Staro 17.11.2014., 18:40   #1
eroktic
Datum registracije: Jan 2014
Postovi: 25
Pomoc oko watta
pozz!
treba mi savjet oko napajanja,dali ga treba mijenjat ili ne?
spec:
ASRock 970 Pro3 R2.0 http://www.asrock.com/mb/AMD/970%20Pro3%20R2.0/
AMD FX 8370 http://www.cpubenchmark.net/cpu.php?...370+Eight-Core
GeForce GTX 760 OC Gigabyte http://www.gigabyte.com/products/pro...px?pid=4663#ov
CORSAIR CX430M http://www.corsair.com/en/cx-series-...ed-modular-psu
Cooler Master Hyper T4 http://www.coolermaster.com/cooling/...oler/hyper-t4/
HyperX Black 8gb http://www.kingston.com/en/hyperx/memory/black
Xigmatek Recon http://www.xigmatek.com/product.php?productid=215
2x hdd
ne planiram oc, vrlo vjerojatno idu jos 2 fana gore
eroktic je offline   Reply With Quote
Staro 17.11.2014., 18:44   #2
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Ne trebaš mijenjati napajanje.
Staro 17.11.2014., 19:03   #3
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment.
-It`s what Jesus would do.
B3mt1 je offline   Reply With Quote
Staro 17.11.2014., 19:43   #4
eroktic
Postovi: 25
Autor ShanTech Pregled postova
care, koji god topic napravim,ti mi pomognes, puno ti hvala!
Staro 17.11.2014., 19:45   #5
VedranO
VedranO's Avatar
Datum registracije: Jun 2013
Postovi: 400
Nije to malo nategnuto? CX 430M ce to drzati ali ce ga cjediti dosta pod punim opterecenjem.
VedranO je offline   Reply With Quote
Staro 17.11.2014., 20:14   #6
ShanTech
Postovi: 3,784
Nije nategnuto. Napajanje se neće "cijediti".
Staro 22.11.2014., 14:15   #7
eroktic
Postovi: 25
oke,imam problema sa temperaturom i bojim se da su vati problem.
evo vam ss mog kompa. na dnu je dok nis ne radim i dok sam u igri,dize se i preko 80
Staro 22.11.2014., 14:16   #8
eroktic
Postovi: 25
fan na prednjoj strani*
Staro 22.11.2014., 14:21   #9
VedranO
VedranO's Avatar
Postovi: 400
Koja ova TMPIN0?
Staro 22.11.2014., 14:25   #10
eroktic
Postovi: 25
systin,cputin,auxtin,amd fx-package,gforce-tmpin0, sve je na slici
Staro 22.11.2014., 14:31   #11
VedranO
VedranO's Avatar
Postovi: 400
Ova najdonja TMPIN0 je temperatura grafe, 79 stupnjeva. I to je po meni malo previse za grafu s takvim hladjenjem ali nije kriticno.
Ono sto je sigurno previse je tempratura procesora a ako dobro vidim ventilator na procesoru ne ubrzava kad je pod opterecenjem ali ventilator na kucistu da.
Znaci da je vent na procesoru valjda ustekan u 3 pinski prikljucak ili si namjerno stavio da mu je brzina uvijek takva?
I napon na procesoru mi se cini previsok.
Staro 22.11.2014., 14:38   #12
eroktic
Postovi: 25
u 4 pinskom je procesor,stvarno neznam u cemu
je problem.mozda su ventilatori krivo okrenuti?
Staro 22.11.2014., 14:42   #13
VedranO
VedranO's Avatar
Postovi: 400
Prije da je u BIOSu brzina ventilatora lose podesena. I ja bi ga probao malo undervoltat da mu padne temperatura.
Staro 22.11.2014., 15:15   #14
mierdadeltorro
mierdadeltorro's Avatar
Lokacija: zadar
Postovi: 241
jel se to meni čini ili ti je vent od procesora okrenut tako da puše prema dolje direktno u grafičku?
mierdadeltorro je offline   Reply With Quote
Staro 22.11.2014., 15:22   #15
VedranO
VedranO's Avatar
Postovi: 400
Autor mierdadeltorro Pregled postova
Cini ti se, ne puse kroz hladnjak nego izvlaci zrak sa njega, puse u stranicu kucista.
Staro 22.11.2014., 16:13   #16
Postovi: 33,982
Krivo postavljeno. Fan na cpu mora puhati u smjeru venta koji izbacuje topli zrak iz kućišta. U tvom slučaju, trebaš cijeli cpu cooler zarotirati za 90 stupnjeva u smjeru kazaljke na zidu.
I napajanje je krivo okrenuto - fan mora biti dole da uvlači hladan zrak odozdola.
btw, koje veze imaju ovi zadnji postovi sa W?
Staro 22.11.2014., 17:32   #17
eroktic
Postovi: 25
ventilator na cpu ne moze biti okrenut za 90,moze za 180.
okrenuo sam ga prema grafickoj.napajanje sam okrenuo da puse prema van.
monitor kaze da je temperatura ista ko i prije. (cak i gora za 10 stupnjeva).
otvorio sam bios i unutra je previse funkcija za volte. jedina stvar sto sam mjenjao je da nije full on nego je auto i to da nakon 50 stupnjeva vent radi na max brzini. mogu li dobiti detaljnije upute o smanjivanju volti?
tema je tu zbog toga sto sam mislio da mi je napajanje preslabo,molio bih ako je moguce da se topic prebaci u pozeljan dio foruma.
Staro 22.11.2014., 18:02   #18
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Autor coconut Pregled postova
Autor eroktic Pregled postova
Poslušaj kolegu i napravi kako ti je rečeno...zarotiraj cijeli CPU hladnjak tako da ventilator ispuhuje prema stražnjoj strani i okreni napajanje da mu ventilator odozdola uvlači hladan zrak!
Rino je offline   Reply With Quote
Staro 22.11.2014., 18:44   #19
eroktic
Postovi: 25
moja maticna koristi ove zubce na sredini i nemoguce je okrenuti cooler prema pozadini kucista. jedino ju mogu okrenuti za 180 stupnjeva.
napajanje sam okrenuo i ocito nema napredka.
Staro 23.11.2014., 11:30   #20
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Da jer je napajanje ispuhivalo jedan dio vrućeg zraka van.
Ovo za cooler nisam siguran da se ne može montirati nikako drukčije...jel imaš backplate...sve mi ovo smrdi na lošu instalaciju.
Uglavnom najbitnije od svega je da nemaš problem s watima!
U kojem si dijelu Zagreba?
Staro 23.11.2014., 12:00   #21
veve
woot!!!
veve's Avatar
Postovi: 2,496
CM Hyper T4, intel ima back plate, dok je kod amd rjeseno samo kopcama.
@eroktic
Koji procesor imas? I daj sredi tu sumu kablova, jer ti ubija protok zraka.
veve je offline   Reply With Quote
Staro 23.11.2014., 12:40   #22
hedgehog
hedgehog's Avatar
Datum registracije: Apr 2013
Postovi: 1,336
I ako ti ventilator na cooleru puše prema grafi, a čini mi se da puše, okreni ga na drugu stranu.. Nije baš pametno da vrući zrak puše na grafu direkt
hedgehog je offline   Reply With Quote
Staro 23.11.2014., 13:41   #23
eroktic
Postovi: 25
ima backplate ali je kvadrat,moja maticna je pravokutnik. citao sam o maticnoj i pisu da asrock ima velikih problema sa grijanjem,da im je heatsink los,tako da sam mislio zamjenit maticnu.
spec kompa pise gore na vrhu.
u preckom sam
Staro 23.11.2014., 17:29   #24
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,054
Koji je to cooler opće ?
EDIT: nvm skužih. T4 se neda okretat na AMDu jer je bedasto napravljen, šteta jer je recimo TX3 složen tak da paše kako god pošto se kopča da rastavit i zavuć kroz pajpove.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Zadnje izmijenjeno od: Chuxonja. 23.11.2014. u 17:35.
Staro 25.11.2014., 09:30   #25
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Mislim da ti matična nije uzrok visokih temperatura procesora, moguće je da senzori krivo očitavaju pa probaj "prst metodom" dodirnuti bazu hladnjaka i ako te zapeče da ne možeš držati duže od par sekundi onda je temperatura veća od 50 stupnjeva.
Ukoliko je baza hladnjaka na dodir mlaka moguće je da nije dobro sjeo na procesor pa je to uzrok visokih temperatura.
Probaj i skinuti hladnjak, očisti pastu i stavi novu (ako ne znaš ima dosta videa na Youtube-u) i uslikaj procesor kad ga skineš da vidimo kako hladnjak naliježe na njega!
I sve što radiš radi polako i pažljivo...kad jednom spustiš hladnjak na procesor nemoj ga više pomicati!
Na poslu sam i imam spor net pa vjerujem da ima i boljih videa od ovog!
Ventilator smjesti s donje strane hladnjaka i neka puše prema gore kroz njega jer su rezultati bolji nego kada provlači zrak kroz njega!
