Datum registracije: Oct 2011
Lokacija: Vtc
Postovi: 25
Fritzbox 7490 VDSL2 T-HT
Flat rate or volume rate: the FRITZ!Box is always connected with the Internet. This setting is not suitable for Internet rates billed on the basis of connection time. -->
The Internet connection check failed. The Internet service provider is not responding to PPPoE packets. Repeat the test at a later point in time. PPPoE error: Timeout. ( This status message informs you that the DSL connection was cleared for the reason displayed. If the error occurs again, contact your DSL provider. U prilogu dostavljam stanje na ADSL2+ i kasnije za VDS2, Molim za mišljenje i objašnjenje problema. Zahvaljujem Poštovani,
imam Fritzbox 7490 na T-HT infrastrukturi. Do sada sam imao ADSL2+ na brzini 10 Mbit/s i to je radilo relativno stabilno. Prije nekoliko dana su mi omogučili Turbo20 na VDSL2. Dobio sam brzinu od 20 Mbit/s i to za sada radi dobro (nisam imao prilike dulje testirati), ali uz velike FEC i druge errore čak do 10-ak milijuna greški. Ovo nakon uvođenja VDSL2 se odnosi na ZTE router koji sam stavio kod promjene. Vračanjem fritzboxa internet ne radi. Prijavljuje mi slijedeče greške: " Flat rate or volume rate: the FRITZ!Box is always connected with the Internet. This setting is not suitable for Internet rates billed on the basis of connection time. The Internet connection check failed. The Internet service provider is not responding to PPPoE packets. Repeat the test at a later point in time. PPPoE error: Timeout. ( This status message informs you that the DSL connection was cleared for the reason displayed. If the error occurs again, contact your DSL provider. U prilogu dostavljam stanje na ADSL2+ i kasnije za VDS2, Molim za mišljenje i objašnjenje problema. Zahvaljujem |
Datum registracije: Feb 2010
Lokacija: Ploče
Postovi: 1,183
Normalno da neće raditi jer sad od T-com centrale ide drugačija modulacija tj. VDSL2 umjesto stare ADSL2 na koju je podešen Fritzbox. Pri tako velikoj "Line Attenuation 59/27 dB " radi sad ZTE sasvim solidno ali bi ipak provjerio spoj od modema na tel. utičnicu da nije negdje oksidiralo... |
Postovi: 23,503
Jeli taj Fritz ima VDSL modem i Vlan tagiranje ? Oboje je nužno i ispravno podešeno da bi "stvar" proradila. U susjednim temama imaš / potraži parametre. Slijedeći problem će ti biti podešavanje VoIp - a. Ako ti je Fritz drag tj. želiš da on bude gl. za Internet onda na ZTE ostavi VoIp i osposobi Bridge / PPPoE Pass-Trough za Internet a Fritza konfiguriraj kao WAN router preko jednog Lan porta. |
Lokacija: Vtc
Postovi: 25
Koliko sam shvatio fritzbox 7490 international je najkompletniji što se tiće različitih VDSL2 postavki u Europi prilagođen većini providera pa ne vidim razlog zašto ne radi sa T-HT vds2. Prije prebacivanja na VDS2 router je uredno radio na ADSL2+ postavkama. Nakon restarta kod prelaska na VDSL2 izostala je konekcija za internet. Postavke su iste kao i ranije. Voip uredno radi. Ne želim napustiti fritzbox 7490 koji je po mnogim recenzijama u vrhu, a po meni daleko bolji od ZTE-a. Zadnje izmijenjeno od: Nikky. 26.05.2016. u 13:42. |
Postovi: 23,503
E pa nisu iste postavke ako ne računaš user / pass za Internet konekciju. Gore sam spomenio, treba prebaciti na Vdsl sa odgovarajućim profilom (vidi u ZTE), potom treba riješiti Vlan tagiranje ... tek onda bi moglo proraditi. |
Datum registracije: Apr 2015
Postovi: 1,699
po mom iskustvu fritz 7490 kad mu jednom pospremiš postavke hoće to zapamtiti pa ti je moj savjet prvo ga vrati na tvorničke postavkepa se prvo probaj spojiti direktno na utičnicu pa vidi,voip bi isto trebao ići preko vdsl obnovi firmware 6.30 internacional ti je zadnji ili 6.55 njemački imaš friz recover firmware 6.30 en-internacional friz recover firmware 6.50 de njemački iščupaš friza iz struje i pokreneš tool i kad ti kaže priključi priključiš i pričekaš dok završi da bi prelazio sa internacionalnog na njemački ili obrnuto moraš prvo brending promjeniti. neznam dali je isto na vdslu vlan 100 kao na optici ali bi ti trebao biti ispod mjesta gdje upisuješ korisničko ime i pass preklopni izbornik plavim slovima kad stisneš to trebalo bi ti se pojaviti use vlan i upiši 100
- - ![]() Zadnje izmijenjeno od: skalar. 26.05.2016. u 13:10. |
#7 | ||
Lokacija: Vtc
Postovi: 25
Hvala Citiraj:
Hvala. Zadnje izmijenjeno od: Nikky. 26.05.2016. u 13:42. |
#8 | |
Postovi: 1,699
Citiraj: Autor .Delboy ![]() Za t-com VDSL idu sljedeći vlanovi na korisničkoj strani, ne koristi se vpi/vci: 1203 Internet 1500 MaxTv 1405 VoIp 1300 Acs - nadzor modema 1400 Netphone za poslovne korisnike @nikky ovaj info bi trebalo negdje ubaciti jer se već ponavljalo ovo pitanj "ne koristiti wizard "
- - ![]() Zadnje izmijenjeno od: skalar. 26.05.2016. u 13:23. |
Postovi: 23,503
@skalar Imaš pravo, kasnije smislim gdje ću ubaciti, vjerojatno gore u neki Sticky. @zeljko2 Evo te kolega uputio u pravom smjeru. |
Lokacija: Vtc
Postovi: 25
"skalar" prema tvojem uputstvu za VAN ID šifre za VDSL2 konekciju uspio sam ostvariti vezu. VPI/VCI sam stavio na auto detect, a pod VAN ID sam stavio za internet 1203. Nakon restarta je veza proradila. Hvala Tebi i svima koji su pomogli savjetima. Pozdrav. |
Lokacija: Vtc
Postovi: 25
Opet problemi! Kada uključim VAN za internet sa tagom 1203, a voip sa tagom 1405 ne radi ništa. Moram naizmjenično jedno od dvije funkcije imati isključeno da bi ono drugo radilo. Ima li tko kakovu ideju. |
Postovi: 23,503
Uređaj mora imati takvu pamet da omogućuje više različitih istovremenih konekcija i da je na svakoj drugačiji Vlan tagiranje. |
#13 | |
Postovi: 1,699
ali 7490 je novi pa ... vlan tagganja po portovima nema,alternativni firrmware za friz nepostoji, imaš samo ko addonove za firmware,dodatni problem je da u zemljama iz kojih redovito dolaze neka rešenja fritz voip +internet+ iptv radi bez greške i predkonfiguriran je u firmwareu. eventualno može probati factory reset wizard odmah prekini nakon toga,pa prvo voip iskonfigurirati i kad se on spoji tek onda podatke za internet, znaći ne dirati ništa s internetom dok se voip ne spoji i dok nedodjeliš broj tel portu,kad to proradi onda tek internet konekciju ,takve su upute na netu. kod mene neprolazi al sam na optici možda na vdsl-u prođe,ak ne prođe možeš ga koristi jedino kao čisti ruter nažalost
- - ![]() Zadnje izmijenjeno od: skalar. 28.05.2016. u 15:32. |
#14 | |
Lokacija: Vtc
Postovi: 25
Zahvaljujem |
Postovi: 1,699
#17 |
Postovi: 1,699
spikao sam ja sa tehničarom rutere prijavljuju prilikom izmjene na serijski broj ne macom i preko acs se ruter puni na serijski broj, sad dal je ili nije uglavnom znaš postupak ak se ponovi.
#19 |
Postovi: 1,699
#20 | |
Datum registracije: Aug 2013
Postovi: 4,316
"ACS Username" u kojem je upisan serijski broj routera: 2C957F-ZXDSL931VII-ZTEE40NE6HXXXYY i "ACS Password". S tim upisanim podacima router se sam spaja i povlaci defoltne postavke tamo upisane za doticnu liniju/tel. broj. Znam to jer na istoj ADSL liniji koristim tri razlicita routera i svi se uredno spajaju na ACS i povlace postavke, bez potrebe za nekom intervencijom SZK/tehnicara. Isto vjerojatno vrijedi i za ostale vrete prikljucaka... |
#21 |
Datum registracije: Jul 2013
Lokacija: Tenja(Osijek)
Postovi: 1,125
E ovo je zanimljivo. Prošireni stock firmware http://freetz.org/ Koliko vidim hrpa stvari je dodana,a ono što u ostatku svijeta ne odgovara je maknuti ili patchano da radi. Evo i popis podržanih uređaja. http://freetz.org/browser/trunk/FIRMWARES Šteta što nemam Fritza,inače bi odmah probao. Jedino što nema gotovih već se builda iz stocka na Linuxu. |
