Staro 03.10.2014., 01:12   #571
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,039
Jako decent za price range, ja sam sa svojim jako zadovoljan tak da dobar pick.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 03.10.2014., 17:34   #572
scarwin
scarwin's Avatar
Datum registracije: Sep 2014
Lokacija: Zagora
Postovi: 179
Nisan virova da stock hladnjak od fx6300 može bit onako glasan, ajme, radi na 4700rpm a temp 61..podhitno minjan to haha
Jel valja ovo? LC Power LC-CC-120? Ili CC-95? Ili neki treći do 150kn
I isplati li se stavit neki ventilator u kućište?
scarwin je offline   Reply With Quote
Staro 03.10.2014., 18:32   #573
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Oba hladnjaka su dobra. LC-CC-95 bi bio dobar kao zamjena za stock, a s LC-CC-120 za ne puno veću cijenu možeš i klokati cpu u budućnosti.
Koje kućište imaš?
Staro 03.10.2014., 20:15   #574
virus1
virus1's Avatar
Postovi: 495
Autor scarwin Pregled postova
LC-CC-120 i vent u case
virus1 je offline   Reply With Quote
Staro 03.10.2014., 21:57   #575
Chuxonja
Pajcek
Chuxonja's Avatar
Postovi: 1,039
Čo'ek bi očekivo da nekog vraga i radi kad tolko piči, al kifla. čak i oni stockovi za FX 83XX seriju koji kakti imaju heatpipe i donekle liče na neš, vrište na 6k okretaja, al ni tad niš ne hlade. Komp moš uredno zaklat da se pregrje i zgasi ak je dulje vremena pod full loadom na tim govnima.
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
ODD: LG GH24NS70
OS: Windows 10 Pro
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
ODD: LG CH10LS20
HDD1: WD Green 1TB
LINK
ODD: LG GH22LP20
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
PSU: Enlight 400W
OS: Windows XP SP3
LINK
HDD: WD 160GB
OS: Windows XP SP3
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 03.10.2014., 22:14   #576
scarwin
scarwin's Avatar
Lokacija: Zagora
Postovi: 179
Autor ShanTech Pregled postova
Koje kućište imaš?
OK, hvala, valjda će valjat taj CC-120 s obzirom da nije baš skup.. Kućište je neko noname mid-tower, ima postolje za ventilator na bočnoj stranici
Staro 03.10.2014., 23:59   #577
ShanTech
Postovi: 3,784
Itekako bude dobar.
Za kućište si provjeri kojih dimenzija ventilatori ti idu inutra, dal su to od 80, 92 ili kojim čudom od 120mm. Dovoljan je jedan naprijed koji upuhuje zrak, te jedan otraga koji ispuhuje, mada bih ja preporučio da bezveze ne bacaš novac na sad kakve ventilatorćiće, nego da skineš bočnu stranicu na kućištu (ide zima, bit će dobro), te si štediš novce za neko kućište tipa Zalman Z1, Zalman Z3, Raijintek Arcadia, Xigmatek Recon, Xigmatek Mach, AeroCool GT Advance.
Na nabavi možeš vidjeti kako se kućišta kreću cijenom (www.nabava.net).
Staro 04.10.2014., 19:15   #578
scarwin
scarwin's Avatar
Lokacija: Zagora
Postovi: 179
Itekako bude dobar.
E hvala ti puno, svaka čast
Staro 05.10.2014., 11:38   #579
Talaba
Talaba's Avatar
Datum registracije: Jul 2014
Lokacija: Serbija
Postovi: 108
Može i ovakva bebica da ti pomogne Seidon 120v
Talaba je offline   Reply With Quote
Staro 05.10.2014., 13:27   #580
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Samo u slučaju da kučište prima 120mm ventove otraga ili na vrhu (nije napisa koje ima, pa da ne bude posli kmečanja )
Pomelo mi sig -.-
Staro 05.10.2014., 15:39   #581
Talaba
Talaba's Avatar
Lokacija: Serbija
Postovi: 108
Neće da stane samo ako nije spreman malo da moduje plafon kućišta što je lako, ako ne može da stane. Ali sam ja zadovoljan kako hladi moj FX 8350, 4.6 Ghz doduše u puš-pull varijanti.
Staro 11.10.2014., 18:24   #582
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Jel ima tko ili je isprobao ovo čudo od hladnjaka?
LC POWER LC-CC-120
namjeravam uzeti novi hladnjak da hladi mog Phenoma II x4 965, pa sam razmišljao o ovome modelu. Imam njegovog mlađeg brata koji me ugodno iznenadio sa preformansama i cijenom
Eventualno preporuka za neki drugi hladnjak? Možda neki od ovih kao alternativa?
SCYTHE Katana 4
SCYTHE Katana 3
ARCTIC COOLING Freezer 7 Pro Rev.2
SCYTHE Samurai ZZ Rev B
U svakom slučaju ne bih išao iznad 200 kn sa cijenom hladnjaka, pa eventualno ako netko ima šta za pounditi za prodaju...
** AMD FX-4300 @ 3.8 Ghz ** Asrock 990FX Deluxe 3 **16 GB G-Skill 1600Mhz ** Intel 545s 500 GB + 2xWD 1 TB ** MSI GTX 660 2GB ** DVD-RW LG H42N ** Corsair HX620 ** Logitech MX Master 2S ** Dell U2414 **SAMA Vulture
Zadnje izmijenjeno od: Babaloo. 11.10.2014. u 18:32.
Babaloo je offline   Reply With Quote
Staro 11.10.2014., 19:27   #583
Drvoje
Drvoje's Avatar
Postovi: 4,037
Grijeh je ne kupit Thermalright Macha za 250 kn, razbaca ove nove coolere do te cifre ko "đubar po vinogradu".
Također cooler na slikama izgleda u mint stanju (mora da ga ni ne zna montirat ), i ne zaboravi provjerit imaš li dovoljno mista u kejsu, memoriju s visokim pasivcima...
http://forum.pcekspert.com/showthread.php?t=263717
Pomelo mi sig -.-
Staro 11.10.2014., 21:29   #584
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Autor Drvoje Pregled postova
Malo mi izlazi izvan financijskih okvira jer tu još onda moram računati i poštarinu, a bojim se da bih mogao imati i problema što se tiče montaže te grdosiije na matičnu ploču
Msilim da ću malo googlati testove, eventualno ako netko drugi ima neki drugi savjet ili preporuku neka slobodno napiše par riječi
Staro 11.10.2014., 22:02   #585
scarwin
scarwin's Avatar
Lokacija: Zagora
Postovi: 179
LC CC120 uzmi i nećeš falit..mom FXu u full loadu ne da priko 40°c..montaža je lagana, samo tribaš skidat matičnu za stavit backplate
Staro 11.10.2014., 22:13   #586
Drvoje
Drvoje's Avatar
Postovi: 4,037
"Stavider" neki SS Prime-a, OCCT-a, Super PI-a inače te nitko neće doživljavat, ipak je FX-6300 termalni odron (pitaj syssa )
Ovako paušalno napisano je predobro da bi bilo istinito, koji imaš kejs, koliko ventova u njemu na koliko okretaja, sobna temp.? bla bla bla
Pomelo mi sig -.-
Staro 12.10.2014., 18:10   #587
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Šta se ne montira samo na onu plastiku kod AMD-ovih procesora?
Zadnje izmijenjeno od: Babaloo. 12.10.2014. u 19:01.
Staro 12.10.2014., 18:45   #588
scarwin
scarwin's Avatar
Lokacija: Zagora
Postovi: 179
Evo uslikat ću upute pa vidi..triba skinut ono postojeće postolje od stock hladnjaka i montirat to novo..Click image for larger version
Staro 24.11.2014., 00:16   #589
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Jedno pitanje za AMD-ovce s foruma
Nedavno sam nabavio Phenom II 965 BE i zamijenio sam dotadašnji Athlon II 250. Ono što me brine kod tog procesora (clockan ili na stocku) jest njegovo zagrijavanje. Jasno mi je da je TDP njegov veći nego od ovog Athlona i da ne mogu očekivati baš polarne temperature, no u idleu meni tempeature budu od 48-58 stupnjeva (ovisno dal je clockan ili ne), a u loadu idu preko 70 a ventilator se vrti na maksimumu. To mi se nekako čini ipak previše, ili sam u krivu? Hladnjak je Noctua NH-U12P. Jel možda treba podesiti nešto na ploči kod tih procesora?
Još jedna napomena, kada stavim Athlona ispod tog hladnjaka i clockanog na 3.5 Ghz, temperatura mi je u idleu do 30 stupnjeva s time da se ventilator čak ni ne vrti na maksimumu, tako da bih isključio mogućnost da hladnjak ne naliježe dobro na procesor.
Mišljenja, savjeti?
Staro 24.11.2014., 00:34   #590
hedgehog
hedgehog's Avatar
Datum registracije: Apr 2013
Postovi: 1,336
Puno previše.. Jesi siguran da je hladnjak dobro sjeo?
hedgehog je offline   Reply With Quote
Staro 24.11.2014., 00:47   #591
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Autor hedgehog Pregled postova
Pa poprilično siguran, nekoliko puta sam stavljao i skidao, zavidam ga jednako na obje strane, a i nije da prvi put mijenjam procesor i hladnjak pa da neznam kako treba sjesti
kao što kažem, na ovom drugom procesoru su temperature fantastične s tim istim hladnjakom i isto normalno naliježe na njega
Staro 25.11.2014., 21:06   #592
Deamon101
Deamon101's Avatar
Postovi: 635
AMD Athlon II X2 250 65 Watt
AMD Phenom II X4 965 125 Watt
Može i jedno teoretsko pitanjce? TDP ide eksponencijalno?Mislim na toplinu npr 2tdp je više od 2x toplije od 1tdp?
edit : ah logika nalaže da ne nakon malo razmišljanja.
Zadnje izmijenjeno od: Deamon101. 26.11.2014. u 00:07.
Deamon101 je offline   Reply With Quote
Staro 26.11.2014., 00:36   #593
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Autor Deamon101 Pregled postova
Da, to mi je jasno da je ovaj skoro dupli TDP od ovog drugog, no svejedno mislim da u idleu ne bi trebale biti tako visoke temperature
Staro 26.11.2014., 00:45   #594
boy005
boy005's Avatar
Postovi: 598
Koliko soka dajes x4? (V)
boy005 je offline   Reply With Quote
Staro 26.11.2014., 10:06   #595
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Autor boy005 Pregled postova
podignem za 0.025 V, mislim da je to onda 1.450
Staro 26.11.2014., 11:36   #596
Deamon101
Deamon101's Avatar
Postovi: 635
Autor Babaloo Pregled postova
Znači nemaš pojma.
Misliti je k znati opet nemaš pojma o čemu pričaš.
Ovdje se puno spominje "poprilično siguran i mislim da...." što u ovoj raspravi znači k i samim time trošiš vrijeme ostalima koji ti pokušavaju pomoć..
0.825V - 1.4V je za taj proc znači digo si za 0,5(1.450v) i od tud to zagrijavanje...osim ako nisi siguran u postavke u tom slučaju mani se čorava posla.
Staro 26.11.2014., 15:38   #597
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Znači nemaš pojma.
Ja bih te zamolio da se maniš bahatih komentara i ostaviš taj cinizam, ironiju i sarkazam za nekog drugog (ako sam to krivo shvatio onda moje isprike).
S obzirom da sam došao pitati ovdje za savjet, onda to već u startu pokazuje da nešto neznam i da sam svjestan toga i da trebam pomoć, jer inače ne bih ni postavljao ovo pitanje vezano za hlađenje.
Što se tiče onoga "poprilično siguran" to se odnosi na montiranje i ako si primjetio nisam nigdje napisao "100% siguran" ili slično. Kažem "poprilično" iz razloga što sam hladnjak montirao na ploču dok je ploča bila vani pa sam mogao direktno gledati kako sam hladnjak sjeda na procesor, a koliko sam vidio sjedao je dobro. Drugi razlog iz kojeg smatram da sam dobro montirao isti jest taj da kad stavim drugi procesor pod isti hladnjak, temperature drastično padaju. Ono što sam i napomenuo jest da vidim da Phenom ima skoro duplo veći TDP nego Athlon ali me zanima da li te temperaturei moraju biti toliko visoke ili tu nešto ne štima. A što se tiče onoga "0.025" to se odnosi na pomak koliko sam stavio u BIOSU ploče, nakon čega mi je pokazivao napon od 1.45 V. Očito je da nešto ne štima.
Stoga, ako imaš neki konkretan savjet slobodno ga iznesi i bit ću ti zahvalan, u protivnom se ostavi zlobnih komentara, to mi ne treba.
Staro 26.11.2014., 16:01   #598
Deamon101
Deamon101's Avatar
Postovi: 635
1.4 volti treba biti za taj proc namješteno, probaj smanjiti u biosu jer nekad i najmanje povećanje napona iznad specifikacija eksponencijalno diže temperaturu a pogotovo 1.45 volti što je po meni overkill za svaki proc.
Kako god smanjiti voltažu i sa prime95 vidjeti dal je stabilno. evo baš čitam nejasno je dal je 1.4 ili 1.425 tvornička voltaža...iako vidim ekipu i da s manjim vrte ispod 1.4
http://www.tomshardware.co.uk/answer...t-voltage.html
Sori za malo agresivan stav loš dan danas
Staro 26.11.2014., 17:02   #599
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Nema problema, desi se svima
Sutra mi treba stići nova ploča (Asrock 890FX Deluxe4) pa ću onda zajedno montirati na nju i namjestiti fiksni napon pa vidjeti kako se ponašaju temperature, jer sam googlao i gledao malo temperature za taj procesor, uglavnom se ljudima vrte oko 40 C u idleu sa nekim malo boljim hladnjakom...
Staro 26.11.2014., 17:33   #600
lobo64
lobo64's Avatar
Postovi: 1,345
Babaloo
Athlon IIx4 620 underclock i undervolt (1,6 G, 1,075 V) hlađen CM 212+ sa AC 120 PWM u push-pull (vidi moj komp), idle 38 C, load 55 C (prema speedfan).
Temp. su skoro pa iste kao i na def. naponu i kloku.
Kada ga klokam na 3,6 sa 1,425 V, idle 40 C, load 66 C.
S obzirom da je Noctua bolja nego CM hyper 212+ (bez obzira na push-pull, moje kućište (Antec REMOTEMAX) nema vent za ispuh, ustvari nema nijedan drugi vent osim na procu, grafi i napajanju), mislim da definitivno nešto ne štima.
Probaj očitati temp pomoću nekog programa, pa usporedi vrijednosti sa onima iz biosa.
Ili, flešaj MB sa najnovijim biosom ako nisi, možda pomogne.
lobo64 je online   Reply With Quote
