Staro 29.12.2015., 11:10   #6421
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,044
nakon 2-3 puta ih stisneš da to krpanje postaje besmisleno lagano i da bi bio red da odobre novi uređaj.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 12.01.2016., 20:18   #6422
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Zagreb / Maksimir
Postovi: 4,003
Postao sam u ISP/tcom temi al budem i ovdje.
Jel zna netko pod kojim uvjetima mogu jednostrano raskinut ugovor s tcomom? Naime, nekakva grupna smetnja na mom području, već 8 dana nemam ni telefon ni net ni maxtv. I ne znaju rec kad će kvar bit otklonjen, samo mole za strpljenje. Ja strpljenja više nemam.
Thx
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 13.01.2016., 08:52   #6423
xXTheLuka1998xX
xXTheLuka1998xX's Avatar
Datum registracije: Feb 2015
Postovi: 353
Pozdrav,neznam dali sam pogodio temu,ispricavam se ako sam falio ja imam ogroman problem s hrvatskim telekomom d.d ,naime kupio sam kod njih 26.5 mobitel,išao je 3 puta na servis,nisu mi htjeli odobriti novi uređaj,zvao sam inspekciju i dobio sam spor no sada imam problema s povratom novca,mobitel sam im uredno poslao na njihovo skladište a gospoda sada kažu pošto je kupljen mobitel na rate možemo vam samo stornirati i vratiti preostali neplaćeni iznos ili ga umanjit ko je sad tu lud?!
xXTheLuka1998xX je offline   Reply With Quote
Staro 13.01.2016., 16:43   #6424
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,823
Autor xXTheLuka1998xX Pregled postova
Mislim da te žestoko prcaju. Pare moraju vratiti - puni iznos.
Staro 15.01.2016., 13:22   #6425
logitek
logitek's Avatar
Datum registracije: Nov 2010
Postovi: 30
Pozdrav,
isprike ako sam posta u krivu temu. Naime posjedujem Saphirre r9 290 referenti model te mi je temp u idlu 70'C kad komp duže radi. Probao sam istu takvu od kolege stavit kod sebe u kućište i na njegovoj bude oko 43'C.
ASBIS mi govori da je to normalno te unutar specifikacija proizvođača, ali meni nekako razlika u skoro 30'C nije baš normalna.
Inače grafička radi ok, nema grešaka niti problema osim te temo u idllu.
Preporuke, savjet?
logitek je offline   Reply With Quote
Staro 15.01.2016., 13:47   #6426
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
ciscenje graficke+stavljanje nove termopaste i vizualni pregled koliko dobro lezi hladna povrsina na jezgru graficke
scarzz je online   Reply With Quote
Staro 15.01.2016., 13:52   #6427
logitek
logitek's Avatar
Postovi: 30
to bi mi onda trebali u servisu napraviti? al eto samo su mi odgovorili da je sve ok
edit: grafička je kod njih od tjedan dana..
Zadnje izmijenjeno od: logitek. 15.01.2016. u 14:07.
Staro 15.01.2016., 14:39   #6428
scarzz
scarzz's Avatar
Postovi: 414
pa trebali bi da, 70c u idle nije nikako normalno.To je temp za full load
ocisti i zamijeni pastu sam ako ne gubis garanciju, nije mudro slovo
Staro 15.01.2016., 18:56   #6429
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor logitek Pregled postova
Pozdrav,
Preporuke, savjet?
Koliko grafa ide u full loadu? igrama, testovima?
70C je sasvim normalno jer te grafe neke idu i preko 80C...
Ali idle mora biti niži...
Staro 15.01.2016., 19:12   #6430
logitek
logitek's Avatar
Postovi: 30
u full loadu ide do 90'C, al to je normalno kolko sam citao. Podignut ću je sa servisa pa provjerit, navodno su očistili, zamjenili pastu.
Al ak će opet bit do 70'C u idlu onda nebu dobro.
Imam jos mjesec dana garancije pa nebi htio da me preveslaju sam tak
Staro 15.01.2016., 21:34   #6431
partwish
Creeper
Datum registracije: May 2013
Postovi: 2,211
Odgovor ministarstva na upit o obveznom jamstvu od 24mj. Maknuo sam osobne podatke.
Staro 15.01.2016., 22:56   #6432
wooden
Datum registracije: Dec 2013
Lokacija: hr
Postovi: 804
Već je sličan odgovor ministarstva postavljen ovdje na forum mnogo puta (dvije stranice unazad).
Ali eto, svejedno svako malo netko piše dezinformacije.
wooden je offline   Reply With Quote
Staro 23.01.2016., 18:31   #6433
AbAdd0n
AbAdd0n's Avatar
Postovi: 246
Autor AbAdd0n Pregled postova
Frendu otišla grafa, garancija je do 23.12.2015. ....
Evo prošlo je 30 dana još mi nisu javili ništa konstruktivno iz servisa iako sam slao brdo mailova. Rok je 45 dana je li tako i tek onda mogu nešto poduzeti?
test konfa
AbAdd0n je offline   Reply With Quote
Staro 23.01.2016., 18:50   #6434
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
A šta su ti uopce rekli?
Staro 23.01.2016., 18:56   #6435
AbAdd0n
AbAdd0n's Avatar
Postovi: 246
Zadnje je da su poslali upit u ovlašteni servis o stanju garancije ali da nisu dobili odgovor. To sam dobio 19.1,
12.1 da je testiranje završeno te da čekaju riješenu reklamaciju iz servisa,
8.1 da je testiranje završeno te da čekaju obavijest o načinu rješavanju garancije.
Meni se sve to čini kao template odgovori kada nemaju pojma što se događa ili ih nije briga.
test konfa
Zadnje izmijenjeno od: AbAdd0n. 23.01.2016. u 19:21. Razlog: nadopuna
Staro 23.01.2016., 18:58   #6436
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Reci da upit prosljede telefonom Dobiti će odgovor odmah
Tiskaj malo, 30 dana je već svakako previše... i ne moraš čekati 45 dana
Staro 09.02.2016., 18:42   #6437
Night bird
Lokacija: Varazdin
Postovi: 137
Pozdrav u Iponu sam naručio matičnu i grafičku. Paket stiže 28.1. s matičnom je sve u redu a grafička kartica je vidno korištena, ima prašine po ventilatorima i manja fizička oštečenja. Isti dan sam im poslao mail na koji dobivam odgovor 29.1. da im pošaljem slike. Nakon što sam im poslao slike slijedi ignoriranje. Nakon čega se opet javljam i dobivam odgovor da mi je najbolje otkazati ugovor po vlastitom trošku .Overseasom je taj iznos 200kn, znači samo za grafičku i to je cijena za jeftiniju soluciju tj. duže trajanje puta. Da ne spominjem da je preduvjet otkazivanja ugovora ne korišten proizvod a ja sam dobio korištenu grafičku. Nakon čega sam se žalio na skoro sve njihove mail adrese(osim rumunjskih domena) i smradovi me dalje ignoriraju. Znači i da šaljem na vlastiti trošak, riskiram plačanje poštarine cca 250kn (50 i nešto sam platio kada su oni slali) za grafičku koju mi možda natrag uvale. Da sam siguran da će mi vratit novce ili poslat novu grafičku, bacio bih tih dodatnih 200kn za poštarinu. Više stvarno neznam što da radim pa molim za bilo kakav savjet pošto mi rok za otkazivanje ugovora uskoro ističe.
Night bird je offline   Reply With Quote
Staro 09.02.2016., 18:52   #6438
nino
nino's Avatar
Postovi: 12,613
Ama kakav ti savjet zelis, a da nisi vec opisao u postu? Otkazujes ugovor, saljes o svom trosku i nakon primitka robe, oni ti uplacuju sredstva.
Ili se pozali madjarskom uredu/inspektoratu za zastitu potrosaca.
Neznam kakav drugi savjet trazis?
Staro 09.02.2016., 19:33   #6439
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Evo ja ću dati savjet
Nemoj slati Overseasom, jer ti je najskuplje... šalji hpexpresom
I naravno, sretno i javi kako je prošlo p.s. koliko love si ušparao u odnosu na HR trgovine?
Staro 09.02.2016., 19:38   #6440
panasonic
Datum registracije: Jan 2014
Lokacija: EU
Postovi: 1,215
Autor Night bird Pregled postova
Jel možeš postaviti te slike ovdje?
panasonic je offline   Reply With Quote
Staro 09.02.2016., 19:58   #6441
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,278
može i sjest u auto, otići tamo i tražiti popust u cijeni putnih troškova uz potencijalni međunarodni skandal
MojSkuter
Staro 09.02.2016., 20:07   #6442
Alfa_R
Alfa_R's Avatar
Postovi: 2,898
Svakako ih blatiti svugdje gdje je moguće. Da da mi hr trgovina to napravi i onda još ne preuzme sve troškove nevezano o zakonu na sebe - gledao bi da im nanesem štetu na sve moguće legalne načine.
Uvijek kad kupujem u napomenu ide - isključivo tvornički zapakirani i neotvoreni proizvod. Zadnji sam dobio je bio sa razbijenim sealom pa sam skoro sa povećalom tražio tragove korištenja.
Ako me probaju zajebati očekujem u najmanju ruku i da pokriju sve troškove uključujući i povrat robe i ispriku.
Staro 09.02.2016., 20:41   #6443
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Autor FRipper Pregled postova
Ovo je zapravo najjace pitanje.
Programer
Staro 09.02.2016., 20:56   #6444
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,946
Autor Bubba Pregled postova
I uvik je isti odgovor na to pitanje Meni svaka eventulana reklamacija ili bilo kakav problem kad kupujen van Splita je trošak koji me skoro pa izjednači sa ST cijenom, ali opet nedan gušta Linksa (ili kome već) pa nešto šta mogu uzet za 650 sa dostavon da plaćan ovdje 770 recimo.
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 09.02.2016., 21:25   #6445
Night bird
Lokacija: Varazdin
Postovi: 137
Hvala, oko 200kn sad su cjene nešto drugačije, u svoju obranu čitao sam da su ljudi uzimali cijele konfe bez problema. A điberio sam iz razloga jer sam prvo imao u planu kupit rabljenu amd grafičku.
Autor panasonic Pregled postova
1 2 Ove bijele mrlje su od pašine i još je jedan kabel lagano zagreban al to nisam slikao
Autor Eladio Pregled postova
Svašta mi je več prošlo kroz glavu
Autor Alfa_R Pregled postova
Prijavio sam ih nabavi ali nabava nemože ništa konkretnije učiniti sve dok se ne javi više ljudi. Odgovorili su opsežnim mailom te su se zahvalili. Napisao sam tu na forumu i planiram se registrirati na bugov forum te i tamo podijelit moje iskustvo.
Takođe to očekujem od trgovine i to sam im sve napisao. Bila bi druga priča da su mi bliže ali ni financijski ni vremenski mi se ne isplati ići do njih.
Staro 09.02.2016., 21:54   #6446
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,480
Osim znakova korištenja (skoro nevidljiva prašina i malo izgrebani ventilator) inače je grafička ispravna?
Vjerojatno im je netko unutar 2 tjedna vratio tu grafičku ili zamjenio za drugu i ti si potrefio na tu. Ali iskreno, ja ne vidim toliku potrebu za histerijom. Ovo izgrebano se možda moglo desiti u transportu ako se struže s donje strane u nešto a prašina je mogla biti dio "testiranja", tako nešto ti i oni mogu odgovoriti. Ja bi tražio 100kn kupon ili da mi pošalju nešto besplatno. Lakše i tebi i njima.
Da ti je došla neispravna i da ne žele prihvatiti servis ili popraviti to bi već bilo ozbiljnije.
Zadnje izmijenjeno od: Ag008. 09.02.2016. u 22:07.
Staro 09.02.2016., 22:17   #6447
Night bird
Lokacija: Varazdin
Postovi: 137
Autor Ag008 Pregled postova
Vjerojatno im je netko unutar 2 tjedna vratio tu grafičku ili zamjenio za drugu i ti si potrefio na tu. Ali iskreno, ja ne vidim toliku potrebu za histerijom. Ovo izgrebano se možda moglo desiti u transportu ako se struže s donje strane u nešto a prašina je mogla biti dio "testiranja", tako nešto ti i oni mogu odgovoriti. Ja bi tražio 100$ kupon ili da mi pošalju nešto besplatno. Lakše i tebi i njima.
Slike su jpeg, kad potegneš prstom ostane prašine na njemu. Roba se može vračat u roku od 2 tj. kao ne korištena... U transportu da struže o spužvu ili foliju? Pa ako je test verzija neka onda bude test cijena. Za cijenu od 1750 kn očekujem da mi smrdi po Kini a ne da je izgrebana i prašnjava. Kakav kupon, od njih više nebi kupio ni cd. Nemogu se ništa dogovorit kad ne odgovaraju na mail.
Staro 09.02.2016., 22:22   #6448
nex
nex's Avatar
Lokacija: .
Postovi: 526
Ti bi se valjda dao i naguziti bez vazelina za bon od 100 kuna.
nex je offline   Reply With Quote
Staro 09.02.2016., 23:06   #6449
Ag008
Ag008's Avatar
Postovi: 7,480
Svatko bi novo i ispravno trebao dobiti.
Nego vidim gnjavažu trgovca (koji god bio) u pravilu bi u ovakvom slučaju trebao platiti poštarinu od tebe do njega, zamjeniti i poslati novo. Mislio sam da bi rađe uzeo neku stvar od 100kn pa je njima možda lakše a i ti zadovoljan.
Koliko sam vidio u njihovim uvjetima imaju nekog "garancionog kurira" gdje bi oni trebali doći po proizvod te ako se ustanovi da je ipak bio ispravan tada plaćaš 45kn.
Svakako ti trebaju odgovoriti da se to riješi.
Meni je jedan poznanik isto naručio grafičku preko ipona pa mu stigla normalno, ispravna i jeftinija za 150kn nego drugdje.
Btw ako nisi šalji im mail na engleskom, ionako odgovaraju na mješavini eng-mađarskog.
Staro 09.02.2016., 23:26   #6450
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Autor nex Pregled postova
Ahahahahahahahahahahhahaahha - ovo je išlo u PrtScr tj. QFT
Pomelo mi sig -.-
