Staro 05.02.2015., 22:36   #1231
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Ja kažem da ovo još nije istraženo kako treba. Sada doslovce postoji samo jedna igra koja sigurno prema svim izvorima može povuć preko 3.5 gb na 1080p - i ponaša se čudno? Onaj yt video (džej2cents) je (pre)lako prešao preko njezinog čudnog ponašanja. Mislim, razumijem i ja te recenzente, ne žele se zamjeriti jednoj takvoj firmi, ipak od toga žive...
Ne znam, možda je igra takva sama od sebe (s dropovima)...
Evo jedan od komentara sa frejmtajmingom (ovo nije nigdje potrvrđeno, ali bome čini mi se nije ni pošteno istraženo nigdje):
Problems that weren't adressed here:
1. No frametimings are shown. These are what makes playing with a 970 the horror. There are some serious fuckups in the timings. You rock with 60+fps (thats 17-ms fremtimings) and bam there is a little microstutter. Look at the frametimings and yes there was a 100+ms frametiming, that's a single frame at 10fps or less. You won't notice that with the fps. You can see this even when the card uses under 3.5 GiB but only sometimes and it get's really serious if you use over 3.5 GiB.
1.5 Use a downclocked GTX 980 to compare frametimings and VRAM usage. The downclocked GTX 980 is the card that was advertised. You can see that the GTX 980 doesn't have the same issues with the frametimings, also if you force the GTX 970 to use over 3.5 GiB (You have to force it because while the 980 uses 3.8 GiB the 970 will still use only 3.4 GiB because the driver forces the card to do that) you will see that the performance degrades up to 20% compared to the downclocked GTX 980. Once again, the downclocked 980 is what was advertised.
2. That brings us to the fact that the GTX 980 uses significantly more VRAM than the GTX 970 in the same settings in the same game. No word here? Why?
3. Quite a few people have gotten a GTX 970 for SLI. And the others could upgrade to it when the fps get to low. Well now they are fucked because they have enough horsepower for 4k gaming but can only use mid settings because they can only use 3.5 GiB.
Što se tiče igara - doći će još takvih poput mordora (i gorih). Nvidia će vjerojatno svakim driverima obuzdavat sporih pola gige
Izgleda već dolaze
Dosao novi patch za Dying Light i ovo mi je vrlo zanimljivo posto znam da igra ide iznad 3.5gb na 1080p,igram ju.
- Minor performance tweaks for GTX970 users
Staro 05.02.2015., 22:40   #1232
Dottore
Dottore's Avatar
Postovi: 7,701
Autor karlo10 Pregled postova
EDIT: a i kak bi po tvome trebal dobiti 760, ako ih microline nema više u ponudi, a cijena na računu mi za msi 760 piše 1922kn, koliko sad otprilike dođe 960..tak da zbilja tu ne vidim problem, ako očekujem msi 960
Cijena ne igra ulogu. Dok još ima 760 na lageru i dobit češ je.
Tako sam ja kupio prije 2 godine Vertex 4 120GB za 900kn i bios ga nije prepoznao. Reklamacija i dobio Vertex 460A istog kapaciteta za nekih 600kn. Od Microline.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 06.02.2015., 12:41   #1233
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
I možemo se mi na PC-u ljutiti i buniti koliko god hoćemo, ali bojim se da će nas vrlo brzo sve staviti pred gotov čin.
HBM kapaciteta 8GB ide u proizvodnju 2016. To je s Pascalom (2016 GPU) realnost.
A što je s DirectX12?
Moramo biti svjesni toga da su konzole te koje drmaju PC tržištem. Sve se njima prilagođava, jer tamo je lova.
PS4 ima 8 jezgreni procesor i 8GB jedinstvanog RAM-a. Da, reći ćete, te su jezgre spore, ali i dovoljne za 720p / 30fps.
Doći će game developer pred zid - izdavač će mu staviti vrlo kratke rokove i možeš misliti kako će imati vremena sada programirati za nekoga tko ima segmentirani RAM na grafičkoj. Jel radi na konzoli? Ako da, štancaj igru. A kada ide port, na PC-u ionako lako možeš kupiti jaču grafičku ili smanjiti detalje, dakle minimalno ulaganje za izdavača.
Ili kupi novo ili ... ustvari nemaš izbora.
Staro 06.02.2015., 12:59   #1234
karlo10
šekler
karlo10's Avatar
Postovi: 115
Autor Dottore Pregled postova
A gdje vi vidite te silne 760 na lageru?? pa na microline cjeniku je već preko mjesec dana nema.. neki zdrav razum i logika mi govore, ako imaš nešto na lageru, onda to i ostaviš na cjeniku ne?
U IQ zagria koji je njihv dućan (bar su tak na bugu pisali) također nema 760-tki.. zbilja ne kužim gdje se skrivaju??
Nema ih.
karlo10 je offline   Reply With Quote
Staro 06.02.2015., 15:42   #1235
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Budući doktore, nemaš se što grčiti. Najgore što se može dogoditi je da dobiješ istu grafu
Samo imaj na umu da ti slabiju grafičku ne smiju dati, a samo je na tebi onda hoćeš li se dopustiti preveslati ili ćeš odraditi to muški. Piskarati dalje na tu temu, koja je prožvakana u temi o garancijama, ovdje smisla nema.
Spoiler alert!
Staro 06.02.2015., 15:54   #1236
Dottore
Dottore's Avatar
Postovi: 7,701
@karlo
Zadrži zdrav razum , pusti logiku i nemoj previše veseliti. Kad budu te zvali i onda sve češ znati. Ovako busanje prazne slame i nadati novoga pretvori u veliko razočaranje. Strpi se
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 07.02.2015., 12:01   #1237
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,593
Nema ih.
Nakon čitanja tvojih postova ili si Troll ili njubina.
Dota2 nafrljana do kraja ide 60fps na prastaroj 5770HD
GTX760 bez problema vrti TombRaider 60fps maxx bez tress fx.
A ovo vezano u raspolaganje ti ide ovako.
Ako nemaju onda naruče preko uvoznika.
Pošten trgovac:
1,2,3,
Staro 07.02.2015., 12:57   #1238
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Haha, ja sam je igro na medium na ION2 sa Atomom 525, kucnom mini PC-u ;D Pa to radi sa rucnim satovima vec danas.
Bez potpisa.
RaneZ je online   Reply With Quote
Staro 07.02.2015., 13:04   #1239
Postovi: 8,231
Pa neide bas, meni povremeno padne na 60fps sa 660kom kad je fajt. Sumnjam da bi mi 5770 drzala stabilnih 60fpsa uz sve nafrljeno.
Al da se moze igrat i na predpotopnim kompovima, moze uz smanjene detalje i rezu.
Nece narucit od nigdje 760ku kad ima na lageru 960ki. Jeftinije im je zamjenit neko posebno naručivat karticu koja se neproizvodi već xy vremena. A i da dobije 760, opet ima novo jamstvo i gg.
Staro 07.02.2015., 16:29   #1240
karlo10
šekler
karlo10's Avatar
Postovi: 115
Ljepo sam napisao ako uključiš DSR.
Btw ide i na integrirki od haswela, ali na med detaljima..
I sad offtopic, Microline je uvoznik, ako ne znaš.. kako će uvoznik naručiti preko drugog uvoznika?!
I još nešto, već mi je slučaj od utorka riješen (tako kaže kad utipkam kod), a oni ništa ne šalju.. pa logično je da imaju 760-tku da bi ju već odavno poslali ne?
Staro 07.02.2015., 16:34   #1241
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
šta bi ti htio gtx 960,trebao si im to napomenut i reći,mislim da im to nije nikakav problem...možda da je skuplja pa onda samo nadoplatit
esc je offline   Reply With Quote
Staro 07.02.2015., 16:44   #1242
Postovi: 8,231
To vjerojatno znači da je potvrđen kvar
Staro 07.02.2015., 17:24   #1243
karlo10
šekler
karlo10's Avatar
Postovi: 115
Pa da potvrđen je i to mi je rekao kad sam zvao. Ali i da mora još nešto s šefom (ili nekakvim voditeljem) još provjeriti..
Gle potpuno m iej svejedno što ću dobiti, samo da ne moram ručno pokretati ventove i da nije Ati/AMD..
Jedino zbog čega bi radije 960 nego 760 je onaj fancy šmensi svjetleći zmaj na cooleru (očito je to nekim članovima foruma jako zasmetalo)
Za tih 10% +/- performansi me zabole džon..
Staro 07.02.2015., 17:53   #1244
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Ja kažem da'š dobit' 960ku
Staro 07.02.2015., 18:00   #1245
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Kad vec drobimo, prije neg se sve pobrise, dobit ce refurbished 760-eku ako je MSi u pitanju, tak i tak sve kartice idu natrag njima na RMA i onda oni salju zamjenu s novim jamstvom. Prosli dani ponosa i slave, i zaradivanja na takvim kombinacijama.
Staro 07.02.2015., 18:38   #1246
Postovi: 8,231
Autor xulos Pregled postova
I ja isto kažem
Eo nek se javi samo što je dobio, jer ovoga vjerojatno neće biti više.
Staro 07.02.2015., 21:32   #1247
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
jesi gledao temp procesora da ti se procesor nezagrije pa da mu automatski neuspori herce i da ti do toga nebude pad
VoodooRain je offline   Reply With Quote
Staro 08.02.2015., 01:40   #1248
darkydark
N0teb00k n00b
darkydark's Avatar
Lokacija: Zagreb/Koprivnica
Postovi: 2,112
How yes no.
Quadro K4000M i FirePro M6100 nisu u stanju dotu2 sa svim na maxu vrtit u kombinaciji sa i7 4810MQ, a obje su fest jače od 5770.
Očito smo igrali drugačiju Dotu 2.
1TB A2000, 2TB KC3000
Linđa
Truenas Scale
Staro 10.02.2015., 11:34   #1249
esc
Lynnfield
Postovi: 1,023
kad izlazi gtx 950?
Staro 11.02.2015., 01:18   #1250
debeljko
Datum registracije: Apr 2014
Postovi: 44
temperatura procesora ne dode niti do 50c, pričam o loadu tokom gejmanja, jer imam dobar cooler. znaci nisam na stocku. Niti jednu igru koju sam igrao mi ne štuca u gameplayu, to je bilo što fraps tokom loadinga ocita namjanje fps-a pa zapise da je toliko bilo najmanje.. dok u gameplayu se poveca
debeljko je offline   Reply With Quote
Staro 11.02.2015., 01:25   #1251
debeljko
Postovi: 44
I dečki da malo kurim jel ste polako zaboravili na problem sa 970 ili se igrate i skroz zaboravili na taj problem? Čitam po drugim forumima da ljudi govore da ce bit jos neoptimiziranih igara odnosno konzoloskih porteva poput dying lighta, gdje bez problema igra uzme i preko 4gb vrama, jebate led, mi koji smo pljunuli 3200kn, smo zapravo najvise izgubili, grafička umjesto da tjera kak spada najvise ima problema u navedenoj igri te u Shadow of Mordor, to su vec dvije igre, na full hd rezoluciji, ne govorim tu o 4k i sl. a kaj ce bit za god-dve, morat cemo promjenit graficku od 3 hiljade krvavih zarađenih kuna.
Staro 11.02.2015., 02:06   #1252
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Lokacija: Svuda okolo / EU
Postovi: 1,404
Mjenjaj VGA, nema ti druge, imao gtx970, prodao cim sam cuo za probleme s njom, ili probaj od nekoga posuditi 290x na par dana pa ces vidjeti da je stvar do VGA ipak.
JozicA je offline   Reply With Quote
Staro 11.02.2015., 02:51   #1253
Manuel Calavera
Postovi: 14,589
Zašto bi mjenjao kad
Nikako mu se ne isplati (dobije mrvicu slabiju ili podjednaku grafu u prosjeku, koja troši 80% više struje, te još u transakciji izgubi novce).
Činjenica je da vlasnici gtx 970 nemaju nikakvih alternativa (niti potrebe za mjenjanjem). R9 290/290X se ne isplati iz gore napisanih razloga, a gtx 980 također, zbog gubitka love prodajom svoje + masne nadoplate za ne preveliki boost u perfomansama (gtx 980 ima loš price/performance ratio) + time dodatno "nagradi" nvidiju za muke. Najbolje mir.
Druga je stvar da on sad nema ništa pa da kalkulira što će uzet.
Staro 11.02.2015., 10:08   #1254
syss
syss's Avatar
Postovi: 10,805
šta zbog jednog lošeg porta grafa ne valja? de brate...
Staro 11.02.2015., 10:27   #1255
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Autor syss Pregled postova
Znaš i sam da je problem malo dublji od toga
Staro 11.02.2015., 10:47   #1256
syss
syss's Avatar
Postovi: 10,805
ama igra koja troši 4gb vrama na 1080p nema šta tražit na tržištu KO NI ATI GRAFIČKA IN THE FIRST PLACE!!!
Staro 11.02.2015., 12:01   #1257
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Ovo za igru se u potpunosti slažem. To je ništa drugo nego čista lijenost ili nesposobnost developera da igru učine optimiziranom. I takve igre se ne bi ni smjele uzimat za tesitranje hardvera. S ovom igrom jedini cilj je dokazat da se iznad 3,5gb grafa zblesira, a van toga nema što tražiti u benchanju grafičkih ili ostalog hardvera. (i dalje ne opravdavam postupak nvidie da netko krivo nešto ne shvati )
Zadnje izmijenjeno od: xGAME. 11.02.2015. u 12:08.
xGAME je offline   Reply With Quote
Staro 11.02.2015., 12:55   #1258
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
Vjerujem da Dying Light i Mordor nisu mogli dobiti bolju reklamu. Gotovo nitko nije javno napao developere za manjkav i nedovršen posao, ljudi nisu napravili masovnu pobunu na Steamu da hoće novce natrag. Čudno je to, jednome oproste grešku, drugome ne.
Igrao na 970 kartici, to je munjevito brz komad hardvera. Jest da košta, jest da ima manu, ali budimo iskreni - kartica je fakat brza i u 99,99% igara će zasjati.
Staro 11.02.2015., 13:03   #1259
darkydark
N0teb00k n00b
darkydark's Avatar
Postovi: 2,112
Danas su neoptimizirane igre u pitanju, sutra budu optimizirane gutale tolko vRama i kaj za godinu/dve ? Sa svakom novom igrom cekat nVidiju da "popravi" drivere kaj se slucajno igra nebi rashitala preko magične memorijske brojke.
Grafa ima stvarno lepe performanse, al uzdizanje u nebesa koje je doživela od novinara prilikom izlaska i razina "opreznosti" koju su svi imali prilikom izvještavanja problema mi je smiješna. Svi pucaju o nekakvom FPS-u, a ekipa se uporno žali na Frame Latency i Stuttering barem jedan kolega kojeg citiram:
"**bem ih ja glupe, el nisu mogli jednostavno isporucit grafu sa 3.5gb, a ne metat ovaj crvuljak od pol gige koji samo sranja dela i tu je 99% zbog činjenice da jer je neko u marketingu reko inžinjerima - ne 3.5gb, mora bit okruglih 4gb i sad sa svakom novom igrom ak se covjek zaigra sa eye candy pi***rijama nek me ceka ovaj usrani stutering, kaj me briga kaj mi je fps 40-50, ak ovo na oko ima osjecaj ko da je 15, a nasi uvoznici se prave kilavi."
Ovo za stutering da nisam uzivo videl, ne bi veroval.
Linđa
Truenas Scale
Staro 11.02.2015., 13:08   #1260
syss
syss's Avatar
Postovi: 10,805
e to je već veća pizdarija, ali i dalje mislim da je to do usera
