Staro 21.08.2014., 01:24   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
Firefox postao gori od IE
Pozdrav svima,
Vec nekoliko dana imam problem s IE pop-upovima koji mi iskacu nakon otvaranja FF-a.
Primjerice cinema plus reklame (nemam taj addon u firefoxu!), pa onda ilivid i sl.
Probao sam spybot, adaware te jos nekoliko opce poznatih freeware programa cija specijalnost su uklanjanje ovog gore. Probao sam takodjer i resetirati FF i reinstall, no nista!
Antivirus? Probao sam sa nekoliko AV programa no nista nisu pronasli. Jedino ako koristim Chrome nemam bas nikakvih problema, i sto vam to govori? Da nije Firefox kupljen od strane Microsofta(sarkastican sam)? Obicno tad pocinju problemi, tako je proslo sa skype-om i svime sto je MS kupio.
Slusam vase preporuke sto mogu jos probati?
Korisitm Win 7 ultimate 64bit.
Hvala unaprijed!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 21.08.2014., 02:00   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Glupo ali imas u FF instaliran adblock?
Znam da je "zadnje vrijeme" bas na svakom sajtu toliko tog smeca da ono, ali sa adblockom (meni) je to dosta bolje.
IE6
Linux is Not Windows
Staro 21.08.2014., 03:18   #3
VedranO
VedranO's Avatar
Datum registracije: Jun 2013
Postovi: 400
ja imam adblock plus i stvarno blokira sve, cak i sto ne treba.
VedranO je offline   Reply With Quote
Staro 21.08.2014., 08:57   #4
Nick7
Lokacija: Velika Gorica
Postovi: 1,532
Iako mi se zna desiti kod startanja FF-a da par adova prodje. Prvi reload stranice, ili otvaranje novih - sve OK.
No, jos veci problem je sto mi se dosta cesto skrlji Flash plugin...
Staro 21.08.2014., 13:00   #5
dadoremix
dadoremix's Avatar
Postovi: 4,734
pitanje je dana kada bude i java odbačena kao što je na mobilnim sustavima ios i android
Stvarno java se sako malo sruši, ako i ne onda je žderač resursa golemi
Staro 21.08.2014., 13:03   #6
wnbeeeE
wnbeeeE's Avatar
Datum registracije: Mar 2009
Postovi: 600
haha to se neće tako brzo dogoditi
Darker than a moonless night and hotter than hell itself, that is coffee.
wnbeeeE je offline   Reply With Quote
Staro 21.08.2014., 13:41   #7
Postovi: 34,029
Pogledaj koje add-onse imaš instalirane (Tools - Add-ons) pa izbriši nepotrebne, a možeš slobodno pobrisati i cookije (sve ili dobar dio njih).
Staro 21.08.2014., 15:38   #8
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
Autor Nick7 Pregled postova
na ovo potpis. sve ostalo se tako lako prilagodi na mozilli da je i dan danas broj 1 od browsera na mom/mojim kompovima.
iako isto tako moram priznati da mi se unazad mjesec dana (recimo mjesec) puno manje krlja flash plugin. mozda su nesto i opravili.........
jedini nedostatak sto bi volio da se popravi (sto recimo na chromeu radi automatika) je update flasha. da, to je do adobea, ali svaki put moram skinuti instalaciju flasha (fajlic od <1MB) i zivcira sto uvijek guraju mcafee. meni cak nije toliki problem, ali masi ljudi kojima tutnem mozillu na komp to zaborave maknuti ili ne citaju uopce itd. koja svrha uopce tog mcafee-ja, mene iskreno niti ne zanima, ali ono - ja hocu samo flash .
Staro 21.08.2014., 16:23   #9
Mikeyy
Postovi: 2,078
Ja sam blokirao update flasha, nemam pojma na kojoj sam inačici. Ne sjećam se kada mi se zadnji puta srušio FF na poslu ili doma zbog flasha.
Općenito su najveći izvor problema na FF, dodaci...
Nekada popizdim zašto mi nešto ne radi na stranici, ali u 99% slučajeva je AdBlock ili Ghostery. Vjerovatno se netko glupira pa blokira normalni dio stranice, i onda završi u adblock bazi pa podjele i svima ostalima koji koriste dodatak.
Staro 22.08.2014., 17:10   #10
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor Joke Pregled postova
Vjerovao ili ne imam adblock i nista. Ista situacija i dalje.
Staro 22.08.2014., 17:28   #11
Forace
Lokacija: Petrinja
Postovi: 1,604
Ma da? A koje filtere / liste koristiš na adbloku?
Primjerice meni je iz nekog razloga odlučio adblok odbrisat sve pretplate . Ali sa par klikova je easy list vraćen natrag i youtube je opet sretno prazan od čudnih stvari .
Forace je offline   Reply With Quote
Staro 22.08.2014., 17:53   #12
Valley7
Datum registracije: Apr 2012
Lokacija: qsd
Postovi: 567
Samo da dodam kako je meni portable firefox 10x bolji nego klasični install sa kojim u zadnje vrijeme stalno neki cirkusi...
Ovako me ne siluje sa updejtanjem u pozadini, lakše diše... Ako što ne valjda jednostavno mu obrišem mapu, skinem & otpakiram drugi bez da ostane smeće po sistemu. Puno bolje.
Valley7 je offline   Reply With Quote
Staro 22.08.2014., 20:16   #13
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,068
U zadnje vrijeme je FF općenito kifla, nemaš više normalnog browsera praktički. Još me najviše Linux forkovi vesele jer su ostali donekle normalni.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 23.08.2014., 00:40   #14
Forace
Lokacija: Petrinja
Postovi: 1,604
Autor Valley7 Pregled postova
A tko još ostavlja auto update uključen?
Najbolje da će se software sam updetat kad on to poželi ... ako ima opciju onda ostavim da me obavijesti da postoji update ali ja ipak odlučujem kad će se to dogodit - nikakve automatske i pozadinske gluposti.
Staro 23.08.2014., 12:38   #15
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,894
Malwarebytes antimalware+avast browser cleaner i miran si
Staro 23.08.2014., 12:58   #16
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
FF mi je primarni browser cca 4 godine i ne mogu reći da sam imo problema s njim. Čak se ni šugavi flash ne ruši. Imam 2-3 provjerena addona i nijedan nije addblocker. Stvarno se ne mogu požaliti.
Staro 24.08.2014., 00:15   #17
Valley7
Lokacija: qsd
Postovi: 567
Autor Forace Pregled postova
To je teoretski tako, ali klasičan install stalno je nešto pokušavao prošvercati bez obzira što je sve u postavkama za update bilo isključeno.
A najveća debilana mi je kada klikneš na "about" i update automatski krene bez ikakvog pitanja. Treba javno strijeljati onoga tko je izmislio takvo sranje.
Staro 24.08.2014., 01:50   #18
Baja 001
Baja 001's Avatar
Postovi: 7,504
FF frisko instaliran (inace koristin Chrome), sve ok radilo, danas skrolanje zapinje? Sve ostalo ok radi, adblock je jedino instaliran (od prije).
Staro 24.08.2014., 04:42   #19
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Ja do prije par dana nisam imao niti jednu zamjerku na ff. Koristim ga odkad znam za sebe ali problemi su krenuli jer neželi puštati veliku većinu youtube videa.
probao sam clean install, brisanje cachea cookies, update flasha nema što nisam, googlam 2 dana...
Sad instalirao Chrome i sve radi kako treba ali mi je sučelje katafakingstrofa. :/
Staro 24.08.2014., 13:42   #20
Dottore
Dottore's Avatar
Postovi: 7,691
Chrome je loš u adblocku. Ne blokira baš automaČki nego treba ručno i opet pojavi druga reklama. FF i Opera ima bolju suradnju.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 24.08.2014., 17:41   #21
Valley7
Lokacija: qsd
Postovi: 567
Kod mene Opera 22.0. Sve to radi lijepo, kao što se od opere uvijek i očekivalo, adblock super.
No nekakav programer, koji je često u djetinjstvu padao na glavu, zaključio je da odnedavno treba unutra staviti prisilan auto-update koji se ne može kontrolirati u opcijama.
Googlanjem je utvrđeno da se u folderu od opere treba obrisati/preimenovati neki .exe koji je zadužen za taj mutavi update. Nakon toga mir božji. Stvarno ne kužim, uz dopuštenje, takva izdrkavanja. Kad ću htjet novu verziju onda ću je i skinuti, nek konačno sjašu sa tim patroniziranjem.
Staro 24.08.2014., 18:18   #22
dtrixxx
Lokacija: _
Postovi: 193
Firefox je upravo kifla postao, svaka verzija sve gora, u zadnje vrijeme stalno memory leak. Potrošnja se dize sve do 3.2gb, skroz usporen i na kraju crasha.
Probao Waterfox u nadi da ce se sto popraviti i ovaj je jos gori, sam preglednik trosi do 3.8gb i na to jos 0.5gb za plugin container, tako da lijepo 4gb+ memorije samo za browser.
Ja mislim da je najbolje se vratit na Firefox 3 i bit miran, otkad su poceli novi broj za svaki update sve je krenulo nizbrdo.
dtrixxx je offline   Reply With Quote
Staro 24.08.2014., 21:17   #23
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,143
probaj pale moon
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
HumWeed je offline   Reply With Quote
Staro 25.08.2014., 01:53   #24
Dottore
Dottore's Avatar
Postovi: 7,691
Autor HumWeed Pregled postova
probaj pale moon
Kakav je? Podržava FF addone?
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 25.08.2014., 02:13   #25
xXxSsS
xXxSsS's Avatar
Postovi: 121
ja sam već dugo na dev chromiumu, i radi mi odlično, nemam nikakvih problema bez obzira što je developer/beta verzija a još je i portable.
https://download-chromium.appspot.com
xXxSsS je offline   Reply With Quote
Staro 25.08.2014., 02:13   #26
Valley7
Lokacija: qsd
Postovi: 567
Autor Dottore Pregled postova
Podržava.
Staro 25.08.2014., 03:25   #27
Shifo
Postovi: 86
ja ga koristim neko vrijeme i mogu reći da je odličan, brz je i stabilan. Bolji i od Firefoxa i Chromea
Shifo je offline   Reply With Quote
Staro 25.08.2014., 12:04   #28
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,092
Na kraju ispada da IE još radi i najbolje
Donedavno sam isključivo koristio IE ali sad sam opet instalirao Operu jer mi IE ne želi otvoriti linkove u komentarima na Facebooku. Firefox sam isto nedavno probao ali mi se Flash ruši više nego kaj otvorim tabova
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 25.08.2014., 12:59   #29
Valley7
Lokacija: qsd
Postovi: 567
Dobar dio problema je u tome što je flash šugava, zastarjela, manjkava i neoptimizirana tehnologija.
Staro 25.08.2014., 14:42   #30
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,092
Nažalost prave alternative još uvijek nema, HTML5 je još uvijek nestandardiziran i nema neke mogućnosti koje Flash nudi.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
