Staro 03.10.2014., 21:56   #1411
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Može i jeftinije proć (doduše intelov ima 5 god. garancije, al ovi su ako se ne varam noviji i nešto brži)
http://www.nabava.net/search.php?tp=0&q=SSD+Pyro+240gb
http://www.nabava.net/search.php?tp=...al+MX100+256gb
Staro 03.10.2014., 22:30   #1412
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,061
Čak i netreba pretjerat sa hlađenjem, moj je relativno hladan u kombinaciji sa Themisom, a ganjam ga na 4.5. Mada je neka vodica uvijek fin izbor bez obzira
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Zadnje izmijenjeno od: coconut. 04.10.2014. u 09:15.
Staro 06.10.2014., 00:02   #1413
Zx636
Zx636's Avatar
Datum registracije: Sep 2014
Postovi: 35
Evo malo bio zauzet ali evo me opet sa pitanjem jednim i mislim da ce to biti manje-vise zadnje posto je to lagano sve vec sastavljeno u glavi barem pa evo pitanja.
Koliko se isplati uzimat taj ssd od 240gb umjesto ovoga od 120gb s obzirom da je gotovo duplo skuplji barem?
Sve u svemu to bi bilo to i hvala svima na pomoci i sto ste odgovarali na sva moja glupa pitanja.
Mislim da ce se dijelovi pocet narucivat lagano za koji dan pa kad se sastavi sve javim kako je to na kraju sve ispalo.
Zx636 je offline   Reply With Quote
Staro 06.10.2014., 00:18   #1414
Manuel Calavera
Postovi: 14,584
nema tu neke mudrosti - duplo veći - duplo skuplji... Ako misliš igre instalirat na ssd (samo brži loading dobiješ) onda uzmi veći... Al stane ti i na 120gb OS+programi + igra-dvije koje trenutno prelaziš. Filmove/serije/glazbu i ostale igre trpaj na hdd
Staro 06.10.2014., 17:47   #1415
FranKrsto
Datum registracije: Apr 2014
Postovi: 10
Moze misljenja o ovakvoj konfiguraciji za do 9k
Napajanje: XFX Core Edition 80+ 750W 719,00kn
Procesor: i7-3770, 3.4Ghz socket 1155 2.330,00kn
Hladenje: SCYTHE Mugen 4 368,00kn
Maticna: ASUS P8Z77-V LX, 1155, Intel® Z77, DDR3 797,00kn
Memorija: DDR3 16GB (2x8GB) Corsair, 1600MHz, CMY16GX3M2A160C9, 9-9-9-24 1.350,00kn
Graficka: MSI R9 280 3GB GDDR5 384bit 1.750,00kn
Kucište: Zalman MS800 PLUS 765,00kn
Ukupno: 8.079,00kn
SSD (Samsung 256gb) i veci HDD ostaju iz starog kompa, isto kao i monitor, ostalo naravno moram mijenjati jer se stalno izmisljaju novi socketi a i kuciste ima vec jako puno godina i pocelo se raspadati
Ne znam bas puno o ovom napajanju al daju 5 godina garancije na njega sto mi se cini super...
FranKrsto je offline   Reply With Quote
Staro 06.10.2014., 17:57   #1416
Lak
Lak's Avatar
Datum registracije: Feb 2010
Postovi: 397
Ne trebaš skupi cooler i možeš uzeti povoljniju matičnu ako baš ide taj procesor koji nije namjenjen za OC. Također niti 750 watta nije potrebno.
Ne znam gdje su izvađene cijene, ali r9 280 ide za cca 1550 kn.
Kučište za te novce ide Fractal Define R4 koji je odličan.
Koja je namjena kompa?
Lak je offline   Reply With Quote
Staro 06.10.2014., 18:06   #1417
FranKrsto
Postovi: 10
Igranje + renderiranje videa.
Cooler sam stavio iz razloga sto mi je ovaj sadasnji komp dosta zatvoren (stol ima predviđen "box" u kojem se nalazi i nema bas strujanja zraka pa je sa stock coolerom bez ikakvog OCa ovaj prosli i7 dosta jako grijao i komp i sobu.. Radije bi zamijenio cak i ako ne planiram raditi OC...
Ove cijene su sve iz istog ducana, znam da sigurno moze jeftinije ako idem preko nabave.net al onda cu ga sam morat slagat a sa proslim kompom sam imao negativnih iskustava jer su i procesor i maticna bili neispravni (a treba nase trgovce uvjerit u to) pa bi prije sve uzeo u istom ducanu i dao im da ga oni sami sloze.
Koja bi bila preporuka za napajanje?
Zadnje izmijenjeno od: coconut. 07.10.2014. u 06:26.
Staro 06.10.2014., 18:18   #1418
Lak
Lak's Avatar
Postovi: 397
Mozes staviti bilo koji drugi cooler za 150 kn manje i neće biti problema.
Imam dojam da bi se na istim komponentama iz drugog dućana moglo uštedjeti, pa to malo pogledaj.
A zašto ne uzmeš haswela i7 4770 kad već imaš takav budžet i z97 ploču, pa imati mogućnost eventualne nadogradnje, to je sve tu negdje sa cijenom.
Napajanje je dovoljno i 500 watta, pa recimo xfx 550.
Staro 06.10.2014., 18:20   #1419
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
Idi na Haswella odnosno noviji s1150 s kasnijom podrskom za Broadwell (i7 4770/4790).
Ukoliko te oc ne zanima preporuka je neka dobra H97 mbo poput: As Rock H97 Anniversary ili nesto od Asusa.
Sto se tice hladnjaka, dovoljna zamjena za stock bi bio LC CC 95.
Graficku zamijeni s XFX Black ili Gigabyte Windforce modelom - ako ti nije hitno strpi se do dolaska jeftinijih modela GTX 970: Msi, Gigabyte, Gainward.
Kuciste zamijeni s Fractal R4 - iste cijene, a daleko bolje opremljen te kvalitetnije napravljen.
S napajanjem ne pretjeruj dovoljni su ti pouzdani igraci poput: Fortron Raider 550/650W, XFX PRO 550W ili ako si spreman potrositi vise Seasonic G 550W 80+ Gold.
Osim Intela razmisli o dobroj zamjeni od Amd-a s obzirom na svoju namjenu - FX 8320 i neka ploca poput ASUS M5A97 R2.0 / EVO, Gigabyte 990FXA-UD3.
lolofuxy je offline   Reply With Quote
Staro 06.10.2014., 18:46   #1420
FranKrsto
Postovi: 10
Gledao sam tu razliku između haswell i ivy bridge i po onome sto sam citao, razlika za sada ne opravdava visu cijenu.. A komp mijenjam otprilike svakih 5 godina tako da sto se ovih osnovnih komponenata tice (procesor, maticna), nikad tu zapravo nema nadogradnje, sve se promijeni..
Ne znam, dosta ste mi dali za razmisljat, napravit cu koncept iz pocetka..
Mozda bolje da uzmem neki procesor koji cu moc OCat pa tako komp bude duze aktualan..
Staro 06.10.2014., 19:37   #1421
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
Pa razlike u performansama su minimalne jos od Sandya, ali razlika u cijeni nije uopce velika - bile su dok je tek izasao Haswell, ali se sada to sve svelo na isti nivo u cijeni.
Za ovo drugo po zeljama, pitanje je koliko ti to zaista treba i da li ti se isplati skok u cijeni za skuplju mbo, hladnjak.
Staro 07.10.2014., 11:01   #1422
šokre
Postovi: 324
Autor lolofuxy Pregled postova
Ja ne kužim ove preporuke za 3770 (ne K) po 2300kn??
Pogotovo kad je razlika u cijeni 50-100kn (na 8k+ kn)
Da ne pričam o online dućanima u DE... 4790k 307 eura
šokre je offline   Reply With Quote
Staro 07.10.2014., 16:03   #1423
hvco27
Postovi: 2
Pozdrav ekipa !
Htio bi kupiti racunalo za cca 8500 kn.
U obzir dolaze samo Intel i Nvidia, ssd mislim da mi ne treba. Koristio bih ga za gaming i cad ( catia v6, solid itd. )
Bez periferije
Hvala
hvco27 je offline   Reply With Quote
Staro 08.10.2014., 09:39   #1424
šokre
Postovi: 324
Autor hvco27 Pregled postova
Pozdrav ekipa !
Bez periferije
Hvala
Ili dodaj 2-3000 kn i možeš to i kod naših trgovaca kupiti.
Staro 08.10.2014., 09:55   #1425
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Pozdrav ekipa !
Bez periferije
Hvala
1 x Intel Core i5 4690K 3.9GHz,6MB,LGA 1150
1 x Hladnjak Prolimatech Basic 81, 120mm, Sck. 1156/1155/1150/2011
1 x GIGABYTE GA-Z97X-SLI
2 x Kingston DDR3 HyperX Fury, 1866MHz, 8GB Black
1 x SEAGATE HDD DESKTOP SSHD 3.5" / 1TB / 64m/ SATA/ 7200rpm
1 x Gigabyte GeForce GTX 770, 2048MB GDDR5, 256 bit
1 x LG DVD±RW 24x GH24NS95 SATA black bulk
1 x Zalman GV 700W, 80+ Bronze
1 x Zalman Z3+, USB3.0 black ili Zalman R1 koji ti više odgovara
8500 Kn Cijena je za keš
Ako plačaš karticom:
1 x CPU Hladnjak Raijintek Themis Black, 120mm, PWM
1 x Asrock s1150 Z97 EXTREME3
1 x KINGSTON DDR3 (8GB,1600MHz(PC3-12800) CL11
8500Kn
Staro 08.10.2014., 11:51   #1426
šokre
Postovi: 324
Autor FRipper Pregled postova
8500Kn
gtx770 za 2300-2500kn??
Staro 08.10.2014., 17:17   #1427
Rimac
Cigan.
Rimac's Avatar
Datum registracije: Jan 2010
Lokacija: Underground
Postovi: 62
Pozdrav,
molio bih cijenjene clanove eksperte da pripomognu oko odabira nove konfiguracije. Sluzila bi vecinom za rad i naravno malo igranja Naglasak bi trebao biti na brzini kompletnog sustava prilikom obavljanja rada koji vecinom ukljucuje obradu slika i multitasking. Igrice koje se igraju su vecinom LOL i malo WOT.
Monitore vec imam i cijelu periferiju. Potrebna je samo kutija. Također imam i SSD samsung 840 evo. Budžet je 10 000 kn. (nije fiksno )
Unaprijed zahvalan.
Kriminalom protiv gladi.
Rimac je offline   Reply With Quote
Staro 08.10.2014., 17:56   #1428
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor šokre Pregled postova
nismo u njemačkoj...
Autor Rimac Pregled postova
Pozdrav,
Unaprijed zahvalan.
1 x Intel Core i7 5820K 3.3Ghz,15MB,LGA 2011-3
1 x ASRock X99-EXTREME4, 2011-3
2 x Crucial RAM 8GB DDR4 2133MHz CL15
1 x Toshiba 2TB,7200rpm, 64MB HDD
1 x Gigabyte AMD Radeon R9 280, GV-R928WF3OC-3GD, 3072 MB
1 x Zalman R1 mid tower case
1 x Fortron Hyper 700W, 80+
Ukupno: 10239,76 kn
Staro 08.10.2014., 22:02   #1429
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
@Rimac
Ploča: Gigabyte GA-X99-UD4
Procesor: i7-5820K
Hladnjak: Thermalright HR02 Macho Rev.A
Memorija: Crucial DDR4 8GB (1x8GB) 2133MHz CL15 x2
Grafička: Gigabyte R9 280 WindForce 3 OC 3GB
Kućište: Cooltek Antiphon Black
Napajanje: XFX PRO550W
Disk: Toshiba 2TB
DVD: Samsung SH-224DB
=9600 kn
Cijene si možeš pogledati na nabavi www.nabava.net
Staro 09.10.2014., 09:31   #1430
šokre
Postovi: 324
A onda OK, mislim tamo je grafa 220 eura (1680kn), tu je 700 kn skuplja a i sad je izašla 970GTX.
Staro 09.10.2014., 09:34   #1431
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
a jbga... tu su gtx970, 500-700kn skuplje
Staro 09.10.2014., 14:31   #1432
Manuel Calavera
Postovi: 14,584
Takve su ti cijene gtx 770. Jedino ako mu se čeka gtx 960 (pitaj boga kad će) - to će vjerojatno biti isplativo
Staro 09.10.2014., 22:58   #1433
šokre
Postovi: 324
770GTX je super grafa, ja je imam, al ne po toj cijeni.
Baš gledam na computeruniverse (tamo sam kupovao već) i sve 770GTX su od 210-250 eura. To je 100 eura manje nego u RH? WTF!?
Baš vidim da se na podforumu ljudi čude kak cijena ne pada kad je izašla 970GTX. Ja se ne čudim, a sumnjam da će i padat uopće. Nekom će ju uvalit u gotovu konfu.
Je.e se meni, kupujte ljudi kod nas ak vam je bed zbog eventualne garancije i reklamacije i nije vam žao para. Al samo jedan osvrt. Nedavno sam imao problem s monitorom kupljenim u ZG. Trebalo im je 4mj mislim da riješe problem (zamijene monitor). A kolko čujem ni crknute grafe i sl se ne riješavaju/zamijenjuju u dan-dva kod nas. To traje!
A poštarina iz DE je 200kn.
Na 1000 eura imate barem 200 eura uštede ako kupuješ vani (s tim da ima brutalan izbor).
4690k je 400kn jeftiniji
asus sabertooth Z97 mark 2 300 kn
itd....
Al vaše su pare.
Staro 10.10.2014., 00:15   #1434
Manuel Calavera
Postovi: 14,584
Što se tiče reklamacije - vjerojatno si u nekom crappy shopu uzeo. Inače kažu da bi po zakonu max 45 dana bi ti to trebalo trajati ili povrat love do tad.
Što se tiče cijena - jbga tako ti je to kod nas. Ljudi uglavnom izbjegavaju vani zbog garancije. Ja ovo što sam malo gledao computeruniverse za buđet konfe - ne isplati se, premala razlika ili nikakva naspram naših jeftinijih shopova. Još pogotovo kad uračunaš cijenu dostave i potencijalne zajebancije oko reklamacije...
Staro 10.10.2014., 09:04   #1435
šokre
Postovi: 324
Al ovo su konfe od 8-9k kuna. Tu se bome isplate.
BTW shop je jedan od najvećih - neću reći koji da ne pljujem tu. Uglavnom na kraju sam nakon puno natezanja uspio dobiti lovu nazad (trajalo je puno preko 45 dana)
Staro 10.10.2014., 11:22   #1436
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
opet...očito si uzo u nekom us*** shopu
u dobrim trgovinama sam max čekao 15 dana, a reklamirao od igle do slona...znaci sve!
a i što se tice poštarine za njemacku...da ušparam na cijelom kompu recimo 2000kn
krepa mi ploča, šaljem tamo to je cc 200kn... krepa mi memorija šaljem tamo... krepa mi grafa šaljem tamo... krepa mi napajanje šaljem tamo...i eto opet krepala ploča i drugi put šaljem tamo...
mislim, nije da se ne moze dogoditi, more i di smo onda? u minusu debelom...
koliko kod dobro zvucalo odmah proci jeftinije, nije uvijek, pa skoro niti nikada na duze staze jeftinije
Staro 10.10.2014., 20:41   #1437
ShanTech
Postovi: 3,784
@šokre
Nisu baš po 2500 kn, ima i jeftinijih, samo treba dobro napisati na nabavu. Ova Palit za 2100 kn je isto ok kartica, samo je na njih dvije godine garancije, ali ima Asusova za 2200. Vani su naravno dosta jeftinije.
http://www.nabava.net/search.php?tp=0&q=GTX+770
Staro 11.10.2014., 14:15   #1438
dado-brado
Datum registracije: Oct 2014
Lokacija: Kutina
Postovi: 7
Pozdrav svima,
Evo, zamolio bih vas za pomoć oko konfiguracije za GAMING u rangu do 8500 kn, sa monitorom Full HD do 22".
U Instar-informatika sam dobio preporuku za gotovo računalo:
http://www.instar-informatika.hr/racunalo-instar-gamer-killer-intel-i5-4690-35ghz-8gb-1000gb-amd-radeon-r9-290-4gb-gamepad-gratis-/IN3350
te monitor:
http://www.instar-informatika.hr/lg-215-led-22m45hq-b-gaming-hdmi-fullhd-2ms/lg-22m45hq-b
Pa bih Vas molio za mišljenja oko iste, tj. preporuke kakve ako bi se za te novce moglo složiti što bolje?
Uzimao bih sve u Instar-u pošto oni i slažu komponente. Uzimao bih to tek u 11. mj istina, ali bih se htio informirati malo prije.
Također, ako smijem ubaciti u ovu temu (?).
Imam laptop Asus ROG G53S (6GB RAM, Nvidia GTX560M 2GB)... kako saznati koji RAM ide unutra, te isto tako grafička.. rame mogu proširiti do 12GB a grafičku do 4GB.. gdje kupiti, koje kupiti, cijena? Ili me uputite na temu prigodnoj za ovo pitanje pošto sam novi pa se baš ne snalazim.
Unaprijed hvala
dado-brado je offline   Reply With Quote
Staro 12.10.2014., 11:40   #1439
dado-brado
Lokacija: Kutina
Postovi: 7
Može i sa nabava.hr komponente, pa da mogu još jednom dobro razmisliti kako-šta
Staro 12.10.2014., 12:12   #1440
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
a kako plačaš? gotovina ili kartice?
