Staro 26.02.2015., 23:41   #1381
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Skužio kasnije da se može šaltat
Staro 26.02.2015., 23:47   #1382
Nybelung
Nakon svake zahtjevnije igre će Nvidia morati izbacivati novi driver za GTX 970.
Moš mislit dokle će to trajati.
Staro 27.02.2015., 01:30   #1383
Manuel Calavera
Postovi: 14,584
A stalno se sumnjalo u frame timing
Ja kažem da ovo još nije istraženo kako treba. Sada doslovce postoji samo jedna igra koja sigurno prema svim izvorima može povuć preko 3.5 gb na 1080p - i ponaša se čudno? Onaj yt video (džej2cents) je (pre)lako prešao preko njezinog čudnog ponašanja. Mislim, razumijem i ja te recenzente, ne žele se zamjeriti jednoj takvoj firmi, ipak od toga žive...
Evo jedan od komentara sa frejmtajmingom (ovo nije nigdje potrvrđeno, ali bome čini mi se nije ni pošteno istraženo nigdje):
Problems that weren't adressed here:
1. No frametimings are shown. These are what makes playing with a 970 the horror. There are some serious fuckups in the timings. You rock with 60+fps (thats 17-ms fremtimings) and bam there is a little microstutter. Look at the frametimings and yes there was a 100+ms frametiming, that's a single frame at 10fps or less. You won't notice that with the fps. You can see this even when the card uses under 3.5 GiB but only sometimes and it get's really serious if you use over 3.5 GiB.
1.5 Use a downclocked GTX 980 to compare frametimings and VRAM usage. The downclocked GTX 980 is the card that was advertised. You can see that the GTX 980 doesn't have the same issues with the frametimings, also if you force the GTX 970 to use over 3.5 GiB (You have to force it because while the 980 uses 3.8 GiB the 970 will still use only 3.4 GiB because the driver forces the card to do that) you will see that the performance degrades up to 20% compared to the downclocked GTX 980. Once again, the downclocked 980 is what was advertised.
2. That brings us to the fact that the GTX 980 uses significantly more VRAM than the GTX 970 in the same settings in the same game. No word here? Why?
3. Quite a few people have gotten a GTX 970 for SLI. And the others could upgrade to it when the fps get to low. Well now they are fucked because they have enough horsepower for 4k gaming but can only use mid settings because they can only use 3.5 GiB.
Što se tiče igara - doći će još takvih poput mordora (i gorih). Nvidia će vjerojatno svakim driverima obuzdavat sporih pola gige
Izgleda već dolaze
Dosao novi patch za Dying Light i ovo mi je vrlo zanimljivo posto znam da igra ide iznad 3.5gb na 1080p,igram ju.
- Minor performance tweaks for GTX970 users
Autor darkydark Pregled postova
Grafa ima stvarno lepe performanse, al uzdizanje u nebesa koje je doživela od novinara prilikom izlaska i razina "opreznosti" koju su svi imali prilikom izvještavanja problema mi je smiješna. Svi pucaju o nekakvom FPS-u, a ekipa se uporno žali na Frame Latency i Stuttering barem jedan kolega kojeg citiram:
"**bem ih ja glupe, el nisu mogli jednostavno isporucit grafu sa 3.5gb, a ne metat ovaj crvuljak od pol gige koji samo sranja dela i tu je 99% zbog činjenice da jer je neko u marketingu reko inžinjerima - ne 3.5gb, mora bit okruglih 4gb i sad sa svakom novom igrom ak se covjek zaigra sa eye candy pi***rijama nek me ceka ovaj usrani stutering, kaj me briga kaj mi je fps 40-50, ak ovo na oko ima osjecaj ko da je 15, a nasi uvoznici se prave kilavi."
Ovo za stutering da nisam uzivo videl, ne bi veroval.
Nema dok švaba ne istestira teknologiju
Staro 27.02.2015., 08:50   #1384
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,319
Fantasticno!
Bas mi je fino citat ovakve testove, pogotovo nakon sta sam istresao 3k kn za usranu graficku.
Na svu srecu, nit me dying light privlaci, niti total war, a u igrama koje igram nisam primjetio nikakve probleme....ali samo je pitanje vremena kad ce naletit neka igra koja ce razapet ovo ''cudo tehnologije''
Slobodno me dodajte na PSN
Staro 27.02.2015., 09:25   #1385
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Autor Disco Pregled postova
Fantasticno!
Drage cu volje preuzeti tvoj "teret" za 1500kn
Bez potpisa.
Staro 27.02.2015., 09:50   #1386
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Fantasticno!
trebo si istrest za gtx 980,bilo je predobro da bi bilo istinito(cijena,performanse u odnosu na gtx 980)...nvidia uvijek ima poseban "feature"
esc je offline   Reply With Quote
Staro 27.02.2015., 09:57   #1387
syss
syss's Avatar
Postovi: 10,805
isto ko što ati ima fičr da ne radi hdmi... recimo
Staro 27.02.2015., 10:00   #1388
Flood
Into my head it goes
Flood's Avatar
Datum registracije: Feb 2004
Lokacija: space de luxe
Postovi: 779
Autor syss Pregled postova
To ima neka cijela serija?
Staro 27.02.2015., 10:04   #1389
syss
syss's Avatar
Postovi: 10,805
to ima maltene kompletna ergela
Staro 27.02.2015., 10:12   #1390
Garro
Postovi: 2,392
Ovo mogu potvrditi. Kada sam spojio telku na komp putem HDMI-a, nema nikakve slike prije Windows welcome screen-a. Zamisli zabavu kada mi je komp zapeo u boot-u, a ne znaš što se događa pa tegli monitor do kompa. Vrhunski odrađeno.
Ali svejedno, ovakav strmoglavi pad od vrhunskog hype-a do totalnog pljuvanja po 970 ne sjećam se kada sam zadnji put vidio...
Staro 27.02.2015., 10:14   #1391
Flood
Flood's Avatar
Postovi: 779
Meni radi ka podmazano
Staro 27.02.2015., 10:21   #1392
syss
syss's Avatar
Postovi: 10,805
oke nemam veliki uzorak ali 280x - jedan boot, 280x - nema slike, 290 - jedan boot, 290x - nema slike, 270x - radi. nakon mog javnog istupa kako mi se čini da je ovo neki debeli bug se javio još jedan član koji je rekao kako je imao isti problem na 6xxx i 7xxx modelima, jedno ono 5-6 komada.
ne bi rekao da se baš radi o malom bug-u
realno što se 970ke tiče... da, zayebali su to sve stoji, ali hype oko toga jednostavno nema smisla.
to je preslab gpu da može procesuirat 4k gejming modernih igara (da ne kažem konzol-portova), a to je realno jedino što je može "prekobaciti" do tih 4gb iskoristivosti.
Staro 27.02.2015., 10:22   #1393
esc
Lynnfield
Postovi: 1,023
trebao bi bacit van tu 270x i kupit si neku poštenu nvidiu,a to je gtx 960
kako nema smisla hype,ili ima igara ili nema koje mogu prebacit ali oni su lažno oglašavali,kartica nema stvarnih 4gb,mogli su jednostavno stavit i 3gb(pravih) i nitko se nebi bunio
i onda još gazda nvidie veli to nije bug,to je feature
Staro 27.02.2015., 11:11   #1394
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,319
Autor RaneZ Pregled postova
Ma poklonim ti ju, ionako imam para na bacanje
Staro 27.02.2015., 11:16   #1395
Flood
Flood's Avatar
Postovi: 779
Jedno je random zajeb,drugo je generalni zajeb,nadam se da se slažemo oko toga.
Istu priču sam slušao oko Kingstonovog asinhronog nanda,pa znaš to je samo u benčevima,i dalje je to brzo ovo ono.
Gle,nisam dobio to šta sam platio i ostala utješna priča me uopće ne zanima.
Kingston baj baj,samo poklone primam.
Uvaljotke treba osuditi ili prelaziti preko njih?
Staro 27.02.2015., 11:21   #1396
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
To si zaključio na temelju ČAK vas DVOJICE koji imate problem s time?
Tvoj hejt prelazi u nešto kudikamo smješnije i tragikomičnije....
Ja eto, na već 11oj radeonki unazad par g primarno koristim hdmi za spajanje kompa na monitor, i pazi, SVIMA RADI hdmi....
Iskreno, jedini PRAVI bug hdmi izlaza na radeonkama je power management istog. To je tak debilno složeno da bi je zavitlao kroz prozor da nemam sammyeve monitore sa tv-om pa imam daljinac za upalit monitor.
Naime, sleep kompa imam isključen u winsima, ali sleep monitora mi je na 30min neaktivnosti. Kad prođe tih 30 min, monitor ukopčan u hdmi se ne ugasi, nego objavi da provjerim spoj, to blinka još cca 5 (ili čak 10 min) i onda se baci u sleep. Vratit ga iz sleepa se ne može ničim osim paljenjem na daljinski ili na touch panelu na monitoru na on tipku, bez obzira što sam ja stisnuo key na tipkuši ili scimao miša, komp da signal da sam ja to napravio, ali monitor ne dobije 'pobudu' za dizanje iz sleepa, kao što recimo najnormalnije funkcionira ako je spojen na dvi ili vga ulaz. Žešća debilana, imho.
Autor esc Pregled postova
Kako će bacit radeonku van, kad em je mazohist i voli imat ono po čem k.nja, em te divne zelene grafe ne mogu majnat, šta misliš da se on uhvatio radeonki jer su mu lijepe crvene pred očima
A ova izjava velikog zelenog vođe, ne da je za plakat, nego je za kolektivnu tužbu cijelog svemira zbog notornog bezobrazluka i bahatosti a ne tih par amera što se skupilo za tužakat se s njima....
Staro 27.02.2015., 11:29   #1397
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Autor jopis Pregled postova
Čak se u ovom slučaju slažem s tvojim radikalizmom
Staro 27.02.2015., 11:34   #1398
syss
syss's Avatar
Postovi: 10,805
ako se ne varam ti se ne baviš it-jem nego osiguranjima i autima jel?
(ako ćemo radikalno jel...)
Staro 27.02.2015., 11:46   #1399
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Op op, nema smajlija u syssovom postu, nije dobro.
Spoiler alert!
Staro 27.02.2015., 11:50   #1400
esc
Lynnfield
Postovi: 1,023
ja se povlačim eod
Staro 27.02.2015., 11:50   #1401
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Nisi čuo za primarnu i sekundarnu djelatnost?
Daklem, em ti uzorkovanje ne ide jel ti je MALI uzorak uočene nepravilnosti, em segmentacija po djelatnosti ti isto ne štima.
No, uostalom, lijepo sam ti na drugi quote konstruktivno i kreativno odgovorio u vezi hdmi-a i radeonki a ti tu mene hoćeš eliminirat iz konstruktivne rasprave činjenicom s čim ja zarađujem za kruh, ko da nitko ne može imat sidejob. Jest da moj traje već skoro 20g, al dok traje dobro je
Ovo što ti navodiš, budući da nisi naveo okolnosti u kojima se to događa, tj. da li si spajao primarni monitor na hdmi ili je u igri tv kao sekundarni, itd., može tu bit svega po malo, a ne odmah bacit rant na jadnu nevinu grafu
Staro 27.02.2015., 11:57   #1402
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Odo ja u ISP thread
Bez potpisa.
Staro 27.02.2015., 11:58   #1403
syss
syss's Avatar
Postovi: 10,805
moja primarna i sekundarna djelatnost je it.
okolnosti u kojima se to događalo je da na dvi 1 je dell iz potpisa, a na jedan jedini hdmi je spojena telka koja je radila preko identične instalacije na jedno 5-6 nvidia grafa.
Staro 27.02.2015., 12:06   #1404
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
Mislim da je ukupni zaključak da bi nVidijini programeri morali dobiti porciju brutalitija!
Inače, da se vratimo na temu 9xx kartica, evo još jednog testa. Ovaj puta je 960 kartica na tapeti. Koliko vidim, minimum framerate je čavlima zakucan za pod :-( link
Zadnje izmijenjeno od: Amepshi. 27.02.2015. u 12:12.
Staro 27.02.2015., 12:15   #1405
Garro
Postovi: 2,392
Drugi syssov post bez smajlija.
Ja moram ići...tamo negdje...jel... vidi glečer iza leđa! (kidam naljevo)
Staro 27.02.2015., 13:19   #1406
Manuel Calavera
Postovi: 14,584
Zašto svi spominju 4K i 1440p, takve igre su tu i događa se već sad na 1080p preko 3.5gb (jedna dolje prebaci i preko 4000mb na gtx 980)
Znamo kakve igre dolaze, još ako bude microsttuter kad se aktivira drvena memorija...
Zadnje izmijenjeno od: Manuel Calavera. 27.02.2015. u 13:26.
Staro 27.02.2015., 13:31   #1407
syss
syss's Avatar
Postovi: 10,805
koliko je realno takovih naslova?
mislim da bi bubba mogao čistom matematikom mogao objasniti zašto igra na 1080p ne bi smjela trošiti više od ne znam... 2gb... jedino ako su texture u .bmp-u
Staro 27.02.2015., 13:40   #1408
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Zašto ne bi?
Pa bf3 je sa svim napucanim do kraja trošio tj troši nešto sitno preko 2gb vram-a na 1080p u mp-u, na 4ci se nisam s tim smarao, al može se probat.
Nije isto radit texture za tetris i za par kilometara mape i sve sile detalja po njoj.
Isto kako će se i ovih 128bita na 960kama brzo objelodanit koliki je to fail, samo dok krenu neplaćene recenzije.
Staro 27.02.2015., 13:55   #1409
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
BF3,4 itd ne trose vrama vise nego im treba za razliku od mnogih u zadnje vrijeme..
Total War ide bolje na Radeonkama vec neko vrijeme..
Staro 27.02.2015., 14:25   #1410
Nybelung
Autor MAGARAC Pregled postova
Otkad to? I na releasu i kroz prva dva patcha su Titanic i GTX 780 bile uvjerljivo najbolje kartice za Rome 2. Igra nije podržavala ni CF ni SLI, tako da ni tu nije bilo diskriminacije.
