Zaključane teme
Staro 26.02.2015., 14:52   #1
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,547
Usluga Reflow/reball grafičke
Pozdrav, dakle ovako imam jednu strganu grafičku koja mi je otišla nedavno i sad sam ostao bez grafičke na žalost a novaca nemam za novu niti da nekom platim da mi napravi reball koji vjerujem da bi ju popravio pa ako ima netko platio bi mu piće il neku simboličnu cijenu samo da mi proradi grafička opet, hvala unaprijed.
Zadnje izmijenjeno od: Thermaltake. 24.03.2015. u 08:19.
Thermaltake je offline
Staro 27.02.2015., 15:49   #2
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,037
Probaj pećnicu, to ti je quick fix ako uspije.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Chuxonja je offline
Staro 27.02.2015., 16:09   #3
Thermaltake
1
Postovi: 3,547
Nebi rađe to htio radit, htio bi da se na normalan način popravi, ako je ikako moguće.
Staro 27.02.2015., 17:54   #4
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
NHF.........
ali da netko gubi zivce i vrijeme za pice bi tebi osobno trebao biti jako jako dobar prijatelj. kvragu, pa meni se nebi dalo rastavljat graficku, palit heatgun i przit ju, keljit novu pastu i sastavljat za pice .
tako da realno, budi sam svoj majstor. ako imas heatgun, imas graficku sljedecih par mjeseci, samo ju zakuris dodatno kada prestane davat sliku. ali ovako, da ti netko radi reballing .
znas sto je uopce reballing, znas sto trazis tocno?
Burko je offline
Staro 27.02.2015., 18:01   #5
Thermaltake
1
Postovi: 3,547
Nemam na žalost ništa od alata, a i nisam nikad s tim radio. Ja ću je sam rastavit i dofurat samo nek je taj ako može prekugla i sastavit ću je isto sam i natrackat pastom i probat.
Naravno da znam, reflow bi najvjerovatnije isto popravio stvar ali na jedno kraće vrijeme ovisno kolko se profesionalno napravi, a nije mi u cilju ni da ju mogu popravit i da imam heatgun svaki put kad neće u win. dat sliku ga palit i podkurivat, nego bi ju htio popravit da traje duže u tom slučaju bi reball trebalo.
Ha jbg razumijem ja jer sam i ja radio stvari za đabe isto ljudima koji mi nisu prijatelji jer su bili u situaciji u kojoj ih razumijem pa eto opet sam pomogo.
Zadnje izmijenjeno od: Thermaltake. 27.02.2015. u 18:15.
Staro 27.02.2015., 18:22   #6
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 495
Alvin???
he,he
zlatko je offline
Staro 27.02.2015., 18:32   #7
Thermaltake
1
Postovi: 3,547
Pitao sam ga ali ima puno posla a i morao bi mu platit materijal, a nemam na žalost tolko kolko traži.
Mislim možda bi i reflow prošo samo ga treba profesionalno odradit preko lemilice, a ne heatgunom.
ko recimo ovdje
https://www.youtube.com/watch?v=T_KHCzGaPnc
Zadnje izmijenjeno od: Thermaltake. 27.02.2015. u 18:41.
Staro 27.02.2015., 19:12   #8
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 495
Ako je u pitanju lemilica, heatgun ili rebaling, u pitanju je hladan lem. Neki od kontakata su loši. Ako imaš vremena i volje, uzmi lemilicu, dobro je ugrij i idi redom. Kontakt po kontakt. Ako je nešto drugo u kvaru, neće ti pomoć niko, osim elektroničara...
he,he
zlatko je offline
Staro 27.02.2015., 20:06   #9
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Koliko ja znam "reball" je micanje staroh čipa i stavljanje novoga... A ko bi taj novi čip platio? pa nije to da košta kikiriki... i reball se nikako ne isplati
Napravi dobar reflow, i ako ga dobro napraviš raditi će možda i duže od 1god...
Od alata ti treba samo neki mali brener, a možeš i upaljačem ako baš ne možeš nabaviti maleni baner imaš one upaljače u intersparu,kauflandu kod kase...koji su kao breneri Peri i deri..
btw koja točno grafa?
FRipper je offline
Staro 27.02.2015., 20:09   #10
Thermaltake
1
Postovi: 3,547
Ja bi htio ako je ikako moguće da mi netko to na lemilici napravi mislim na reflow jer je profesionalno a ovako sa heatgunom reflow radit mi je 50/50 da ću dobro napravit a mogu i još više zeznut stvar ili će ostat kako je i sad. Znači nije nužno onda da mora bit reball baš promjenio sam ime naslova jer sam vidio da se i sa kvalitetnim reflow-om može isto jednako dobro i kvalitetno to napravit, ali nikako nebi išo na varijantu reflow-a sa heatgunom.
Zaboravih navest znači grafička je Gtx 470.
Zadnje izmijenjeno od: Thermaltake. 28.02.2015. u 15:34.
Staro 04.03.2015., 08:56   #11
Thermaltake
1
Postovi: 3,547
Još uvijek sam u potrazi da mi netko napravi reflow na grafičkoj ako ima koja dobra duša bio bih zahvalan.
Staro 26.03.2015., 17:59   #12
Thermaltake
1
Postovi: 3,547
I dalje u potrazi.
Staro 26.03.2015., 19:58   #13
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 833
Majketi mile,jel znas ti koji je to posao? Za piće sto znaći 8 kuna (kola,pivo,kava). Ja znam i nema teoretske da bih ga radio ispod 300 kuna..Posao da se usereš da prostiš,i moraš imati reball podložak koji košta 30 $ na ebayu zavisno od čipa koji imaš. Nije GPU ali je postupak isti. Link Moras imati heat gun i tocno paziti da ti temperatura PCB-a i GPU-a koji zagrijavas ne predje 200 c s fluxom i tocke otapanja lem kuglica.
Romano.Cule je offline
Staro 26.03.2015., 20:39   #14
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
ukratno..jeftinije je kupiti drugu gtx 470
FRipper je offline
Staro 30.03.2015., 00:37   #15
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Lokacija: Svuda okolo / EU
Postovi: 1,404
Ma probaj pecnicu, ja tako od 6 ubacenih 5 osposobio da rade, frendovi nisu vjerovali, ali svim jos rade, skines ventilator i dobro je ocistis, zamotas u alu foliju, upalis pocnicu na 200 stupnjeva 10tak minuta da se zagrije, i onda na 10minuta stavis VGA u nju i temperatura mora biti 200 stupnjeva, tj. kod mene je bila, ni vise ni manje, 10 minuta je taman, izvadis je nakon 10min i ostavis da se ohladi, stavis novu pastu i ventilator, i kako je rekao jedan pametan covijek, sansa je 50:50... ili radi ili neradi...
JozicA je offline
Staro 30.03.2015., 09:24   #16
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
lakse je nekom dati 10kn da to napravi umjesto tebe
FRipper je offline
Zaključane teme
