Staro 28.10.2018., 13:08   #211
Autor trpi Pregled postova
evo jos jedna gtx1060 3gb, dakle;
ryzen 7 1700 @ 3.7ghz
gtx1060 3gb, 2012mhz core / 4600mhz memory
score = 8953
Kako loše, ni 9000... pffff.
Staro 28.10.2018., 18:03   #212
trpi
dobro evo
Staro 29.10.2018., 19:33   #213
Nikox
Nikox's Avatar
Datum registracije: Aug 2017
Postovi: 1,228
Evo da malo poboljšam prosjek
Nikox je online   Reply With Quote
Staro 29.10.2018., 22:41   #214
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Evo nakon clockanja sa afterburnerom, a ne aorus softwareom i updateanjem drivera, score se jos malo odnosno dobro popravio...
ID:	20372   Click image for larger version
ID:	20373   Click image for larger version
Zadnje izmijenjeno od: zwer54. 30.10.2018. u 20:59.
Staro 22.12.2018., 12:59   #215
Prki
Prki's Avatar
Postovi: 1,315
Kužim da nije loše za 11g. staru kantu
Staro 22.12.2018., 13:28   #216
Nikox
Nikox's Avatar
Postovi: 1,228
Kanta ti je stara ali grafa ti je nova 2g ,a kod ovog testa ti je naj bitnija grafa tako da stavi grafu od prije 11g pa da vidimo
Staro 23.12.2018., 19:18   #217
axo
Datum registracije: Sep 2017
Postovi: 1,428
Taj program jede fps ko blesav....
Staro 28.12.2018., 16:36   #218
Deyo238
Grazie Michael
Deyo238's Avatar
Lokacija: Ogulin
Postovi: 360
i7 4790k @4.6GHz, 16GB RAM
Gigabyte RTX2070
1080p medium i 4k optimized, malo je 1080p slab ili mi se čini?
ID:	20652   Click image for larger version
CPU: Intel Core i7 3930k C2 Sandy Bridge E 3200MHz @ 4500MHz (100x45 @ 1.288V) HT enabled
CLR: Corsair H100x
MBO: ASUS RAMPAGE IV FORMULA
RAM: Crucial DDR3-1600 2x8GB + 2x4GB (24GB) @ 1600MHz - 10-11-10-24-1T @ 1.535V
VGA: KFA2 GeForce GTX1070 8GB EXOC
HDD: ADATA SUV800 256GB ++ WD BLUE WD30EZRZ 3TB ++ WD Blue WD6400AAKS 640GB
PSU: Corsair CS550M 550W 80+ Gold Modular
BOX: Jonsbo W2
LCD: DELL P2417H 24" LED @ 1920x1080
OS1: MICROSOFT Windows 10 Pro N x64
GSM: iPhone 11 black 4/64GB
ROM: latest iOS
Deyo238 je offline   Reply With Quote
Staro 28.12.2018., 19:44   #219
Pred godinu dana sam vrtio taj benč.
Staro 06.02.2019., 19:13   #220
windfucker
Evo i mene sa prinovom, stara dobra 1070 Phoenix-ica otišla u mirovinu...
I, prvo se baca pod Afterburner, pa odma' zatim benč na brzaka, tradicija je tradicija, dašta!
Boosta preko 2k za gpu (digao slider za 270 MHz odokativno) bez diranja napona, još samo pomakao slider na max. za power i temp. limit i dodao 50MHz za memu...
Prošlo benč, za ostalo bog zna sada i ovako...
E , da pa koja je to sad fora sa auto OC u MSI AB?
Vidim opciju, idem kliknuti (čoban ) i krene ona poruka o traženju OC vrijednosti...automacki?!
E, jebeš ga, u šta se oc pretvara...još samo čekam da sa slijedećom verzijom drivera komp sam zaigra umjesto mene...
Staro 06.02.2019., 19:24   #221
Da ti nije malo slab proc za tu grafu ? Ne za benč nego za gaming općenito?
Sent from Usreo Mobara
Staro 06.02.2019., 19:31   #222
windfucker
E, Druže tu sada dolazimo do...mađije.
'Vako je za 24/7 a može Miško i nešto brže, kada mu povežem oči (viđu sig), tako da mi se čini da je još za sada potaman
Imamo dogovor: on neće da crkne, a ja neću da ga prodam...p!zda 'ko izda
Staro 06.02.2019., 19:35   #223
Ohoho, povlačim sve rečeno svaka čast. Mađija.
Do ploče ili do proca?
Staro 06.02.2019., 19:41   #224
windfucker
A to je onaj non-k bios od Asrock-a...malo podjebavaju Intel, pa su i u novijim revizijama ostavili tu mogućnost, samo malo zakopali u postavkama (z170 ext4)...divni neki ljudi
Intel je već dvaput moju personu mučki pokušao sabotirati kroz w10 patcheve, no nisu uspjeli
Do proca je, stvarno je golden sample, na hwbot sam tada imao 2. rezultat u svijetu (a čisto sumnjam da su i ostali OC-ali na zraku, no ovaj je to mogao).
Dalje nisam išao, žao mi bilo ubiti ovakav proc za ništa.
Zadnje izmijenjeno od: windfucker. 06.02.2019. u 19:58. Razlog: zabunijo se za matičnu :D
Staro 06.02.2019., 19:44   #225
Imaš veći takt nego mnogi sa 6600K koji je bio osjetno skuplji.
Sretno dalje i neka poživi
Staro 23.03.2019., 21:29   #226
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
evo još nekoliko, grafe stock..
XFX RX480 8gb GTS OC
MSI RX580 4gb Armor OC
GB GTX 1060 3gb windforce OC
GB GTX 1060 6gb G1 OC
nisam već dugo
ID:	20960   Click image for larger version
ID:	20961   Click image for larger version
ID:	20962   Click image for larger version
MojSkuter
Zadnje izmijenjeno od: Eladio. 23.03.2019. u 21:35.
Staro 08.04.2019., 15:39   #227
suedamA obmaR
Game, PC ,motobikes, bike
suedamA obmaR's Avatar
Datum registracije: Jan 2010
Lokacija: Sibenik
Postovi: 776
APU 2200g stock i oc 1650mhz
[IMG]superposition-stock
dice roller
[/IMG]
[IMG]superposition1650
dice roller
[/IMG]
suedamA obmaR je offline   Reply With Quote
Staro 23.04.2019., 10:23   #228
Lynnfield
Zmaj od Bosne
Lynnfield's Avatar
Datum registracije: Dec 2011
Postovi: 218
Superposition sa RTX 2080 TI
RIP Šaban (21.6.2016)
Staro 24.04.2019., 21:14   #229
Iluzionist
Iluzionist's Avatar
Datum registracije: Apr 2019
Postovi: 415
...slika sve govori
Staro 21.07.2019., 20:22   #230
tetak dudo
tetak dudo's Avatar
Lokacija: 45.594-16.217
Postovi: 239
da i ja pokažem, zlatna sredina
tetak dudo je offline   Reply With Quote
Staro 21.07.2019., 20:26   #231
tetak dudo
tetak dudo's Avatar
Postovi: 239
a ovo je na 4K
Staro 15.08.2019., 22:57   #232
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Evo default i 4K test.
ID:	21423   Click image for larger version
Staro 13.12.2019., 18:08   #233
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
Autor Eladio Pregled postova
nisam već dugo
evo mene opet, ovoga puta GB 1070 G1
MojSkuter
Staro 13.12.2019., 19:16   #234
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Evo identičan setup
Staro 06.03.2020., 22:14   #235
FT1000
Datum registracije: Dec 2017
Postovi: 102
kompjuterčić za igrice
FT1000 je offline   Reply With Quote
Staro 08.03.2020., 02:40   #236
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Evo jedan slican setup, a slican je i score...
Staro 08.03.2020., 12:13   #237
FT1000
Postovi: 102
Navukao sam do 28500, to je vec zona kad cpu, cak i najmocniji gaming proc 9900k ulazi u bn zonu u pojedinim scenama se vidi pad gpu usagea
Staro 08.03.2020., 15:21   #238
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor FT1000 Pregled postova
Na kolko drzis cpu i na kolko si ga za bench dizao?
Staro 08.03.2020., 16:29   #239
FT1000
Postovi: 102
Autor zwer54 Pregled postova
evo sa CPU na 5Ghz, inače ga držim stock
grafa se vidi OC
Staro 08.03.2020., 18:22   #240
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
grafa se vidi OC
Ovo je ogroman oc... Ja sam gpu digao za 115mhz i memoriju za 250... Cpu drzim na 4.9 sve jezgre...
