Staro 30.09.2020., 19:46   #8341
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Autor Sn4k3 Pregled postova
LOL e kad bi bilo tako
MojSkuter
Staro 30.09.2020., 19:56   #8342
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Kaže Tom iz The Moore Law is Dead da mu je ime kao 5000 serija potvrđeno, a ovih 5ghz nije - ne nužno kao neistina, nego da izvor ne zna (još) ili nije siguran
Staro 30.09.2020., 20:09   #8343
Postovi: 8,325
Lako za 5.0GHz, jer to je ionak nebitno u cijeloj priči. Zen 3 bude itekak OK ispal, a AMD sljedeća dva mjeseca ima poplavu novih proizvoda, kaj sa svoje strane, kaj pomoću konzola.
  • Zen 3 najava 08.10.
  • Zen 3 lansiranje 20. ili 27.10.?
  • RDNA 2 najava 28.10.
  • RDNA 2 lansiranje 09.11.?
  • Xbox Series S + X dostupnost 10.11.
  • PlayStation 5 dostupnost 12.11.
AMD Ryzen 5000 Zen 3 processor retail availability dates revealed
AMD's latest assault against Intel's Core family of desktop processor is just around the corner. The company has already revealed that its Zen 3 Vermeer-based Ryzen 5000 desktop processors will be unveiled on October 8th, but what wasn't stated is what the lag will be between the announcement and actual processor availability. Well, according to Yuri Bubliy, the man behind the comprehensive (and recently released) ClockTuner app for Zen 2 Ryzen processors, the big launch day will occur on October 20th. This is a little less than two weeks from the reveal date, and less than a month from today. So, enthusiasts out there that are eager to get their hands on AMD's latest processors won't be waiting long. ComputerBase has backed up that information by alleging that it has also heard of an October 20th launch; it also hedges its bets a bit by adding a second possibility of October 27th.
Izvor: HotHardware
Staro 30.09.2020., 20:23   #8344
Manuel Calavera
Postovi: 14,584
Ne vjerujem u tako rani launch. Početak ili sredina 11 mjeseca najranije, jer će MSI do početka 11 mjeseca izbaciti beta biose (i to za 500 čipsete). Još je pitanje gdje su 600 čipseti u čitavoj priči
Za RDNA2 je bila priča recenzije 09.11., a release 11.11. tako da se tu brojke donekle poklapaju
AMD je rekao da big navi na desktop pc dolazi prije konzola, a PS5 ima release 12.11 - 19.11. tako da se i tu poklapa
Zen3 je veći misterij, pogotovo 600 čipset. S jedne strane 3000 serija se ionako još prodaje kao alva, dok s druge strane nebi bilo loše da zajašu val novog high end gpu relesea pa da high end pc koji će se slagati do božića koristi zen3 kao top gaming cpu
Zadnje izmijenjeno od: Manuel Calavera. 30.09.2020. u 20:29.
Staro 30.09.2020., 20:26   #8345
Postovi: 8,325
Sve se poklapa. Kak god bilo, ali AMD namjerava utopiti Intel i nVidiju u čaši vode i to sve u mjesec i pol dana. Beta BIOS-i idu na sve strane za postojeće vlasnike i ploče.
600 serija čipseta se zasad uopće ne spominje, ide samo podrška za postojeće, a većina MBO ekipe već ima spremne osvježene (B400/X400) modele za Zen 3.
Staro 30.09.2020., 20:35   #8346
Dr. Strange
Datum registracije: Aug 2020
Postovi: 898
Sumnjam na 5 ghz, ali vrlo blizu 5 ghz je realno, nova arhitektura + poboljšani proizvodni proces.
Staro 30.09.2020., 20:42   #8347
Postovi: 8,325
Uglavnom, AMD u listopadu (29.10., plus/minus koji dan) ima službeno izvješće za treći kvartal fiskalne godine i možemo se kladiti da budu sve ovo pripremili na vrijeme.
Staro 30.09.2020., 22:08   #8348
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Nebi me zacudilo ni najmanje...
Sto se tice izlaska zen3, zar nije netko od AMD-ovog osoblja potvrdio na twitteru da ce novi Ryzeni izaci definitivno prije predstavljanja RDNA2... sto bi znacilo prije isteka 10.mj.
Pokusat cu iskopati post...
Staro 30.09.2020., 22:10   #8349
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
Ryzen 5000 Zen 3 5800X Benchmarks Leak - AMD Ryzen 4000 Performance
Još malo leakova i usporedbi 5800x sa 3800X...
https://twitter.com/AdoredTV/status/1310829819228286976
https://www.youtube.com/watch?v=rFSRrw6h4ps
Staro 30.09.2020., 22:13   #8350
Splitska Posla
Splitska Posla's Avatar
Datum registracije: Jul 2019
Postovi: 124
Ako će TDP bit 150W onda nemogu nadograditi kako sam mislio. A ni ostali koji imaju B450/X470 ploču. Viaremovi su preslabi za to. Osim ako bi uzeo ili već imam kućište s dva gornja ventilatora pa ih upregnit da hlade dole šta treba. Sa stajališta ne-gejmera, upgrade sa Zen 2 na Zen 3 je čisti snobizam ali upgrade sa Zen+ na Zen 3 je pos'o.
Splitska Posla je offline   Reply With Quote
Staro 01.10.2020., 00:37   #8351
Manuel Calavera
Postovi: 14,584
Taj ashes of singularity je čudan benchmark, a uvijek prvi leakovi na njemu, kao i retardiranom geekbenchu i Final Fantasy XVI, vjerojatno jednoj od najbeskorisnijoj igara za benchanje
Staro 01.10.2020., 06:56   #8352
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Potpis, evo onda jedan malo "korisniji" benchmark, CPU-Z
(navodni) R9 5900X vs R9 3900X, 25% veci single-core i 15% veci multi-core skor (thx to tviteras @9550pro)
Staro 01.10.2020., 10:01   #8353
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
Zar nije to usporedba moguceg 5900X vs 3700X ?
scarzz je offline   Reply With Quote
Staro 01.10.2020., 10:07   #8354
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Pitanje je zasto bi žurili s izbacivanjem Beta BIOS-a ako neće biti procesora, mogli bi čekati onda da izbace finalnu verziju ako će launch biti nekad u 11 mjesecu.
Tako da vjerujem da će launch biti oko 20-tog, taman prije recenzija RDNA2.
Staro 01.10.2020., 10:16   #8355
Sad je samo pitanje je li toliko bolji IPC ili procesor "bolji drži" viši takt tj da mu je "sustained" clock osjetno bolji od kraćih burstova na Zen2.
Ovo izgleda brutalno, ako je istinito. Izgleda kao već skok sa Zen2 na Zen3 nego što je bio sa Zen/+ na Zen2. Možda će se za ovo čudo isplatiti kupiti 500čipset ploča ako ne bude išao na 300čipset ploče. No vidim da je hype puuuuno manji nego lani kad je izlazio Zen2. nVidia navukla sve spotlightove na sebe i neka je. Za 7 dana info, a do kraja mjeseca sve saznamo.
Oko taktova opet oprez da nebi bilo kao i lani 4.7, 4.8 pa i 5GHz a na kraju škocke suze jer nitko nije čuo "dajte malo soli". Ne treba ni 4.8 ni 5.0, jer ako IPC recimo u najgorem slučaju 15% (navodno je više, ali recimo da je 15% nekakav realni scenarij) to znači da na recimo Zen3 na 4400MHz = Zen2 na 5100MHz koji nisu mogući ni u kojem normalnom scenariju sa Zen2 procesorima.
Loši neće biti sigurno. Samo je pitanje koliko će biti dobri, manje ili jače
Ono što me više zanima je što je sa pločama? Procesori se predstavljaju za 7 dana i launchaju za max 40 dana. Lani smo imali predstavljanje procesora krajem svibnja a launch 7.7., ali smo za X570 ploče znali već dobro debelo u ožujku ako se ne varam. Sad ni muu ni bee vezano za X670 ploče.
Moj gestimate je da će Zen3 Vermeer ići na postojeće X570 i B550 ploče uz BIOS koji je već vani (MSI). Ono što mi nije jasno je što je Zen3 Warhol? Ako mu launch bude 2021 kako je najavljeno, jel moguće da to bude neki die-shrink hibrid koji će biti neki AM4(+) procesor sa DDR4 i DDR5 podrškom na tom X670 čipsetu, a onda 2022 pravi AM5 socket, X770 čipset i Zen4.
Ili je Warhol u pipelineu samo kao odgovor na nešto Intelovo ako ovi izbace neki cpu nasviran na 5.5+GHz.
Kako god bilo, od 2017 na ovamo, stvarno je zanimljivo na području procesora. Čovjek ima izbor doslovno na eci peci pec, ovaj ili onaj i koji god kupi nema nekih velikih kompromisa kao recimo prije 2017 kad je izbor bio i više nego jasan. Dobro je sve.
Staro 01.10.2020., 10:35   #8356
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Autor scarzz Pregled postova
Da, na slici je usporedba sa 3700x, imas pravo, ali skor je dobar u usporedbi sa 3900x...
Wccf kaze 25% vise od R9 3900x i 27% od R7 3700x u single-core testu, dok je multi-core
75% veci od R7 3700x i 15% od R9 3900x...
Staro 01.10.2020., 10:46   #8357
Postovi: 8,325
Pričala je Baba u par navrata da Zen 3 ne bude običan refresh, već konkretan napredak u svakom pogledu u odnosu na Zen 2 i izgleda da nije lagala.
Staro 01.10.2020., 11:57   #8358
BusMaster
BusMaster's Avatar
Postovi: 343
ASUS Announces Refreshed AMD B450 Chipset Motherboards
Autor MadBoY Pregled postova
_____________________________________________________________
Upravo tako... evo ASUS izbacio novu gen. B450 (?) ploča, novi biosi i pojačani VRM-ovi, nisam vidio najave za B550, ali one uglavnom redom imaju dobre VRM-ove, evo link:
https://www.techpowerup.com/272816/a...t-motherboards
Staro 01.10.2020., 13:09   #8359
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
...Kako god bilo, od 2017 na ovamo, stvarno je zanimljivo na području procesora. Čovjek ima izbor doslovno na eci peci pec, ovaj ili onaj i koji god kupi nema nekih velikih kompromisa kao recimo prije 2017 kad je izbor bio i više nego jasan. Dobro je sve.
Definitivno nas ceka jako zanimljiv mjesec sto se tice cpu-a, gpu-a, konzola itd...
kazu da slika govori 1000 rijeci, pa evo jedna prikladna da ne pisem bezveze
Zadnje izmijenjeno od: Sn4k3. 01.10.2020. u 18:03.
Staro 01.10.2020., 19:03   #8360
Manuel Calavera
Postovi: 14,584
Usporedbe radi R9 3900X je od 2700X bio brži 8.4% u singlecore cpu-z (djeluje premalo za 15% IPC-a i većim singlecore taktom), te u multiju 66,7%.
Izvor mi je bio ovo https://www.guru3d.com/articles_page...review,11.html
EDIT ovdje dobijem 24.5% za singlecore (to je već realnije)
A ovaj 5900X je od 3700X 27% u singleu i 75% u multiju... Keep in mind da uspoređujem 12c24t nove generacije i 8c16t prošle, no samo je takva usporedba i moguća sa 2000 serijom.
Problem kod cpu-z je što se sa svakim updejtom rezultati mogu vidljivo promjeniti
Uglavnom po svoj prilici čeka nas skok najmanje kao sa zen+ na zen2
Dajte vi sa 2700X i 3900X izvrtite najnoviji cpu-z (sa stock postavkama)
Zadnje izmijenjeno od: Manuel Calavera. 01.10.2020. u 19:09.
Staro 01.10.2020., 20:48   #8361
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Moj 280hz monitor postaje nestrpljiv xD
MojSkuter
Staro 01.10.2020., 21:08   #8362
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 718
Oba stock, za 2700X samo iz arhive, a za 3900X sam ponovio danas
2700X _ 471,0 / 4961,0 (CPU-Z 1.85)
3900X _ 557,8 / 8430,6 (CPU-Z 1.89)
danas:
3900X _ 554,5 / 8397,5 (CPU-Z 1.89)
3900X _ 544,8 / 8329,5 (CPU-Z 1.93)
Prvo mjerenje za 3900X je zima, niža sobna temperatura i vjerojatno stariji Win10, 1903 ili 1909.
Render istog 3D modela u istom softveru:
2700X 272 sec.
3900X 152 sec.
Staro 01.10.2020., 21:11   #8363
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 918
Čeka se jedan 5900X. 🥰
Sent from my ONEPLUS A6013 using Tapatalk
Staro 01.10.2020., 21:13   #8364
Manuel Calavera
Postovi: 14,584
Autor Max Rockatansky Pregled postova
OK, iako nisu iste verzije programa (što može utjecati par %), znači +18% single, te 70% multi. Drži vodu (onaj singlecore od guru3d baš i ne, samo pitaj boga možda je do verzije). Onaj drugi link su najbolji primjerci (OC score table pretpostavljam, pa ni to nije mjerodavno)
Staro 01.10.2020., 21:22   #8365
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,156
Kolka je šansa da bu x370 ploče dobile support za 5000 seriju?
Staro 01.10.2020., 21:23   #8366
Manuel Calavera
Postovi: 14,584
Službeno - nikakva, neslužbeno - velika. Na kraju dana 400 čipseti koji će dobiti support su samo rebrand 300 čipseta. Kvaliteta ploče je invidialna odnosno ovisi od ploče do ploče, neovisno o čipsetu. Po meni tu nema nikakvih prepreka da dobije support kao 400 čipset - biosom sa selektivnom listom cpu supporta. Eventualno će trebati duže čekati.
Staro 01.10.2020., 21:59   #8367
Autor nub Pregled postova
Od 0 do 100%
Podrška 300 serije čipseta nužno ne ovisi od proizvođača ploče već i o AMDu.
Jer ako AMD baš ŽELI da mi sa prastarim pločama ne bootamo Zen3 procesore, AMD će to riješiti kroz PSP. I ako oni to riješe, MBO makeri se mogu j...
Ako AMD to ne zaključa kroz PSP, onda ovisi o MBO makeru tj onda može ali NE MORA izdati BIOS jer AMD "dozvoljava" support na 400 čipsetu dok za 300 postoji jasno NE.
E sad, dobra stvar je ta što imamo ljude koji će nam reći je li AMD zaključao to kroz PSP ili nije. Ako zaključaju, navuči će shitstorm na sebe što nikako ne žele. A ako ne zaključaju, vrući kesten prebacuju na MBO makere koji će se onda vaditi kako znaju.
Moje mišljenje oko Zen3 podrške na 300 pločama objektivno je malkac podijeljeno. Ima i ZA i PROTIV. Iako imam X370 i volio bi tinkerat još jednu generaciju Ryzena na njoj, postoje neke sumnje u dobrobit toga. Zašto?
Recimo da dobijemo isti tretman kao i 400 ekipa. Za 400 ploče je rečeno "dobit ćete 1 beta BIOS u kojem neće biti podrške za starije procesore i NEMA NATRAG sa njega (ne znam jel vredi za Flashback-button ploče)". I što ako taj 1 beta BIOS bude imao pizdarija kakve su imali prva 2-3 BIOSa za Zen2 na 300 pločama? Sumnjam da će itko u Assusu razvijati i debuggirati BIOS za skoro 4 godine staru ploču iako je bila flagship. Možda hoće a možda i neće.
Šta god da bilo od gorenavedenog, saznat ćemo brzo. Matematika je jednostavna. Ako netko želi Zen3, a nebu šljakalo na 300 ploči, bude kupil B550 ploču eto sad Tomahawkice za 1200 kn što je steal za takvu ploču. Jest da je škrta sa priključcima iza ali kome je dost tih 5 USB portova, mislim da nema kaj gledat dalje previše. No bumo se još malo strpili
Zadnje izmijenjeno od: Brko. 01.10.2020. u 22:05.
Staro 01.10.2020., 22:05   #8368
nub
PREMIUM
nub's Avatar
Postovi: 2,156
Pa mislim da je slična priča bila i za 3000 seriju, a sad vidim da imam full support kaj se tog tiče, maltene gore može 3950x ¯\_(ツ)_/¯
Staro 02.10.2020., 01:50   #8369
d0X
Kostolomac
d0X's Avatar
Postovi: 1,517
AFUDOS trpi svašta
PSN Steam
d0X je online   Reply With Quote
Staro 02.10.2020., 11:51   #8370
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,308
Od 0 do 100%
Vidio sam tvoje pitanje za Stilta vezano uz x570. Nego o kojoj tabli konkretno razmišljaš?
Inače i ja sam pomislio da će reći baš to što i je, x570 je bespotrebno rastrošan i zahtjevan chipset dok je B550 više nego dovoljan.
Meni je malo muka jer sam c6h uzeo prošle godine i trenutno sam jako zadovoljan sa njom, a opet me vuče da pređem na zen3, samo ovaj put nema žurbe. Opet razmišljam, pa koliko smisla ima preći na B550 i recimo 8/16 ili 12/24 zen3 kada za 1g izlazi DDR5 platforma. A Lisa se nameračila da svakom generacijom Zen-a da pošten skok, a ne ko plavci (i to me mami da bacim novčiće )....pa možda i ostanem na zen 2 do zen4 ili zen5. Ili puknut 3900x/xt kad mu padne cijena i bok. A što se tiče Flashbacka, koliko sam ja skužio, FB je u stanju doslovno pregaziti sve SVEEE, tako da mislim da ćemo moć šeteat napred-nazad kako nam paše.
Inače mi se moram priznat čak i sviđa dio gdje izgleda 6xx chipseta neće ni biti, skužili su valjda da ih je narod prokužio da je to sve (osim x570) jedan te isti chipset samo prepakiran....ili im je neisplativo i žele ''pomoć'' vendorima da rasprodaju silne zalihe.
Slobodno me dodajte na PSN
