Postovi: 750
Evo moja očitavanja. Očitavano everestom sa zatvorenm bočnom stranicom bez propuha unutra, ovo je idle temperatura. Matična ploča 33 °C (91 °F) CPU 48 °C (118 °F) CPU dioda 47 °C (117 °F) GPU 50 °C (122 °F) GPU memorija 51 °C (124 °F) Seagate ST360015A 41 °C (106 °F) Hladnjaci CPU 2518 RPM GPU 3579 RPM |
KILLER
Lokacija: UNDERGROUND
Postovi: 66
Kod mene je: proc 42 kod opterećenja 48 matična 30 kod opterećenja 38 na procu 6490rpm na kućištu 5075rpm
IRON MAIDEN FOREVER |
Džabe si krečio!
Postovi: 5,191
AMD Barton XP 3000+ @ 2420 mhz, 1,85V - idle 43 max 51 (zalman 7000 Cu ) ~ 2000 rpm6800@ 1,4V idle ~60 max 72. (NV5 silencer) Matična chipset ~ 40 konstantno, neko aluminijsko pasivno sranje. Hard ~ 38-40 80 mm x3 venta na case-u, ~2000 rpm. Zadnje izmijenjeno od: Sam Fischer. 04.09.2005. u 13:28. |
Postovi: 1,313
CPU: 34 chipset: 39 GPU: 50 Ram na vgači: 41 seagate barica IV: 38 seagate barica VII: 38 hitachi 160 sataII: 39 cpu hladnjak: 831 rpm ispuh: 900 rpm upuh: 750 rpm puhalo po chipsetu (sharkoon silent eagle 2000): 1200 rpm
Biti lud ima prednosti koje razumiju samo ludjaci ![]() FKT meber jednog dana high priest... |
Postovi: 50
CPU: idle 35, load 46 GPU: idle 48, load 62 NB: idle 36, load 39 HDD: 25-28 u sobi 25c otvorena bocna stranica i jedan 80mm vent puse na northbridge
MBO:Asus A8N-SLi, nForce 4 + Zalman ZM47 J CPU:AMD Athlon 64 3000+ @2405 Mhz 283x8,5, Winchester, 512 kb c. | BOX Cooler GPU:Sparkle GeForce 6600 GT, 128 MB, 600/1240 + Zalman VF700 AlCu MEM:1 Gb (2x512) Kingmax SuperRam @ 438 Mhz Dual Channel, 2,5-3-3-6, 1T HDD:80 Gb Maxtor Diamondback 9, ATA PSU:Fortron 350 W, Super Silent, 12 cm Fan MON:Samsung Syncmaster 900 NF |
Postovi: 4,190
CPU: 29 freezer64 2000rpm SYS: 31 2x120mm (1200rpm) + 2x 80mm (oko 2000rpm) GPU: 43 2400rpm vga silencer HDD: 30 NB: 45 pasivac i po njemu puše bočni 120mm vent |
Postovi: 12,433
CPU -> 3000+@2,7GHz CPU -> 32 idle, 40 full (freezer64@2000rpm) CASE -> 30-33 (120+80mm@ 1500rpm) GPU -> 42 idle, 60 full HDD -> 26-30 (80mm@2000rpm)
Lokacija: Zagreb-Dubrava
Postovi: 505
nb - 30 pasivno cpu - 48 2400rpm gpu - 40 gpu memorija - 39 hdd - 29 |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
Temperatura Matična ploča 36 °C (97 °F) CPU 36 °C (97 °F) Aux 40 °C (104 °F) Seagate ST380011A 32 °C (90 °F) Seagate ST320410A 31 °C (88 °F) Hladnjaci CPU 1592 RPM Napajanje 1214 RPM Ova aux temperatura je zapravo procesor. Inače pretpostavljam da svi koji imate cpu temperaturu jednaku ili nižu od case temperature znate da vam ploča laže ![]() |
#16 |
Postovi: 1,313
kak ti hladis te svoje diskove mislim da i oni lazu disk ispod 35 u tihom caseu ne postoji ![]()
#17 | |
Lokacija: Zagreb/Dubrava
Postovi: 2,869
#18 | |
Postovi: 5,777
#19 | |
Postovi: 1,313
#20 |
Postovi: 7,568
Evo mojih temperatura. Disk hladi 120mm cooler (da ne bi bilo nismo znali). Zadnje izmijenjeno od: McG. 19.03.2006. u 19:07. |
#22 | |
Postovi: 7,568
#23 | |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
SAMSUNG jako tih i hladan disk, Barica se može sakriti po buci i hladnoći... Imao je.. |
#24 |
Postovi: 505
Hard je bez hladjenja dva venta su na prednjoj strani a hard je iznad njih. [img=http://img386.imageshack.us/img386/637/clipimage0026ez.th.jpg] |
#25 |
Lokacija: Sibenik
Postovi: 1,226
idle/load cpu 32/36 mbo 20/22 gpu 43/46 hdd seagate 160 ncq 29 |
#26 |
Postovi: 562
iz siga: idle/load cpu: 35/45 mb: 25/30 hdd M: 25/30 80mm vent isped njega hdd S: 20/25 cooldrive 3 hdd WD: 38-45 bez hladenja gpu (jednom mjereno digitalnim termometrom): 35/50 ovo je onako ugrubo a rekao bi da je +/- 2-3 C ![]() |
#28 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Mrvičak je zašljivilo, clockana X800XL sa Zalmanom VF700Cu u idleu urednih 33c hardovi na 33 i 34, proc 36.Eh da mi je sad onaj 1200C da mi malo zgrije sobu... ![]() |
#29 |
Postovi: 505
#30 | |
Postovi: 12,433
''Of all the things I've lost I miss my mind the most'' Mark Twain Zadnje izmijenjeno od: Wolverine. 10.08.2008. u 21:14. |
