a considerable amount of credibility, and the Athlon 64 (and FX) of today will not bring AMD back to the heydays of the Athlon. if you’re looking for nothing more than a purchasing decision let’s put it simply: if you’re not an overclocker, do not buy any Prescott where there is an equivalently clocked Northwood available. This means that the 2.80E, 3.00E, 3.20E are all off-limits, you will end up with a CPU that is no faster than a Northwood and in most cases slower. The performance of Prescott today is nothing to write home about, and given the extensive lengthening of the pipeline it’s honestly a surprise that we’re not castrating Intel for performance at this point. When you include AMD in the picture, the recommendation hasn’t changed since the Athlon 64 was introduced. If you find yourself using Microsoft Office for most of your tasks and if you’re a gamer the decision is clear: the Athlon 64 is for you.
Izvor: AnandTech (1 - 2)
... umjesto ovog, mogli su napraviti Comet Lake refresh, s time da ostave orginalni Core i9 10C/20T model, samo s 11900K imenom, dok za Core i5 i i7 slože ove "nove" jezgre koje ima Rocket Lake i to je to. Nitko se ne bi bunil.
Staro 31.03.2021., 22:14   #27
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Staro 31.03.2021., 23:22   #28
Pa napisao sam gore: kad TechPowerUp napiše nešto tako za Intel i nVidiju kojima je poslovično naklonjen, onda znaš kako se usrala motka.
Ovo nije trebalo ni izaći. Mogli su komotno Comet Lake gurati još neko vrijeme do Alder Lakea. Žali bože resursa potrošenih na ovo. Još ovaj 11600K je skroz solidan proc, ali ovaj i9 jer stvarno Intelov Bulldozer.
I sad još masovno povlačenje 10th gen robe sa skladišta da bi se guralo i prodavalo ovo...
Ko misli 10th gen uzimati, neka krene što prije dok ih ima.
Staro 01.04.2021., 08:17   #29
popo1
Postovi: 228
Je,a devete još u trgovinama ko šalate
popo1 je offline   Reply With Quote
Staro 01.04.2021., 08:28   #30
Jedno su trgovine a drugo lageri dobavljača i distributera
