Staro 02.12.2014., 18:24   #1
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,563
Seasonic M12II-520 Bronze
Da li ovo napajanje može izdržat konfu u moj komp uz sljedeće izmjene
umjesto grafičke gtx470 da dođe gtx970, umjesto i3 da dođe i7 2600k i još dodatnih 2x8Gb memorije.
Staro 02.12.2014., 18:38   #2
hedgehog
hedgehog's Avatar
Datum registracije: Apr 2013
Postovi: 1,336
bez frke..970 čak troši manje od 470 ako se ne varam
hedgehog je offline   Reply With Quote
Staro 02.12.2014., 19:54   #3
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,041
Ne sam da će držat, ostane i lufta još
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 02.12.2014., 20:02   #4
Thermaltake
1
Postovi: 3,563
Nisam baš istraživao kolko troši, al ako manje troši to je super. A ja baš mislio da ću trebat nabavljat od 650W, mislio sam isti uzet model ko i ovaj bronze samo 650 umjesto 520 jer mi je super ovo napajanje ima corsairove čipove unutra bar ovaj model moj, ostali mislim da ne. To kad sam ga uzimao pa sam se informiro, a i tiho je i fakat eo da pokucam o stol nemam problema nikakvih.
Staro 02.12.2014., 21:21   #5
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
...ovo napajanje ima corsairove čipove unutra bar ovaj model moj, ostali mislim da ne...
U mene doduše je S12II, ali za ovo prvi put čujem.
Corsair jedino ima vlastiti logo dizajn, a sve ostalo mu drugi rade bar šta se tiče PSU jedinica.
http://www.realhardtechx.com/index_archivos/Page447.htm
Pomelo mi sig -.-
Staro 02.12.2014., 22:06   #6
Thermaltake
1
Postovi: 3,563
Autor Drvoje Pregled postova
Ima tu negdje na forumu tema gdje se to spominje da su u toj verziji corsairovi čipovi prosrčaj malo i gugl i to.
Staro 25.03.2015., 18:42   #7
Thermaltake
1
Postovi: 3,563
Kako bi ovo napajanje se ponašalo sa sljedećom konfom
i7 3770k
trenutnom matičnom pod moj komp
sa recimo 2x8Gb DDR3 na što većem taktu
hardovima isti ko i pod moj komp
grafička bi bila možda 770gtx gainwardova najvjerovatnije mislim da neću ić na 9xx seriju jer eto 960 mi je malo još slaba tj. slabija od ove 770, a kod 970 mi smeta ovo šta su prevarili sa 3.5Gb pa iz principa ju ne želim kupit.
4 venta od 140mm u kućištu
1 PCI konverter za PCMCIA karticu
Možda bi i neki overklok lagani recimo opalio na ovoj ploči još pošto je dosta dobra za klok.
Zadnje izmijenjeno od: Thermaltake. 25.03.2015. u 18:55.
Staro 25.03.2015., 19:01   #8
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Konfa će ti trošiti ~350W u full loadu.
Staro 25.03.2015., 19:06   #9
Thermaltake
1
Postovi: 3,563
Kako to izračunaš ? Ja sam tamo na nekim sajtovima računao i uvijek mi više nego šta mi napajanje ima ispadne, predpostavljam da su to neke defaultne vrijednosti programirane tamo pa zato. Ima kakav sajt gdje mogu realnu potrošnju izračunat ?
Staro 25.03.2015., 19:21   #10
Postovi: 33,938
Nema. Svi ti online kalkulatori debelo pretjeruju sa zahtjevima konfe. Uzmi TDP od proca i grafe, dodaj 10W po hardu (iako je i to previše) i par W po ventu i imaš približnu potrošnju konfe.
Staro 25.03.2015., 19:28   #11
Thermaltake
1
Postovi: 3,563
Ok tnx na info.
Staro 25.03.2015., 19:51   #12
Postovi: 8,209
Al trebas vidjet koliko je napajanje staro i isfurano već. Jer to više nije baš tak mlada platforma.
Što se tiče snage, vjerojatno bude dosta, samo hoće te buka zadovoljavat to je drugi par opanaka.
Staro 25.03.2015., 20:15   #13
Thermaltake
1
Postovi: 3,563
Staro je četri i pol mislim godine napajanje. Meni nikad nije bučilo čak ni kad sam spojio onu 4870x2 na nju i igrao igrice tako da me uopće to ne brine, a i inače mi je glasno kućište sa ova 4 venta pa mi to ne smeta
Pa valjda nije nakon te 4 godine izgubilo tolko puno na jačini ako i sa recimo overklokom bude trošilo u full loadu cca 430W opet će bit dovoljno jako mislim da nije sad 90W već otišlo dole, a iskreno napajanje se nikad nije ni oznojilo kako treba sad jel to dobro il loše ne znam.
Zadnje izmijenjeno od: Thermaltake. 25.03.2015. u 20:24.
