Staro 04.12.2019., 11:44   #4501
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,081
Servisa kao takvoga kod nas nema kolko ja znam, Ezy je distributer pa njih eventualno moš pitat za info.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 04.12.2019., 11:45   #4502
Alfredo nr.3
Alfredo nr.3's Avatar
Lokacija: Požega
Postovi: 1,266
Napravio ali dobijem ovu poruku:
The listed warranty terms and conditions refer to end customer!
Channel requests / questions about the terms and warranty period, you could contact your Sales Representative.
Alfredo nr.3 je offline   Reply With Quote
Staro 04.12.2019., 11:49   #4503
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,396
to mi smrdi da vidi ime pod koje je kupljena pa te sad hebe jer si stavil svoje.
mozda kenjam, neznam. nisam nikad to delao jos. vidi sta ti ekipica iskusna ovdje kaze.
Staro 04.12.2019., 11:59   #4504
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Nemam pojma ali mislim da ništa od garancije. Traže mi račun a ja ga nemam. Da ga imam ne bi ih kontaktirao.
Ok, ovako mogu sam promjeniti pastu. Malo je izgubila na vrijednosti pri prodaji a prodavat ću je ako se ne priviknem na buku.
Kupit ću neku slabiju i tišu
Staro 04.12.2019., 12:02   #4505
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,699
Neznam kako tebi to dolazi.
Ja jučer uredno napravio prijavu na njihovj stranici i registrirao Grafu preko serijskog broja (isto se radi o rabljenoj kupnji, dakle ja sam drugi vlasnik). NAkon registracije proizvoda otišao u tab my products, i tamo lijepo piše da imam produljenjo jamstvo od 3 godine od dana kupnje. Doduše sam tu na poslu pa ne uspijem naći točne dane, jučer kada sam doma završio registraciju lijeo u zelenoj boji pisali još 280 dana preostale garancije
Staro 04.12.2019., 12:13   #4506
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Si uplodao račun?
Staro 04.12.2019., 12:23   #4507
thunder11
thunder11's Avatar
Postovi: 1,699
yep.
ALi i prije uploada računa mi je sve bilo vidljivo.
p.s. na samom računu piše da se garancija produljuje sa 2 na 3 godine pri registraciji proizvoda putem web stranice, te da se zadnja (treća) godina garancije isključivo uvaža direktno kod EVGA.
Zadnje izmijenjeno od: thunder11. 04.12.2019. u 12:32.
Staro 04.12.2019., 12:40   #4508
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Ako želiš vidjeti kako se grafa ponaša toplinski nađi neki review Gdje se vidi load, temp I fan speed/rpm.
Otvori kućište i digni ventove i ako tvoja ide na dosta veću temp ili rpm onda je vjerojatno do paste.
Oni testiraju obično na otvorenom pa to moraš uzeti u obzir.
Mene je MSI otpilio da je to normalno, nije mi se slala grafička u shop pa budi dugo vremena bez nje i onda mi je vrate da je uredno da grafička radi na 77c u igri, jer znate to je jaaaaka grafička.. vuče 300 w.... (je, ako je referentna, ne za trio x) pa sam rekao zahebi sve i promjenio pastu sa kryonautom. 20c pod istim uvjetima niže otišla (isti bench, fixnim rpm).
Staro 04.12.2019., 13:31   #4509
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Da, bit će da trebam promijeniti termalnu. Može bilo koja termalna? Ostalo mi je termalne od proca.
Uglavnom u recenziji ovakvi rezlultati:
https://www.legitreviews.com/evga-ge...view_183371/10
evga-gtx1080-temps-645x406
Moje:
Igrao sam quake 2 rtx, temp grafičke 64, hladnjak 75% vrti na nekih 2500.
ps. U Quake 2 RTX dobivam 9-10 fps
Zadnje izmijenjeno od: Alfredo nr.3. 04.12.2019. u 13:46.
Staro 04.12.2019., 17:38   #4510
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Nije li evga 10x0 serija imala onaj problem sa hlađenjem vrm-ova pa su prvo davi bios sa jačim fan profilom, a poslje slali ljudima free thermalpadove za vrm?
to bi objasnilo razliku u temp i rpm.
Staro 04.12.2019., 17:45   #4511
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Nemam pojma, imaš kakav savjet?
Staro 04.12.2019., 17:58   #4512
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
A jedino da naštelaš custom kao njihov dakle 75c 40% i tko jebe vrm.. tu je garancija ako ode...
Edit - S time da je njihov open bench pa stavi 50%.....
Staro 04.12.2019., 18:04   #4513
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Ipak ova kartica nije s greškom, sad mi je lakše.
Based on your Serial Number , we recommend the following:
Your EVGA Graphics Card already has the recommended VBIOS Update and Thermal Pads applied.
Staro 04.12.2019., 18:52   #4514
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Pa točno... i ima novi vbios sa agresivnom krivuljom venta. Na testu je stara verzija kojoj su vrm-ovi kuhali, ali je bila tiša.
Fulali su tu seriju jer su šparali..... i hotfix je da smanje vrm temperaturu je to da su prvo digli brzinu ventilatora, a onda još dodali i padove....
Staro 04.12.2019., 19:42   #4515
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Autor Alfa_R Pregled postova
Gdje se vidi temp vrm?
Staro 04.12.2019., 19:50   #4516
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,514
U ime oca sina i duha svetoga pa linkas gpu/z i onda pitas di se vidi ,i daj koristi afterburner i namjesti krivulju ventova 50c =20% itd..
To je polovna nemos ocekivat bolje od toga sta imas .
Staro 04.12.2019., 19:55   #4517
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Namjestio sam na 50 i dobro radi. Sad se jedva čuje. Max temp je 76.
Staro 04.12.2019., 19:58   #4518
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,514
Vrm temp ti je dolje skrolaj na gpu/z.I prodaj to uzmi 5700/xt.
Staro 04.12.2019., 20:20   #4519
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Ne znam za evgu, ali moje msijevke nisu imale vrm temp. To su testirali sa termalnom kamerom i ljudima se rušile kartice jer bi vrm zagrijao rame pa su te evge blackscreenale ili bi vrm explodirao...
Jednostavno je evga stavila premalo faza bez adekvatnog hlađenja i eto sranja.
Staro 04.12.2019., 20:24   #4520
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,514
Nemogu vjerovat da nemaju vrm(senzore) ocitavanje znaci grafe od tada skoro 5k kn.smh
Staro 04.12.2019., 20:29   #4521
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Nema ni EVGA vrm senzor zato GPU-Z ne pokazuje.
Staro 04.12.2019., 21:59   #4522
IHrvojeI
¯\_(ツ)_/¯
IHrvojeI's Avatar
Datum registracije: Sep 2016
Lokacija: Pag
Postovi: 1,254
...ili bi vrm explodirao...
Pred malo je nekom na forumu prdnula... Ne znam u kojoj temi
IHrvojeI je online   Reply With Quote
Staro 04.12.2019., 23:08   #4523
Moja je riknula EVGA Gaming FTW ali još 2017. Ne znam što se dogodilo. Došo doma, crna slika i ventovi na 100%. Rebootao komp, nije htjelo power up.
Pikno u drugi komp, ista stvar.
Dobio drugu koja eto već 2 godine i 2 mjeseca radi ko zmaj.
Ali ne znam od čega je umrla i što joj se dogodilo. VRMovi su bili normalni i niš nije smrdilo po paljevini.
Staro 06.12.2019., 12:54   #4524
tetak dudo
tetak dudo's Avatar
Lokacija: 45.594-16.217
Postovi: 239
ja sam još na 1070ti ftw2 icx mislio mjenjat ali ovo za što mi treba je i predobra
https://i.postimg.cc/x1QhTJBM/Snimka-zaslona-19.png
Dell OptiPlex Micro
ThinkPad T470
tetak dudo je offline   Reply With Quote
Staro 15.12.2019., 07:58   #4525
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Koristi li se ista termalna pasta za cpu i gpu?
Imam Manhatten CPU thermal paste i ShinLtsuMicroSi termalnu pastu koje sam koristio na procesorima.
Htio bih promjeniti termalnu na grafičkoj, mogu li koristiti jednu od njih dvije?
Staro 15.12.2019., 10:18   #4526
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,616
Možeš
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 15.12.2019., 10:18   #4527
Immortalis
Slobodan leni seronja
Immortalis's Avatar
Postovi: 852
Slobodno.
Ja sam mx-4 koristio i za cpu i gpu
Staro 15.12.2019., 14:48   #4528
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Super, hvala no sad mi je malo od pomoći.
Naime, danas sam prebacivao komponente u drugi kučište, sve spojio i nema slike. Pale se ventovi, slike nema. Izgleda da je grafička riknula. Ne znam što bi još moglo biti. Na monitor piše No signal. Probao drugi kabel sve isto.
Nisam ništa radio samo prebacio iz jednog kučišta u drugo. Ne razumijem.
Ima li netko neku ideju?
Zadnje izmijenjeno od: Alfredo nr.3. 15.12.2019. u 14:58.
Staro 15.12.2019., 15:26   #4529
Alfredo nr.3
Lokacija: Požega
Postovi: 1,266
Nisam siguran da je grafa. Izvadio sam Ram i on dalje vrti, nema nikakvih zvučnih signala. Sve upaljeno i samo se vrte ventilatori.
Ne razumijem. Što ne bi trebalo da bipa kad nema rama?
Staro 15.12.2019., 15:41   #4530
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,616
A jesi spojio speaker od drugog kućišta na matičnu? Dal uopće kućište ima speaker? Ova nova kućišta većinom nemaju ugrađenih speakera nego moraš naknadno ubaciti speaker direktno na ploču koji je na 2 kratke žice
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
